- Suspension Problems
- Loud Vacuum Noise
- Air bag alarm!
- Sunroof Closes, but it's 1/4 inch above roof
- Used Parts - GX 470 Atlanta Area
- Can Someone Run This VIN on Owners Site For Me?
- Add Backup Camera 2005 GX?
- Rust Concerns?
- Broken E-brake handle on 2007 GX470
- 07' GX470 108k...smoking on startup
- BF Goodrich KM2 (Mud Terrain) on lifted GX
- How to check to see if timing belt was changed?
- Where to find Recommended Maintenance Schedule
- 2003 gx470 vibration on steering wheel
- Clicking when turning wheel
- 245 70 17s on a GX?
- Replaced OEM Headlights with Depo Sport Package Headlights
- GX470 C1223 C1241 and C1246 codes thrown
- Rear Differential Question
- How to update Nav System on 2007 GX 470?
- Rear driver's side air bag leaking only on normal height
- Wanted GX 470
- Drive Shaft Install Question
- GX 470 with ZERO Registration/Service History!?!?
- Change Default Home Screen at Startup?
- Toyota settles for $3.4B for rusty frames - mean anything for the GX?
- Ford EcoSport rear door opens to the left
- Going into low range and locking differential
- Lifts: "Boss Performance" vs. Radflo vs. Icon
- Best ON-ROAD Suspension Upgrade? (not OFFroad!)
- Travel Trailer - what do you tow with your Lexus?
- 2005 gx470
- downloading iPhone phone book to Lexus system
- "Bump" Under Floorboards at Idle
- GX470 Mods, Fixes, & Parts You Need
- Can't get video mode to work with RCA cables
- Buying Used Midwest GX - Please Rate This Rust!
- How many miles are too many?
- GOBI Roof Rack & Ladder group buy discount
- Suspension issues PLEASE HELP
- Brief and total loss of electrical power at speed
- Connect iPhone to 04/05 Navi w ML
- Sound options for 04/05 with Nav
- 3rd GX - Never had this problem before. Phantom lights and alarm!
- Seized Rear Wiper Arm and Shaft Repair
- GX470 - Kumho ROAD VENTURE AT51
- KDSS Confusion!
- How Do Front Shocks Work Without Air When Using Comfort/Aport Mode??
- Looking for a GX, question about wood color
- Ride Quality; Shocks?
- passenger side air bag light...
- Headlights not coming on... sometimes
- Question about local lexus dealer advice on timing belt...
- Cleaned Hazy Headlights
- Can't get answers to change stereos 03 GX470 WITHOUT NAV
- greasing zirk fittings for u joint and slip yoke
- Weird sound while driving
- Thinking of buying a GX470 have a few questions
- Trade '11 Pilot for GX470? (no off-roading or towing)
- Passenger side Catalytic converter
- Front wheel bearing issues
- P0356 Ignition Coil Error Code - Only in Reverse
- 2004 gx470
- RX 330 tools to use
- front break calibers
- Dash replacement in Canada (NOT!!)
- 2004 GX 470 - Air Servo Issue (maybe???)
- 2005 GX470 Mechanic Changed Starter and Bent Valve
- Replacing coolant.
- Water pump replacement after timing belt change a few years back
- Buying 2003 GX 470 in 48 hours. . suggestions.
- Tips for finding a clean Non-Nav GX470???
- TPMS Reset Question
- Older Model Year With Less Miles? Or Younger Model Year With More Miles?
- Wheel lug length?
- 2008 GX Towing Receiver
- Trouble Pairing a Samsung Galaxy S6 to '09 GX
- Backup Camera Options
- Mechanic Reccomendation on Long Island
- Rear A/C
- 2005 gx470
- Gx470. 2005
- Jacking my car up
- Anyone Run the Magnaflow OEM Exhaust Manifolds?
- Air suspension drops as you drive
- Locate AC Freon Leak
- New Owner
- Check Engine, VSC Trac, VSC Off, Anti Skid Lights On
- Dash Replacement - Oder???
- What do I need to know?
- front outer lower window seal
- TPMS on 08GX
- Trade in Value
- Independent fog light mod, which pin on relay?
- Bad Secondary Air Pump code p0418 & p2445
- Instructions: Complete 100% trans flush with filter change
- Required tools for replacing a radiator
- Best timing belt kit to order for 2006
- 06 Gx timing belt
- First Time Diff/TCase Fluid Exchange - 2007 GX470
- Driver side, front end suspension clunk when turning. Video attached.
- Price Check from Shop
- 2007 seized FL brake caliper
- P0430 Catalyst System Efficiency Below Threshold Bank 2
- Thoughts on Lexus GX470 Purchase
- New 2003 GX
- 2nd gen wheels on a 1st gen?
- New owner!
- Lifted Lexus?
- Wheel Spacer for stock 03 gx470
- Driver side moulding clips help
- Do I need to buy shims for a brake pad job?
- Where is my coolant going??
- Stock to FJ wheel swap
- Bilstein 5100 and Moog 4Runner springs review
- Inner CV Boots
- How to release air from rear bags
- good lord, KDSS sway bar during strut install
- 2003 gx470 lift?
