- lexus lx 470
- Dual Zone Air Problem
- 01 LX470 Ignition Switch Lock Problem
- Challenge - LX shuts off and no restart
- 1997 Lx 450
- just installed running board courtesy lights
- New to the Lexus line - Where to buy parts
- need help with key programming issues
- wanting to buy LX450
- Test Drove a 2004 LX, Issues with 4LO and Center-Difflock
- Dealer says the car is "settling!"
- Lexus factory warranty
- Thinking of buying '99 LX with 150k miles
- 2000 LX470 Ground Wire Location?
- Over-Cranking but will not Start
- No Audio LX470 2002
- Air vent in roof head liner
- Between comfy, regular , and sport
- Problem with driver sit's power lock after trying to disable remote control
- Are two belts actually needed?
- Cooling fan bracket
- Differences in the 1996 and 1997 LX450s?
- Massive repair estimate, cv boot, radiator
- mrgclaytrd
- max rim size for lx470
- Interior lights/dome fuse blowing repeatedly
- Better than Landcruiser 100?
- Need Help with Horn Issue
- 98 LX470 - shocks and spare tire mechanism
- antenna mast
- LX450 Power Issues
- LX 470 Battery Light and Power Steering Issues
- need 22" lx470 wheels n tires
- Lx 470 2006 steering wheel needed
- lx470 reserve fuel tank
- Install spoiler
- Differential Lock Sign?
- The different between D2R and D2S for high beam bulb on lx470
- 2001 and 2006 LX470 front seats interchangeable?
- Radio Wiring Diagram for a '99 LX470
- Rotors and Brakes
- '99 LX470 rear end noise (thud)
- Lx and Gx
- 98 lx opinions
- 1997 Lexus 450 2x4??
- Looking to put LED lights in the interior of 2003 LX
- Need Help
- real world driving difference between 04 and 06?
- Fuel Consumption
- Water Leak Drivers Side
- Air leaks at driver's door
- aftermarket installation of iphone in a lx470 2004 with nav
- Just Wanted to Introduce Myself
- Lx 450
- Lx450
- Lexus GX-460 and Human Factors Engineering
- FS does not go here, it belongs in the classifieds.
- New Antenna Mast Scratching Sound
- Locking Center Differential and VSC OFF Problem
- Disconnecting alarm on LX470 ????
- jawaad
- New FULL Leather Seats and Accessories under $450
- Maintenance Schedule
- VSC Question
- Parking Light Issue
- 2004 LX470 Tachometer not working
- TRD Parts vs. Standard Lexus/Toyota Parts
- My built 1997 LX450
- Fog Lights - 2003 LX470
- Don't do what I did while fixing power doorlocks!
- Engine starts but lights out and shifter stuck in Park
- Is Drive light supposed to be lit?
- LX 470 1998 Help!
- Bug Shield for 2006 LX470
- Disable VSC TRAC in LX470
- New LX450 to the Stable
- New to the Forum
- AHC question
- Wood cracking on 2001 steering wheel
- [Help] for Lx470 electric wiring of mirrors!
- Deep scrape on rear bumper
- Windshield problems
- Fold in mirror issue fixed ...
- wheels for 98 to 02 LX470
- Running hot
- Clother Hanger
- My 2005 Lexus LX470
- Front Half Spoiler
- Headlight on LX 470
- Electrical malfunctions
- 97' Lx450 front bumper
- Hi New to forum
- North Jersey Regular Maintenance Options
- 2005 stereo options?
- Mystery: Having to jump start on occassion but everything checks out o.k.???
- help with '99 double DIN install
- Sunroof Leakage, Horn And Console Light Dimmed
- Navigation Screen Signal from DVD ECU
- program the garaging door opener on lx470 homelink
- Roof rail extra mount point
- Installed new weathertech visor today
- 2002 LX coolant leak
- LX470 GPS update
- catalytic converter 2006 lx470
- 2001 LX470 warning buzzer, but no warning lights or messages?
- 2004 LX 470 Sunroof
- Catalytic Converter Experiences '06 LX470
- 06 Lx470 Acceleration Problem
- LX470 tires
- 2006 LX 470 airconditioning
- 01LX470 Headlights auto function not working
- 2006 LX470 Satellite Radio Options and opinions, please
- LX470 - suggested tire sizes
- Broke my Gf's LX470 CD player
- VSC, VSC TRAC and ABS lights on.
- 470 LX Roof Cargo Rack
- Change front right parking light?
- Selling '07 LX 470
- Bluetooth audio
- Lexus LX470 - ABS Actuator
- Regarding steering wheel
- A LX question
- lx450 bumper
- WTB - 2012 LX570 Factory Rims
- Price for Michelin tires for LX470
- 2000 470
- Remove gas cap in order to start engine
- WANTED: 2003-2005 LX Hitch
- Lx 2003
- replacement headlight
- Good Independent Service in Santa Fe?
