- Trunk safety feature question.
- Will missing a scheduled maintenance invalidate warranty
- Snow tires
- Ac help
- Stereo not functioning
- code PO157
- Navigation Previous Destination Date
- Rattle Warranty? Dealer won’t repair speaker under warranty.
- Replacing Struts/Rear Shocks
- Light clicking noise while driving RX350?
- Full left or right clank noise at end of turn
- Oil change error
- Maintenance on 2012 RX @90k
- sensors not working
- Right knee panel issue? pics inside
- Tint installer burned Pillars replacement diy help
- Trying to figure out if these wheels fit...
- RX 450hy door lock mechanism
- How to replace sensor retainer outside round clip
- Winter Wheels and TPMS
- Rear Speaker Volume
- Cost of tailgate motor on 2013 RX350
- 2013 RX350 front plate bracket screw size
- Air Filter Notification Reminder
- locking doors
- Tubing size for bleeding Catch it bottle.
- Is Navigation Hard Disk Drive Replaceable?
- rubber trim on roof is gone
- Liftgate alarm
- Difference Between a 2011 and a 2014 RX 350
- Condensation
- 2013 rx350 fsport engine tick
- Pandora in Enform App Suite
- Engine difference between '11 and '12?
- Missing bumper piece-2015 lexus rx350
- Cost to replace struts and one shock in Lexus RX 350
- Sun Visor Keeps Falling Down
- 2016+ F Sport Bumper on 3rd Gen
- Sour milk smell in my 2013 rx350
- Valves on “Lexus Preowned”
- 2012 RX350 driver side lower chrome molding coming out!
- How often do you pop the hood to do a visual?
- Color Preference vs What you Have
- Problem with debris/leaves under hood causing fire hazard.
- Certification criteria for Tire
- Advice purchasing used 3rd gen / Top 5 common problems
- Why don't my side mirrors come back up after reversing?
- 60,000 miles list
- Climate Control System Error
- Headlamp swap?
- Microphone not working. Rattling steering noise on low speed
- RAV4 to RX350?
- Brake Pedal Frozen
- Knocking Noise - Irritating the goodie out of me.
- Oxygen Sensor Replacement
- Need help with reading transmission temperature from OBD2
- Headlight bulb replacement help !
- If Key fob battery is dead, Can I still start the car?
- Wifey's RX350 Build Thread
- Radio reset
- Installing door edge guards
- ABS Issue, ABS system pressurization
- Hire a pre-purchase inspection mechanic
- Key for 2015 Lexus RX350
- Interior Driver Door Trim Protection?
- is 0-20 really correct for hot desert climate?
- Body kit for 2011 rx 450h
- Key not detected
- Audio cuts out in hot weather
- Somekind of autohold?
- HUD stopped displaying
- 4th Generation Regret?
- Lexus Dealer Diagnostic
- New Owner / DIY'er Question
- Display button constantly pushing itself
- mixing brake fluid
- 2010 RX450H strange noise
- Terrible experience at service center, here's my rant give me your opinion
- I jammed the tailgate of my 2015 Lexus RX450H
- Auto (Proximity) Unlock
- 2013 RX 350 Engine Mounts
- Shift flare?
- 2010 RX 350used purchase
- Certified Pre-owned RX Rust Warranty
- 19” inch wheels 19x10.5 +22 on 2015 lexus rx350
- All RX450h Equipped with Parking Sensors?
- Radio changes channels
- Does the back tailgate window open on a 2010 RX450h?
- Auto Bright
- 450h clicking sound
- Exterior B-Pillar Trim Removal
- Buying out my 2015 RX350 Lease
- Downsizing Wheels
- Noisy and Terrible Ride
- Wheels offset
- Picked up an RX yesterday, brake question
- 2013 -> 2018 Rim Swap 19" to 20"
- oil maintenance light
- Front Bumper Sensor
- Hood light and door lights not working
- Need advice on buying a 2015 RX 350
- Engine oil grade change by mileage
- Defective Voice Recognition
- Uninstall underbody splash shield
- Resurface or replace?
- open hood from outside
- emergency key keeps turning
- Where does this piece go?!!
- 2013 Lexus RX 350 notifications
- Rear Bumper Sensor.
- Black glossy vinyl on roof of silver 3rd gen?
- Is this how your transmission shifts?
- Purchase advise, 450h vs 350 vs ?
- 2010 parking assist help
- Seat heat and filling switch
- The dreaded Climate Control servo issue??
- Hitch and LED install
- 2015 RX350 starts by itself
- 2014 RX350 Brake Actuator Noise?
- Passenger side mirror won't hold its setting
- RX350 Foam from vent
- No Brakes
- Advice needed!
- Front parking sensor / sonar replacement
- 2010 Rx350 airconditioning sensor message
- Bluetooth issues - only music, no phone calls
- Brake malfunction
- 2012 RX 350 Lease and New UX for 2 Seniors; Radio problems
- 2015 RX 350 Air Conditioner Problem
- ABS Light/Warning Beeping - Car seized, Steering locked...
