View Full Version : Suspension and Brakes
Pages :
5]
13
14
15
16
17
18
19
20
- Do I NEED toe arms?
- Thinking about changing Brake Calipers
- Possible budget bigger brake upgrade - 2014+ GS 350 F-sport
- GS350 coilovers interchangeable with IS350?
- rear brake install IS 350
- Ksport coilovers is250 AWD
- Toe? Camber? Lowering an AWD is250
- 2011 IS250 f-sport package suspension
- 2006 Lexus IS 250 AWD Axle boot torn repair cost?
- BC coilovers in an AWD is250
- Tanabe Sustec DF210 Springs?
- is250 awd front shocks on is350 rwd
- Road magnet springs
- Post spring install issue
- RX 350 Struts
- Shock options for 2008 is350
- Brake rotors choices for IS350
- Help: Front strut top insulators torn
- I need help! Lowering springs question.
- H&R IS350 Part number
- Car vibrating only when braking at high speeds - help
- Brembo pads
- Wide Wheels?
- Check headlight system
- Megan vs. BC Racing vs. Stance vs. Tein vs. Tanabe vs. Others
- Megan ez street coilover fitment
- f sport springs/struts unavailable
- Adjusting height on Megan EZ Street Coilovers
- Shock dust boot necessary or not? Experienced suspension gurus only plz!
- SET brand lugnuts / eBay lugnuts
- Which Front Brake Pads? (Akebono)
- Stance gr+ preload setting
- Back shock 2008 IS250
- Just picked up Stance gr+ coilovers
- Akebono rear caliper
- *** Inconsistent Brake Pedal ***
- 26mm Front and 17mm Rear - Correct OEM sway bar size for 06+ IS350
- Is350 Shock life expectancy
- Invidia Q300 exhaust/Cusco Strut bar/ISF ECU questions
- Rear Driver Brake Noise (IS350)
- Godspeed coilover
- Camber questions
- Would 17" ES350 wheels clear IS350 Brakes?
- Best brake pad and rotor combo for the money?
- Squeaky Suspension! Camber? Need Advice
- BC Racing BR coilovers upgrade to Swift Springs
- Need replacement parts help ASAP
- front passenger pop sound -redid brakes/rotors-
- replacing shocks/struts help
- F sport BBk Noise.
- Front brake squeal
- F Sport Springs
- anyone have stock 17's on h&r springs with spacers?
- Coils or
- Possible AWD Lowering Solution...
- 2IS Not Tracking Straight
- 2012 IS250 AWD upgrading to IS350 calipers - BIG FAILED!
- Before&after H&R springs IS250
- AirREX Struts/Bags - Please share your experience if you own them
- 2008 IS250--- Cusco or Hotchkis Sway Bars
- ISC N1 coilovers | Review
- Brake Change: Best way to depress the piston without removing caliper
- 2012 IS250 AWD Brake upgrade questions
- Need more clearance up front after roll & relocated bumper tabs
- Air suspension for AWD IS250 HELP!
- Autocross w H&R springs
- Just change my brake pads...
- Advice on Correcting Alignment after Lowering
- fsport sway bar question
- Coilovers! In need of them!
- BCR Coilover blown shock??
- F-Sport Shocks Break-in Period (Fact or Myth)
- coilover vs lowering spring
- Wagner 'Perfect Stop' pads
- is350 caliper
- Installing coilover on IS250
- ISF camber arms fitting ISx50
- Squeaky Sound! Coilovers? Camber?
- BC coilovers camber
- Japanese 60k/55k springrates for IS250
- What are the different between these F sport Springs or shocks?
- Ebiach 350 springs vs F sport springs
- airforce bag/struts and ride height
- 2011- Pass side brake rattle when coming to a stop
- Fsport front sway bar
- 08' isF rims on 14' Is350 Fsport
- 06 AWD ABS Speed Sensor Info
- Lowered is25O on 20's
- Decent coilovers for Is250 AWD 2007?
- ISC N1 Coilovers REVIEW.
- Tein H-tech on F-sport Shocks Big Question
- Need help deciding F&R sway bar upgrade
- Brake discs
- Attention eibach pro kit owners! Did i just get screwed?
- Just got a used IS250 F Sport - which F Sport suspension bits do I already have?
- Color Caliper For Black Sapphire Pearl
- Really bad break dust
- help. squeak noise coming from front drivers side wheel well
- Wanting to lower '11 is250
- Tein H-Tech JDM version on IS300 install
- Front Rotors and Breaks Suggestions?
- Question about custom/modded front UCA
- Front boots are done..Need help
- Tein htech for awd?
- Akebono vs Brembo
- Front brake change question..
- New brakes - Silver Zinc Plated Cross-Drilled And Slotted Rotors w/Z16 Ceramic Scorch
- 350 AWD lowering suggestions
- Oem 18inch wheels for is350 2007
- Tein rubber spring spacers
- any of u modify megan rear camber kit OR suggestion for an aggressive camber kit ?
- Function and form type 2 coil overs
- F-Sport Springs & Shocks
- Oem shocks/suspesions looking to buy
- Eibach Pro Kit - where should I order it from?
- 2007 is 350 ? Lower springs to manufacturer height.
- Can I replace pads only?
