- Rear Arm Rest Cover
- Nipples!
- Window trouble
- 2015 RX with 33,000 miles Question
- rust under back camera
- Changing rear side light marker bulbs on 2015 RX350
- 2015 Lexus RX350 noise
- Can I replace only one tire?
- Center console cover for 2015 rx 350
- Outside tire wear on Michelin original tires
- 2015 RX350 - 60 Manufacturer Communications on nhtsa.gov
- USB and Play Lists?
- Volume when alarm is on
- Smoked!
- 2015 RX450h Question
- Oil Cooler Lines
- Clunk in Steering Wheel
- Fog Lights Stopped Working
- Cracked tail light cover advice
- Center console not opening
- Towing Capacity for 2009 Mariah Boat
- Intake Filter Ebay vs Toyota vs Fram (pics)
- Ebay Rear Fog lights chrome bezel installed with pics and impression.
- How to replace Hood struts DIY from Ebay (Pics)
- Torque spec reference?
- Larger or other improvements from 2nd Gen?
- Differenses in spec grades
- How to install Nav + Mirror Iphone + Front&Rear Camera for a 2010 no nav???
- Anyone replaced front struts on their RX?
- Windshield washer reservoir replacement
- High Beams not working / DRL's are Fine / All Modes
- Acoustic Glass?
- A Pillar Fitment
- Mobile 1 ATF for power steering fluid?
- 2012 rx350 hdd becoming unresponsive.
- rx450h lift gate - hatch failure need help
- Do the rear passenger window comes down completely(Lexus RX 350 2012)
- Bluetooth drops when listening to Satelitte?
- Push button start - how to ACC?
- Sport design vs F-Sport
- Greasy substance line on rear car frame(Near rear Right wheel) Lexus RX 350 2012
- Should I buy or run? 2010 RX 350 with 2 "problems"
- SRS Airbage Warning?
- Too many contacts to transfer; not the right ones
- Chrome Door Handle (install and impression)
- Front Bumper Retainer replacement? Is it necessary?
- Regular Gas (350) vs. Premium (450h)??
- Weird engine noise at post start up idle...
- Is it worth it to buy a used 2010 Lexus rx350 with 90k-123k miles from carmax?
- Check PCS System and Check Brake System warnings
- Do I have premium package or not?
- Awd, check engine and traction off
- Problem with abs 2011 rx450hu
- Wireless key won't open back door
- what model is my navigation system?
- 2015 rx 350 Cracked Windshield
- 4th Gen 20 inch wheel on 3rd Gen
- Coolant additive and sludge flush?
- Moderate "Chain-like" rattle in the engine at idle
- Changes from '14 to '15 RX seats?
- Engine Coolant
- How to remove Arm Rest for reupholster (ebay)
- doubt with air suspension
- RX400h wheels on a RX450h?
- Bump on rear hatch doesn't lock car
- Help!! I got into a wreck today!
- Rx350 cargo cover
- Replace Steering Rack?
- Passenger Folding mirror opening wide
- Why are some cargo floors raised on the RX?
- Rusted door handles and extended warranty coverage
- labor time front struts 2012 RX350 AWD
- Coolant level sensor
- 2013 RX350 phone connection sometimes lost.
- Remote is very short range and unreliable.
- Will 4th Gen backup camera work on 3rd Gen?
- inspection before warranty expire
- Parts crossover within 3rd gen
- Can I stop the side mirrors from auto-tilting when in reverse?
- Caliper guide pins. Front and back
- Oil filter cap leaking
- Anyone with experience on replacing 2010 RX350 rear diff?
- Worn driver's seat bottom cushion- need replacement
- Roof rack question for 450h
- Headlights
- Fuse for the cigarette lighter for RX450h location???
- Rear rotor and brake pads replacement
- Mark Levinson Audio Concerns
- Bumper interchangeable?
- Static Noise from Driver Side Speaker?
- Weird Starting Problem
- Bluetooth echo
- lug nut specs
- 3rd party source for cv axel replacement
- Cargo area power outlet not working
- Dead transmission
- Need Advice on Buying Another RX Model
- Lexus CPO Dealer in Texas
- 2014 Rx350 light sensor not working...
- Power back Door
- Is there anyone has a roof top tent on your 3rd gen rx350?
- android and the RX350
- Ect & 4 wd
- 2015 RX 350 Phone set up
- Anyone have 90M?
- Anyone modify Center Console Lid to Open more?
- 2014 to 2015 differences? Looking to get an RX 350
- Rear bumper protector strip for 3rd Gen RX
- New to me RX with Empty Coolant Reservoir
- Fob doesn't open rear hatch Door
- Cross bar
- Touch door unlock all doors
- Pricing for 2015
- Decibel Level of Factory Horn
- Start Stop Technology Special Service Campaign
- 2010 Lexus RX 450H wont start: 12v battery dead?
- 10 beeps when I lock the door. My pasanger door lock is not working, is this why?
- Poll 350/450-H discussion threads
- 2013 RX 450h - Good Deal????
- Remote starter
- HVAC Blend Door Actuator 2013
- AFS Message
- 2015 350 Wiper blade switch on steering column
- C1433 anyone have any info
- Car won't start 2012 RX450 H
- Second week with the RX and loving it!
