- Top speed of a 2013 RX350?
- drivers.lexus.com site UPDATE issues
- Park assist problem after body shop?
- Auto Climate control a learning system.
- Excessive wear on leather seats for leased car
- Set GPS address while 2013 RX350 is moving?
- Potential RX450 Owner
- Lexus ENFORM not working for few days, anyone else unable to login?
- Smart Key not working
- Rear seat center section material
- Rain Sensor woes
- Smart key/wireless entry key issue
- RX350 Spoiler
- Price on 2013 RX350
- rear view mirror question
- Lexus RX450h from Spain
- 2014 Rx350 rear climate control, yes/no question
- Is there a way to upgrade the reverse camera
- Thinking of buying 2013 rx350 from dealer?
- Right cabin air damper replaced under warranty
- RX 350 Engine noise
- Reducing Cost of 90,000 Mile Service
- 35k Service - Loaner Car
- 2013 RX350 CPO- extended warranty
- is there still a way to get diagnostic codes from a/c?
- Is this Lexus RX 350 a Good Deal?
- ac failure
- Blue Tooth Audio paring issue
- 2013 rx350 car cover. Looking to buy
- Spiked! Rats...
- 2012 Lexus RX 350 - Question about remote touch feature
- RX350 Struts/Shock Replacement (merged threads)
- 2015 RX350 25000 mile service?
- Rain Sensing inop - new Windshield?
- LED headlights?
- Tire Rotation
- Parking brake
- License plate bolts
- 2013 RX350 emergency vehicle turn signal wires
- RX350 Service Issue
- How to Replace engine coolant (Super Long Life)?
- Typical cost for synthetic oil change at Toyota Dealers
- Towing capacity reduction sticker?
- Used 2014 RX350@21k for $35k w/Navigation+Lux package- Fair Price?
- Left Gas Cap Off-Which Fuse to Pull to Reset Check Engine Light
- Happy with your RX350?
- Truly weird headlight issue, ever heard of this?
- Upgrade mirrors and blind spot
- Remote Touch: How to display song artist and title?
- Intermittent Morse code type noises similar to parking assist
- Constant cycling between 'Portable player connection successful' and ...
- Trailer Hitch Recommendation
- Tweaking the heated seats?
- 2013 CPO with 42,000 miles. Is the price too much?
- Speedo vs Average MPH read out
- Best Smart Phone for 2013 RX 350
- Automatic Trunk Close Button Question
- HID Bulb Replacement Instruction
- Airbag Module
- Question about 2013, 2014 Options/Std Equipment
- Flashing light + Turn Engine Off warning light
- new member, Hello. 2010-11 RX for daughter?
- Disassemble panel to the right of the driver
- Anyone in Indiana with programming software?
- Rattling noises on 2015 RX 350
- Strunk strut get rusty
- good Lexus Indy shop in Bay Area (Cupertino area)
- Leg room in 2013 RX350. Knees hit the steering post
- i don't even own a lexus, but.............
- Looking At 2014 RX350 Need Input Please
- determining country of origin
- Installed Power Stop Brake Kit
- Difference between Japanese and Canadian built RX
- OEM Windshield
- crossbars- OEM or aftermarket
- My 2010 lexus rx350 with aftermarket 22x10.5
- RX350 2010/2011 Air conditioning DTC B1479 cheap solution
- Cargo Door Intermittent
- Remove tow bumper cover from 2015 RX 350
- Alloy spacers
- dealer recommended service - fuel induction and ac refresh
- Dog Crate for 2013 RX350
- Did my first oil change on my 2010 RX450H
- New to Lexus and looking at a RX350
- Mold/mildew smell from hatch area
- Automatic Headlight Dimmer
- How to access the mirror light bulbs
- Coolant replacement question
- Ready for a 3rd Gen RX350
- Alignment Question 2010 Lexus Rx450h
- New Mazda CX-5 or 2013 RX350?
- 2013 RX450h Body Damage - Estimate?
- Occasional no start
- Trying to make sense of the Navigation system
- Manually opening the rear door
- A Little Motivation for the Customizers
- Engine air filter
- Remanufactured Transmission
- RX driven while being serviced at the dealer
- Airbag recall
- 2010 RX 350 drivers side servo motor replacement
- Gas choice
- A/C Condensation/Mildew
- How does Lexus part number work? specifically A/C amplifier (control module)
- Getting first Lexus service done - $780 yay !!
- 5.5 Quarts of oil fills mine?
- Minimum OEM Rotor thickness
- Hitch lights without tow package
- Got my first oil change (that I had to pay for) OMG $$$$
- Tranny and wheel bearing problem show up at the same time
- Difference in hitches, one hole, two hole
- Engine tapping noise 2011 rx350
- RX 350 Changing Grill
- Lexus RX 350 2010 brake caliper torque specs
- Tires at Costco
- Brake Kit Recommendation for RX350 AWD
- New to RX450H .. have maintenace questions
- Worst experince in a rx 350 ever
- Chirping Sound from the front engine on 15-RX350
- Reset button under dash
- Strange Experience At Lexus Dealer
- NAV screen and HUD become so DARK for unknow reason !
