View Full Version : Hybrid Technology
- help with warning light
- Dash Lights & Dead Caliper after replacing pads
- Inverter pump replacement 2006 HiHy
- Modern head unit addition without display sacrifice
- PLEASE STICKY: Lexus RX 400H Registry
- Trickle Charger on 12 volt?
- preaching to the choir?
- lexus RX 400 h 2006 èproblem at the starting
- Anyone else have rattle when accelerating?
- Shifting out of D
- 2006 rx400h service manual
- RX400h EV Mode Button / Switch?
- Replace Main Hybrid Wiring Harness
- Need help! Battery replacement?
- 2006 RX400h running question
- Gear shifter is hard to move
- Can not move the vehicle
- Check Engine light: P1420 Evaporative Canister Small Leak
- lower control arm info needed
- Suspension Work
- RX400h - Hybrid System can not start and no message.
- RX 400H vs RX 300
- Clatter when car is in gear with foot on brake?
- Changing Lubrication Oil from 5W-40 to 0W-20.
- RX400h - Check Hybrid System, Check VSC System Warning.
- Battery Degradation- Traction Battery
- hesitation on accel 400h hybrid
- why buy a used 400
- On RX400h 2008. 150100
- cruise control not keeping set speed
- Lexus Rx 400h 2006
- Need Help With Weird Light
- AWD Hybrid
- Clicking noise- car won't start or respond to key fob
- RX400h 2007 awd
- 2008/58 400h a/c problem
- What to watch out for in used RX400H
- How to monitor hybrid battery with Torque app
- Wish to replace the Multi Display without Navigation TO with Navigation.
- Water pump/Timing Belt Change Time???
- Looking to buy RX 400h with 200k miles..
- hybred battery failing
- Center consol not working
- 2006 RX400h - no sound, AMP OK - checked via diagnosis tool
- 2007 Lexus RX400H - Struts replacement recommendations
- Special Service Campaign (SSC) FLD - Certain 2007 Model Year RX400h Vehicles - Engine
- 2007 RX 400h Serpentine belt
- Gs 450
- RX 400h whirring noise
- Transmission vs differential fluid change for 2010 HiHy
- 2006 400h shifter is stiff and not engaging correctly
- Bad coil really confuses hybrid system
- Is Aisin ATF-OWS compatible with Toyota ATF -WS
- heater blows cool air
- New or Original Coolant during Water Pump Service
- okay, i feel like an old guy asking...
- MPG suddenly low, rear engine not working?
- gearbox problem in toyota highlander hybrid mod 2006year
- Has anyone seen this?Another tranny post-sort of.
- 2006 RX400H Purple Battery
- 2006 RX400H problem please help
- No Water Pump Listed On RX400h 90K Service
- tranny innards
- Rear Splash Shield fasteners
- Cold weather starting problems
- Hi guys, has anyone had a problem with a vibration on the gas pedal fixed?Rx400h
- 2008 with 150k
- 2008 with 150k
- Common issues on 2007 RX400H
- Hard to shift into drive.
- 07 RX 400h ABS sysstem
- Check Hybrid System light on
- 2006 lexus rx400h want start after sitting few months
- 2008 RX400h No heat when run on battery
- small rear end collision, P0A0D
- Should I buy? Please offer some feedback
- Rear Hatch power opening
- Hybrid Battery
- Cost of replacement hybrid battery
- 2006 Lexus RX400 Hybrid Speedometer needle stop working
- What the @#$%&*. please forgive me.
- What should I know before buying a 400h?
- New owner of 2008 rx400h
- 2013 RX 450h front brakes
- Heat issue with the Hybrid when idle
- New Lexus Owner Some Questions
- Is my gas engine charging my hybrid battery?
- what does yours look like?
- 2007 Lexus RX400H Check Hybrid System Error
- 2006 Lexus 400h HID / AFS Aftermarket Headlights?
- Auxiliary belt?
- Is it normal for the start of the gas engine to cause a "bang and shake" when it star
- Junk in the car and battery failure
- VCS 51 CODE 58 - help!
- Mildly Interesting Dash Story
- Akebono Brake Pads
- When to put in new struts
- "Change Battery"
- has anyone noticed?
- Hybrid battery level
- Rx400H Transmission Oil Pump - Error P2603
- 2008 400rx h battery warranty
- Code $7E8 and $7E9 read from scanner.
- Xtra curtains in rear?
- 2008 rx400h battery costs
- engine covers
- Home Link Remote
- 12 Volt battery dying?? 2008RX400h
- reset the Idle Speed Control
- Dash matts-for RX400h
- Surprise when refueling
- Lexus RX400h - smoke from hood. What could be the issue?
- Weird message in car wash
- My recent Yosemite trip
- RX400H Yr 2008 - Center Storage Console "Close" Button won't pop back up
- Verizon Samsung Note4 disconnecting calls.
- Lexus RX400h / RX330 Ingnition lock Cylindar repair.....
- Is it worth buying a 2006 Lexus RX 400H at 104,677 miles for $10,000?
