View Full Version : Suspension and Brakes
Pages : [1] 2 3 4 5 6 7
  1. Spring difference
  2. Installing megan LP coils tmr ( help with settings pls )
  3. Difference in FSport Brakes for 250 and 350?
  4. High pitch brake squeal
  5. Shocks dead do I replace Eibach Springs too?
  6. CEL After Lowered?
  7. brake pad replacement options?
  8. Brake Rotors "Non-Servicable"?
  9. IS250 RWD + 20's +Fsport Springs??
  10. Is there any long term damage on coilovers if I leave it on the lowest setting?
  11. confirm
  12. F-Sport shocks and springs on AWD?
  13. My BC Racing coilovers are very noisy!
  14. F-Sport or Tein S-tech Springs?
  15. how do i know when my shock is blown
  16. IS350 recommended brakes and rotors
  17. brakes and rotor recommendations
  18. H&R Sport + F-Sport Shocks
  19. Front Camber Kit for IS350??
  20. KW Variant 3
  21. F Sport Shocks Will Raise Your Car Again? Or Do They Settle?
  22. DIY Parking Brake Adustment on an IS350?
  23. F-Sport Rear Sway install-Lube the rubber Bushings or not?
  24. Tein CST coilover clunking noise. Anyone have any ideas or clues
  25. Tein CST coilover clunking noise. Anyone have any ideas or clues
  26. Question about Megan coilover Dampening
  27. Recommended Rotors & Pads for IS350?
  28. Some Low for the Lex
  29. Yonaka Coilovers Tested - PASS!!
  30. Awd suspension
  31. Suggestions needed... (looking to get a set of cross drilled and slotted rotors)
  32. coilovers vs lowering springs
  33. tein s tech owners.
  34. Purple Erkel BBK
  35. NEW TSB: Noise with F-sport Springs!! Released 10-14-09
  36. H&R Spring Owners, chime in...
  37. installed Tein H tech..
  38. Are coilovers worth it?
  39. DEALER quotes RE: brakes.. WOW!
  40. Question about IS250 front calipers
  41. IS 350 F-Sport Sway Bar Ride Comfort
  42. OEM rotor weight
  43. So what kind lof lowering springs should i get for my IS350??
  44. how low can i go?
  45. OEM springs or shocks?? giving out already?
  46. Squeeking brakes? Look in here...!
  47. brakes screeching
  48. IS350 Brakes making noise
  49. Debate: Stance LX+, Stance GR+, Megan LP, JIC Coilovers
  50. Very loud creaking in suspension
  51. Stance LX+ coilover install and review IS 250
  52. Goodbye springs, Hello Coils!
  53. alignment specs
  54. cars with air?
  55. F sport Rear Sway Bar
  56. Coilover question
  57. Coilovers: Aluminum casing vs Steel casing
  58. Anything else besides F-Sport sways?
  59. AWD on Springs?
  60. Front Camber Adjustment
  61. QUESTION : TANABE or MEGAN COILS ??
  62. Post Pictures and Reviews of your aftermarket Drilled Rotors with OEM calipers
  63. question about springs.
  64. tanabe coils making a squeaking like sound
  65. Stoptech slotted rotors!!!
  66. Weird problem...HELP!!
  67. HELP!! want to lower my car...which brand
  68. 2007 IS250 RWD Sqeeky Upper Control Arm
  69. Change Brake Fluid
  70. Tanabe TEAS
  71. Uneven drop on Eibach springs!
  72. Spring rates for the Advox and Advox Sports??
  73. How necessary is it to rebuild coilovers every year??
  74. IS350 Brake kit?
  75. HKS coilovers
  76. need more help with F-Spring clunking issues...
