- Lexus rx350 2010 Liftgate not closing by the door bottom
- Rattling noise on Steering column
- Please help to identify if the wheel Rim is Real or Rep
- -Window switch wiring help needed.
- 2015 RX350 AWD 20in wheel upgrade
- Year, Mileage, and Major components replaced. Go.
- Can Bus IDs for 2011 RX 350
- 2010 RX350 rear drain tubes in moonroof
- Front headlight film separating?
- Google Maps through Bluetooth Audio...
- Puddle lights under mirror not working
- Lexus OEM push button switch blanks
- Use RAV 4 OEM parts for RX
- 2015 Driver side low beam with auto leveler
- 2014 RX350 Fsport- timing chain or belt?
- Help: ONLY my MPG display isn't working!
- 2014 RX 350 passenger heat issue
- Rack and pinion steering fail a second time cause?
- Battery dead after 1 week
- 2013 RX350 Door Lock Issue
- 2010 RX Heat Issues
- Self Maintenance Question?
- Timing chain problem
- Number of Catalytic converters
- Data Communication Module has corrosion??
- Ticking Noise from Dashboard
- Headrest removable?
- Put new front break pads on my 2013 RX 350. Won't start. Check AWD system light is on
- SRS Passenger sensor needs recalibrated
- Just bought '15 RX350 -Any bad stuff I should know about?
- Can anyone ID this glove box part's name?
- Fog Light Replacement
- Drive Cycle Readiness Monitors
- Suspension upgrade
- 2015 RX350... No Heat on Passenger Side (front)
- Auto-dimming Rearview Mirror, removing housing
- 2015 RX 350 rear suspension rattle slow bumps
- 2013 RX350 - Test drive - "snow tire" hum from front end above 60 MPH
- Clucking sound and steering wheel movement
- Bluetooth keeps turning off, especially during rain or cold weather
- 2013 RX350 2WD Repeated Brake Rotor Warpage
- Shudder (guessing transmission)
- Trans software update??
- 2010 Steering Wheel Need More Telescope
- Brake / ABS Issues
- Rear Brakes wore out way too fast
- Interference noise coming from speakers
- 2015 Lexus RX350 AWD Mayday(backup) battery issue
- Is the color under the hood different?
- Curt 13143 Hitch Installation on F Sport
- Missing "Filter 10A" and "20A TOWING BATT" fuse?
- Certain Dashboard Lights Don't Light UP
- Buying a 2010 Lexus RX-350. Weak transmission?
- BIG Brakes On Our Cars? Possible leads from 5th gen RX
- Hardrace Rear Stabilizer Bar On 3rd Gen - Anyone Tried One?
- Hood Latch issues
- 3rd Gen Lift?
- Here in late '22: can beneficial LED's be put in Halogen OEM's?
- 2013 RX350 Idle Engine Noise w/ Video
- Anyone know how to get to the cigarette lighter?
- Front end noise
- Please Help my lexus rx350!
- auto door unlock issues
- CV boot replacement
- Air Vent/AC flow issue
- 2012 rx350 exhaust pipe gasket
- drive train slack
- What Is This Part? I'm Stumped!
- Ticking Noise - Valve Lifters
- Tail lights
- Bottom cushion leather replaced
- CarPlay Android Auto now available for Lexus RX 2013-2015 No-Nav
- Squeaking rear sway bar
- 2013-2015 F-Sport Steering Fix? (Stay Tuned)
- Heated mirror temp question
- Steering gets hard and forces comp reboot
- lexus rx head-up display doesn't turn on
- Grom Vline2 now available for non nav 2013 & 2014
- Door lock problems
- 2013 RX350 Radiator Replacement Project
- Door won’t open from the inside
- Got to get my feet wet!
- chrome wheels for '13 RX350
- 2014 HUD Retrofit
- Electrical issues - 2010 RX450h
- 2010 RX 350 with 177k miles - what should I worry about?
- This normal brake wear?
- 2013 RX350: Driver's door lock/unlock (only works with key)
- Rear wheel panel scratched
- Help with "Check Headlight Leveling System"
- Fuel gage fuse
- Toyota Highlander 17" OEM rims on 2010 Lexus RX450h?
- OEM Backup Camera install
- 2010 rx350 low oil pressure
- 20 in OEM wheels on a 2015 RX??
- 2010 lexus rx450h, installing led d4s
- Accidentally pulled out inner CV boot
- Alternator replace error
- Replace radiator hoses at 111,000 Miles?
- 2014 Lexus RX450h water dripping on the floor below the engine
- 2011 Rx350 climate error
- Standard vs automatic shifting
- Clunk noise rear RX 350 2014 AWD
- Seat Extension
- air recirc button turning off on its own?
- can not send text message
- Major services for 2010 RX350 besides oil change?
- Alternator replacement
- brake/tail light change- with pictures
- 2012 RX Intermittent engine whine noticeable at start
- Seat uncomfortable after 100k - advice please
- Shop or Service Manual
- P0138, P0607 -- RX350, Check AWD, CEL and Trac off
- Chevron Havoline Pro DS 0W-20 Full Synthetic Oil
- Sticking or gluing 2 inch rip on headliner
- Check headlight levelling system
- VVTi Oil Cooler Line
- Reybestos Premium/Coated Rotors and Pads
- Weird code
- Can motor of driver’s side mirror be fixed?
- Climate Control System Error
- Stripped rear license plate bolts - 2012 RX350
- Does rain sensor bracket come with glue on it?
