- Mesh Grill
- 2006 GX 470 Rough Idle at Stop Light
- transmission?
- Headlight restoration
- Lights out
- Immobilizer questions GX470 2006
- does anybody have westin light bar installed?
- Scangauge Install
- Need New Battery
- 2004 GX470 Strange Noise
- Cold Start
- Suspension enhancment
- Wrapped wood trim pieces in 3M 1080 brushed black metallic
- Home link Programming issues
- Take off wheels
- 2007 GX470 shocks and struts
- Stiffer Anti Sway bar options for a Non KDSS GX?
- About ready to pull the trigger
- 90K + Service Quote
- Budget Buying Options/Opinions
- 2005 gx 470 wheel well inner shield or liner
- Demello offroad bumper
- Opinions about tires
- Console mounted power socket
- Need your guy's help - Missing tools
- Airbag (SRS) Light On
- Claying&Waxing
- GX470 Automatic folding side mirror
- Steering wheel shimmy
- White Tux Edition GX
- Weathertech Vent Visor owners chime in...
- right speakers now working
- 215.00 for weather stripping? AYKM?
- Nav update questions
- Help! Front Bumper trim
- Where do you hide your cargo?
- Value of 2007 gx470 (or, how to valuate?)
- $1100 Cup Holder
- New gx470 owner speedo occasionally not working
- Careful! Don't use the wrong key!
- Outside Mirrors
- If I have extended warranty (100k) - should I do the timing belt/water pump at 90?
- GX 2008 NAV Motion Overide Tap Sequence
- VSC, VSC off and Check engine light
- The best LED fog light out there
- Installed new rotors and pads
- 75k service?
- Lifter Noise
- New on Board
- Inner Tie Rod/Wheel Alignment Issue!!!
- planning to buy a bull bar, need advice
- Rear coil conversion kit
- height control reservoir assembly
- Timing Belt/Water Pump Replacement Parts List
- Fuel smell
- Front wiper motors $587?!!!
- what are the common repairs?
- Driving in Snow
- hazards flashing by themselves and low battery?
- Does anyone have an Odyssey Battery in their GX?
- Anyone has this blinking red car with key on dashboard?
- Door Weatherstripping
- I agree screen
- Nozzle Cuts Off when Pumping Gas
- Air injection pump??
- Nav error Insert Proper Disc
- Vaistech SL3sat w/ SL2i
- Headlight Assembly Removal
- No Volume Amplifier 2003 GX470
- 12 volt blue back light volt gauge
- Cargo cover anyone??
- No Acceleration after Traction Control Engages
- About to make a GX purchase, is this legit?
- Fuse question
- O2 Sensor? 04 GX470
- Window switch flashing
- TPMS Light Flashing
- Cool box
- 2003 gx470...never ever again smh
- Suspension Clunk Over Potholes
- Secondary Air Pump
- DVD sound is not working
- GX 470 side mirror cover
- Old Nav/New Nav?
- Brake light Electical issue..need help or advice
- Illumination question ( pic attached)
- ghost
- Alignment specs
- Hairline Cracks in Wheel Paint
- Soft Car Top Luggage Bag-fit question.
- Dashboard Clean and Finish
- Today's project, OEM rear spoiler
- OBD Port location
- Back up light, plastic cover removal
- Rear HVAC, just AC, or heat as well?
- Heater not working
- 90,000 Mile Service/TB/WP Chicagoland
- Cost of Brake Job
- fuse block
- got rear ended need fix advice
- Use of NAV while in motion
- Advice on new GX
- New 03 with 56K rough ride ?
- GX poor ride quality - rears bottom out - Problem solved
- Shoulder belt replacement - 2nd row, middle
- defroster
- CCV or ICV, other valves/vents to clean?
- Experiences with longer crossbars?
- Seat Warmer Light Bulb
- Independent Repair Shop in Houston
- Techstream
- Ipod/MP3
- Multiple Blown Fuses
- Lost Wheel lock key
- Operating Temp how long to reach?
- New Owner
- what do all these codes have in common?
- New GX 470 owner
- Cabin Air Filter
- HELP!!! Should I buy?????
- Interior / Dome Light Problem...HELP HELP HELP
- Icon coilovers
- Bluetooth!?!?
- new owner
- Gx timing belt
- Full-size spare - 250 mi road-trip realistic?
- TPMS light blinking
- New GX Owner
- what's your 0-60 time?
- How do you test the height sensors
- KDSS Leak?
