View Full Version : Hybrid Technology
- Dash MPG Reporting Accuracy
- Buying a RX400h - What is considered high miles?
- 2007 RX 400h lost power, even with new IPM
- 2007 Lexus Rx 400H - Buying advice - Help please
- Purchase an RX400h for towing?
- radiator
- Replaced radiator, not DIY
- How wide spread is the faulty inverter issue?
- 2006 Lexus 400h Power issues
- Fair Price for a 07 RX400h?
- 2007 Lexus RX 400h - premium or regular gas?
- 2007 400h repair price estimate
- Changing tire size?
- B is for Baffled
- Write Off RX 350 just Bought a 400H
- Looking to buy a 06' RX400h
- Lexus RX 400h, 2007
- R400h legroom - possible to add more?
- Older ('06 or so) RX400h dirt cheap - why?
- Short battery life and hybrid braking system?
- 2008 RX400h Crack type sound when brake pedal depressed
- Battery Dies Too Quickly
- Timing Belt Kit Advice
- Advise please (2008 400h)
- Too much speed variation when in cruise control
- normal behavior when hybrid battery low?
- RX 400h key replacement
- Check Hybrid System error code
- outside temperature gauge not working after car wash?
- Lexus Extra Care Extended Warranty
- RX450H 2010 Noise from Front Right
- windsheild washer reservoir leak?
- 2008 rx400h front license plate bracket
- Alternatives to LEXUS Dealership Service in the DMV
- C1313 code but no light
- Rear Door opener switch melted
- Yellow arrows on when standing at red light
- Toyota Class Action Settlement (Canada)-Cash payment of $62.50 or free BOS installa
- MYSTERY GAS LEAK or HAVE I SOLVED IT
- How to get IPM recall repairs done on my 2008 RX400H in Toronto Canada Area
- RX400h ML- Right side dash speaker problem?
- Warranty Services on 2008 RX400H
- cel just came on
- help! just had invertor recall done 2 weeks ago, car wouldn't start
- Rattle on engine start
- Looking at buying
- can someone please check you head lights and see if its normal
- 2011 RX350 19" OEM Wheels on 2006 RX400H
- Buying an RX 400h. Please advise
- 2007 400h, 46,800, leaking water pump
- Help me identify this fluid leak
- Water pump
- Engine problems
- Warranty- Headlight Housing Moisture
- any1 had any problem after IPM recall fixed
- extended warranty
- washer fluid switch
- Low mpg
- Power Gauge Not Working - Ideas?
- 2006 Lexus 400h generator MG1 issues
- Keep '08 RX400h or Upgrade?
- Have deposit on 2006 400H - What do I need to know?
- Test driving 06-07 rx400h and some have more get up than others...
- Leaking radiator
- EV switch mod
- lock key lost
- 400h unusual noise from rear end
- air conditioning
- 87 octane for hybrid?
- buying 2007 400h
- Long term maintenance gameplan
- Tires for RX400h
- -Recalls?
- Throttle body cleaning DIY for 400h?
- 2008 RX400h Water pump gone
- RX400h 43K with NAV for $15.5K?
- 2006 RX400h CV axle question
- Locking passenger windows
- Should I buy it ? 2006 rx400h
- Emergency help Needed for replacing totaled 2006 400h
- Lexus Recall
- About to buy a Lexus 400h
- RX 400h 2008 Rear Seat Concern
- Battery life of RX 400h's
- Key shell
- OEM 18" wheel specs
- AM Radio Problem
- It's been a long hot summer with no new inverter complaints...
- Off roading upcoming setup
- Rear view camera
- rooftop carriers
- Nitro instead of air
- In a flap!
- ALARM CALL 0300 Hrs
- Anyone used Cataclean
- Rattler Taming
- Beige Plastic Trim Repair
- Nav is in different load version
- Shadow Chrome Refurbs
- Aircon
- Hybrid Battery Display
- Cleaning interior cloth coatings
- What octane fuel do you use?
- Spec for 400h SE Nav
- Plastic plug fastening missing
- Door seal repairs
- Fog ligths as drls rx400h
- Car wont go into cruise and noise/vibration
- Bluetooth Audio Stream
- Battery died and now no navigation
- In a whirlwind...
- RX400h Brake issue
- Buying a 2007 RX400h: Has accident report and 98K miles; need advice
- Rx400h se nav
- Spark plug change on rx400h
- - Happy with the MPG's??
- Tail Gate / Rear Hatch Won't open
- DLR LED for 2008 rx400h
- New RX400h Owner
- How to drop the dome light housing
- HI! just bought a 2008 rx400h
- 2008 400h - short drives enough to charge?
- Coolant replacement
- Dealer Wants $2200 for Brake Actuator
- 2006 RX400h Window Visor
- 2008 rx400h key code?
- mileage range
- Just put a deposit down on an '06 400H
- Is it normal for ICE to be almost always running?
