View Full Version : Suspension and Brakes
Pages :
13
14
15
16
17]
18
19
20
- is it compatible? (Tein S-Tech Question)
- what shocks are out there for is250
- Final Rant for AWD Coilovers!
- lifespan of coilovers?
- F-Sport AWD Picture Request
- Night Pager (Dural) Rotor Bell Hat Cover EVO
- who has Tanabe DF210 3GS
- Loving the F Sport Suspension
- i want springs
- Replace all 4 brakes or just the fronts?
- F-sports VS eibach VS tein? springs only
- Will coilovers fix my rubbing issue with my 20s ??
- Tein SS and Tein CS
- F-sport Brakes
- spring VS coilover..money wi$e need some thought..
- Does anyone know anything about the Tanabe sustec pro five coils?
- brake pad replacement
- Brakes problems..sigh
- Factory Suspension Problem
- Lowering my IS350 with 20x8.5" wheels and 30 series tires
- Brake TSIB on '08 2IS?
- Do i need shocks to go with eibach kit?
- fsport shocks with eibach pro kit...
- Question about Teins spring 1.6 drop.
- Megan Lower Spring on Ebay
- Should i get eibach or megan?
- F-Sport Springs for IS250 AWD?
- Lowest springs?
- Do the F-Sport Springs Need the F-Shocks?
- 2 questions from a new is owner..
- OEM IS250 17's on a IS350?
- IS350 Rear Brakes The Same as 250?
- Tein S Tech on IS250 AWD
- Really good deal on the F-Sport Brake Kits
- Ride: F-Sport Springs vs. Sport Suspension
- Eibach on AWD?
- This has got to be the slowest section I have ever encountered on any forum....
- Too good to be true?
- Anyone noticing grooves like this in their rotor?
- Anyone care to explain... (steering feel on '08 AWD)
- Toe Setting
- Need some technical info on F-Sport Springs vs Eibach Springs
- F-Sport Springs Installation Quote
- Installing F-sport springs to keep warranty
- Will springs blow the stock shocks over time?
- What springs would/did you buy?
- Another Question About the TSIB Dustless Brake Pads
- Does anybody have a pic of the OEM sport spring compared to the regular springs......
- I asked this before, but it never got answered: IS250 springs vs. Sport spring rates.
- can't decide Tein SS or Tanabe PRO 5
- Rumble in my seat
- ?'s regarding Endless BBK
- F-sport shocks AWD available?
- Chassis Brace installed.. I can't tell the difference but VDIM can
- F-Sport SwayBars again...
- tein s tech spring???
- H&R Springs
- People who used Lowering Springs
- Tein CS/EDFC vs Tanabe Sustec Pro Five/TEAS
- Need pics of 19" wheels before and after drop
- What is the spring rate of IS250 standard vs. sport suspension..........
- Tein EDFC Question
- From Springs to Coilovers AWD
- Had Brake TSB Done, No More Freaking Brake Assist Garbage!!!, Brakes Much Smoother
- Rims
- We all know these damn cars lean on the driver side, how does this sound for a fix...
- Brake Rotors/Pads Selection
- Installed - F-Sport Shocks w/ Eibach Springs
- Any place I can buy Eibach springs cheaper?
- drilled rotors
- Stainless steel brake lines
- F-Sport Springs Clunk Noise. Normal?
- 12 piston brake caliper
- brakes (how much is a brake job IS250 awd)
- High Pitch Brake Squeak!!!
- Megan LP Coils vs. Teins CS Coils
- F Sport Sway Bars or Rear Member Brace?? Which makes most difference?
- What type of springs should i get for my IS250 AWD??
- Need info
- couldn't resist ....
- Creaking sound
- brake pads..
- Pic request: 08 IS250 with 18's and the F-sport lowering springs
- Summary: the drop level of each spring
- sport package springs part #
- EIBACH or HOTCHKIS Sway Bars
- Awful Steering
- Would it be risky to drive 1,000+ miles right after lowering car?
- Review: F-Sport Springs and F-Sport Bilstein Shocks
- F-Sport Springs are here!
- Poll: Lowing Springs worth it or not
- F-Sport springs on AWD
- TEIN H tech or F-sport?
- Tread life on tires with lowered springs
- F-Sport Spring
- Thinking about installing tein CS myself! need opinions & DIY guide
- Will lowering my car improve MPG and handling?
- Anybody have both the Eibach spring/swaybar setup?
- whats the normal price of an alignment?
- brake worn out unevenly?
- F-Sport Springs/Struts/Sways
- Best Upper Tie Bar Strut doe thw IS???
- 2008 Brake Pad TSB?
- Tein SS settings
- F-Sport Springs on Sport Package IS350 - Installed!
- F-Sport Front/Rear Sway Bar on Stock sport Suspension
- Tom's / Advox Coilovers
- Would you go for Tein H tech or Tanabe NF210?
- need reviews for Tein SS & CS
- **Official Alignment Info for ISx50**
- Will the F-Sport Springs have camber issues??
- Horrible rear tire wear!!!!!!! Pro Kit
- dropped on 250 pro kit
- Alignment after lowering/rims?
- IS-F brakes on ISx50???
- How many of you have lowered ISX50 in NY area?
- Cutting springs to make even drop - bad idea??
- F Sport Springs
- anyone purchased/installed f-sport bilstien shocks???
- rotational mass lost by changing brakes??
