View Full Version : Suspension and Brakes
Pages :
10]
13
14
15
16
17
18
19
20
- Are there significant differences between ride quality for coil/springs?
- Suspension shop in VA/MD/DC Area
- Has anyone tried the Quaife QDF26E in the IS350 yet?
- Rear brakes seizing
- Clunk while braking
- Anyone have any experience with OPParts rotors?
- Are pillow mounts included with BCR or Buddy Club coliovers?
- r1 Concept rotors/pads
- trust worthy? [EML performance rotors and pads]
- Anyone know how to remove lower control arm or shock bolt?
- Need some help on lowering spring install
- hypothetical brakes switch
- Rear Brake Problem
- Camber Kit questions
- Air runner struts but need help
- Figs toe links
- Help.. I destroyed my calipers!
- More low
- 2007 Sway Bars on a 2011 350
- F-Sport front inner tire wear
- Used springs, would you buy?
- End my debate [on S-tech vs H-techs] once and for all!
- is350 suspension help....
- Do I need a front camber kit?
- New Brakes needed for IS250 AWD
- 09 is250 caster bushings [replacement help needed]
- Fsport springs only vs Fsport springs + Fsport shocks
- megan camber kit
- Rear vs Fsport sway bars set
- WTB: Lexus stickers
- Anyone running: 18x8/35F 18x9/32R
- looking to upgrade to a set of IS350 brakes, is this the right parts?
- height adjustment and alignment
- Just got my F-Sport Sway Bars in the mail
- IS 350 AWD H&R Spring
- IS 250 Rotors
- Noob Questions about camber & offset.
- Guess what I found out today! - SEMA - SPC Camber Kit
- Megan lp coils good/bad???
- Quick question [Dropping on H&R springs]
- Will RX brake calipers work on ISx50??
- BC Racing Coilover Problem
- Looking to switch from springs to coilovers!
- Upgrading of rear brake
- what kind of coils should i get?
- Any advice in the proper way to break-in new Rotor's
- When Replacing Brake pads did you replace shims?
- coilovers
- New to lowering...Need some advice or help!
- should i spend the money on the fsport struts???
- Squealing sound when braking slowly
- Brake drain and pad replacement
- Will they fit?
- tein H spring
- Very Satisfied With Megan LP Coilovers
- Brake Dust is normal , says my dealer !!!!
- Lowering
- How to increase steering feel and driver involvement?
- how much fluid is needed for a brake flush?
- I need advise on alignment for my IS.
- Dealer told me the brake pad is shot
- BCR 8k/6k Stiffness?? SLAMMED/FLUSH GUYS HELP PLEASE!
- Spring/Coilovers - General info please
- Which coilovers are good for improving handling?
- Caliper Cover
- Front Brake Pad TSIB For Squeak
- Quick Caliper Painting Question
- Just lowered 07 IS 250 AWD
- Maxing out Tein CST coils.. bad?
- Where did u get your SPRINGS?
- Suspension Gurus...need your help with Tire and Wheels on IS250
- Rotors
- IS350 Break Rotor and Pad Upgrade for Track Days
- 2 Megan EZ coilover questions
- Eibach Lowering Springs
- Road Magnet Springs
- Rear Pads Only Installed - Break-in?
- Lowest AWD>?
- DIY for front struts???
- Form Function Coilovers ???
- Dropping your car with springs?
- Megan coils.... LP vs Easy
- F sport front BBK caliper dimensions
- NOOB QUESTION ABOUT F-Sport SwaY BARS
- Difference between BC Racing vs Tein Comfor Sport
- is350 awd brakes on is250 awd?
- break in brakes (pad bedding question)
- Coilover maxed out
- Weird tire wear bc of suspension??
- need help lowering is250
- is250 lowering springs install help plz
- Loud Screeching from aftermarket brake pads?
- Advice Regarding Coilover Install
- rotors
- Which CL vendors have stoptech x-drilled rotors for IS350?
- Fellow CL members: Sway bar
- Anyone's ride improved with lowering springs?
- just got some [lowering springs]
- IS350 brake calipers information
- BC Racing Coils Slammed or Flush w/ Spacers?
- Decided to "upgrade" rotors,need help.
- ordered brakes from sewell.
- Do You Have To Be Slammed When You Have Coils?
- BC Racing Coils problem
- sispension help please!!!!
- When will coilovers need rebuilt?
- Springs? Anything more comfortable than H-techs?
- How low with BCR?
- Squeaking noise
- Where to get best price for stock brake pads?
- Can someone label each Megan arm
- specs for is250 rear brakes
- D2 or k-sport suspension
- Squeaky suspension and groaning/grinding brakes
- Springs vs Coils
- painting is350 calipers question
- Help check brakes
- Paint shop for powdercoating brakes?
- Do coils for 3rd gen GS suspension fit on 2g IS?
- Bc racing vs Megan racing coilovers
- Need New Brakes, Advice Please
- Daily Driver and Megan Coils
- Thought's on the Wobbling/Vibration on AWD's.