- is this brake repair cost for LX470 reasonable ??? pls help
- Mud and brown slime in windshield reservoir
- My search for LX470 continues... does this sound like a good deal?
- 99 LX470 wire harness/sound system
- fuse location for ecu
- License Plate light fuse
- Hi there, new from Ontario
- Side Mirror Turn Signal LED lights + Paddle (courtesy) Lights
- Side View mirror wiring
- 2000 LX470 O/D off not working
- Nokian Winter Tires
- Stalling in hot weather
- HID flicker once when ACH pump turns on!
- Timing Belt every 60K or when you see cracks?
- tape player
- '03 LX470 GPS Screen won't go into night mode
- Test drove 99 LX470 ... Height control "OFF" light blinking
- 1997 lexus lx450 passenger side airbag
- Is this a real problem with the early LX470?
- Looking to buy used LX470 ... pre 2003 vs 2003+ differences?
- 1998 LX470, 154K. Repacking wheel bearings, necessary or no?
- LX 470 fuel pump issues
- Camera upgrade
- a/c problem
- Rear DVD info
- LX470 2000 Buzzer Problem
- New LX Owner with some suspension questions
- Roof Mount Storage
- 97 Lx450 suggestions?
- Parts List: Repack Bearings and Brakes
- Third Row Seats - Tan Leather - FOR FREE
- 90,000 service. Should I change water pump with timing belt change?
- Transmission replaced & shifts w/o command HELP
- LX470, 2004 towing rating?
- Advice on 2003 LX470 for sale
- 1997 LS400 stereo system put int a 1997 LX450?
- Mark Levinson….Best Factory Car Sound System?
- 2003 cabin air filter
- heater/ac fan motor whine
- RIP Lexus 2000 LX470...
- My New LX450 - Is this 4WD Diff Lock??
- 1999 LX470 misfiring
- 2012 LX Gets New Video From Lexus
- lexus 450 lx evaporator coil replacement
- Two Front Seat Problems
- AC clutch relay for LX470 2005
- Transmission/Transfer Case
- Timing Belt Questions
- Replacing Speaker
- How do you remove the rear door panel on a 2003 LX470
- GPS Problem
- Need Advice On Purchasing Used LX450
- Why LX470 petrol consumption very high? Any idea
- CD - DVD Changer choked on a DVD
- Overheating problem
- Diff lock problems
- Issues with the rear dvd player
- XENON HID Headlights
- Is LX frame rust a common issue?
- Blizzard Pearl OEM Touch up paint
- Any recommendation where to find parts for hood support
- Something is wrong. Vehicle or battery?
- 2003 LX470 Need amperage for Interior light fuse
- AHC Suspension Issues
- Start issues resolved with oil change???
- Drivers window trouble LX470
- Trouble with keyless entry 1998 LX 470
- Normal running temperature for LX470 (2003)?
- Exhaust nightmare
- Back again
- Replace License Plate Bulb
- $2k front suspension question
- 1997 LX450 power seats not working
- 1997 LX450 RPM's running too high
- LX470 Seat Buckle Problem
- Lx470 Runs Rough when in Drive
- 2001 lx 470 leather seats coming apart at the seams and then some
- New Tires
- New Windshield... oem or aftermarket for lx 470...?
- Pricing advise
- Just bought a near perfect 06 LX470, with jacked up chrome grill...
- Bought a 1996 Lexus lx450
- Auto leveling question
- '98 need help, photo of wire harness next to brake fluid reservoir
- '98 with 67k miles, yup got my hands on one
- Navigation Won't Go Into "Night" (Dim) Mode
- Anyone run these LED tailights?
- amplifier diagram
- 1999 Lexus LX470 Engine Running Rough But Clears Up!
- 2004 LX 470 towing
- LX470 Transmission problem
- Electrical wiring diagram for third seat row interior ceiling light
- Broken Latch on Top Console Cover
- Just got an 07 LX470 and I'm loving it!
- Looking for a good Indy Lexus mechanic in NYC
- New guy jumping in head first with a TRD supercharger
- New (to me) LX470
- TRD supercharger
- Rattling sound in my LX 470
- LX 470 squeaky brakes
- upgrade 2002 to 2007 please help.
- Car seats make noise when move back and forth
- Change steering wheel with audio control
- Change of navigation CD
- Long Distance Driving
- Brake Controller Wiring
- U Need 18" Inch wheels?
- Ahc
- Front Door Key Lock Direction!?
- LX470 used parts?
- Mark Levinson No Audio - Please Help
- 2002 LX470 - Buying Advice - details & pic included
- 2004 LX470 Mark Levinson Compatible Music Formats
- What are these strange stickers!?
- HVAC Fan / Blower Chiring / Screeching Sound
- Mark Levinson Amp
- Navigation / Telephone Speaker Problem
- Mirrors stuck when warm
- LX470 Jumpy
