- Rear Door Speaker Removal/Replacement
- got my lx470 99 face lift to 2007 comments plz
- annoying noise while shifting gear from "p" to "D"
- Exhaust Manifold LX470
- Rear wiper motor
- Lx470 owners i need some feedbacks please!
- bumpy ride
- 2007 LX Sports Edition, I'm tempted to...
- Lx470 (1998-2003) Roof Rack End Cap
- iPhone Car mount and XM?
- Replacing Seal
- Check this link....How much its going to cost?
- 99 Lexus won't start
- How to remove/clean the console around the gear lever
- Battery drain
- 2001 LX470 lighting
- Flushed brakes, ABS,VCS, brake light/chime on
- Mystery Connector???
- Receiver Hitch Issue
- how to remove lexus lx 470 windows door panel
- cooling system?
- 2006 LX 470 idling a little rough, what to do?
- how many miles per tank?
- 1998 LX470 front ac blower
- Seat belt type buzzer on 2000 lx470
- 2001 LX470 - Timing Belt
- 2001 LX470 - Additional Fog Lamps
- 2001 LX470 - Wheel Bearings/ Odd Sound
- 01 & 03 LX470 - Sound System
- 2001 LX470 Radiator Replacement
- AHC troubleshooting
- First Lexus lx470
- reg gas or premium gas
- octane rating for 01 lx470 question
- 2002 lx470 roof rack
- 2000 LX questions
- 90k, Timing Belt & Water Pump Today
- Steering Tilt / Telescope does not work, no sound
- Driver door
- 2000 LX 470 Daytime Running Lights Recall
- 2000 lx 470 q
- A few questions about a 00 LX470
- Tires for LX470 - 275-65's?
- Rear Land cruiser emblem on 2002 Lx470
- 00 LX470 Starting Problem
- 1997 LX450 vibration during acceleration
- Looking to buy a 1997 LX450
- Wheel Lugs LX470
- comfort vs sport settings
- GPS Replacement
- Lx Conversion
- 02 LX470 Starting Problem
- Check Engine Light, VSC Trac, VSC OFF Lights Amber- LX470
- disable DRL 2002
- best Blue tooth, ipod and if possible rear camera 2003 LX470
- LX-470 Frame Rust
- LX 470 wheels
- steering problems
- adding backup camera and disable DVD during motion
- new member with 97 lx450
- VGRS recall from September 2010
- Trouble with voice commands?
- 2000 LX470: driver's seat only reclines backwards not forwards
- Can (Should) I change to Synthetic Oil ? Best filter? 2001 LX470
- Has anyone fixed lumbat support problem
- 2001 LX470 - Subwoofer replace with JL Audio 6WO 8ohm ?
- steering failure LX470
- SIDE step rails for 1999 LX470
- What is going on?????
- Most amazing! (I prefer the LX470 over the new LX)
- When my '99 LX comes to a stop it gently rocks 4 or 5 times
- LX470 things i have left over
- Setting Timing Chain
- 2003 LX470 common problems????
- Just bought two LX's--one for me, one for her! - (and a quick wheel question)
- Denso or Bosch Oxygen Sensor
- 2003 LX470 navi voice guide??
- Replacing Back up / Reverse Lights on 07 LX470
- Urgent: Advice needed for replacing the Nakamichi stereo
- 1999 LX470 A/C compressor replacement?
- navigation system
- Car stero shop south Florida,
- huge difference in KBB and AutoTrader trade-in values
- LX470 A/C noise
- stock battery, cca rating?
- 2005 Lexus LX470 ODB Codes
- Considering projector headlights. any thoughts?
- VGRS light
- How to tap DVD changer output for additional headrest monitors.
- Who is using iPhone and LX's Bluetooth?
- 2004 LX470 roof rack cover (passenger rear)
- Is it worth to fix Nakamichi CD changer (2000 Lx470)
- Taking my LX470 to 3100 + round Trip- what needs to be checked
- 2007 Lx470 Tail/rear lights on 2000 Lx470
- Manufacturer Control(code 1305)
- Cruiser control
- Tech Advice...2000 LX470
- Rear Exterior Vents?
- Head unit change for 2000 LX 470
- 90k Service on 2000 LX 470
- CV Boots & Steering Rack & Wheel Bearings
- Greetings and Tribute
- Strange electronic squeal sound please help identify
- Clunking Rear Drive Shaft
- 01 lx470(sometimes wont start)need help
- 06 LX470 30K Miles Value
- 2000 Lx470 Nakamichi stereo Err 3(and how to remove the stereo)
- Chrome grill for 2000 Lx470
- Ash tray and power window
- Thinking about purchasing this Lexus LX450....
- Chaning out the emblems
- Radar and Laser
- Navigation LX470
- Lexus Platinum Extended Warranty
- ACH Issues
- Lexus LX 470 replace windshield wipers
- Seized Rear Calipers
- Help me convince dealer there's problem with "HARD RIDE"!