- Clanking noises after lowering on Road Magnets IS250awd
- Metal noises when driving on the speed ups
- DIY on GTSPEC Front 4 Point Lower Tie Brace for Lexus IS250/IS350/ISF
- Front camber kit!!!
- Maximum Ride Height for BC Racing Coils
- Need help in finding rotors that don't do what's in this pic
- OEM Brake Rotor Longevity
- Low dust front brake pads standard on a '10?
- Just had F sport Shock/Spring Installed -- CLUNKING NOISE
- Heavy Steering (again lol)
- lowering springs...
- wheel fitment question
- Upgrade for AWD IS250?
- Brake Problem?
- spc front/megan rear
- Deco Magnetic Caster Camber Gauge...anyone ever use one?
- Wheel clearance. 19's
- lowered on OEM wheels and rubbing
- Brake pads
- F-sport springs on Sewell
- Getting Bc coilovers
- Eibach Springs: Different for 250/350? (Urgent)
- Lowering my IS2 on 20's.....what mods are needed??
- Car Handling Mods
- Question: IS-F Sway Bars
- Lowered IS350 AWD Anyone?
- Rear Axle Help
- What kind of rotors are you using? Anyone try the ebay ones?
- Front vs rear sway bar for IS250 AWD? Recommended anyone in Chicago to help install?
- Springs and mileage
- What to do?
- 2011 F-Sport Brake Rotor Size?
- Fender pulling
- 30k miles, time to replace brake, what kind should i go with.
- Is it ok to replace just the front tires ?
- How do i know if the shop did alignment after install lower spring
- F-sport Spring only
- Front passenger thump
- Megan coilover question
- Is250 awd on 20's
- F-Sport Suspension - Any long term assessments?
- camber kit- do i need it?
- heigh control sensors (AFS light) info with diagrams
- Quick noob question about adjusting ride height Megan Ez cs
- cusco harness bar?
- My parking brake doesn't work!
- Yellow Speed Coilovers
- Question bout Spacer
- I really need help with my car
- steering wheel doesn't return to center position?
- Someone please post the link
- Will IS250 struts work in an IS350?
- Megan Ez Coilovers IS 350 pictures of your drop?
- Megan Ez Coilovers, Some questions in general
- 250 dollars to install Fsport front/rear sway bars and my Ez Megan Coilovers
- bc coilover extender
- Eibach Sportlines
- rear struts blown
- My alignment specs
- front Brakes and Rotors
- f-sport springs question.
- need help with camber in the front
- Alignment specs after F Sport spring installation
- NEW Megan Racing EZ Coilovers, 620 dollars shipped.
- At what mileage is a brake job recommended
- Just bought F Sport sway bar set front+back for 250 dollars (Is that a steal?)
- Please Help a NOOB!!!
- Anyone dry the Hotchkis Lowering Springs?
- please help me if you can
- Clunking noise during a slow turn?
- What kind (brand) of Front and rear brake pads for IS250?
- new brake rotors questions
- End Link replacement
- F Sport springs are finally installed!
- IS350 BCRacing Coilovers Review
- GI: RB BBK for 3GS and 2IS, stock wheel clearance
- What do you guys think about camber kits?
- Get quote for 550 for just install lower spring
- Rotors worn thin- recommendations for replacement?
- BCR coilovers
- F sport springs sluggish in corners
- Need some help picking out brakes
- Quick Alignment Question
- BC Racing Coilover Stiffness
- LS460 brakes on IS250?
- Need Help with Alignment
- Thinking about getting after market coilovers or lowering springs
- Question for 2011 F-Sports that are lowered!
- AWD Wobble/Vibration Solution - Testers Needed
- Should I get the F Sport springs?
- Black IS250 - Tein S-Techs
- F Sport Suspension
- F-Sport spring insulator/rubber question
- BC Racing DIY?
- Do i really need to buy Alignment Kit for H&R lower spring?
- Need Help with IS-F BBK install
- best place to buy airrunner kit?
- where can i buy rubber silence for the spring
- F-Sport Complete Suspension: EBAY
- Cut my Fender on IS350
- will my tires rub?
- New BCRS/MEGAN/SPC Set up
- SAI spec way off?
- Cheapest place to install f-sport springs/shocks?
- gs350 awd brake conversion?
- Suspension myths and misconceptions.
- Shock absorbers?
- What's a good alignment spec for DD?
- Anyone using StopTech pads?
- Megan camber kit installed
- springs?
- What Suspension drops the is350 lowest?
- Looking for Wheel Spacer Recommendation
- Coilover Height Adjustment?
- Powder coating brake calipers - How to disassemble??
- Rear Brake Pads (EBC vs stock)
- 07 IS 350 with C1203 Code, Help!
- How low can I go?
- Scrubbing with just 19"?
- Lexus refused to change my brakes...
- About to purchase coilovers
- Alignment
- ABS/VSC/AFC lights on after Stance GR+ Install
- Help camber issue!
- Eibach Pro Kit installed - before and after pics
- Tire size...
- Lowering and Camber issues
