- 99 LX470 Turns over but won't start
- Newbie question about Rear DVD
- seat heater only on low
- rear windows defroster
- New Owner: 2007 LX470
- Lexus Announces Intent to Voluntarily Recall Certain LX 470 Vehicles
- Third brake light removal
- all weather floor mats for LX
- 03 LX470 Mark Levinson sounds like speakers are blown
- Buying advice on a 2002 LX 470
- Vibration at 40 mph on my LX470
- audio setup in LX
- 470 DVD counsol doors stuck
- LX470 Towing Pics
- extra headphones and headrest dvd player
- Lx for off road toy and hunting vehicle
- LX470 Nav Bypass (versus DVD bypass)
- rear air?
- 06 LX470 Shut down
- Rear a/c blowing warm air?
- Slightly Tilted
- Transmission Fluid Change
- sun screen for LX
- 2003-2007 LX470 Recall
- aftermarket radio - 2001 LX 470 HELP!
- static sound in speakers when playing dvd player on the road
- 03 lx470 dvd headrests
- Adding Back-up Cam to LX470 NAV (2002)
- LX470 Aftermarket Head Unit Solution
- 03 LX470 DVD in Motion
- Replacing Headlights on Lx 470?
- Just got a 2006 but it has fault codes, how bad is it?
- navigation update
- '03 LX470 security light
- 02 lx470 Questions
- LX470 not starting
- Did LX470 ever get factory iPod / mp3 connectivity?
- water leaking in by rear hatch
- Thinking of Buying CPO 2005 LX470
- Radio Head or Amp?
- Power Lock Issue when programming a key?
- Lowering LX470
- my *new* 2007 lx470
- sat radio 2007 lx470
- Lexus care / warranty for 100k - do not go for this
- 2007 LX470 performance ECU tuning
- LX470 continuous chime alert
- (1) Rear tail light guard and (2) front grill guard
- Anyone near New Port Richey Florida?
- LX470 AHC Suspension
- Please provide your Insight
- Stiff and bouncy front shocks 1999 LX
- NEED HELP finding throttle position sensor
- Gps
- Need Help - Pin sized hole in my High Pressure/Slimmer A/C Line on 2002 LX470
- throttle pedal position sensor A circuit
- Coordinates in the LX470 2002
- 2007 Lexus LX 470
- iPod Adapter- 07 LX470 (Vais vs USA Spec)
- What year(s) LX would you buy or best value for $$
- Low Beam Headlight Adjustment
- A sad goodbye...
- A/C lines need repair
- Another Nakamichi Problem
- LX470 2004 Radio Clicking, No Music
- Year Comparisons
- Ignition Suggestions- need ideas Please.
- Help please. Odd radio problem.
- Sewell Lexus Parts Online Discount
- Replace low-beam headlamp 2001 lx470
- Wind Noise from Windshield
- AHC...What's Wrong??
- SL2Vi VS. SL2Vi-P4
- oxygen sensor query
- LX470 new Stereo old amp
- Emblems
- Preferred tire pressure?
- aftermarket stereo install
- Replacement/extra key for 2003 LX470?
- Can't find a Grille Guard for LX450 1996 HELP!
- Tires for '03 LX470?
- 12v power ports not working...
- Control valve assembly 2002 LX470
- Need help
- iphone and 07 LX470
- Ambient Lighting in 07 LX470
- $1700 to replace Throttle Body from Lexus of Rockville Ctr.
- Searching for fender flares.
- 2007 LX470 Just Arrived
- What color is Galactic Gray Mica?
- 2001 LX470 Aplifier
- Replacement stereo
- License plate lights
- New Mods on a 2000 LX470
- United Payment Services
- Independent mechanics near Birmingham, AL and/or Jackson, MS?
- 05 lx470 head light
- shuddering issue
- newbie
- Bought 2006 LX470
- Rough Ride and Tires
- Repair Broken Stud
- 02 LX470 -- bumping noise when I accelerate?
- Driving Position Memory System
- Height Control Problem | 2002 LX470
- Disconnect Lexus Link, 2003 LX470
- Active suspension off when towing?
- Really stupid radio question
- Poor Radio Reception
- Hitch cover for '03 470
- After market/retro fit radar cruise?
- steering shakes when driving at low speed and steering vibrates when braking
- Looking for smooth SUV, LX470?
- Air Bag Message
- Can you deactivate the VSC for 2002 lx?
- Suspension binding popping sound, sticky bushing?
- Extended warranty on a 2003 LX470
- Height Sensors
- LX 470 Feels slower and MPG is down...
- She's gone
- Compatability of Iphone 3GS with Lexus GX 470
- '02 LX470 Where is the OBDII connector hidden??
- wiring harness lx 470 rear hatch
- Any way to get brighter backup bulbs?
