- Help
- New shocks needed? / 2008 GS 350
- 2006 GS430 Strut Bar
- Installed "F Sport" Springs on my 08 GS460.
- Update on my Autopilot v2 setup
- Replacing struts on 07 GS350
- Best struts for lowered GS?
- Any videos or instructions on installing f sport springs?
- Ksport air struts plus Airlift Autopilot v2.
- Ride Quality after lowering
- HELP!! what do i need to get wheels fully straight with no camber??
- Tenabe or H&R spring updates?
- DIY Camber Kit Install for 3rd Gen GS300
- Ultra Racing
- Air Suspension Question
- 2006 GS300 Rear Strut Replacement
- UAS Suspension Questions
- NEED HELP*** OEM Springs
- improve the handling
- Who used the 2gen IS Megan front upper arm on a 3GS
- For those of you that are very low
- GS300/GS350 vs. GS300AWD/GS35AWD
- Front camber kit required?
- Camber kit on lowered 3GS awd
- Negative camber question
- 2nd Gen IS front upper arms on 3rd gen GS fitment confirmation
- IS Strut Bar
- Lowering a 3GS vs 4GS awd
- FIGS Front UCA and rear LCA bushing
- Those who have the SPC front camber ball joint, I have a install question.
- F sport springs-installed
- Tanabe NF210 for RWD
- IS250 Tien CST
- Alignment Specs
- front camber arms
- Megan's Rear Upper Control Arm
- anyone ever hear of road magnet springs?
- Struts for 07 350 awd
- caster arms?
- Suspension
- Best replacement shocks for '09 GS350?
- BC Racing Coilover issue?
- uas on bc coilover awd question ???
- Thumping, speed bump blues
- Bag Suggestions
- Clarity on stock suspension. KYB Ready to order.
- Successfully Completion of BCR install
- Accuair install help
- Need New Rear Shocks
- Anyone have pictures on how to cut BC Coilover Rear Extenders
- Coil overs causes check lights
- lower control arms
- F-Sport Sway Bar for GS450h
- gs450h coilovers help - how to get to top mount bolts (rears)
- BC Racing Coilovers
- Gs430 spring and shocks?
- Looking for rear strut part number
- Eibach springs installed.... Rear sitting a lot lower
- headlight's lowering after coil install
- Camber Suggestion for GS350 AWD
- Suspension Questions
- need comfortable coil over's for a 2006 gs430
- Installing coilovers this week.... Rubbing issues??
- Question about shocks
- Coilovers
- Megan racing ez street coilovers damper kit
- Megan Coilover/Tanabe Coilover
- 19 or 20 wheels
- Camber Kit Suggestions for GS350 AWD
- Gs450h df210
- NF210 Install - gap differences?
- Wanna Drp 06 GS430,
- Lowering Third Generation 430 Question
- Need 19 mm lower strut bolt (lower control arm)
- f sport suspension installed *almost
- 2006 GS300 AWD lowered on NF210 and RCA
- Replacement shocks AVS-450h
- non awd, wheel wobble all of a sudden
- just installed F-sport sway bars
- Last year was 18s now 20s quick photos sitn on coilovers AWD
- Springs or Coilovers
- Where can I order control arm bushings
- Where to get "axle spacers" machined?
- Stock Camber
- Just ordered F-sports sway bars
- AWD GS350 Springs
- Im having a hard time putting my stock AWD front struts on
- 2007 GS 450H Suspension
- Introduction/Wheel/RCA Blocks
- Finally dropped
- It's Going Down, Literally. AirREX Air w/ Full Wireless Management
- Megan Racing Lowering Springs???
- modifications on my lexus gs 450h
- Vibration?
- 2010 GS AWD drop on Vossens setup?
- New Guy- 2008 GS460
- F-Sport Chassis Brace... does it fit 3GS?
- Bc coilovers damper settings
- First modifications
- wat do i buy to avoid camber wear
- APSSS Removal?
- GS350 AWD Coilovers - HOW LOW SHOULD I GO???
- Lowering with AVS suspension
- looking for stock struts 06 gs300
- Tein ss coilovers vs Bcr coilovers
- Creaking Front Suspension
- Ride comfort between 2nd and 3rd Gen GS?
- Need Diagram Dimensions - Brakes / Suspension
- Installed F Sport springs... Kinda disappointed.
- Received a package from Malaysia today
- Help with findind a thread about struts, had service manual pics in it
- Front end makes a clunking sound -
- RWD vs AWD Shocks & Springs
- Looking for answers on lowering with springs...
- Do I need a camber kit
- Lowering the AWD GS350
- GS450H drop with RCA block?
- Which route to go with lowering?
- Sage REAR RCA Install Pics
- Need help after df210 install...
- BC Coilover Part Number for GS430
- 2007 GS with active suspension - what is causing the nasty rear end clunk?
- Spring rates.
- F-Sport Springs Installed on GS450h
- Active Stabilizer suspension????