- aftermarket wheels with no tpms, but light didn't come on?
- My poor GX
- o2 sensor for GX470
- Gear Oil Question
- Hub bearing grease
- Navigation map color....
- Possible To Remove HVAC Controls From NAV
- Head Light Staying On
- Steering wheel controls not working properly
- Confused on Service Schedule
- Possible Transmission Problem
- TPMS Light off in both switch positions
- Really poor revving due to altitude change
- High Quality Cree LED Dome Light Alternative
- Grom USB vs GPS Upgrade
- Hi Guys I have a question about the SRS light?
- Lubricate front shaft bushing- DIY Help
- when to turn off height control?
- AC Temp Button Faded -Looks ugly
- Climate blows hot on the left, but stuck cold on the right.
- Hood shocks : aftermarket replacments
- 2003 gx 470
- Getting 90k Service done - anything else I should do?
- New to this site
- New Owner of GX470!! So Excited!!!
- Aftermarket Stereo install HELP!!!
- HELP! DAC downhill Assist Control Keeps Flashing
- LEDs
- CV boot clamp leak : cheap fix
- Introduction 2008 GX470
- Looking for the latest and greatest Navi Headunits - Audiophiles enter here
- Looking for Lexus 2007 GX470 Roof Rack End Cap Covers
- Looking for '05 GX - anyone ready to move on?
- Towing confusion
- 2007 seats in a 2004?
- lexus gx470 tire pressure sensor
- new 18's and hankook dynapro atm pics
- Alarm going off
- 2005 GX470 anyone replaced air injection pump or valve??
- Its official...I pulled the trigger!!!
- Anyone installed parking sensors on the GX?
- Newbie GX470 update GPS DVD UPDATE
- GX first generation ABS making interval noise, is this expected
- white LED plate bulbs
- Pulsating when warmed & braking
- tire choices for 265/60/18
- gps dvd disk upgrade
- A quick experiment w/the OEM shocks
- Bilstein 5100s
- TPMS light not coming on?
- Rear Suspension ?
- Heater Is Not Working Properly
- 08 GX470 running board...
- 2004 mid-year updates??
- 265/60/18 on 18x9 rims....
- glove compartment rattle
- GX470 Alignment Issue
- Gx470 alarm keeps going off
- Does anyone know this GX? About to pull the trigger
- Sport Package
- Rear DVD through sound system??
- shopping... 2004 sanity check
- Whining/Humming Sound
- Re-installing cross bars. Question
- Please help!!! Overhead screen not working
- New to Lexus and GX470
- Rear suspension Air bag replacement
- Whining noise
- Buying my first GX...help me choose.
- Oil Change Interval
- Mirror switches and dash lights control
- rear ride height uneven...
- Seat belt buzzer revisted
- Rockauto closeout items for GX
- 285/50/20 vs 275/55/20 tires rubbing??
- anyone run 275 55 20 tires on 20" rims?
- Time to make a sticky! All aftermarket suspension parts & part numbers go here
- NJ Mechanic needed
- question about timing belt tensioner
- Rear Window on GX470
- Empty slot next to the 2nd start button
- Looking to buy GX - Anything to watch out for?
- Any 2006's out there with dash cracks?
- wire harness support clips
- Hypertech for the GX - If anyone is interested in squeezing out a little more power..
- Overhead Console?
- Click Click Click
- Height control switch illuminated?
- Sewell Lexus...
- Running Board Clip Improvement ( 2003- 2007 GX470 )
- GX470 - Shock Absorber Replacement Criteria
- How to initialize Power Windows - GX after battery Replacement or Reset
- VSC& ABS Lights on . How to reset?
- Rear door weather strip
- Potential New Buyer
- newbie with a few questions
- World Standard Fluid change.. whos done it?
- Coilovers : 06isDriver please chime in
- Just bought 2007 GX 470 yesterday...phone book code question
- Climate control temperature setting seems off...
- hi-lo gear lever vibration
- Ugly new windshield
- 2013 Maps
- Problems already?
- Excellent article on the history of our trucks
- What maintenance would you do?
- New to me GX
- Key Fobs Stopped Working
- Just got a GX
- Lexus GX without a sunroof?
- Instrument cluster back lighting?
- Battery Died
- Starter -- any early warning signs or should I replace mine in advance?
- gx470 alarm goiing off
- 2003 GX470 - How to pull the radio?
- rear suspension raises or lowers after I turn off the car
- feels slightly sluggish and slight decrease in mpg
- Front license plate options
- GX purchase
