View Full Version : Suspension and Brakes
Pages :
3]
13
14
15
16
17
18
19
20
- Strange "knock" felt through pedals
- IS250 AWD vs RWD Upper Control Arm
- Brake/Rotor replacement
- Knocking Noise, unsure if suspension related.
- Rear Crossmember Braces
- Lowered Lexus on 19" GS F-Sport wheels
- Lexus IS250 camber installed issues
- Aftermarket Springs on Stock Shocks
- Powered By Max coilovers
- EBC Pad Anti Squeal Shims
- RR USRS super stiff?
- Is350 fsport Check Headlight System
- Coilovers ride height
- Front Suspension SQUEAKS over bumps and while turning
- Upper Control Arm IS250 AWD
- Brake pads
- '08 IS250 150k: Shocks Shot. Koni Sport or F-Sport?
- Anyone gone from OEM F-Sport Suspension to Fortune Coils?
- Raybestos Brakes - IS350
- Problems Installing Rear Camber Kit
- American Graffiti 250;
- Rear Shocks Suggestions
- Alignment on lowered car
- Brake issue
- Coilovers
- Group Buy: RR-Racing USRS Ultimate Steering Response System
- Brake pedal issue
- Rear brake creaking in park
- Rear 2007 is350 Caliper Upgrade?
- 2007 is350 Coilovers
- Brake screeching
- Brake pedal clunk / stick
- Front chassis bracing available?
- Need front tires, do I have to buy the $240 tire again?
- F-Sport Sway Bars on ISx50 AWD Anyone??
- Megan Racing Sway Bar
- F Sport or Megan Sway Bars?
- IS-F Steering Ecu Upgrade on a IS350 - Vibrations
- Light popping noise front passenger side
- 2012 IS250 F-Sport - Leaning toward H&R Springs... Advice?
- FS threads go only in the classifieds, not here
- Spring for trade 2011 is250 F sport
- Lowering Springs and Struts Replacement
- DIY rear sway bar install
- 2012 Lexus IS250 Shocks Replacement
- IS350 caliper slide pin question
- DIY Un-Seize Coilovers
- Rebuilding BC Coilovers - Reassembly
- IS250 2006 Manual Suspension
- 2011 IS350 F-Sport Brake Pads
- '06 IS350 Suspension/wheel/tire upgrade
- Need help on setup: Lowering + New wheels
- IS350 caliper piston dust covers
- TIEN Street Advance Z
- 2011 IS350 AWD Swaybar options
- Centric Economy Rear Rotors
- Looking for DIY: Rear Control Arm install
- Replacing Rear pads, question about rotors
- Wheel hop and single "knock" sound from suspension
- Brake Degradation / Loss of Power
- Spring upgrade on Megan Coils?
- BC Coils track use
- Coilover suggestions
- Wheel alignment thoughts 2008 Is350
- HELP:Single Knock/Click/Pop Sound from front of car
- Clarification: OEM IS-F rear sway into IS250awd
- New KYB shocks and Front Axles Rebuilt on my 2010 IS 250 AWD.
- Front and rear suspension bushing upgrade?
- Centric rotors and pads question
- Need Help Choosing
- F-sport shock obsolete in system already?
- suspension upgrades
- Upgrading suspension, have questions
- Lowering Springs installation
- Tyre size. Front diameter inc.
- IS250 AWD Front Camber Kits?
- Advanced Auto Brake Pads and Rotors, Need Quick Suggestion
- LS to IS
- Strange "hopping" feeling when reversing at full lock
- BC Racing / Spring Rate ?
- Wheels/tyre coilovers Q
- Do F-Sport lowering springs fit 2012 IS350 AWD?
- Going back to OEM
- Brake Pad Replacement Frequency on '07 IS
- RS*R Springs Installed Plus New Pics!!
- Brakes and Rotor Replacement
- Good Springs to lose wheel gap!
- Sage RCA spacer BOLT issue w/ stock 17" wheels
- Rear struts replacement for IS250 2008
- Part Number for 2010 Lexus IS250 AWD Front Shocks
- T-Demand Coilovers -- any reviews?
- Caliper slide pins kit
- Wheel Clearence
- Car Needs Front Struts--Which Ones To Get?
- Best affordable air ride system!?
- Question about struts
- Seized caliper? How do I check?
- Internittent brake issue
- BC racing DR series coilover for 2IS
- Caliper bolts?
- Brake Guru neded, rear caliper plate?
- '06 Blown Shocks - what to buy
- Caliper bolt torque
- IS350 Front Brake Calipers installed on IS250: Questions!
- Replacing worn shocks
- 2 front Camber bolt seized please help
- Megan Arms - Which Do I Need?
- F-Sport Shocks Mono Tube or Twin Tube
- Metal Ticking/Clicking Sound from rear
- Brake Screech
- How Low Before Camber Kits
- When to replace brake lines
- Replaced shocks, now car seems "unstable" over rough roads
- 2008 IS250 RWD (X-type)
- IS350 Front brake rotor question
- Lowered on h&r need info on spacers
- Creaking When I get In - Shocks?
- F Sport Sway Bars or RR Racing USRS
- New poster - Quick F Sport spare question
- What's your coilover height?
- Brake problem after brake pad change
- 2007 IS250 Brake & Suspension
- Popping sound coming from right front when i hit the brakes
- Single Click Suspension Noise
- Can't decide between a few coilovers...
- Suspension
- Coilovers or IS-F Suspension
- What handling Mod next?
