View Full Version : Suspension and Brakes
Pages :
12]
13
14
15
16
17
18
19
20
- Stealership brake diagnose
- Advice for finding coils installer
- Just Dropped My Car Off...
- what should i do for front brakes?
- F sport spring TSIB... HELP!!!
- 2007 IS 350 Brake issues
- Where to order hub bearing
- Coilovers and Camber kits
- Brake caliper painting life
- IS350 Rear Brake Problem
- Coil Install Time?
- F-Sport Springs vs 06 Sport Package Springs
- Painting brake calipers...
- problem installing springs today!!!
- Are coils a hassle?
- Autozone & O'Reilly front brake job
- Tanabe NF210 vs Fsport springs
- Changing from F-Sport Susp. back to Stock
- Seeking Air ride advice, with a few questions for those who have them equipped.
- Coilover Vs. Springs ?s
- Brake pads video please.
- Car needs a brake job? Go with aftermarkets instead?
- BCR Install instructions
- Help - Rear Brake Caliper Slide Pin Seized
- F-Sport Sway Bars for AWD
- Just got my F sport sway bar... installl help pls********
- Help me Decide: Keep Fsport Springs or switch to Coilovers
- Dealer won't do alignment
- BCR coils creaking
- is350 w/ sport package lower?
- bad to run just springs??
- 2011 IS 350 AWD with F Sport springs/teasers :)
- There is a front f-sport sway bar for the AWD now?
- F-Sport Spring Pics per request
- camber kits?
- EBC Redstuff Brake Pads Review
- Going back to the stock set-up.
- F-Sport Springs & Shocks - Much Better So Far
- Tanabe Sustec NF210 ??
- Coilovers!
- air force suspension
- FIGS MEGA Arms LCA for the 2IS soon to release!! Simple Camber option
- Eibach Pro Kit Drop on 19's
- Tein SS Coilover ?s
- ques: big brake 4piston upgrade from swell
- Winter driving coilover dilemma ..
- Trading in old F sport springs
- Wider Brake Pedal?
- Brakes - need suggestions
- What color to paint my calipers, lugnuts?
- Camber and spacer questions
- Anyone with Road Magnet?
- Wilwood brakes.........?
- Ride Comfort
- Random Question
- is250 brake upgrade
- Tein CST for isf on is350
- gs300 same brakes as is250?
- Rear Suspension Control Arm and Spindle Problem. Need Help ASAP Please
- Springs or Coilovers?
- Help Please...Stock Front LCA Bolt
- New style EBC slotted rotors...thoughts???
- to all those on air runner, question?
- noob question about brakes/rotors
- New Megan coil-over for AWD
- Slamming the car
- 350z brakes for lexus is250rwd
- Squeak!!Squeeak!!Squeeeak!!Squeeeeak!!Squeeeeeak!!
- Changing Suspension a One Man Job?
- What parts do I need to do a 350 upgrade on my 250
- Centric slotted and Power Slot slotted rotor?
- Aftermarket Brake Setup for IS250 AWD
- Brake Grounding Sound
- JIC Magic Coilover Rebuild
- Is this shock/spring application possible?
- Need help with rotors.
- Installing KW Coilovers - need help!
- Suspension newbie..need help..
- Porsche Cayenne brakes in is250
- brake article misprint?
- Brake Job
- Changed rear brakes and rotors, now scraping noise?
- squealing brakes....argh!!
- Rotors and Pads Question
- F-Sport-Springs-Only Didn't Work Too Well
- springs to coils?
- Most comfortable springs for IS 250 RWD
- Bleeding brakes yourself, and rotor thickness?
- Worn brakes. sugesstions?
- Front and Rear Brake Interchangability
- IS350 stock BBK vs LS460 stock BBK
- How much to install springs on awd car?
- Tein S Springs
- lexus oem bbk
- IS250 with IS F and IS350 brakes
- is250 rotors, suggestions?
- F-Sport BBK + Braided Lines?
- Dealer refusing to do TSIB update on F sport springs?
- Is the 2nd Gen IS300 brake system the same as IS250 or 350??
- All cs owners please help ones again
- Loud grinding noise when backing up
- Brake pads and rotors help!
- IS350AWD bbks for 250AWD?
- Removing dead weight?
- Searched for TSIB on F sport rear springs, but no luck? Anyone have it?
- Stoptech IS 250 Slotted Rotors 06-09
- Help
- Just Lowered: Thoughts?
- Caliper Piston
- Adjust parking brake
- just dropped on H&R, now spacers???
- Replacing stock brake pads and rotors
- H&R question
- Different Brands of Suspension
- Megan ez coilovers?
- Coils and Cornerweighting
- Front Brakes on IS250
- 2010 is250 awd
- Rotors and Brake Pads
- brake bleed question
- are they different in upgraded F-sport spring?