- SEMA 2012 Ohlins Interview - Road and Track Coilovers
- e-level
- Do I need to change shock? My GS350 61k now. I feel the shock is a little bit hard.
- Lowering with Springs
- Lowering with Eibach springs on AVS shocks
- Camber off with stock suspension
- Gen2 GS300 Rotora BBK on a 07 GS450h
- Lexus GS 450 Coilover
- Has anybody ran the eibach kit and did they like it
- Thinking of lowering with df210
- fsport sways installation options
- Does coilover height affect ride
- Where to buy springs?
- SPC Front Camber Balljoints 67530 - Anyone Install or Using these?
- CEL came on after NF210 install
- Threshold for Lowering AWD Before Vibration/Wobble
- Megan Racing Springs ??
- Will i rub with this setup?
- Anyone here tried installing kw v3?
- BC Racing Coilovers in & some extra goodies!(PICS intensive)
- Noise from coilover?
- Tein SS coilover
- Control arm bushing replacement
- rca block question.
- KW coil
- i know nothing about shocks/springs... a quick push in the right direction
- gs350 Coilover
- does this sound like a good deal?
- question for gs430 onCoils
- RCA Owners Have a question...
- BCR Coilover settings?
- Air runner ????
- For all you BCR Owners.....
- Tanabe NF210 anywhere??
- Help with lowering my 2006 gs300 awd Please help!!!
- Megan coilovers make my car go BANGBANG!!
- Is F sway bar for 06 GS430 different w/ 07 GS430 ??
- camber, toe kit needed?
- Anyone with AWD and F Sport shocks?
- any pics of dropped on 18's?
- Megan Racing Coil Overs Fitment Issue
- Spring Rates?
- Shocks
- 3GS appreciation to suspension mods
- GS 430 Variable suspension Question
- please help... Sage RCAs Front Drop????
- suspension
- gs350 2008 shock/tire&wheel
- 06 gs300 rwd and 08 is250 rwd use same coilovers?
- Phantom Suspension. Just ordered it!!
- nf210 spring with awd qustion
- megan street coilovers?
- Rear Strut Replacement
- please help with this possile bbk fitment!?!?
- My car on BC Racing Coilovers and after i got it detailed.
- Bagged it...Ksport Airtech Pro Plus Kit
- lowering awd
- Current tires and rims, want to lower--any rubbing?
- Went 1/2 inch lower
- Tein CS Dampening Adjustment
- rubbing???
- SPC Ball Joint/Camber Kit
- Help! Gs450h lowering problem
- F-sport shocks for 08 GS 350 AWD
- car sits 1/2 inch lower on one side???
- TTE springs on 08 gs350 awd..? on sale right now
- Protecting my investment : coilovers sleeves
- DIY Coilover install >>>VIDEO<<<
- (rear) UAS air bags are rubbing when car dropped...how to avoid this?
- RCA 20mm kit on my 06 GS300......PERFECT FIT !!!!!
- Finally got her lowered but suffering from squeaks and chirps!!
- gs350awd lowering
- Awd lowered and hearing suspension noise
- is*50 lowering springs on lexus gs350????
- Questions about these Springs
- what lowering springs fit the 3gs? please help
- Need help after drop with coilover
- Question about these Springs
- tein coilerovers
- what springs stech or eibach?
- Steering rack GS 300 AWD
- Check headlight warning after installing springs?
- Question for owner with UAS
- Quick Yes or NO for Coilovers
- Prices to install springs gs300 awd
- Need help RCA install
- Improving 3GS Rigidity
- Shock Absorber - Rear
- GSh + 1" drop springs = ?" drop in the rear
- Advice? F-Sports or NF210's???
- help
- Megan ez coilovers
- Finally took the plunge with coil overs...
- Which way is better!!??
- Cutting the bump stop when lowering?
- BCR Coilover or F-Sport Spring for '11 GS350-AWD
- 20x9.5 +10 / 20x10.5 +5 or +10 on Air/Rear Camber arms?
- want to lower my car which springs do you recommend?
- Installed 25mm RCA on 06 GS300
- Lowered+dealer=help
- Tein SS coilover
- buddy club coilover question squashing noise
- Eibach Pro-Kit
- NEED HELP!!! Front Knocking Noise
- Drop + Camber combo
- DIY: Lowering your GS
- Shock replacement - DIY questions
- After installing lowering springs
- F sport sway bar
- F-Sport Swaybar Clunking Noise Fixed
- Tein S
- Need a 3GS Owner in the Colorado Area! FREE Parts!
- Just lowered my gs300 awd
- F-sport springs fits on 06 gs awd??
- Which coil overs?
- gs350 alignment help w NF210's
- more questions on awd vibrations
- Springs?
- HELP!! 2006 GS300 AWD lowering springs
- NEED HELP!! 2010 GS350 AWD Suspension
- Gs350 sway bar oem
- fitment bc coils for 2is awd and 3gs 350 awd
- Megan LP coilovers gen2 gs3 to gen3?
- Air Runner installed (with pics)!
