View Full Version : Performance
- Upgraded Exhaust???
- has anyone swapped the stock throttle body
- Greddy GS430 install instruction (Japanese)
- GS350 header test car
- help DIY transmission fluid flush
- 1998 gs400 swap to 2jzgte info?
- can i retrofit my 01 430 throttle to a cable?
- My GS400 running weak / sluggish
- Blitz Twin Compressor kit Soarer UZZ40 3UZ-FE
- 2000 GS 300 - Check Engine Light
- Help with transmission plug
- gs300 intake
- converting to manual
- Making custom exhaust for the ride
- What turbochargers do you use?
- looking for Info on if i should do a 2jz-gte swap or SRT turbo kit info
- OMG Replace your fuel filters at 100K!!!
- What Aftermarket Intake Should I Get?
- Remove resonators or install x-pipe?
- Sickest exhaust?
- Question about stock resonators
- OBX Headers, Downpipe, HKS Exhaust Installed
- 2jz-gte exhaust for gs300
- Heating non heated seats
- ? for Aristo Swapped w/ Single Turbo Owners
- Who here has done dyno tune after S&S header install?
- Gearing question with Supra 3.76 LSD
- Where can I get an upgraded torque converter?
- All Aluminum Radiator for the GS430
- Anyone with Cat Converter issues answer me this...
- slipping transmission?
- Inline transmission filter kit
- I have a lost remote transmitter but i have the cut key itself!!!! What do i do
- What Exhaust to buy
- Alternator connector broken
- Arthur Exchange Wheels "NEED HELP PLEASE"
- 2000 Lexus GS400 Supercharged...what spark plugs should i use?
- Exhaust CatBack Sound clip!
- Junction Produce Type III exhaust?!?!
- Dyno Testing - Miami
- lack of acceleration on my 98 gs4
- 1UZ Twin Turbo V160 6 spd is done!!!
- Misfire under load when hot
- Transmission Upgrades
- knock sensor connector.....HELP !!!
- New To The Forums
- Weapon R intake for GS400
- Anyone had good experience with a Haltech F10X?
- GS300 Evap Emissions Work
- Is the Apexi AFC Neo right for my GS?
- very poor gas mileage HELP
- Modified IS300 K&N Intake into GS300?
- SRT Supercharger install directions??
- What does this dash light mean?
- Help car wont start please
- GS 400 1998 O2 sensor connector wires melted??? TSB
- Hard lines on GS400?
- What OEM superchargers are best to fit on a GS?
- RMM Exhaust is LLOOONNNGGG
- GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light
- Need help! changed spark plugs now this...
- At the Shop....and this pulls in.....
- Is it possible to do with this exhaust?
- Top Speed axle back?
- Got a little concern here guys, Need some help/input...
- Turbo Kits plz
- Car Overheating (fan relay switch)
- 1.5jz?
- still cant run my k&n!!
- x2 Toyota Aristo Turbo's (JDM spec) for sale locally
- RMM Supercharger... Who has the kit?
- intake found for $50 thoughts, also gs300 intake fit gs400?
- Help with new differential!
- Check Engine Light On - First Place to Look?
- 5-15-10 Dyno results
- tundra headers on the gs400?
- Change oil n now engine makes gurglin sound
- Mod chip / Cold Air intake / HID questions
- Adjustability of VSC system?
- Sprintbooster..anyone using this?
- Header and torque converter install - advice and install
- Info: Leading Cause of Transmission Failure at Elevated Power Levels.
- Where can i find a supercharger?
- VSC lights and Check engine lights
- VSC light and engine light on
- Headers
- iragii alternator
- Srt 2.0
- srt intake replacement filter
- What does the GS300 sound like with no mufflers?
- Traction Control Problems
- Acceleration Problems... PLEASE HELP!
- LSD to GS430-02
- Loud noise and vibration
- My NA-T project is almost complete
- GS300 Misfiring
- LS430 supercharger kit on GS430/400
- Mid pipe muffler
- Need To Do a Coolant Flush
- NEED HELP, finding quad exhaust rear lip for 2gs
- Installed resonated Magnaflow resonated tips today.
- Question CAR WON'T START
- Custom exhaust question for GS300, NA now but will be 2JZ-GTE'd later
- Does this seem right?
- Here's what I got? (for a swap)
- 1999 Lexus GS400 - Intermittent starting issue
- mishimoto thermostat
- Intake manifold question
- Lets talk about transmission behavior when the car is cold
- !!!Engine Thocking Need Advice (Gs430) !!!
- what size bolts/nuts for S&S headers?
- GTE vs LS1
- deleted resonator
- APEXi NEO Vs. APEXi SAFC2
- K&N GS400 intake question
- even auto and open dif, they do drift... video!
- Megan Downpipe
- how to achieve firmer shifting?