- What is making this noise?
- Rear camber arms SPC performance
- 350 rear driver caliper seized
- Need Help, New Rear Pads Won't Fit on 2008 IS250 RWD
- 2012 IS350 rear brakes?
- Another brake mod thread
- Suspension mods for traction?
- Anyone have RSR Down springs?
- Remove Plastic Shield under Wipers
- Bad brakes while its raining
- HELP! Rotors and Brakes
- Can anyone tell me how to get this color brake caliper posted on here a while ago?
- Suspension mods for bagged 2is?
- Help is this F-Sport rear sway bar?
- Will Tein comfort coilovers for IS F fit IS350?
- Lowering my 06 IS250
- ISF sway bar on IS350
- BCR Coilover Installation Help(AWD)
- Does having my car slammed/lowered hurt performance?
- 2006 IS250 AWD Megan Racing 1.25" Drop Lowering Springs (After Shots)
- 2008 IS250 LCA Bushing offset?
- Air cup / piston setup - AWD IS250
- Starter Clanging on starup
- 2011 IS350 AWD lowering springs! HELP!!!!
- IS250 Rear Strut Bolt Nut Size
- 2007 IS350 front LCA replacement - 2007 = 2009 part?
- Brake Master Cylinder 130.44041
- Lowering Spring Install Help!
- 06' IS250: Lowering Spring Installation HELP!
- Completed Brake Calipers!
- BC Racing vs Megan LP
- Need your opinion on lowering springs or coilovers...
- Want to buy used Lowering spring or coil !
- Lowered Suspension on an AWD Model - Clarification on Vibrations
- BC coil making noise
- Rear Strut Replacment
- Tokico HTS
- Best pricing for F-Sport sway bars (F+R) for IS350?
- ABS Error, check VSC and etc
- Lowering IS250 AWD causes vibration?
- Bushings Question
- Need help on calipers installation
- Lowering a 2007 awd Lexus is250
- Trying to decide on lowering springs
- issue with EIBACH PRO KIT
- Where to buy stock suspension?
- Quick Question: Figs mega arms camber adj.
- Cup Kits - Where to go for best bang for my buck?
- Suspension noise
- 2009 IS250 AWD Rear Shocks KYB Gas-a-Just or Monroe oeSpectrum?
- Looking for a rear toe link install DIY (FIGS, Megan, etc.)
- WTB Coilovers! Opinions? Facts?
- Megan UCA's instead of SPC's ??
- Need a set of new bushings
- Do I need Camber Caster Ball Joints?
- Is 14K/12K too stiff for DD?
- yet another suspension and lowering thread
- IS250 Brakes Dragging
- Dusty Brakes
- Installed KYB Shocks on IS350
- 2006 IS350 RWD Suspension Overhaul
- H&R springs and F sport shock bouncy, anyone else?
- Koni FSD Shocks 2100-4130 for 2008 IS350
- What is a "Bag over Coilover" Air suspension and is it cheap?
- Question for all you Lowered 2IS's
- trying to understand spring rate here....
- AWD airlift 3H airride pressure presets?
- How to determine if a shock is leaking or not?
- Air struts damaged
- Help with Wheel Spacer for AWD and Coilovers !
- Which of these Shocks to choose?
- IS*50 with BC Coilovers help me with some pics!
- 2008 Lexus IS250 front clicking noise while turning please help?
- My IS F-Sport upgrades
- IS250 vs IS350 rear brake calipers?
- Best ride, quietest, longest lasting 19 Tires?
- Tires size for IS350 AWD
- KYB Struts for Front L/R
- Decided to buy BC Racing Coilovers
- F-Sport 19 inch wheel vs 17 inch wheels?
- Need your opinion on lowering springs...
- Steering wheel pulling right when brake at close to 0 speed
- WTB: IS250/350 AWD coils, prefer used
- Brakes........on fire!
- 2012 IS250 AWD Front Control Arms?
- Help needed: BC Coilovers out of the box rule of thumb for height
- Muffler upgrade, any input? IS 250 F Sport
- 2011 IS350 Brake Resurface?!?
- IS250 rear crossmember differences?
- Eibach Springs and AWD CV Joint Boots failing!!! HELP
- Pictures of suspension with tire off
- Godspeed/Truhart Upper front control arm
- Can i swap my 17" for 18" wheels?
- HSD HR vs. Megan vs. BC......
- How do BC Coilovers handle extra weight?
- Wanting to buy factory springs
- Lexus wants $1,000 to..
- Burnish / bed in brakes experts
- ISF springs on IS250 awd?
- BC Racing coilovers question
- Installed F-Sport Shocks
- Lowering Springs for IS350, Please Advise
- Brake fluid pressure flush
- D2 Racing Lowering Springs
- BBK Question
- Seized rear caliper lower pin/hinge
- What size tyres
- F-Sport Rubber Exhaust Hanger
- 2009 IS250 AWD Lowered w/ Eibach
- Just got my Tein Flex A Coilovers dialed in
- Rear pad shim kit?
- Tire Thread and Suspension - SF Bay Area Local
- How-To Tuesday: Suspension Mods for Your Lexus IS/GS
- 2008 Lexus IS250 RWD Tein S Tech Springs Installed
- Quick IS350 rear caliper question
- 2012 AWD IS350 Camber Kit
- SSR wheels
- Allowable Mods for HPDE Events at Road Atlanta
- Tein S-Tech Springs
- Caliper Brackets
- Excessive tire wear.