- Whole front-end low to the ground
- why my front end down???
- Q | "L" Low Speed Position
- charging system warning light won't go off!
- Headlights & Tires
- New LX owner!
- Need help with timing belt
- Ls 430 or Lx 470
- Changed Belt. Still Sqeaking!
- 2007 LX470 3rd row needed!!
- List of Modification Questions
- Need help
- How To Replace Belt? Squeaking From Engine!
- Possible HID fog light problem?
- Anyone has experience on removing passenger airbag?
- Want to buy LX470
- 1998 LX470 Steering Wheel
- Electrical problems
- Hancook tires?????????????
- Crazy stuff going on with my 2000 lx470
- Help bulb replacement
- GS 300 Performance
- iPod for 2000 LX (Searched)
- Another LX owner
- New LX owner
- LX470 or GX470, HOW MUCH?
- Wood Steering Wheel for 1999 Lexus LX???
- Timming (cam) belt 1999 LX 470
- fuel pressure
- Window Washer
- Replacing 1999 LX steering wheel with a wood one
- DVD Override 2006 LX 470
- New Owner, some questions
- Problem with heated seats
- Part Time Transfer Case Conversion
- Overriding NAV lockout in 2002 LX470 (tried everything, looked everywhere)
- Electrical woes
- LX470 As a daily driver?
- "exhaust booming at idle"
- LX470 HID foglight install problems?
- Disable Power tilt and Retract on Steering Column?
- Shopping for an LX
- Need a Lexus Mechanic close to BURLINGTON, MA
- radio not working
- 1999 Lx470 Rear heat will not get Hot
- lx 470 (TRD SUPERCHARGED)
- AHC Fluid Flush
- need help - continuous annoying beep in 2003 LX 470
- Are all the headlights compatible?
- 1999 LX470 , Adjusting low beam headlight vertically
- LX 470 new rotors clacking and smoking???
- Locking the center-diff
- Gen 4 Navigation DVD
- Locating Cylinder #6?
- purchasing
- Cracked side window trim ?!?
- Sun Roof wind deflector vibes ?!?
- Painted the whole frame
- help with Parking Brake adjustment
- AHC flush - simple and safe
- HID Question
- Electric Window Problem
- '96 LX 450, squeaks on turns
- AHC change your fluid
- lower cladding paint color code for 2000 LX470?
- LX470 Rear Brake Sound
- looking for 97 lx450 body cladding
- How can I disable DRLs on a '99 LX470?
- Wheel Damage/Repair
- Can i change out the subwoofer on my LX470 myself?
- Steering Column Tilt Motor Failure Lx470
- HELP...AM/SAT button stops working on my 2006 LX470
- just fitted extractors to my lx470
- Headlight removal for HID kit
- Finally got my truck back
- Our LX Broke Down Today - 1st Time Ever!
- Wheels on the LX470
- LX470 with custom LED's from Audi S6
- Install kit for after market stereo in 2000 LX470?
- Nav update for LX470 map
- HID Install question
- LOW Setting on Suspension when Parked
- Navigation unit compatability for 2002 lx470?
- Height difference at front and rear
- Best place to buy accumulators?
- Engine running rough and check engine light came on
- Need 2002 LX470 LCD NAVIGATION SCREEN
- Itegrated Blue tooth for phone/ipod/satellite radio
- Howdy - New Member - GPS question
- 98" Lexus Having Trouble Starting?
- hitch for 2004 LX470
- Acummulator Part Numbers
- filling up the ac gas for lx450 and installing the HIDS
- Steering lock to lock truck will not move! Help!
- Thoughts on 96 or 97 LX450
- Cooled seats + Used LX pricing guide
- Loud noise when shifting from park to Drive
- LX 470 interior parts
- I'm tired of searching
- Rides to the Right
- Trailer Light Fuse Location 2001 LX470??
- 2001 LX Transmission Problem - causes an engine stall
- trouble changing ac belt...... Help!
- Should I buy this LX470?
- 1998 LX470 Questions
- set of 16 inch oem lx470 wheels and tires for sale
- Will 06 grill fit on an 04?
- IPOD Integration with 06 LX470
- New HID Kit ready to install.
- what to check before picking up my lx470?
- Best Lube for Combi Switch Parts ?
- Side mirror followup and OEM parts
- Side mirror issue
- Ignition problems
- Interior fuse diagram?
- Another Price Check Please
- Diagnostic/Repair for LX470 Electrical System
- New LX owner
- LX470 won't start
- I'm considering a 99
- 03 LX - HOMELINK problem (no lights at all)
- Leather Seat making Sounds
- Considering an LX470 - need some advice
- Battery - how long does it last?
- LX 470 HID fog light conversion wiring hardness ?