- Front right side Wheel Vibration when turning left
- Suggestions for shocks on lowered springs
- Shocks to pair with Eibach Pro Kit
- suspension refresh at 100k?
- Squeeeeeeaaaaal!!!!!
- eibach is250 pro kit on an is350.....would you do it?
- Cusco Swaybars
- My OEM shocks are leaking, need recommendations for replacement
- pulsing after brake job
- Would I need a camber kit for Road Magnet Springs on Is250?
- Brakes @ 60k miles. Rotors too?
- Help: Need spacers spec recommendations
- Looking for affordable suspencion upgrade
- Completed Coilover Install
- best air ride
- Bc Racing or Megan Ez coilovers spring rates with Vossen CV7s?
- Has this happened to your coils?
- Help with rear shock replacement
- Springs/Springs Rates and Ride Comfort
- Straight Spoke Styled Wheels?
- The Comfy Ride Thread (225/50/17)
- Removing end links
- HELP CAN NOT GET THIS OFF! (Suspension)
- Brakes issue
- 2012 is250 rwd coilovers or springs?
- opinions!? coils.
- Suspension/Lowering question
- Rear dampening adjustment
- Road Magnet
- Front wheel rub, stock wheels, H&R springs
- 2011 IS250 Brake Bleeding
- Coilover Suggestions.
- Brake help?
- Shocks for IS250 w/ eibach springs
- F-Sport Springs still Stiff/FIrm
- Front end clunk noise 09 IS250
- Why does my 06 is350 weigh so much!?
- LS460 rear 2 pot brakes for IS250?
- advice for lowering
- Lowering problems
- Bought a lowered car, is there anything to raise it half an inch?
- Should I do alignment for oem shocks replacement?
- Sway bars.. Will they make a noticeable difference?
- decided on springs.... now what?
- For those on BC's- Pillowtop or Rubber?
- Faint rubbing noise
- Accuair/ Air suspension question
- Shop told me they couldn't adjust toe?
- Alignment wait time after lowering
- Another BC Coilover Rates Thread!
- F-Sport accessory springs and shocks just installed. Impressions!
- general drop kit question
- New front oem pads with no slot?
- Options for this price range...
- Biggest Tire Size on Tein S Techs
- cheap camber kit?
- Which brake rotors?
- Rear toe arms for the IS250 AWD?
- Genesis wheels on IS350. What spacer?
- Brake Pads
- strange creaking noise driver's side wheel well
- Please Help, Crazy clicking/popping noise coming from my suspension
- Tein S Tech part#
- coil overs or springs
- Floating spacer on rear?
- Brake rotors
- Original OEM Shocks Life
- installing coilovers on IS250, need help with what alignment components i need
- Factory camber
- BC coilover extenders with Megan coilovers?
- ISC N1 Coilovers
- Want to buy: Stock IS350 shocks and springs
- I have a 2013 is 350 fsport its on coilover help
- New Struts KYB or OEM
- Neo Motorsport dynamic purple coilover review
- In depth review Lower Springs + F Sport Shocks + F Sport Sway Bar
- lowering rear suspension by half an inch, do I need to re align?
- F-Sport shocks
- F Sport Springs Install Cost
- Camber Kit (Adjustable Ball Joints)
- Creaking Noise from rear. Need immediate help finding bushing
- Questions re. recent coilover install
- coilovers height adustment question
- Noises & Changing of F sport brakes
- Chassis and Sway Bars
- What size sway bar does my is250 f-sport model come with?
- Excessive Popping from Rear Strut, please help!
- Highest mileage lowered is250 awd
- Help Broke ball joint
- Megan Ez's installed
- just installed BCR coilovers
- In need of new brade pads
- F Sport brake noise
- Need help trying to figure out what kind of suspension I have
- lowering springs help
- AWD IS250 Air suspension???
- HELP! Slight wobble when turning
- Megan front UCA in blue?
- Brake problem
- IS x50 RWD with swift springs? Pics?
- BC Coilover with Swift springs
- F Sport Sway Bar Confusion
- Question about IS250 AWD suspension and exhaust
- Lowered On Coils- Camber help
- Coilover which one should i keep?
- Maximizing performance + look + ride comfort + durability
- info lowering spring is 350 rwd
- Track Tires
- 255/40/18 Tire on 8inch rims?
- Track Pad Question
- 2010 IS250 Stock Suspension Fit Onto a 2006 IS250
- Accuair E-Level Install - PITA?
- Newbie question to lowering
- C8 Coilovers?
- are SPC camber kit any good?
- Rear alignment specs -0.28 Toe bad?
- SPC Camber adjustment tool
- Stainless Steel Brake Lines, performance upgrade or not?
- 06 is350 Shock Question
- Trunk won't close help!!!
- Tanabe Pro Five or Z40
- Help: front upper Ball Joint removal and/or SPC installation
- Help air runner system
- H&r & awd???
- Lowering Springs and Struts Combo
- Getting both rear tires spinning?
- Tein CS EDFC beeping at me and not functioning properly
- Need help with False floor and notch frame
- F Sport BBK
- Bc coilovers & Swift springs on is 250 awd
- Installing Megan LP, replacing one shock
- Megan Camber Kit
- F Sport Shocks Only?