- Changing Courtesy light bulbs
- center console help
- Window vents
- Front strut mount bushing install
- Buying a used GX470- key takeaways from initial check
- 2006 GX470 passenger side rear splash guard
- Not another GX vs LX Thread :-(
- Lights on the dash and gauges inop, help!
- Rear Coil conversion
- Rear shock top nut and bushing..
- 2008 GX with 94K miles
- Leaking transmission oil pan
- Strutmasters Conversion - 2004 GX470
- What bilstein 5100 setting with front 4Runner springs?
- Left Front Strut Leaking on 2007 GX470?
- Purchased 07 - need info to remove carpet
- Hilarious GX Add
- Potential Stereo Upgrade ?'s (non-nav)
- Need Opinions Re a 2008 GX470
- Back Suspension Leak
- 12v accessory plug
- What is this brake noise?
- Wait time for dash replacement
- 2 radio antenna cables?
- 2007 GX Wheel Bearing
- My Dilemma - Buying a 2005 GX470
- 2003 Gx470- full tank digital mileage range
- Air horn, which oem horn wires to tap into?
- Need help with turn signal socket part # & source
- front suspension sagging a little
- Has anyone moved their differential lock button?
- Dash to be replace...anything else
- OTC Toyota 09730‑00010 Air Tube Separator
- Front suspension actuator?
- Timing chain or belt?
- GX470 Lift (Icon/Radflo) Handling
- Radio Volume Level (Low)
- A/C Hi & Lo Pressure Readings
- GX470 with or without KDSS
- OEM Navigation Upgrade/Replacement?
- OEM Replacement Suspension
- Asfir skid plates adaptable to a GX?
- GX 470 running board removal
- Mileage Recommendation
- Thank you, Craigslist
- Timing belt replacement
- hood scoop??
- what fuse for interior dash lights?
- My new BFD wheel with Nitto Terra Grappler G2
- Front End Clunk / Thump
- GX470 Rear Bearing, Brake, Caliper, Drilled Rotors, Backup Camera from GS350
- Broke the clip on my Engine Air Filter box. Help!
- Horn is not working and the location of the horn relay
- 2004 gx470 lift?
- OEM HID Headlights?
- Little button (slider) in center of AC vent? Where to find?
- New member who just purchased a 2004
- 06 GX470 Rear Brakes Replaced & Parking Break Repaired
- GX470 Cabin Intake and Burp Ports
- Driver Side Dash/Steering Assembly Squeak/Clink?
- Premature Brake Wear
- Best Front Brake pads
- Coolant change interval
- 2005 GX470 - 70k Miles - At Carmax - Should I do it?
- Do we have a flex pipe in the exhaust?
- Front Struts on 2007 GX 470
- Hiyoooo! New GX470 Owner Here
- Minor Scratch on Windshiled
- AC compressor grumbling
- suspension fail
- Hi! Got a 2008 GX470 yesterday. What are some must-have mods?
- Humming on a/c
- High Mount Brake light cover
- Radio Does not power on
- Hidden fuse for trailer lights?
- Extended warranty
- Paint Codes for 05 GX470
- My custom air intake resonator delete project
- Light Bar
- Fair price for my 2003 GX470?
- Sorry silly question, FJ & T4R compatible parts with the GX...??
- 05 gx470 a/c cycling
- New Member... "new" 2006 GX470... (with pics)
- Would you buy this GX?
- Loose connector in the front
- cooling system refresh
- How many miles will GX last?
- Roof basket/platform directly mount to the roof..??
- Replace O.E.M. dash screen on a 2004 with a Pioneer Avic Z-2...??
- New member -- from 4Runner to GX470!
- Tips for replacing CV Stub Axles
- Cracked Windshield Replacement.
- New Member! Need HELP!
- No sound from speakers on hot days
- Ticking noise when reversing
- Antilock Brake Control Module
- Dun dun dun..... The evil airbags strike.
- How to remove bumper tow kitch cover?
- Alignment Question
- Best online repair manual for 2005 Lexus GX470
- Wheelskins Stearing Wheel Cover
- An introduction and thank you to all...plus a weird TPMS scenario to top it off.
- Coolant reservoir overflow leak
- Gear selector getting stuck
- Joining the Ranks!
- P0420
- Anyone run the Magnaflow exhaust manifold?
- Modified stock air box, interesting
- Anyone out there running with newer tires in back and older in front or vice versa?
- New GX470 Owner
- 1st Gen GX470 questions-nav, towing, RSES
- magnaflow 15781 Fit?
- Running board lights no workie
- No start - instrument cluster flashing randomly
- condenser fan or ac fan ???
- Chasing noise - Motor mount?
- Suspension Question
- 07 White GX on 20" WT4's and 275/55 AT
- GX 470 Suspension Question
- Steering Rack problem
- Program Chipped Key for Immobolizer Solution
- GX470 w/Nav Solution for Aftermarket Stereo?
- 2004 GX470 - Front A/C is Cold, Rear is Not
- Air Suspension Replacement DIY?
- Will 5541260260 accommodate a standard double DIN head unit
- black birdseye maple trim
- GX Transmission Flush - How long is too long?
- New windshield problem
- Gx470 valve adjustment
- Off Road accessories