- 2012 RX350 with high miles
- firmware update for 2013 RX350
- Adding '13-'15 LED running lights to 2010 RX350?
- ? VSC needed on 2013 RX 350 w 29k miles?
- Tail Light Assembly - missing wire from connector
- 2011 RX350 Fender Inner Liner
- Loud chirping, squeaking sound under dash
- Battery drain issue?
- RX 350 - Reupholster seats?
- Is this Lexus Enform?
- Navigation system
- tail lights
- power for dashcam
- 2014 rx350 refrigerant capacity
- Talk to me about a 2015 F Sport
- Aftermarket Wheels Pics
- factory tint = just privacy glass?
- Looking to buy 2010-2015 RX, What features should I target, what to look out for?
- Doors Recently Stopped Unlocking by Touch (FOB in Pocket)...
- Used RX purchase - looking for input from current owners
- how to set up cigarette lighter in 2010 lexus 450rh
- EBC brakes on '13 RX350 base AWD?
- Help me decide between F-sport and non F-Sport
- Heads up display
- Driving without the Key
- Heat only the seat back but not the bottom?
- Auto Movement, Outside Mirrors
- Bluetooth only sometimes ringing
- Looking for Help: Buying Used 3rd Gen RX
- Attempted breakin?
- Tire balancing
- Daylight Running Lamps not on? 2010
- sound system "fails," then magically resurrects, after nav update
- Knocking Noise?
- Help !!!!!! 12 rx350 passenger side led brake light issue
- Passenger side brake light out changed bulb still out??
- 2014 F Sport with high mileage - would you buy?
- Number of this bushing
- Song Titles
- 2010 RX- Large Center Display Freezes!
- Automatic opening of backdoor accidentally turned off.
- Thermostat change with cooling service?
- Water pump and shocks
- 2015 RX 350, 38k miles, CPO from Lexus dealer, listed for $28k
- RX350 Liftgate
- 2015 RX 350 purchased from Feild’s Jacksonville, Fl. Missing option/excessive noise
- Speed dial without phone book??
- 225 width tires for winter use?
- Used 3rd gen RX - advice needed
- L/Certified 2015 RX350 with cracked and bent motorized mirror
- 2010 RX450H - Evaporator coil replacement
- Any yellow or red flags for used 2011 or 2012?
- Alignment required after front wheel bearing change?
- map
- parking sensor wiring repair
- opening tailgate remotely
- Purring sound coming from 2010 RX 450H With Engine On and off
- Tailgate on 2013 RX350 not working
- I need help on the tailgate please 2010 RX350
- Replacement Amplifier in 2010 RX 350. II
- 2014 RX450H Alignment Question
- Power liftgate motor shot, need some DIY help
- Help for new owner!!!
- Replace all 4 on AWD, always? CPO Didn't.
- Will 17" Lexus OEM alloys fit?
- iPhone 8 won't stream music
- Brake Pad Life ?
- XM weather activated - No subscription
- Traffic updates (free XM trial)
- 2011 RX350- Navigation-
- Codes at no cost :(
- Which Used Lexus RX350 Should I Get?
- XM and Nav question
- How to remove caliper guide pin's rubber boots
- Looking for front grill
- DIY Oil cooler line replacment
- Window rain guards
- Replacing Starter DIY with some pics
- Fender Bender
- Power steering reservoir location
- RX350 not starting Options?
- Cabin Blower stays ON all the times
- How to change license plate bulb?
- A/C amplifier
- What is the name of this part on the headlight?
- TPMS Installing
- Does Lexus Hitch from 2004 RX330 fit on 2013 RX350?
- 2013 RX350 Car Charger/USB Not Working
- Voice Recognition - 2011 Lexus RX350
- Radio Power volume Knob changes from FM to BT
- Bumper Conversion 2013
- 2010 rx350 - Heating and AC resetting
- bypass automatic leveling headlight
- Rear license plate screw broke inside... also, how to place front license plate?
- 2010 - Rear shocks discontinued?
- Deteriorating front wishbone and rear radius arm bushes?
- How to replace the factory radio?
- 2010 RX - Engine drone
- Torque specs for a complete brake job
- passenger door problem
- Brake fluid
- Acceleration lag between 1st and 2nd gear
- Windows go down
- 2012LexusRX350Coolant radiator leak!
- Bluetooth
- Lexus RX 350 2012 Yellow substance under all 4 door handles
- High mileage service cost estimate - 2011 RX 350 AWD
- Windshield Wiper Question
- Rear Arm Rest Cover
- Nipples!
- Window trouble
- 2015 RX with 33,000 miles Question
- rust under back camera
- Changing rear side light marker bulbs on 2015 RX350
- 2015 Lexus RX350 noise
- Can I replace only one tire?
- Center console cover for 2015 rx 350
- Outside tire wear on Michelin original tires
- 2015 RX350 - 60 Manufacturer Communications on nhtsa.gov
