- Rx 350 2010 model AWD/ Urgent urgent
- Alignment Spec 2010 RX350 AWD
- after putting my lexus in park and releasing the foot break it moves
- SOLD my 2010 RX350
- Please help Install OEM remote starter 2011 rx350
- Glove box rattle
- Polyurethane sway bar - stabilizer bar bushings on eBay
- Moonroof doesn't close
- 2015 RX350 Hood Strut Replacement Recommendations
- Unable to connect S7 to BT media player
- Turning off Traction control light
- 2010 transfer case gear oil leak
- 2011 Rear Luggage Clips Strangeness
- "Audio Off", Joystick dead, no music :-(
- Pink Caliper for 2014 RX
- Cruise Range Display just disappeared?
- AM radio poor reception
- Widest tire on 2015 F-Sport Stock Rim
- RX350 Horn stops working after driving for a while
- Only highorn sounds from steering wheel. BOTH from key fob panic button!!
- Headlight turns off while driving
- Do you think this will protect the rear bumper?
- 45,000-Mile Service
- Peeling Mouse/Controller
- What gear for towing a trailer?
- RX 450H Air Suspension Conversion
- Front badge/emblem replacement
- Fuse location for lower console accessory?
- 2010 RX350 - Want to change useless fog lights for pencil-beam driving lights
- Dog Bone Engine Mount
- Cracking sound when releasing parking brake sometimes
- Mass air flow sensor cleaning 2010 RX450h
- RX350 Newbie suggestions?
- Dealer overfilled oil? Take a look at this picture
- Where is the oil cooler line on 2012 RX?
- Undercarriage-What am I missing?
- 2011 RX 350 AWD vibration
- Shark fin antenna cover
- 2015 RX350 Dealer Maintenance Upsell?
- Cost for 90K maintenance
- 2012 Lexus RX350 A/C problem DTC B1423
- Seat belt latch
- Factory Workshop Manual on CD ?
- 2010 RX 350 No Driver Side Heat
- Would you tow this?
- GNTX 651 Mirror
- OBDII Scanner Decision
- rear seat air bag
- 2015 rx350 moves forward in neutral
- TRD filters for RX350
- L/Cert 2013 RX350 73k miles purchase question
- RX450h 2010 - Control Arm Bushings Replacement
- Switching from ES350 to RX350
- Rough idle, do I need new motor/trans mounts?
- Blinking security light won’t turn off
- DIY - RX 09-12 Comfort Turn Signal upgrade
- Will these RX350 wheels and tires (235/60r18) fit on F-Sport 2015?
- Powered Rear Hatch?
- Naviation instruction heard while on the phone
- Post-Dead Battery Issues
- b2799 engine immobilizer system fault
- Door lock
- Error Code P0015: "B" Camshaft Position - Timing Over-Retarded
- Mistake in Canadian 2014 Lexus RX350 maintenance calendar?
- Fuel gauge questions
- Lexus 2015 rear window sliding noise
- Navi screen auto sleep
- Carista Settings?
- 2012 RX450h Audio Problem
- Help with Tire Pressure for 2014 450h F Sport
- Sometimes tire valve doesn't shut after being pressed
- DIY 2013 RX350 tail light inner assembly replacement instructions or schematic diagr
- Side Mirror Replacement
- 2010 RX450h vs. 2011+?
- Waze instructions through audio system?
- is this a pulley issues?
- Remote Start not working
- Extra interior plugs
- Additional power outlets
- What's the part called? Please help
- Replace \updating Head Unit
- How long did the TPMS sensors last for you?
- 2015 RX F-Sport Steering Wheel Groan/Whine
- DIY details and part number for O2 Bank 1 Sensor 2 for 2010 RX350
- Rare RX?
- 2015 Sunroof Seal Leak
- Engine moving control rod replacement
- Does Rx caliper uses washers on banjo bolt?
- 2010 Lexus RX 350, popping noise
- Looking to get an RX350, which year is recommended?
- Random noise coming from back door when car is turned off.
- "Low Battery" Voice Prompt...
- Pics of 16+ F sport wheels on 3rd gen ?
- 2010 RX350 Rear Noise (AWD)
- Exhaust system upgrade
- Affordable Transmission Replacement?
- no audible sound when lock car
- A/C so s........l........o.......w
- Windshield replaced - does it look right?
- Tow Hook Plate Holder
- 2015 RX350 Will not start
- need to fix this driver side sun visor, tan or gray
- Injector vibration insulator oil leak
- Hose connected to intake boot is loose
- Weird interaction between door switch, door chime, brake pedal, and Start Stop button
- Buying 1st RX350: 2010-12 vs 2013
- 2015 RX350 Head lamp housing inside fogging
- RX270 fuel filter change disconnect batteryor pull fuse
- liftgate motor part number
- Mirror tap radar detector connections
- Why shouldn't I buy a 2011 RX-350?
- Random problems with my Audio inputs switching
- Adding amplifier to my Lexus 350 2012
- Replaced bulbs burned out after 2 years and 13k miles
- Bluetooth has stopped working
- Advice on minor accident repair
- Strut 2010 RX350
- Upholstering seats 2010 Lexus RX350
- What is this?
- Change tabs - bluetooth with phone
- Door handle unlock
- BSM Stopped Working
- 2015 RX 350 Maintenance Required??
