View Full Version : Performance
- HELP. Fi/c installed, will not rev above 3500rpm
- Differential Brace?
- Fujitsobo exhaust for Gs300
- Exhaust experts! Need your help ;)
- Aristo exhaust same as GS400?
- F-Sport exhaust
- F-Sport exhaust
- HELP!!! Performance ECU upgrade??
- Aristo VVTi question
- 02 sensor for 2000 gs300?
- greddy e-manage
- Transmission whine in 1st and 2nd...
- jdm aristo vsc- traction comp. where does it go
- Soon-to-be GS400 owner questions!
- Solution for the speedo problem for you swap'ers?
- Wtf
- New exhaust installed...
- R154 Tranny
- 98 GS400. Just installed PPE headers and 2.5" cat back exhaust.
- jdm engine codes
- anyone bypass fuel pump control ecu?
- Tranny fluid flush or drain fill plz help
- Tapping Oil Pan on GS400
- I need your expert opinions
- rear end gear change GS 430 2nd gen
- Quote for 2jzgte swap and manual conversion
- Used Transmission Questions
- OK...i know if I search long enough I can find all info, but...
- Pics of my spark plugs...what's going on?
- Exhaust leak, what are my options?
- Call all North Houston,Spring,Woodland Lexus
- Single Exhaust?
- Changing SRT chip to SAFC 2
- Pics of Apexi exhaust
- my 5zigen fireball style exhaust!!! 5inches!!
- Exhaust leak fix
- Aristo VVTI Maf same as USDM Supra Turbo maf?
- Those running BOV's
- GS3 SRT Intake Impressions and Mod
- last missing piece of my 2jz puzzle!!!help
- Apexi neo help.
- Going NA-T... can i use old T3/T4
- 98-05 5zigen frireball exhaust...
- has anyone heard/used this turbo kit by driftmotion?
- Just ordered a couple of maintenance items
- GS to GM LS motor swap ?'s...
- Swap 1UZ for 2JZ???
- boost leak?
- Which is faster. Toyota Aristo (2GS) or GS400
- Turbo setups!?
- Fujitsubo Legalis R Installed
- Quiet Riot
- post race v8 seriously hurt or not?
- anyone running a edlebrock single stage wet kit and what shot/ size jets
- 2JZGTE swap has begun
- Aristo Auto Trans / USDM Shifter Gate Assembly
- Transmission Cooler Threaded Fitting Sizes to use -AN Braided Lines
- Can someone post pics of their L-Tuned exhaust? Part No. ?
- 01 lexus gs 430 catalytic converter problems
- Which turbo to go na-t with?
- Sudden loss of power/acceleration
- Header exhaust question
- HELP! Does this sound like a blown engine to you guys?
- for the na-t guys
- I did the Aristo JZS161 swap but USDM driveshaft won't fit
- Valve cover seals and gaskets
- v8 powaa
- Ok.. 2JZGTE motor is ordered.. Time to start getting everything lined up
- 2nd Gen SS headers crack
- good price for
- 2003 GS300 going Aristo this fall. Help!
- replacing aftermarket exhaust gaskets...
- Interesting info on different dynos...
- GS400 Exhaust cut-outs?
- Any idea what exhaust this is?
- transmission problem
- installed starkes ss coilovers..... very low and handles like stances
- GS300 exhaust help...
- Smoke coming out of exhaust? (long)
- *PIC* my twin turbo 750hp gs400 !! on 24s w/ airbags
- Check Engine Light, VSC OFF, Code P1121
- 1996 gs300 has probs starting, why?
- Intake/Exhaust timing??
- Exhaust questions
- 99 GS300 upgrade on Headers/Mid-Pipe
- My 2jzgte swap
- New Weekend Ride
- GS430 SRT/ECU vs. SRT/S-AFC dyno #,s
- JDM 2jzgte vvti swap GS300
- 2jzgte vvti 99 gs300
- rebuilt twin turbos or install new single turbo?
- Synthetic Oil - Change Interval
- exhaust question
- need info on 2jz swap
- aristo swap issue
- GTE in the works...
- I NEED HELP! Car stalls after warm up.............
- Help with 99 GS300 Swap
- Photon's GS300 Turbo project
- new exhaust for the gs
- Newbe have a problem!!
- Torque Converter? Or Something Else??
- Random Misfire/Rough Idle/Lunging Accel
- 2000 Gs400 with 150k Recommended Maintenance
- Throttle control motor w/magnetic clutch removal
- nice new lil mod...
- Prepping SRT Stage III SC kit...
- Where can I get an O2 simulator?
- Where to find a VVTi GTE swap
- what does everyone have their tire psi set at?
- b.o.v on gte
- High idle problems
- Problem after Fuel Filter Installed, pls help!!!
- OCV/VVTI actuator problem after full timing belt service!
- CL Please Help gs400 wont start until i gas it!
- transmission fluid no need to replace
- Whats the cutoff for 2001 GS300's for Aristo Swap?
- How does your GS430 feel with a 3.76 LSD compared to stock?
- Engine misfire
- My GS430 Wont Start!!!!PLEASE HELP!!!!
- Mobile 1 ATF
- A "what if" question for the supercharged guys...
- Gte aristo swap 2001+ gs300 steering shifter?
- Blitz Throttle Controller 01-05 GS430
- Exhaust question??