- Vibration when stopped in gear
- OBD port doesn't have power
- 2012 RX Throttle Body Cleaning
- Reliability: F Sport vs Standard
- 2012 RX 450h squeeky stops
- arp wheel studs
- 2013 RX350 Complete Brake Job Questions
- Timing chain & water pump
- Cost to replace wheel bearing at dealer?
- rx350 radio volume
- RX450h Clunking noise on the front left
- RX 350 3rd Gen Quality vs. 2nd Gen
- Oil change shortcut
- Away for 1 month. Battery Disconnect or not?
- Debate......older LS or newer RX?
- blind spot mirrors for 2015 RX 350
- Duraflex® Lexus RX 2010-2012 W-1 Bumper (Front)
- front seat wobble
- 2011 RX 450H high mile big price ?
- Recommendations for alternatives to RX?
- What "gen" is the Nav system in a 2014 RX350?
- '12 RX350 blower motor resistor?
- check brake lamp system is on inside the car, outside can not shut the tail light on
- Can the tailgate be partially closed?
- 2010 Rx350 rear passenger marker replacement
- Lexus Enform 2012 RX ?
- Fuel filter for shipping outside US
- 2013 RX450 Navigation screen reboot on loop
- sensor for turning on headlights. change nav display to dark is not working.
- Just picked up our RX, but one question! (Now with Pics)
- A Bit Too Much
- I-Phone 6 & 14 RX?
- 2015 RX350 New Owner & a couple of questions
- Options Installed.
- aftermarket lug nuts
- I have a LexusRX350 2015The nav system starts and restarts on phone calls/maps
- 2012 RX Hood/Hatch Struts
- Floor Matt Choices
- 100,000 Mile Pic
- Help needed SRS warning lights
- Bluetooth pairing problem
- Depress padle message came up after changing battery
- Wondering what front lip this is???
- don't be biased but should i trade my venza for rx350?
- My windshield wiper blades freeze up.
- Garage opening too small for 2012 RX.
- Looking to get into an RX for the family!
- 2013 Lexus RX350 Thermostat/Shop Service Repair Manual
- $200 for a 10K service?
- Removing Front Lip from 2015 F-Sport
- Lexus RX 350 2013 transmission dead
- 2013 RX350 Alarm Chime/Beep Volume
- Buzzing noise and dead battery
- Remote touch control Stopped working
- Leus rx350 replacing FOB
- New 2013 owner with a few newb questions!
- steering knuckle and lower control arm
- 2010 RX or GX
- Sold My 2013 RX450h
- Cargo covers
- Steering Lock Activated
- Camera like doohikey behind rear view mirror & AFS
- How Do I Determine What Options an RX Has ?
- Occasional Metallic Jingling Sound on Driver's Side
- We have a Lexus 2011 rx350 powerlifting will go down auto but will not go up powered
- Lexus RX seat pairing
- Seat Belt tension won't release
- Please help me fix this side view mirror
- Intermittent on/off Passenger side mirror Camera !
- How to replace third brake light
- Intermittent locking problem
- 2011 RX 350 glove box door will not stay shut
- CRACKLE and BIND in steering, 2010 RX350
- Help me find the M&Ms
- New Owner to Be
- Replace Fogs with LEDs-2012 RX
- Window Lockout - locks out controls for all Pax
- Hatch closes
- Bluetooth microphone not working.
- Buying Advice Used RX450h vs. RX400? + Do the electric motors require servicing?
- Heated side rearview mirrors?
- 2011RX350 electrical issue
- Issue with heating/ac 2010 RX 450 H
- Is it okay to put XL tires on my RX 350 that doesn't "need" XL?
- does this look like a busted engine mount ?
- Warning Light & "ECO OFF"
- Considering leasing my 9th RX
- Brake dust cover rusted
- headlight upgrade
- Need a good rust remover for under carriage
- 2013 RX350 Compass ?
- Anyone have a DIY for front bumper/headlight replacement?
- 2015 Rx 350 Rust question
- Wireless key relay theft
- Another 60k Recommended Service thread (dont shoot me)
- RX450h grill/lips fit on Lexus RX350
- "GO HOME" issue
- Thermostat replaced: Question
- lubricant for doors rubber gasket
- Rx 450 h gas mileage decrease after 125,000 mile service
- Address screen is grayed out on navigation
- Thinking about selling my RXh...
- RX450h headlight replacement Q's
- Avtive Steering Lock"mean?
- Fuel pump running all the time
- Front Bumper again
- Sticky door handle on 2014 RX 350
- Remote start
- Front license plate bracket
- Torn between a '09 RX350 and a '10 RX350
- 2013 RX Wiring Diagrams
- 2010 RX350 Misfire Codes - p0300, p0302, p0304, p0018, p0019
- pairing remote keys with memory seats
- 2010 RX350 Power Liftgate Not Fully Closing
- Seat Warmer Fuse
- Lost key fob
- Immobilizer reset
- Rear Tail light bulb replacement
- Lexus tries to start but doesn't.
- 2014 RXH Back Hatch opens any time
- Best RX to buy (used)
- Nav Controller Question 14 vs 15
- Floor Mat Fitment
- OEM Front brake pads didnt come with shims