- Help: F-sport conversion on 2013 base model?
- Driver's side fuse panel
- Need Advice - Financing Lexus RX350
- 2015 CPO - better deal? negotiate?
- need advice: RX versus RX-F
- leasing a used lexus
- Vibrating hood
- Alignment Woes
- RX350 Battery Details
- Blower motor story (wiring diagram needed)
- Right Price
- Vibration in gas pedal
- Park assist goes crazy in wet weather
- buying from a lexus dealer
- Brakes- Pulsing/Warping etc.
- RX 450H Extended Warranty (Lexus Plat) coverage
- Force the HVAC to stay on fresh?
- Rear headrest for 2013 rx 350?
- What repair costs the most have been done for 2012-2015 RX?
- New member seeking (Needing) your valuable inputs
- Enform system USB Question/Mystery
- Torque Spec on Transfer Case Fill/Drain Plug
- '13 450H noise and shaking on engine start
- Best sunroof/moonroof wind deflector? 2010 450h (others similar)
- Newbie on the 3rd GEN
- Disappointed in 2014 RX350
- Drip Molding help!
- 2012 RX350 subframe rust
- RX350 antenna fin came off, can I just re-attach or did it break?
- drl is not working and volume controls
- Steering wheel shaking after 5000 miles/6 months service
- Just purchased my 2013 rx350 need help
- Do you have to remove the headlamps to install aftermarket HID's?
- Bone picking - what's your complain for RX?
- Service Menu: what are HANDLE and DEST check mean?
- does the 2013 rx350 have a series 6 audio system
- Factory running board or another brand?
- AC difference in temperature between front and back
- O.K. Now it's Personal - my car is More Vunerable to Theft?!?
- 2014RX - Lane Change Auto Blinker
- iPhone 6 iOS9 bluttooth music?
- Headlights: HID vs Halogen
- Back up camera fix on 2013 RX 350
- Regular maintenance info
- License plate bracket 2015 RX350
- Radio Removal?
- Need a Central/Northern NJ Independant Service Center
- Keeping LED's on all the time?
- 2015 rx with nav - compass display?
- Fluid Leak on Rear Tire
- new brakes for f sport rx350 --- better then oem?
- Identifying 3RX Options
- 2015 RX Navigation - can't swtich from US to Canada
- Oil changes ?
- Help..... Can I just replace one tire?
- How do you turn the heater on?
- Pump Running?
- dvd movie play
- battery dead,AGAIN!
- 2013-Halogen to Xenon?
- 2010 RX350 Steering Motor Rattle
- I was a happy guy...
- RX350 intuitive parking assist ECU RHD workable for LHD car?
- Upgraded
- Reset 2015 RX350 nav settings
- Need Help Identifying this color
- Seats for a tall guy
- 2013 RX450h service complaints warranty
- Message setting phone set up missing
- Mounting depth for sub in non ML system 2010 RX450h
- Going from 19" to 18" but with 65R tires
- 2015 RX 350 maintenance costs?
- How much would you offer for this 2013 RX350?
- Fog lights not working
- Iphone 6s text messaging with 2014 RX350
- F sport seating creasing?
- How do I know what package(s) I have on my 2010 RX450h?
- What is it called?
- Air vent by fog light
- Speakers
- Good price for a 2010 RX 450h ?
- Bumper Protection
- Heated seats in '11RX
- Replacing battery in the 2014 RX350 remote?
- Screensaver/Picture
- Add 2 more OEM parking sensors to RX350 2010
- 2010 RX350 P0138 and C1241 codes
- Stone "starburst" in windshield (wind screen)
- Best back seat cover that pairs with a car seat?
- Looking at 2014 F Sport
- illuminated door sills
- 2013, 2014 or 2015 RX350?
- So grateful for advice...Audi vs Lexus
- Drivers Side Door Panel ruined handle help
- air bags didn't deploy in front crash
- Advice for a first time Lexus RX 350 2013 owner
- DIY: How to install eBay window visors
- New Owner Questions
- Anyone regret getting the 450h vs 350 or vice versa?
- What is that unplug available under 2010 RX350 passenger button right side corner?
- 2010 450h or 2011 MDX Advance (AWD)
- 3RX with 4GS f sport wheels
- Help with Door Panel Removal/Radio information
- PLUS1RX Build Thread
- New purchase 2014 RX 350
- service manuals for my 350
- RX 350 service
- 2010 RX 350 Radio programming
- what do I have?
- Power Tailgate / Liftgate not power closing automatically
- Passenger side view monitor upgrade 2010 rx350
- Brake Caliper torque
- Buying 2013 Lexus RX350...
- Reliability
- First Ding
- No Rear Diff?
- 2013 RX350 - paint rust and zxilon
- Spark Plug Replacement Question
- LeatherRenew
- Spacers on F-Sport
- 2016 RX350 wheels/tires to 2010?
- Service History on CPO
- Paint flaking off grille - 2013 RX
- Precut tints from ebay
- RX450h faulty lights
- Need help removing 2015 Lexus rx350 fsport Hid bulb
- F sport grill bumper
- Stiff steering