- Lexus RX400h petrol engine not stop when it should be
- RX400 2006 - brake issues
- Check Hybrid system on my RX450h
- lexus power steering control module rx 400h
- Automatic sunroof opener not working
- Clicking sound when backing
- Towing an rx400h on a dolly
- brake fluid
- lexus ct 200h owner
- FUel pump
- BATTERY IN 2007 LEXUS RX400h
- Oil Change Question
- beeps when AUTO Button is pushed (RX400H)
- Possible Issues with Orange HV Cables
- Help with hybrid
- Big Jolt of gas engine in cold start
- 2006 RX 400h "Hybrid Battery Service"
- No-start issue not solved by jump start
- Jump starting RX400H
- What did you do to your 400h today?
- 2006 Lexus RX400h w/ 105K miles - trade in vs potential costly repairs
- Do I need to change my Battery?
- Please Identify Hose Near Air Filter
- Any way to tell how many miles on electric motor vs combustion engine
- Lexus RX 450h hybrid battery warranty is 8 not 10 years in California
- Rx400 H trans fluid change quantity question
- Possible to update nav map to 2016?
- Cargo net install - did I do it right?
- Where is radiator cap?
- Which tool do I need to open the battery cover?
- What's your tire pressure?
- 2008 RX400h Invertor coolant boiling
- heating issues.
- Weird noise from engine?
- Squaking whining sound after cold start
- What does abs feel/sound like in rx400h?
- Oil Change Info
- 2006 RX400h Starting problems
- thinking about 08 400h ?
- Finally I removed headlight and killed condensation.
- Proud new owner of 2007 RX400h
- Transmission cooler oil pump -on at all times?
- Regen brakes don't work anymore!
- 12V Auxiliary died and several warnng msg got
- Coolant Monitoring System
- RX400h Front License Plate Mount
- Hybrid System/CVT Fluid
- Water leak led to "check hybrid system"
- Question about Bluetooth Rx 400h
- why RX400H models are inferior in mileage
- ABS Actuator Warranty Extension!!
- Need Help with Brake Bleeding from FSM.
- Lexus RX400h inverter - broken (need some parts for it)
- 07 rx 400H Which radiator
- Running AC overnight in a RX400h
- RX400h LED Lowbeams.
- Buying a RX400h
- Rough start (shake) from engine
- owner of 2008 RX400H needs your help
- Radiator Failure
- Exhaust smell in RX 400h with heater use
- New Member
- Warning lights rx400h
- RX Headlight Housings replaced on extended warranty
- New Hybrid Battery
- Advice for replacing RX 400H inverter
- Check VSC and all warning lights on
- Noise while acceleration and turning
- 2008 400h replace TPMS and valves on tire change?
- 2008 RX400h Cargo Cover Doesn't Fit Headrest Posts
- Looking to Purchase 2007 400h
- Tech refuses to use AISIN timing belt and waterpump kit
- Help! Radiator Leak
- Service Question
- ABS Actuator Replacement...
- Dreaded Check Hybrid System Warning
- Can someone take a pic or explain the OEM battery tie down?
- Intermittant Ready lamp
- In need of a new 12V battery
- "obscure" OEM 400h wheel spec question....
- Shade Tree Mechanic
- Worth buying a 06?
- RXh Failed Calif Smog Check
- seat repair
- Coolant leak
- 2007 RX400h failed CA emissions
- Buying my first Lexus and can't choose between rx400h and 450h
- Automatic adapter causing major drive computer crash
- RX400h - Error C1203, VSC & ABS lights on after replacing battery
- RX400h - no power brakes or steering and errors galore!
- Is there a way to disable the electric motor?
- Miles on your RX400h?
- RX400h "MENU" KEY PROBLEM
- Park Assist - No more Beeps!
- MyLexus.com join site issue
- 2008 Lexus RX 400h
- Two questions about Rx400h fluids
- Where is tranny fluid fill location on 2008 Rx400h?
- Water in Traction Battery Compartment
- Leaving 400h in garage
- Surging / hesitation at 40mph
- Why I wouldn't tow with a hybrid.
- Issues towing boat up boat ramp.
- Question on 7 pin connector for towing small RV on 2007 RX400h
- Heater Blows Cold, Trying to Remove Glove Box
- service plug
- RX 400h - All Ingnition Coil Code P 0351- P0356
- Best tires I have had on the car.
- Revs Staying High
- Trouble Codes $7EA & $8EA.
- Replace OEM camera with aftermarket...
- 20% MPG Drop After Bridgestone Alenza
- Buying Used 400h
- Water in hybrid battery compartment via shark fin antennae
- Car Wouldn't Start This Morning
- 2006 RX 400h - Timing Belt replacement
- What to do BEFORE an IPM recall
- 2008 400H - how long to keep?
- Power Meter
- What do you guys think?
- 2007 rx 400 h
- Corroded Under Body Spare Tire Carrier
- Slight Upgrade from 1st gen....one question
- Removal of Front Seat Rear Panel???
- Test drove a 2006 RX 400h
- adaptive headlights standard?
- Which one to get ? 2006 Vs 2008 -confused about selection...
- Checklist for buying a used RX 400h
- RX400h AWD handling in snow ramp?
- Dash MPG Reporting Accuracy