  77. picture request for springs
  78. Which coilovers if on a budget?
  79. Just got F-Sport Springs and Sway Bars! Can I do the install?
  80. fsport springs
  81. Tein S Tech question??please help
  82. Coilovers for IS250/350 fit on IS300 (asia/dubai version)-NEED HELP
  83. D2 Brakes.
  84. F-Sport Springs vs Tein High Tech.
  85. Brakes replacement/upgrade options?
  86. a stup!d girl question... (suspension squeaks)
  87. Front brake noise TSIB for '08s?
  88. Question: Stoptech or Rotora
  89. Helping a friend with spring and that lucky bastard...
  90. Getting F-Sport Suspension Installed Tomorrow!
  91. lexus calipers?
  92. Interior strut tower?
  93. TEIN Mono Flex coils
  94. stock ride height and FS suspension ID questions
  95. several spring and sleeve questions
  96. Brakes gone @ 23k?
  97. tanabe sustec pro5 coilovers
  98. Here's a question (coilovers vs. springs)
  99. IS250 Front/rear Brake Caliper Bolt torque ratings?
  100. H&R Rubs!
  101. Camber adjustment
  102. clunking on eibach 350's?
  103. Nervous as hell... (installing F sport springs tomorrow)
  104. Part number for OEM front rotors (250 awd)
  105. Quick question to IS350 owners about your brakes
  106. BC Racing Coilover Review
  107. BC coilover review and install.
  108. F-Sport and 19's !!!!
  109. Supra MK IV Brake compatibility?
  110. Anyone slammed on D2 coils?
  111. Colored Brake pads?
  112. Any Recommendations for springs?
  113. Installing F-Sport Springs ?
  114. F-Sport suspension and ridiculous camber and tire wear
  115. Tein SS ride quality
  116. switching from 18" to 16" for the winter
  117. F-Sport Spring and Silencer ?s
  118. Brake Dust is KILLIN me!
  119. will these BBK fit on a ISx50?
  120. Tips on adjusting HKS coilovers
  121. Durability of painted calipers? Also think it looks 'cheap'?
  122. fsport springs bad ride
  123. Removing IS350 Font Calipers
  124. help identify brake part number
  125. F-Sport Springs vs X-Package
  126. resurfacing rotors necessary?
  127. What springs do you recommend?
  128. rubber silencers?
  129. Brake rotors for IS-350 (2006)
  130. Coilover install on Wednesday - help me set up my drop height!
  131. VSC light came on with lowered height?
  132. F-sports clunking only in right rear?
  133. Tokico D-Spec for ISX50! Finally Out?
  134. Looking for F-sport Sways
  135. Rear brakes / parking brake is causing me to fail my state inspection
  136. How will you know "BBK" will fit the aftermarket wheel?
  137. Replace rear shocks after 62,000 miles???
  138. Brake Fluid Exchange
  139. Whats the distance between YOUR fender lip & rim? (!the smaller the better!)
  140. Talk to me about Coilover Spring Rates!
  141. anyone has a problem with the HID adjust lower after install F-sway?
  142. Cheapest place to buy Eibach Pro-Kit?
  143. springs and shocks???
  144. How much should dealer charge for new brakes?
  145. Best Brake Pads for front & rear
  146. F-Sport Springs - Got Them - Here's My Opinion
  147. Second thoughts on lowering, might bring it back up.
  148. best comfortable coilovers
  149. IS350 OEM wheel stud length?
  150. 2005 Camry Solara wheels and 2009 IS250
  151. Spring Choice Help!!
  152. F-Sport Sway bar problem!!!
  153. IS350 brakes = ISf brakes?
  154. Suspension Torque Specs
  155. Brake noise won't go away
  156. I just got denied for the 08 Dust-Free brake pad TSIB
  157. 250 AWD vs RWD ride height
  158. benefits of having the F-sport Sway Bars... let me know
  159. H&R Springs + Ichiba Version 2 Spacers on 17" OEM wheels
  160. Brake upgrade for 2006 is 250 awd
  161. Softer brake pedal after brake fluid change!!!
  162. F-Sport Springs and Tein Silencers
  163. Brake Pads and Rotor Pricing!?
  164. Did this shop try to sell me an alignment I don't need?
  165. Pic Request, IS 350 F Sport Springs H&R Springs
  166. 2009 Suspension Difference?