- Rear 12V Power Outlet Troubleshooting
- 2005 LX470 - missing fuse #4
- New LX 470 Owner
- Lexus Link
- LX470 Transmission question
- Need Your Advice
- Please Help w/roof rack issues!!!!!
- New owner of a 2001 LX470
- LX-450 Power Steering Problem
- Question on parts
- Finally, DRL are off
- HID Install 07 LX470
- Brake Question for 99 LX
- 2005 Lexus LX470 - 68K Miles
- Cabin air filter? easy to change? help with interior smells?
- Any special alignment issues w/ 2005 LX?
- Selling 3rd Row seats for a friend
- LX 470 Foot Rest Breaking Hazard
- LX470 Fender
- Introduction
- 90 K Service costs
- HVAC Controls "Dead"
- Leaking sunroof
- maintenance required symbol
- Rubber Mat Purchase
- help, steering column not adjusting properly
- help; musty small in cabin
- Help, noise under front passenger side
- Gas Mileage for LX470
- Please help! 02 LX470 navigation/radio/ac stopped working (lost power)?
- Broken passenger mirror on my lx470
- Bouncy Help
- tire pressure sensor and cold air
- FYI..Tune Up precautions
- 01 Fog Light male connector plug in
- Steering wheel question
- LX-450 service, repair manual
- What is a good price on the 2003-05 LX470?
- LX-Special Edition
- The little round fog lights. Some have them others don't?
- Night View System
- Anyone recovered there CDs from a 1999 CD eater?
- Did some 2006s come with the previous style 18" rims?
- Cold air vent passenger feet
- Time to Replace Tires
- LX470 Mechanic in Houston TX
- My car is not recognizing my key.. Why?
- 2002 lx470.. Oem rim question
- LX470 HVAC Blower Motor Question
- Rear Fog Lights
- Check your spare tires for dry rot
- Suggestion/Help wanted
- DVD & NAV Bypass-Has anyone ever cut both VSS wires?
- '07 Headrest monitors power source
- LX/LC's good for hot/humid climate?
- Can a Bearing Problem Cause Pulsing Brakes?
- Anyone in need of 18" oem rims?
- cabin temperature
- AC compressor problems
- 2000 LX470 door lock switch
- Lx470 wiring diagram 2005
- LX470 VSC/ Slip Control Problem..BRAKES LOCKING UP!!
- Coolant Change Questions
- Need suggestions...
- 2000 LX 470 rear infant car seat latch
- LX 470 Rear Spoiler Wing Brake light Replacement
- Question on New Steering Wheel
- 2004 Certified Purchase Help
- O2 sensor failures bank 1 sensor 1, bank 2 sensor 1
- Car will turn over but wont start. No Fire! HELP!
- Problem with front suspension
- Need to Replace a battery for LX 470, 2004
- oil change
- LX 470 Roof Rack paint issue
- Amplifier and subwoofer installation?
- "Helicopter" rotational sound + ? Tire cupping, all 4's
- p0440 code charcoal canister testing ???
- How to remove the door lock assembly
- My New Old LX470
- Vibration at Idle
- four wheel drive question
- 2005 LX470 instruments won't dim
- Spare tire lock '06 LX
- Replacing Rear ACH Shocks
- Lexus (Invision) Dual-Headrest DVD player questions
- Instrument panel & interior panel light problem
- Just wondering, when do you change your tires?
- Has anyone tried K&N oil and air filter?
- Drivers seat heater LX 470
- Has anyone removed a steering wheel off the lx470?
- 2000 lx470 moonroof tilt problem
- Issue installing HID kit, bulbs don't fit thru housing
- looking for a good mechanic in the Duluth, Ga area
- Will Lexus corporate step in? Sorry for the long post.
- Hard to Start
- 2004 LX 470 iPhone adaptor?
- Contaminated AHC fluid 03 LX 470
- A few problems with my 2000 lx470.
- LX 470 Key-Transponder/Immobilizer issues..Please Help!!
- driver side window problem
- LX470 Squeal around Master Cylinder
- Joined the Lexus ranks...
- Tire advice desperately needed....
- 2002 lx 470, running board courtesy light
- 2004 GX470 Window Issue
- 96 LX 450 Factory Alarm Dying?
- 04 lx470 tach not working
- How to swap DRL bulbs
- LX470 electrical (wiring) diagram
- lexus window sticker
- LX470, what the heck is "River Rock Green Mica" is? lc3, grey or green?
- Zerk lube DIY instructions?
- Starter or Battery or ?
- multiple cylinder misfire code
- Exhaust mod ...
- Two HID questions
- Buying Tires...
- AHC making soft bump sound when lowering...
- 1999 LX470 Door Actuator problem.
- maplight housing
- How can i play dvd on my navigation
- Windshield Replacement
- HID Fog Lights
- Front Fog Lights
- Manual Input for phone book in Nav
- Paint Failure
- Turning off turn signal lights
- Ignition Cylinder broken
- 2001 LX470 - High RPM at 75 mph
- Just bought a Lx470- few questions
- 99 LX470 Turns over but won't start