- Extending oil change interval by 2000 miles for exclusive highway driving
- Subwoofer on 2013 rx 350
- New 2010 owner with o-so-many new owner questions
- Replacing tailgate on 2011 RX
- Park Assist error
- Can of seafoam into engine case when 15% of oil life left, thoughts?
- Your opinion on this dealer service quote
- replacing passenger side lower control
- Good tire and wheel / rims combo for 2014 RX
- Aftermarket Front Camera
- RX350 - Unstable on interstate/wind 60-70 MPH
- 2012 lexus rx 450h beeping every 30 seconds when car i
- Potentially a new owner but still needs help in steps for a proper buy...2013 rx350
- Nike Light issue
- Can't control driver's side A/C.
- 14 RX broken auto folding mirror
- RX350 Changing front turn signals
- Oil Build Up on both steering boots and oil cooler 2014 RX350
- getting rid(covering) the chrome
- Opinion on possible 2013 RX350 purchase, Pls
- I can't find the block for AWD system
- Computer got 'wet' during AC repair
- Dvd/cd player decal peeling
- Manually open trunk
- 2014 RX350 Fuse location
- 2012 RX350 trunk won't close
- Trans oil cooler installation
- RX 350 2010 Led Headlight Replacent
- battery terminals corroded
- UCS bar system
- Change brake fluid
- Looking to upgrade to LED headlights, what do you recommend?
- New transmission at 80k miles?!?!
- Can’t pair iPhone XR
- 2013 RX350 AWD stalls and dies, no CEL
- Where heated seat control located?
- Aftermarket Subwoofer
- Question about Auto Dimming Side Mirrors
- Sound system mute when on a call
- Aftermarket HUD that looks nice on the dash?
- A/c malfunction
- Door panel (soft touch injected molded plastic material) making noises
- Should I have a roof rack cross bar?
- Should I buy a 2013 RX350 with 130,000 miles?
- Rear Shocks Torque Specs
- RX 350 oil catch can
- Plastic tab
- Help Me Choose between 3 please
- Version of GPS in L/Certified?
- Advice on 20" tire size please
- When I plug a USB/Thumb Drive into the system to play music run through the playlist
- HUD stopped working
- Deprogram lost key
- Cost to replace rear bumper
- New RX350 owner from Eastern NC
- Distorted Windshield Normal?
- Timing belt or chain on 2011 RX450h?
- Aftermarket plastic engine under cover / shield?
- How to find 2015 has PCS or not
- Towing question 2012 RX 350
- Is RX As Quiet as ES, GX, other?
- Value of Lifetime Powertrain Warranty
- 2013 - STD iPhone/USB interface
- Rear Brake Light Replacement
- Tire rotation question
- Experience with Costco TPMS?
- Original Floor Mat color?
- 3rd gen front bumper upgrade to 2016 style
- Hardwire dashcam for always on power
- 2015 RX350 outer drivers taillight
- Why is it so hard to find a RX350 w/adaptive cruise
- 2015 RX power on problems first thing in the morning
- Grinding noise from transmission
- DIY Specs for recommended Service
- Want to use 2nd gen rims as winters
- What changed from 2011 to 2012 to allow regular gas?
- How many is too many miles?
- Use safety connect power for dashcam?
- Will warning lights go off if service hasn't been done?
- Slip light keeps coming on
- Voice Recognition Stopped Working !
- To paint the center bumper black or not?
- 2012 RX vs 2015 RAV4
- 2011 RX450h pulls to the right under acceleration
- 2015 RX 350 display failure
- 15' RX350 Weird noise when driving
- faint/quiet car lock beep
- Maintenance for 60k, 90k, 120k
- How to examine brake pads
- Remove Airbag and Glove Box
- RX450H 2010 vehicle customization menu missing
- What are the major differences between the 10-12 RX 350 and 13-15 RX 350?
- Parking Assist went south
- 2011 Lexus RX350 Front Brakes
- Trailing arms or control arms seized due to winter weather?
- Clock went crazy
- change brake pad on 2015 RX 350
- Issues with a CPO 2015 RX 350
- electrical problems 3rd gen
- tire warning light
- Buying a used 2010 LEXUS RX350 with 70000 miles
- Voice Training Session
- What's in the RX factory towing package?
- Can't open door with key fob or physical key
- PA ClubLexus Meetup
- Oil change filter question
- 2013 Rx Radio/Media no sound
- 85 or 87 Octane ?
- Can I use 5w-30 on my RX350?
- Cold are intakes, are there any?
- Are 3rd Gen Head units interchangeable?
- 2014 RX250 won’t rev above 2000 RPM
- Phone Quick Reply
- Oil Seepage - 2015 Lexus RX350
- 2010 RX AFS issue please help
- Serpentine belt, broken rear wheel stud, rear brake hardware
- RX350L without Tow Prep Package anywhere?!!!!
- Navigation Display - Flickers, Shuts off.
- Should I stay or should go with a 3rd gen.
- Help choosing Brake & Rotors for RX350
- Is this an RX interior trim piece?
- New owner questions
- Sound upgrade possible for base 2015 RX350?
- 2012 RX450h Brake Warning - C1377 code
- Lexus rx 350 2012 started on own
- Long link connection times - is this normal?
- Issues with mirror adjusting when reversing
