- Seat memory not working
- In search of front bumper lip for 2005 LX470
- No start
- PLEASE HELP (audio issues)
- Titan7 Forged Wheels. Best Quality for your Money!
- Blown Engine in my '02 LX470 - Now what?
- 1998 LX470 will start but wont keep running
- Lx570 2013 rear suspension is very bouncy
- Intermittant start up problems
- LX470 A/C issue or moisture in cabin
- 1996 Lexus LX 450 Spongey Brake Pedal Issue
- Engine Fumes
- no volume
- LX 470 front seat driver
- New LX470 owner
- LX470 low idle after battery jump start help
- Need some QUICK advice - single-owner 2002 w 220k miles for $8000
- 2000 LX470 Millennium Edition Replace/Repair DENSO Navigation System
- Move from 2014 RX 350 to much older LX (or GX)?
- Removing whale tail spoiler 2005 lexus lx470
- 2000 LX 470 - Japanese Model - Denso Navigation System replacement / repair
- Air condition works with bang or unplug and plug
- Rust? (Pics)
- The End OF The Land Cruiser or LX570
- Where is ECU located in 1998 LX 470?
- Tire/Rim fit 2004
- In search of third of ivory third row seats for my 2006lx
- Bent Valves?
- Interested in buying a 2005 Lx as a commuter
- Thinking of selling my 04 pearl white lx470 with 80k mile
- Rough Idle Upon Start Up
- Steering wheel help from fellow lex lovers
- Is this too much rust?
- 2000 LX470 w/ 115000 miles - good mechanic in San Bernardino CA & what year is best?
- HIGHEST mileage award!?! (Expenses associated)
- Interior lights & avoiding dead batt when tailgating
- Pre-purchase inspection checklist
- AHC / Suspension Problem
- DVD fuse?
- AC issue showing not connected Please HELP...
- LX470 vs GX460?
- Headrest DVD help
- 02 lx470 AHC issues
- Possible 1996 lx450 for sale
- 2004 LX Too much rust?
- 2009 LX 570 4LO flashes
- 2005 Bluetooth Issues
- Metal shavings/chips in transmission pan + rattling noise when driving 20-30 MPH
- Blind Spot monitor
- AHC Question
- 2006 LX470 brake pedal vibration when stopped
- 1997 LX450 question, axle...
- 2002 lx470 worth it?? and engine fuel question
- How do I remove back pillar at rear window?
- Read on '03 value
- Timing belt on low mileage
- lx470 2007 limited edition
- 2005 lx470 water leak in rear
- 98 LX470 miss/fuel cut when warm and in closed loop
- Cruise control issue
- Audio System improvements
- Ignition switch rod broken- 7853A
- 1999 LX470 what clip is this for?
- Windows
- Engine Roar and Vibrations
- 2007 LX470 Suspension Advice
- WTB: Armrest drivers side
- Auto locking doors
- Steering wheel locked...ignition key simply moves from lock to start and vise versa.
- ASFIR Front Skid Plate
- Do You Guys Think This LX470 Was Lowered or At Stock Height?
- LX 470 Catalytic converter / O2 sensor question
- 2004 LX 470 with 89000 miles Miami Fl
- 2006 LX 470 Rear Passenger Side Upper Arm
- 2001 lx470 battery issue
- OEM LX450 Floor Mats
- Nerf Step Bars
- Towing with a LX
- WTB: 06-07 LX Wheels
- How much does dealer charge for low beam bulb replacement
- Lexus GX470 timing belt
- Rarer 2007 LX470 Pricing
- Do I Need to Upgrade my Torsion Bar?
- 2006 LX 470: 150k+ mile maintenance schedule recs
- Brake Fluid Sensor - float switch
- Need Recommendations please
- 😁2000 LX470 Running Boards😁
- AHC Parts - Accumulators
- ABS activating unexpectedly while on Highway!
- LX470 in Off-road Sand Dunes
- how rare is the 2002 Lexus lx470
- PA20-TOY Apple's Lightning to 30-pin adapter
- Looking to buy 2000 lx470
- Upgrading the stereo in a 2005 Lexus lx 470
- Lx 470 2006
- AHC functional working but not changing height?
- 2006 LX 470 -To total or not to total...
- 04 with 193k value?
- Looking for 06-07
- Cool clip of LX off road
- Updating Bluetooth in 04 lx470
- 1999 LX 470 Good Deal
- steer wheele looked on up position
- Front suspension
- AHC pressure line replacement 1999 LX470
- Fake Toyota Land Cruiser from China !!!! ?????
- 1998 LX 470 - Horn issue after replacing window shield
- lowering suspension to go underground parking
- Android car radio install?
- Hydraulic shocks
- That squeaky steering column
- 1999 LX470 Nakamichi Sound System Upgrade
- I have an idea...
- Diff breather frozen
- 2000 LX470 Alternator Connector View
- Help!! 2000 lexus lx470 lacking power going up hill!
- Timing light reset help
- New Wheels for '06 LX470
- AC help - 97 LX450
- front differential
- front differential please help
- 2006 LX470 wind noise through driver's side door
- 1998 lx470 front A/C won't get cold but rear will
- New member here!! But....
- What is the cost to replace 2007 GX 470 steering rack? I was just quoted $3,545!!