  167. Tein S-Tech Springs Question
  168. F-Sport Bilsteins - Still Not Sure - Owners?
  169. Anyone run stock brakes with slotted/drilled rotors?
  170. F sport sways
  171. F-Sport Sway Bars - Got Them - Here's My Opinion
  172. KW coilovers for our x50's??
  173. Stabilizer Links
  174. front camber plate/kit
  175. Vibrations from BC coilovers for AWD.
  176. Tein Silencers
  177. Megan vs. BC Racing Coilovers ?
  178. I hear my shocks making pfffft noise, normal?
  179. which coil overs
  180. will 20x10 40 offset and 20x8.5 25 offset work on my is?
  181. struts
  182. is250 rear brake replacement (GREAT DIY with lots of PICS!)
  183. Are these normal in Power Slotted Rotors
  184. AWD bc racing coil...
  185. F-Sport Brakes vs. IS350 Brakes vs. Others
  186. What coilovers to get?
  187. springs
  188. is this normal on an AWD?
  189. f-sport springs and shocks...ride comfort?
  190. Megan Coils making sound?
  191. The Battle of the Chassis Braces!!
  192. How long do the brakes last?
  193. Change in Specs for Front F-Sport Sway Bar??
  194. Brake Pad Wear - Front to Rear difference
  195. Rotor replacement...
  196. HELP! with discounttires code?
  197. F- Sport Springs Review/Opinion
  198. After installing BC coilovers I am having vibrations
  199. BC Racing Coilovers woohooo.
  200. F-Sport Sways w/ Stock Springs & Shocks or ...
  201. F-Sport Springs Noob Question
  202. GTSpec rear 2 point brace
  203. Just installed my F-sport Brakes!!!
  204. Big Brake Kit (BBK) Installation
  205. centric brake pads, anything good?
  206. IS 250 AWD vs IS 250 Brakes
  207. Power Steering Failure
  208. "powerslot" rotors, are they good rotors?
  209. F-Sport Sways same as Hotchkis?
  210. 2009 IS250 AWD and 2009 IS350 RWD sway bar same?
  211. F-Sport Spring Install....HELP!!!
  212. Help- retrofit brakes
  213. Is my dealer telling the truth?
  214. Harsher ride after brake pads and rotors surfacing
  215. Tein CS Drop height
  216. is350 f-sport shocks/springs compatible with is250?
  217. improve the handling?
  218. Brake dust on the front wheels?
  219. H&R vs. Eibach Springs - Comparative Review
  220. F-Sport Springs and Tein Silencers
  221. Can F-Springs be installed at local shop (?)
  222. Rusted Brake Roters
  223. Polishing the 350 Calipers?
  224. What Springs Should I use for my IS 250 AWD?
  225. Suspension Upgrade
  226. Which Lowering Springs?
  227. Spring vs. Rear Sway Bar
  228. IS350 Front Sway on IS250 RWD
  229. brake pad question
  230. Which tools to install rear sway bar ?
  231. Hydro-pneumatic suspension progress
  232. Tanabe SUSTEC PRO FIVE Owners
  233. brake pad?
  234. where can i buy brake spray?
  235. life expectancy of stock shocks
  236. OEM brakes pads or Low brake dust
  237. Soft-metal rotors? Have you ever heard of this?
  238. F Sport sway bar
  239. Going from Tein CST to Megan LP Should I?
  240. Has anyone had brake pad fail due to dust build up?
  241. Ksport coilovers or Tein Coilovers?
  242. BCR Coilovers for IS AWD setting thread
  243. Possible to swap Lux package suspension w/ Sport?
  244. pic/info request: BBK bracket
  245. brake help?
  246. F-Sport Springs on IS350?
  247. Need Help ASAP!
  248. Anyone else unhappy with ride quality on their EIBACH Pro-Kit ?
  249. f sport springs question
  250. How much did you guys get your IS350 brakes pads for?