- Getting springs but which brand?
- TSB Brake Pads for 08 IS350
- TSB Pads are GREAT
- Why are my brake calipers rusted? pictures attached
- early christmas gift......to myself
- Confusion regarding springs
- Swaybars, 101?
- Suggestion on Springs
- Alignment after Eibach Pro-kit
- CHEAPEST Website to buy Eibach Pro-KIT for IS350?
- DIY brakes
- Get rid of Brake dust and also what is a TSIB??
- Sample Question
- F-Sport brace installed :)
- IS350 Owners with Sport Package
- Just Dropped My Gs 350 Need Help.
- K Sport Coilovers vs TEIN CS ?
- is250 wheels and brake clearance
- F-Sport Spring on a 250
- Picture of IS250 AWD w/ Tein S-Tech or Tanabe NF210
- Ceramic Brake Pads worth the $$
- NJ Distrib:Installer : Tanabe SUSTEC PRO FIVE with TEAS
- Will there ever be coilovers for a AWD?
- Tein S-Tech or Road Magnet for AWD? Poll
- brake help?
- Uneven Drop with Tein S springs need help
- do all is250 and is350 both have stock big oem calipers ?
- H&R has 2 part numbers for springs one for 350 and one for 250....
- NEX Coilovers
- Coilovers !
- Suspension drop, AWD, snow
- helps on tires sizes
- Where to order eibach prokit from??
- need aftermarket spring advice!!! help
- Clicking sound when braking?
- need quick decision Eibach or H&R?
- Eibach Uneven Drop? Driver to Passenger side
- I am thinking of lowering my car
- H&R springs question
- need advice: comments after change the brake on 08 model becuase of dust problem
- Post your Eibach Dropped Pictures here!!!
- IS-F brakes on is250 with factory 18's
- Just Got Dustless Pads For The 2008
- Are sway bar part #'s the same for 250 and 350
- how much did you spend for you springs?
- IS350 X package suspension on an IS250....
- tein s techs on 350- camber issues? pics too please
- Shall I swap from Eibach springs to coilovers?
- Help w/TEAS unit...
- IS-F Brake Upgrade
- Tein Cs users need your feedback.
- How much did you pay for coilover installation?
- Suspension to fit without rubbing?
- TSIB brake pad causing clicking noise at slow speeds
- IS350 Alignment specs
- full suspension travel...rub fender well HELP!!!
- rollcall: isx50 owners with Tein H tech springs. show me what you got.
- Alignment questions for recently lowered IS350
- Inner Tire Wear - Factory Suspension
- Installing springs (how to)
- IS-F Brakes on Stocks
- ISF Brake Upgrade
- Calipers Painted Gold
- Brake Noise after 8 months
- When installing coilovers..
- Pulsating brake squeek when brakes are cold
- need opinions on some tanabe nf210
- The Official: "Drop it like its Hot" Thread - How Low Can You Go -
- Need to change my rear brake pads...
- Post pics of springs on OEM 18" wheels here...
- How badly will i rub? Tein-S
- road magnet springs
- discovered a ghetto mod for firmer ride less body roll
- Two coilovers for an AWD?
- Need opinion on IS250 AWD springs
- Replacing Brakes IS250
- Question about Brakes
- Hotchkis IS Lowering Springs
- Did a search, DIY for lowering
- Sporadic creaking sound after installing Eibachs?
- TTE springs for IS
- Bad Tanabe Springs?
- TSIB Brake Pad question
- jic setup...?
- Brake Rust
- Project Kics hubring and wheel spacer question.....
- Which springs for a UK IS250 Rear wheel drive?
- F-sport CC brakes mounted pics for ya'll to gawk at.
- H-Tech springs for a 250AWD?
- Help w/ Camber Kits for IS 350 w/ mod Suspension
- Any choices for aftermarket shocks/struts?
- Ichiba or H&R spacers......
- In terms of ride quality only, is it worth to get a coilover?
- Best springs for the 250?
- Megan Racing Lowering Springs...need feedback.
- Adjusting tanabe coil help
- PSS9 coils
- Thud/Clank sound coming from brakes
- IS350 rear caliper upgrades?
- OEM parts and Shock leak
- Barke Upgrade
- brakes
- TSIB refussal for '07 350
- Tanabe Sustec Pro five Help!
- OFFICIAL: Tanabe DF210 Springs 06-08 IS250 RWD
- Brake TSB for Canada?
- Anybody gotten the Hotchkis sway bars......
- Suspension thread for 2IS
- I need some brake help from you guys
- Dealer gave me 2008 dust pads for tsb instead of dustless pads, what should I do?
- Brake Pad Replacement
- Is250 Coilovers
- at my Lexus dealer now and I asked about the brake dust....
- Lowering an IS250 AWD
- Roll Bar
- 17in wheels on IS350?
- What are the most comfortable Springs????
- Eibach Prokit for 250 on a 350
- Eibach 350 springs on a 250?
- is350 brakes
- Cut springs anyone?
- Where can i get the Lexus Caliper stickers for my 350
- BBK Availibility:
- TEIN Lowering Springs Question?
- Front strutbar question...
- Question Re: Brakes & Warrenty
- Stock IS 250/350 shock prices
- ** GS/IS Coilover-Air Suspension ** Gauging interest thread
- What are good aftermarket brakes?
- Anyone have pics of their 2IS on H&R springs?