- Two tone paint
- Brake actuator assembly
- 2007 lx470 jerking problem
- HIGH Mileage LX470
- Tailgate/ hatch electrical problem.
- Passenger side mirror stuck and clicking when adjusting
- Looking for Nakamichi unit.
- A/C dash light blinking(green)
- 2003 Lexus GX470 Back up camera ready?
- Update back up camera 05 LX470
- Buying Lexus LX470 advice
- I now have a 2001 LX 470
- Lexus LX 470 subwoofer
- Information on ML Sound System
- 98 LX470 misfire only when warm and in gear
- Aluminum Radiator
- 2006 LX470 engine & vsc lights came on
- 5 or 6 beeps when starting.
- where can I get OEM rotors and pads for a 2001 LX 470?
- USA vs GCC
- Pros and Cons of a 04-06 LX470
- 2006 lx470 check engine on/off intermittently
- po420 code and on/off check engine lights
- "check connection to ac" message
- 20" wheel and tires size?
- 2007 lexus lx470 key programming
- 2004 LX470 Button Beep Defeat
- Air Suspension trouble.
- ABS SOL relay removed
- 07 Lx overheat
- Performance Chips
- charging wire?
- Where to sell a 96 lx 450 with a blown head gasket
- 2002 LX470 transmission issue
- timing belt
- 1998 lx470 ecm ecu wiring diagram
- Replacing ML W/NAV stereo.. it can be done
- Interior Color of a 2000 LX470?
- CV axle replacement
- rattling noise from the engine, LX 470
- Making homelink work only with key on...
- Floor board dimension comparisons
- LX470 Door Lock Switch Not Working
- Timing Belt defect?
- Picked up my first LX a few weeks back
- Help with Height control sensors?
- Manuals for LX470 and Land Cruisers J100
- Dreaded ABS issue xmas dash lights
- Is there a cabin air filter for lx450 96-97
- Joining the club - 05 LX470 123K Beauty
- insurance fraud
- 2003 LX470 w/ 116k miles for $15K - buying advice
- 2006 Lexus LX470 with recurring P0305 code
- 1999 LX470 Won't start unitl battery is disonnected / reconnected
- LX470 California Emissions
- 99 LX470 for parts
- Intermittent no crank '99 LX
- 1996 lx450 oil sensor/switch location
- LX470 microphones
- New air intake for lexus lx 470
- LX-470 roof rack questions
- 2006 LX470 Rear Seat DVD Player
- Need new key, HELP
- LX 470 2005 only 40k miles advised many replacements! please advise
- How do get the oxygen sensor plug to release?
- Replacing Passenger Side Headlight Assembly and front clearance lamp
- P1121 on 1999 LX470, Help!
- LX or GX overland build
- feel vibration inside on the wheel of my rx330
- LX470 Touch Screen & Lock Problem
- LX470 Seat Memory Switch
- Need help! Weird rattle sound
- Emergency Flashers
- Keep or trade up newer? Help me decide.
- Pricing -2001 LX470
- 2001 LX470 Cranks but won't start (intermittent)
- Different types of sound coming from the engine bay after starting the car
- Stolen Lexus LX470 Emerges From Storage With Only 1,000 Miles
- Checking out a 1999 LX470...
- not cranking
- bad sound
- Headlight problem
- how to remove passanger door panel on GS450h
- Perfectly maintained, 167k mi, trade or keep?
- 2004 LX470 - Climate Control, Trip Info and Temp Guage, Gear indicator issues
- normal expenses for maintaining a LX 470 with 100000 miles plus
- Light Upgrades
- Can someone help identify this LX470 bumper?
- Lexus dealer experience in Westchester
- 05 GX470 3rd Row Remove?
- Harness wire drawing for lx470 2004
- I have a lx470 2004 with need wire drawing for AC control in the gps screen.
- Main Computer or Transmission Module?
- Used Lexus LX470 SUVs Can Be Had for a Song
- P0442 Check engine light code - Evap leak?
- '98 LX470 rear half of the car slumped down
- start button
- 2006 LX470 Heat and AC quit blowing Hot or Cold, Just BLOWS!
- Anything I should look for on my new to me 00 LX
- GPS Screen For 04 LX 470
- Speaker removal - 1997 LX450
- Aftermarket Headunit with Stock Nakamichi Amp
- 2004 LX470- Inspection Tips
- fuse chance
- Transmission swap - 4 to 5 speed.
- Lx470 1998 stops after few seconds
- Headlight conversion on '99
- Problems with suspension lx470
- 2005 LX 470 power mirror R&R
- HID Foglight Retrofit
- 2002 LX470 Wont Start
- lx470 or lx570??
- Series 100 bumper hitch assembly question
- 2785/75/16 too big for 2001 lx470?
- 2004 LX470 Tow rating
- 2000 Lexus RX300 Fuel Shut off Switch
- Lx470 hid retrofit projector bracket
- 2007 LX470 Radio upgrade
- 2007 LX470 Nav. screen replacement
- windows and sunroof
- ABS Active TRAC, VSC, VSC OFF BRAKE dash lights on
- 2006 Key Issues
- LX470 Arm Rest Fridge
- brake grinding sound under the hood