- 90,000 miles service: Lexus vs Toyota Dealership
- Summer tire options and opinions - advice needed
- Navigation .. please Help
- Do chrome wheels on 2008 400h work?
- P3221 Code
- ATF oil replacement RX400h
- Done , Install Toyota Harrier Folding Mirror On My Rx400h 2007
- 420 miles on a tank! Suspension click.
- Gas motor almost always running - normal?
- Electric motor still pulling with brake pedal pressed
- Going from 2004 Acura TSX to a 2007 Lexus RX400H
- just bought a 2007 400h
- Buying a 2006 Rx400h, is this a good price? Pitfalls
- Is this a good deal?
- can i change manual folding mirror to auto folding - rx400h 2007 -
- Worth to trade RX400h to RX450h??
- radiator leak 2006 400h
- Low miles 2006 or high miles 2008
- RX450H production coming to Cambridge, Ontario
- low volume whistle/whine in 2006 Rx 400H
- Help required in buying used Lexus 400h
- Would you buy a 400h without a warranty?
- 2006 400h Phone book issues
- Help with voice activation
- Interestest in buying one but road conditions make me think otherwise
- Drive home 2008 rx400h :)
- Rx 400h - Ever see this before?
- Thinking about a high-mileage '06 400h AWD
- Wheels/Tires Weight
- RX 400h snow tire size
- Spare keys is not starting the engine
- 2006 RX 400h AWD
- Extended Warranties?
- Finally, I got one...
- Removed amplifier, Rx400h wont start
- Mileage on long trip
- 3 months without using a 400h: what to do?
- Condensation in Headlight
- Follow-up recall to original IPM recall
- Qualifying for CA 150k hybrid warranty?
- Rx400h stationary with exhaust under water
- Just towed a trailer 3300 miles with our 400h
- New (to me) 2008 RX 400h
- Help with a Rim/Tire issue
- My new ride - 2007 RX400h - lots of pics
- Rx400h hum above 35 mph?
- Getting 19.5MPG on my rx400h :( please help
- 2007 RX400h potential new owner
- 2008 RX400h potential new owner
- Weatherstripping around hatch loose
- Electric Steering???
- Just picked up 2006 Lexus RX400h!!
- Lower Oil Pan
- Rx400h
- Can I go Staggered ?
- Annoying "safety" features
- Rear passenger window shattered
- Can software be updated on 2006 RX400H with Gen 5 look?
- A Quieter RX400h?
- HELP! - won't start
- D2S Xenon bulb replacement on RX400h -> How to?
- My mpg trip
- rx400h 2008 sound from right rear
- Just put on 255/55/18s on Stock Rims/Suspension
- 06 400h "Check VSC", "Check Hybrid" and P3221 Code...?
- I Don't think My Hybrid works Properly but i get good MPG
- Lexus Service vs Toyota vs Jiffy Lube
- Trailer Hitch wiring part number?
- 60k Service
- ML stereo versus Base
- 2008 RX400h
- "Chain loose" noise while climbing hill ? Electric motor problem?
- Rx400h - suspension lowered - need help
- Rattling noise on cold start...anyone?
- California RX400h warranty?
- AC leak?
- Hearing some cracking sound from rear
- bluetooth problem
- Considering a 2007 RX400h - Opinions Appreciated!
- bought 400H and have a few questions
- how to keep engine running?
- HELP! To keep or not to keep....
- diagnostic tool for Hybrid?
- iPhone 4S and 2008 400h
- To buy or not to buy, that is my question . . .
- inverter vin # question
- Looking to buy a RX400H - What to look for
- Can the ride be (or made) the same as the LS 430?
- Phone book
- Possibly need THIRD transaxle on 2006 RX400h
- They really are fair-weather friends!
- replacing 12v battery
- what to pay for 2006 400h with 47K miles
- Can't talk them into changing the transmission fluid!
- Another 12v Battery Thread
- New to us 2008 RX400h - Need Help ASAP
- Tires and tire pressure
- Considering an 08 RX400h, need help
- Tranny fluid change on 2006 RX400h? Service advisor said not needed??
- Anybody else pull a trailer with a hybrid?
- ISC resetting - Been to the circus and I seen the elephant; can't fool me no more
- RX 400h doesn't start after sitting one week
- Hybrid braking
- Bad LED tail lights
- Another bad 12v battery
- 12V battery voltage in RX400h
- Advice for replacing headliner
- 08 400h Basic Warranty expiring soon, what should I do?
- Fluid Intervals
- 12v battery strangeness
- RX 400h 2006 with xm tuner installed - play ipod?
- Anyone else's gas mileage suffering as a result of winter?
- Got the Check Hybrid error - Transaxle Pump failure?
- 2006 RX400h- white powder blowing EVERYWHERE!
- 400h Hybrid Battery
- Parada Spec-X in RX400h
- What is this Button -RX400H
- weird noises from brake system
- ISC Learning Procedure Applies to All Years
- Service Tips for Rear Caliper Slide Pins
- Subtle brake problem.