- 99 lexus gs300 exhaust manifold
- Thinking of switching tires...which ones?
- 2jz gte vvti or non vvti ???????
- Improve Cold Weather Start Up
- Stuck Need Help
- tuner for vvti
- cop problems
- flywheel design gs400
- Dynomax Super Turbo Muffler installed (Video)
- sc300 pumpkin into gs400?
- turbo
- GS400 Supercharger manifold
- SRT intake air filter cleaning/maintanance? How and how often?
- Early timing belt replacement?
- Big drop (about 1.6 mpg) in gas mileage -- anyone had this happen?
- exhaust
- Exhaust question
- avg MPG 99 GS300
- Need info on doing some maintenance...
- aftermarket header question
- i feel as if my gs300 is slow compared to my is300 ......is ther anything i can do ?
- O2 sensor
- VSC / VSC Off / Check Engine Light
- please help wanted throttle control motor
- 2003 GS430 SRT intake install problem...
- Performance chips
- 2jzgte vs 2jz na-t
- gs300/400 GTE swap (drive shaft/diff)
- GS300 or GS400 rear diff into GS430?
- Is it possible to keep SRT intake after SRT ECU removal for dyno tune?
- Intake help for a old-newbie
- another where did you buy your intake question but for jzs16
- ECU "re-learning" after K&N FIPK install?
- Apexi Exhaust Installation in GS430
- Limited Slip Differential facts
- DIY fuel pump change on GS300
- Car just dies!
- New GS4 owner cars transmission acting up.. need any input!
- CEL codes P0420 and P0430
- Few questions..
- Timing Belt change intervals
- Change your spark plugs if you haven't before! Also, advice needed
- $180 stainless catback exhaust for 98-05 GS WOW!!!
- Catback system
- For those of you that have the RAYS G35 19" wheels
- question on a 2JZ swap
- Crank timing pulley bolt "size"??
- GS430 oem mufflers vs GS3
- GS430 into GS400
- Does anyone have a recommendation for an oil cap that doesn't leak ?
- Top Speed exhaust reps on ebay for 180?
- Any DIY threads for 2ND GEN GS300 Valve Cover Gasket
- 2jgte vvti or non vvti ???????
- Cleaning up my IC piping before the install. :)
- Evaporative Monitor not ready
- Cam Pulley Issue
- cat forward exhaust parts
- Gs 400 exhaust help please ?
- DTC P0717 error code GS300 2003
- Stock bottom exhaust picture
- Transmission fluid change?
- GS400 ECU / Intake Mods
- GS400 Exhaust Options...?
- How to remove the speed governor
- My GS300 engine misfire when warm
- whats the name of this exhaust???
- Where did you buy your intake?
- ProjectGS DIY: ECU Pinout
- I have the code p1349, how do I inspect oil control valve??
- New 2000 GS300 owner with questions
- Apexi SAFC Neo 99' GS300 Wiring Diagram?
- VSC/Brake/ABS Lights-Alternatives to Master Cylinder
- Using Apexi Neo with SRT intake?
- Exhaust Options revisited :)
- Remove stok mufflers or resonators pros and cons (gs400)
- JDM Aristo CT20A Exhaust Gasket Part number
- Lower Cam Cover Sticker/Label
- My GS400 (with pics) 12MPG and torqueless below 3K?
- Mk1 Aristo 2JZGTE engine into Mk2 Lexus GS300
- Cat Code with Picture
- RMM Supercharger
- Hood and engine issue/help..
- Exhaust Opinion - Top Speed Pro-1
- Car wont start! Fuel filter install
- Should I swap the engine of my GS430........
- 2jzgte vvti 6spd from supra??? gs300 possible?
- Debating ????
- Transmission flush = new car feel
- want to remove the rosonators
- PureOne PL20195 Fits The GS300
- Anyone ever tried Comptech(CT engineering) exhaust on a 2gs?
- Walbro pump gs400 for bad stock pump?
- MAF Sensor
- Quick performance tips.
- Performance Gains: Real, Imagined, Exaggerated
- PPE V8 Headers GS, LS, SC
- Turboing Questions...
- gs300 or 400 (2jz-gte swap)
- please any advise? car reving but not moving
- can I put a 1999 gs 300 transmition on 2001 gs300
- SRT Intake ECU problem!
- GS430 performance chips
- What % decrease u notice after exhaust?
- Thinking Low Boost Turbo
- My 2JZ GTE parts list. Feel free to input!
- 98 Gs 400 1uz performance programmers?
- Apexi Neo not showing RPMs issue
- Is a VB upgrade and regular 3.26 gearing a MUST for a supercharged GS4?
- experience with RHYsS MILLEN INTAKE for GS
- Exhaust Issue... 01 GS300
- Is a 2JZ-GTE swap truly worth it? Your thoughts are appreciated.
- New GTech results in...I still gotta practice :)
- 2jzgte vs 2jzgte-vvti
- New exhaust installed =]
- Long tube headers
- anyone have info on the acoustic control induction system (acis)?
- Red Line WaterWetter super coolant
- Joe Z intake pip for gs430??
- Installed Tanabe Hyper Medallion Exhaust!
- na-t or swap
- SRT Intake Noise Question
- need help about the light of serivce engine is on
- Aftermarket Exhaust Gasket HELP!