- NASCAR exhaust fabricator
- Anyone want to trade borla/l-tuned for an evo2 (2gs)
- Car chokes and feels like its about to shut down
- AEM/FIC which one for a GS 400
- Dyno 4/15/10
- Engine Light on and Diagnosis
- Headers for GS300?
- best drop
- Stock Intake + SRT Chip?
- Exhaust pipes upgrade >sound clip<
- looking for pictures of a black 2gs turbo
- O2 sensor replacement
- Diff options for GS400
- Exhaust Tips
- Hks hi-power exhaust.....
- Help with 2j swap
- 04 GS300 Turbo Install Problems - Need Advise If Anyone Can Help
- L-Tuned Exhaust, how do you feel about it??
- Turbo Timer + 2GS
- HKS Question
- Exhaust pipes?
- Bad cat = screwed! ;(...but their is a silver lining in this!
- 99 GS400 0-60=5.7 1/4 mile 14.2@101 gtech
- Head gasket question...................
- Tranny
- FI GS4XX - Performance results question; a true mystery
- Can I swap a GS400 or 430 transmission into my GS300?
- Will I loose my VSC if I.....
- Supercharging Destroys Cats?
- Cat back exhaust M2 Performancce
- 01 GS300 Turbo
- Newb question. PWR button?
- What's the best diff fluid for 3.76LSD? Read through many old threads!
- Apexi ws2 VS tanabe medalion touring
- Will these exhaust components add to performance?
- wood steering wheel tan and exhaust muffler ...
- Exhaust help!
- blown motor
- What to Expect
- My build has began!!!
- Anyone ever use header wrap on the spark plug wires ?
- What Size FMIC are you running????
- VVTi GURUS/ Jefftsai and the Others
- Engine block grounds for Big 3 on GS400
- car wont stay on after timing belt
- Precision Industries Torque Converter failure
- Best way to improve acceleration on my 04 Gs 300
- Apexi Neo
- Dyno sheet from my 98 GS400
- GruppeM Ram Air
- Engine Swap or Turbo Add-On
- GS300-GS400 MAF mount
- Super Charger Turbo for GS300
- Running Aristo ECU on US GS300
- which rear end is better gs300 or gs400
- Transmission Info, please verify.
- Transmission failure?
- Sticking gearbox - transmission failure?
- A couple of new videos of my V160 GS300
- TRD parts for 99 GS400
- SRT intake vs. K&N
- So I got my Car Dyno'd yesterday and...
- Need advice with custom exhaust bank1 and bank2
- Custom exhaust Q's
- problem starting up...help
- CL Member Transmission Help!!
- Exhaust Bolt Size
- IS-F rear exhaust on 2nd GEN
- Rear gear swap to lower numerical rear end?
- Any Ideas on installation?
- Best source for 3.76 LSD
- Transmission problem, or is it something else?
- JP style exhaust
- Stock ECU swap worth it? '04 --> '98
- to buy or not to buy (intake)
- Had some problems this morning
- w58 swap from MKIII?
- Transmission shifts very hard
- Second Generation GS Major Repairs List
- gs300 98 Need help please....
- Tune-up to 2001 GS300 and now CEL is on
- Any way to disable auto shift in manual mode?
- Many Questions
- another "i cant move my shifter" thread.
- 0-60 Times?
- question about transmission
- HELP!! Ready to set my gs430 on fire! pics. car problems.
- Mother of all P0171 threads
- SRT intake
- APEXI WS2 vs. HKS HI-POWER vs. BLITZ NUR????
- No more S&S Headers
- What is this dash light?
- How important is 90K service on GS430
- 99 GS300 SRT Intake - hose question?
- Weapon R Dragon short Ram INTAKE??????
- is it worth saving my injectors
- Anyone's SRT intake rusting?
- VVTI swap/ Possible emissions passing?
- magnet gas saving fuel or turbo intake save gas
- areomotive fpr and return line on my gs400
- Apexi drop in air filter?
- noob here, in need of turbo help
- New headlights . . .
- Apexi ws2 exhaust??
- exhaust question?
- gs300, 2jz-gte important swap details and questions
- New custom exhaust
- rmm supercharger kit
- Single turbo 400
- P1346/P1349 (Have read other threads) Help!
- 640rwhp at 19psi, Th400 w/ unlocked converter
- Intake Install Require New ECU??
- GS300 Aluminum radiator
- Polyurethane exhaust hangers
- Twin Turbo GS Speaks, Again.
- New to me GS400
- AEM EMS question
- just a cam swap?
- engine bay dimensions
- HELPPP! Engine check light flashing!
- Need a favor from the 2gen group: Fuel Injectors for GS430
- 1UZ and 2UZ engine swap info
- Twin turbo lexus for sale
- Ect pwr?
- What Brand is the Best Cold Air Intake for the GS??
- Gaining lower end power/torque
- converting auto to 5-speed
- thinkin about getting nitrous on my gs400
- borla exhaust question?
- Check out this ebay turbo kit...
- TT Drive Shaft Problem
- Exhaust question?