- Who installed your springs?
- Would F-Sport rear brace help?
- Shocks/struts for AWD?
- Just installed F sport springs and shocks, and now I have a clunking sound ???
- Mix and match springs?!
- what length extended studs do i need?
- Another alignment question.
- H&R springs on stock 17
- Question for those with Tein S-Tech Springs RWD and AWD
- Help with endlink/sway bars!
- Is250 brake pads replacement
- Fake Tein dealer
- Trying to back to stock suspension, need help
- Anyone ever cut 1 coil off of F sport springs?
- Reseting bushings
- DIY removal of springs?
- is factory alignment spec ok for a fsport springs drop?
- BC Coilover install on AWD question
- Drive lots miles....lower car?
- Thinking about Fsport springs but.........
- F-Sport springs question...
- help with some noises after drop
- BC racing coilover
- X Package - What Is It Exactly?
- BCR Coil or F-sport spring&shock?
- low dust pads at 25k miles?
- Suspension guru's, please chime in!
- EBC Redstuff pads
- Is this a good price for drop and fender pull?
- Same springs for IS250 and IS250 C?
- would ISF suspension fit on my 07 IS350?
- Help, need opinions on coilovers!!!
- Pics of your car with F-Sport springs/shocks please?
- Upgrade -- Sway Bar Bushings
- Question about camber
- IS250 to 350 Caliper Upgrade... Whats needed?
- why dont they make......
- New Function&Form and BCR COIL, which one better?
- what should i do
- Yet Another F-Sport Springs Question - "Clicking" Noise
- Ksport Or Megan??
- Springs
- Question about brakes
- Lowering springs question
- Recommended H&R springs dealers.
- DIY f-sport rear sway bar?
- How are your F-sport springs now?
- KSport Coilovers
- Brake Pads
- Lowering springs question from a noob
- F-sport spring rate?
- Cusco Parts released <----------------
- Kw v3
- Question on suspension/springs
- F-sport Springs Part Number PTR07-30090 suitable for IS250??
- f-sport suspension on 2011 is350 awd??
- Help needed - lower springs for IS220d
- Pulling my hair out, one by one.
- Going for an alignment with F-Springs... does my car qualify for "sport suspension?"
- Springs- does this qualify for, "installed by a dealer?"
- Megan Camber Kit Questions
- HELP...My vehicle pulls to right.
- Upgrade time- Brake system
- Isf bbk
- Question regarding replacing pads and rotors
- strut bar
- JIC FLT-RS Coilover VS HKS hipermax III
- what is our rotor min specs?
- Suspension seepage
- Brake creak when rolling at slow speeds - please help
- Cutting down on Body roll
- 2010 coilovers?
- Driver Front suspension squeaking?
- 2009 brake pad material
- Upper control arm part numbers?
- Adjustable shock options?
- Changing Coilover Height
- Worn Front Rotors
- Tanabe Sustec Pro FIVE coilovers kit
- Rear brakes
- fixing rear camber with megan arms?
- Help Me Decide on Springs! H&R or Swift Or Tanabe?
- Rear brake drag after brake job
- Will l Rub If I Get H&R Springs?
- Updated F-sport shocks and springs?
- f-sport BBK grinding noise
- Is this the correct low dust pads for is250? (pix)
- F-Sport Chassis brace
- Coilover install torque specs.
- Adjusting coilovers
- Rotors and pads
- new rotors and pads
- coilover question!!!! please help!!
- F-Sport Rear Sway
- Does anyone know the diameter?
- Fsport spings on AWD
- bagged or coilovers?
- looking to buy coilovers soon
- Can I get this low with BCRs?
- Air bag kit
- Tein cs coilovers
- Questions on install of F-sport BBK
- "softest" drop avaialble
- F-sport spring question
- OEM vs Aftermarket Performance Brake Pads?
- BCR ride quality?
- F-Sport Sway Bar Review for the Lexus IS250 RWD
- Tein SS Coils Installed
- Cross-Drilled and Slotted Rotors
- Dealership Dustless Brake Pad TSIB
- Megan AWD coilover
- Brakes click when changing direction
- Preload adjusting question
- H&R or Roadmagnets?
- coilover help
- Anyone on ISF springs with 18" wheels?
- which brake rotors to get??
- resurface oem rotors
- Stock Shock ?
- 2010 IS250 Brake Dust
- changing brake pads...
- ABS off blinking after installing F-Sport Rear sway bar and F-Sport Lowering springs.
- Adjustable sway links. Only from think design?
- Are BC coilovers shorter than stock?
- F-sport sway bar: does it matter if it's up-side-down?
- Need help with rear brakes...
- Brakes squeal with 1-2 people riding but, not 3?
- Bang for Buck coilovers
- Help - Anyone got is350 calipers laying around?
