View Full Version : Hybrid Technology
- Voltage Spike(s)
- 2013 RX 450h engine buzz
- Maintance for 104K mile RX450h AWD
- How to activate Maintenance Mode
- Water pump
- Used RX450H
- intake air volume, mpg, power and noise
- Problem with dead, unresponsive car.
- Rx450H ready light not coming on
- RX 450h towing ?
- Service Gap
- how to repace lexus rx 450h 2013 battery?
- Stargazer Black 2013 RX 450h
- High mileage 2013 RX 450h
- force electric use...
- Braking on Ice .. another hybrid advantage
- New owner 2011 RX450, won't start
- New owner of a 2013 RX450h
- "ready" and "check engine" blink when starting
- what is the Traction Battery life?
- Gas Milage and Hybrid Battery Age
- E and 1/2 E on consumption Bar chart display
- Does a 2015 RX 450H have any offroad ability?
- 50k and 60k service
- AC Power capacity in 450h
- Parts question and feature question
- Why did Lexus choose ATF in the CVT?
- 2012 rx450h will not start
- Regen of battery power when the batteries are fully charged
- Garaged for 6 months
- 3rd gen RX- model 450H DIY index
- Windshield
- Auxiliary belt 3.5L engine
- 2011 rx450h jolt when electric engine first starts
- Used 2011 Lexus RX 450h Opinions
- Lexus rx450 : Difference between gyl10 gyl15 gyl16
- Difference between 2013 and 2015 rx450h
- Diagnostic Equipment
- My Lexus 450h Warning "Check Hybrid System"
- 2010 rx450h light bar
- Acid smell when accelerating 2012 450h
- towing with rx450h and reversing up incline
- Improving the RX Hybrid - What's on your wishlist?
- Hybrid battery health
- Any one done brake pad change on the new shape RX 450 h 2016 model
- How long is it safe to let a 2010 Lexus Rx 450h sit without driving?
- Backing up an incline from standstill
- Trivia about drive battery indicator
- Klimaanlage beim RX450h
- AC works on one side
- Air duct under rear seat.
- Gas Cap induced light show?
- Tire pressure monitor faulting
- Portable Battery Pack - Booster/Jump Starter
- 2010 RX 450h awd
- Battery size vs. power from MG
- Newbie experience and a question.
- RX450h CVT fluid drain plug and fill plug location (front and rear)
- Need to adjust up led headlight on current RX450H
- Lexus 450 H -2010 ABS Brakes
- Tire pressure readout on dash
- RX450h has 477 combined hp why isn't it faster 0-60?
- Breaks regenerating problem...
- Check Headlight System Warning
- New owner, new questions
- Traction battery care when in storage
- Panasonic D23 Battery Code - RX450h
- RX450h- 2012 model- Australia- Dead Memory seat butto
- Flooring the gas pedal in hybrid snow mode
- 2010 RX450h Hybrid Overheat Message Long Trip
- Leaking air conditioning compressor oil
- First time Lexus Buyer - older used? newer used?
- RX 450h hybrid battery warranty is 8 not 10 years in California
- Fuel economy killer
- Snow Help
- Using the cruise control for regen braking
- engine noise
- Any way to equalize the audio?
- Toy Propeller Sound from Climate Control
- active power stabilizer suspension system
- Lots of noise in car post windshield replacement
- Non-dealer oil change in VA
- RX450h does not start
- Q regarding parking brake and 12v battery
- Power Steering Fluid and Replacement
- TPMS & MPG Observations - 2010 RXh
- Connector question 2013 LEXUS RX450h
- Greetings!
- RX 450h towing package (manual p377)
- 2013 450h maintenance and oil change
- thoughts on buying a used hybrid?
- Resetting ECU
- Looks like I'm joining The Club - officially!
- 2011 450H - Same used prices as a 350? WHY?
- buying 2013 450h
- Engine stalling on hot days.
- HP and Torque Curves - Dyno Charts - 2GR-FXE in RXh
- 2010 RX450h P3190
- Potiential RX450 Owner
- Looking at a 2013 450h... any major issues to check for?
- Engine knock at cold startup - RX450H
- Headlight with DRL fit 2011 RX
- 2013~2015 RXh Among Least Reported to have Sufferd a Non-Crash Fire loss
- Airbag
- 2010 RX450H Headlamp
- Factory HID
- Just bought 2015 RX 450H!
- Led drl with fog light 2010
- Looking to buy 2010 RX450h
- Help....2012 RX450 malfunction cold weather?
- 2013 RX 450H Poor Traction Performance
- Rotten Egg Smell/Odor
- Help choosing between 2012 and 2013 RX450h
- RX 450h 2015 - is it a good truck to buy?
- led interior lights
- 2011 RX450h OEM 12V battery capacity.
- RX450h hybrid ECU firmware update?
- $5200 for new air conditioner?!
- Headache in RX450
- Where is ODB-II port located on RX450h 2014?