- 2010-2012 Lexus RX450h Taillight/Headlight replacement (preferably LEDS)
- 2012 rx350 remove passenger side outside mirror assembly
- 2010 HVAC Blower intermittently working
- The End of 3g Wi-Fi
- Is my car totaled?
- TIS and Part Numbers
- Replace transmission?
- Rattle noise on cold startup
- Question about a rear suspension damper. 2014 rx350 fsport
- Air suspension strut mount
- Radio white noise when radio off
- Taillight Issue
- 2010 Lexus Rx350 3.5 2GR-FE 130k miles Code P0025, C1201, U0073
- 2011 rx as daily driver-what to look out for?
- Steering Wheel Shake 70 MPH+
- Thinking of buying a 2010 RX350 and need advice
- Well it’s so warm and cozy in DFW
- Vvti oil line replacement on 3rd gen?
- Liftgate switch to open not working
- Hood open warning in display
- 2010 RX350 - new owner and member here
- Very strange sound from under the hood
- 2015 RX350 - water pump
- 80,000-Mile Service Today
- Paint peeling on a 2013 RX350
- Towing capacity 2013 Rx 350
- Anti theft issue
- NEED HELP Picking BEST Dash Cover
- Quick Strut Back to OEM Suspension Question
- CV Axle Rair Issue
- External transmission cooler really needed?
- how to disassemble the back door of RX350
- Steering wheel rattling during braking or hitting a bump
- Steering Wheel Vibration
- What is this rusted part in rear suspension?
- Coolant drain plug locations on the engine block
- HID low beam not working
- 80,000-Mile Service Coming Up
- Power up
- Door Bell like chime when I drive by a certain area
- 2010 RX350 A/C Stopped Cooling / Cooling Fans not running
- Unable to reset TPMS warming - 2010 RX
- Potential RX350 Buyer
- Front caliper bottom slide pin should it move?
- New style Tail light For Lexus RX350 RX450 2009-2015 Start Up Animation DRL Sequentia
- Radio and Air Conditioning Control Panel InoperativeI
- Oil Change Frequency
- 2013 RX350 - Getting Serviced at Honda Dealer
- Oil change before or after long road trip ?
- Driver A/C Pass/rear heat ONLY in FL
- Unable to open door with handle
- Single click While driving
- 450H wiper won't park / intermittent or slow
- What is a “tuner” and can it improve gas mileage?
- Add heated steering wheel
- Moonroof issue
- Seat heater/cooler relay, where to find?
- Timing Belt/Chain at 100,000 Mi
- Fuel filter replacement
- Door Sill - plastic cover removal?
- 2014 RX350 Accessories Questions
- Enform app no longer works after last update and Lexus app will not connect to my '15
- Best way to re-glue rain sensor bracket
- Blue Light on Dashboard
- RX350 Reliable? What to look for?
- Are there any grease points?
- uncomanded door lock
- RX350 back up camera replacement
- Power Steering Problem?
- RX 350 2012 Clicking Noise during Gear change
- Custom Wireless Android Auto Build [in progress]
- P0791 Code- Intermediate Shaft Speed Sensor
- under bumper sheet
- rearview mirror wiring diagram?
- How do you replace parking light bulb right above the high beam?
- Rust on chrome/plasti-chrome?
- 2014 AC clutch not engaging
- Replacement foam for Drivers seat RX350
- How I thought I broke my car by replacing the reverse light bulbs
- Looking to purchase 2010/2011 RX 350. Any known issues to look for?
- Front hub
- Help needed removing lower 12V socket
- TPMS tool
- Experience Trailer Towing?
- Roofrack cover off RX350
- Rear Wiper Help
- Blind spot monitor does not function
- ECM location on 2010 RX350
- Noise from dash when cold, static noise from speaker
- Advice before i decide to trade or keep RX
- Installing a gas door spring
- VLEDS V6 Extreme Reverse Light System initial impressions
- Water Leak in Back Row
- Wife's 2015 rear hatch issues
- Catalytic Converter stolen, was Exhaust Coolant Line cut
- Upgrade OEM Hid - OEM LED.
- Oil cooler
- Cold Engine (morning) Runs Rough Only on Reverse Gear!
- Heater blowing cold air
- Any way to get rid of Transfer Complete message?
- 2012 rx350 awd Tow Hitch
- Cannot voice call person in contact list with Google Pixel6 phone
- Loud squeal from wheel
- Lights on, pedal won't depress, takes few tries to start. Is this a battery problem?
- Seat Material in RX450h 2010
- P0161 code. Questions regarding bank 2 sensor 2 location and recommended part.
- Front Lower Ball Joints
- 2010 450h VVTi Oil Line?
- Rattle behind dash near steering column
- Windshield has chip- options?
- Squeaky Noise From Rear Seat Lexus RX 450h 2013
- Battery Replacement Requirements ?
- 2011, Low Miles: Long term maintenance issues to expect?
- 2010 rx spring noise
- 2010 sunroof vibration noise rx450h
- Stereo Pinout Diagrams
- Non-auto folding side mirror is loose
- Tailgate lift arms
- 2010 RX - Weak AC after enginer start
- 2010 Lexus RX450 Service Schedule
- Rear side marker bulb
- Sounds Quality
- New to me 2014 F-sport
- Remote Start 2012 RX Base model
- WIRELESS DOOR LOCK "BUZZER" replacement
- Where is the battery for the Safety Connect
- rx450h 2010 beeping noise inside while driving