- How long for my 2010 RX hybrid "life expectance"
- 2015 Rx450h Mileage overstating and Issues
- DIY: RX450H Rear Brakes
- Battery Tender Connection
- Cross Country winter driving Experience
- New 2011 RX450h Owner
- 2011 RX450h need help with electrical system problem
- Question on brake regeneration and MPG
- Which to buy? '12 450h AWD or 10' 2WD w/less miles?
- Location trailer brake connector?
- 450h traction battery cooling fan question
- Have a little problem with check engine light. (2010 rx450)
- Moving On...
- Long hill excessive vibration
- Does 450h use the exact same shocks as RX350?
- RX 450h Engine Air Filter Part #
- Moving the shifter to S-mode
- rx 450h carpet mat set
- Technical Service Bulletin notice
- Any concern on the 450h battery
- Google's Self-Driving Lexus RX450h Takes on Texas
- Regenerative Braking
- Excess of lubricant...
- CPO RX450h, is there a benefit having the Sport Appearance Pkg?
- 2013 rx450h - 18 or 19" wheels - noise level
- Headlight Sweeping Mode Inop. Code B2431
- Charge Line for Towing
- Combined power on RX450h
- Battery Charge State
- RX450h Pulsing?
- How smart is my Lexus?
- Loud fan/creaking/clicking fan under rear seat
- My RX is leaking
- Track Record for Owning a RX 450h Long Term
- Please evaluate my lease.
- 2015 RX450h Brake Actuator
- Full battery normal?
- gas engine turning on while reversing
- 450H Enform Trip Report "E" icon
- Best accessories/mods for a new Lexus RX450h
- Hybrid Vehicle Dismantling Manual
- what engine oil do you use?
- Replacement 12v battery for Lexus RX450h
- HELP - Major RX450h Issue
- Water in hybrid battery compartment via shark fin antenna
- New to me 2011 RX 450h - issues: driver heat, mpg, hot center console, digital disp
- Need help with my New CPO 2012 RX450H
- rust protection for 2011 RX450h
- battery use when accelerating
- questions about 2010 450h?
- Ham Radio Transceiver in 450h
- Keyless entry not working + AFS check
- Drove her home today!
- Check engine light came on..
- Anyone disappointed in their 450h performance?
- Question about octane
- Why is Lexus degrading the RX450h
- 2010 RX 450H Repairs
- Ordered our new 450h and have one question
- Why higher MPG numbers for city driving?
- Crickets
- Time for new brakes.. @ 77k
- Hot air came from rear seatbelt slots
- 2010 Rx450h vs 2015 RX450h Powertrain Imorovements?
- Clicking sound on acceleration?
- RX450H headlights, which one do you have ?
- RX 450h - Suspension Damper - F Sport
- Lexus Enform Problems in 2013 RX450h
- Buy 2015 RX450h, or wait for New Generation?
- Check Hybrid System warning
- Waterpump Gives Up
- Impressions after 4 months
- RX450h keeps its title!
- 2014 vs 2015 body
- 2010 RX450h Transmission Question
- 2010 450h with 77k, is it worth it?
- Tire replacement, looking ahead
- Oh My! Dealer canceled order
- Finally saw 29 mpg.... And then......
- Tapping sound on startup ?
- sun visor
- My car makes a funny sound
- Long-term hybrid owners: battery questions
- Replacement Battery
- RX 450h EV Mode
- AC/Heater issues with 2010 RX450h
- Help! No power in RX450h
- CPO 2012 with 46k miles
- Why did you choose a RX Hybrid?
- Will they introduce the 450h F-Sport in the USA?
- My car keeps losing my contacts
- Great features but high mileage worth it?
- 2010 RX350 vs 2010 RX450h trade question
- 2014 RX tire pressure info
- 12' rx450H - Problem with Speedometer and Hybrid Monitor
- What's a CPO worth?
- thinking of exchanging RX'h with Highlander
- RX 450h Tachometer
- first hybrid
- 450h AWD in the Snow
- Enform weirdness
- Remote Start in extremely cold temperatures
- Need Help - RX450h
- CPO rx450h or CPO rx350
- worth getting? CPO RX450h
- Eking out the miles per gallon
- 4RX 450h
- Battery Charging
- Weak heat in 450h, is this normal?
- New Lexus hybrid coming to a dealership near you
- Enform audio doesn't recognize iPod USB connection
- CVT Transmission S Mode
- plug-in for RX hybrid series
- Fuel Consumption Screen
- New key fob battery needed?
- Hybrid issues?
- 2014 LED Headlamps - AFS and Intelligent Hi-Beams?
- Best tire pressure?
- Anyone using "S" mode, when and why?
- Is 2013 floor dimensions same as 2014?
- Nav menu cycling
- Anyone else getting exhaust "smoke" 450h
- Deer whistle- where to install on rx450h?
- Exhaust system is very expensive
- RX450H with Remote start, engine won't warm up in winter
- RX 450H - Serious Brake Issue
- Negotiating a lease on RX H 2013 or 2014new
- Sudden Drop in Traction Battery
- Trailer Towing Experience with 450h, FYI
- Are all 2010 RX 450H created equal?
