View Full Version : Performance
- Wanted CarsonTuned exhaust sound clip
- Slow boat has arrived...
- Did the exhaust sytem change in 02 for the gs430 system?
- GS430 SRT ECU instructions wrong?? Need help please.
- Long Term Relaibility with TC & Cooler
- what exhaust do you have or would like to have
- '98 - '05 GS300 hp at wheels???
- Exhaust Gaskets
- Whats the diff between turbo and SC boost
- Exhaust For 99 GS 400
- Has anyone bored out their throttle body?
- the best plugs for gs300?
- Turbocharged GS400 and so it has begun
- Newest Twin Turbo GS400 on the Block (582rwhp/573lbs.tq)!!! Pics Inside!!
- RMM Supercharger- 1 Left
- Which spark plugs are best??
- Best Intake for GS430 ???
- Changing spark plugs and wires for GS400
- K&N FIPK is dangerous (because I get on the throttle all the time now)
- Greddy T78 33D vs Holset HX40 which is better?
- How much Toyota T-IV needed for TC
- Just finish installation of my new turbo.
- Problems after 60,000 mile service
- Need some information on building an engine
- Supra auto tranny on a 2 gen Gs300?
- SRT intake questions???
- srt ecu wires
- HKS In take
- auto dyno
- Will Aristo exhaust fit on a GS430?
- SRT intake, GS 400/430 supercharger reliability questions etc
- PLP Supercharger.. Anyone Actually Have This?
- Torque Master Spark Plugs
- Fujitsubo exhaust price
- Torque converter install in NY,NJ
- Found a PI Dragon torque converter for $720.50
- Anyone here of Transworld in CA
- Installed my Injen Intake yesterday.
- HELP!! Exhaust Hitting Differential
- Horespower
- Do you guys with FI tell your insurance companies?
- Some fotos of Fuel System.
- Need O2 Sensor Info for Headers
- Torque Converter
- After this Cold is over...changing fluids
- Borla Exhaust ???
- Does PI 2800stall TC work with Supercharger?
- trans cooler question
- ?? on TC from lextreme.com
- Supra LSD question....and yes i searched
- GS430 Horsepower Questions
- mark the plumber
- Headers for gs4x engine does not need to be pulled?..
- Intake and Exhaust ???
- installed: geddy evo 1 exhaust
- SRT intake filter
- TC or valve-body upgrade...what's best for my car??
- Does anyone have this exhaust for the GS?
- GS-300 Engine Replacement
- toyota supra bottom end.
- well, my extended 100K warranty was worth it...
- belt squeal
- Driving in Rain w/ a Cold Air Intake...
- Throttle body size
- SRT Intake Horsepower Claims
- Mobil 1 Extended Performance ??
- UPS man is my new best friend!
- Has anyone made a true "CAI?
- FI Guys - where to get one step colder plugs for FI GS4
- 2002 GS430 stuck transmission issue
- Tranny slipping?!
- What luck
- E-shift to first gear?
- Question for members that have moded exhausts
- Putting in 10-w30 instead of 5-w30
- [B]Injen Intake heat shield[/B]
- Is there a special FI TC from PI
- Help!!!! 3 of 8 spark plug boots stuck!!!!
- New member Intro - with ebay turbo GS300
- Help! Anyone know this sound?
- installing S/C questions
- Anyone with opinions on "built transmissions"
- Muffler swap question
- RMM Supercharger Guys - need info please!
- Tranny Problem
- 2JZ-GTE engine number and year made info
- Anyone tried 3.92 gears in GS400
- general exhaust question
- Is It Worth It to Still Fix Up a '99 GS3 w/ 102k mi.??
- Stock 1UZFE...how much can it take?
- is there such thing as a transmission pan filter?
- Installing a TRD LSD in a GS430, how hard?
- TC in GS430, will it set a check engine light?
- Weapon R intake... Questions?
- Why would srt intake reduce low rpm torque?
- anyone know how to get a lsportline exhaust??
- Transmission
- My learning curve with new torqueconverter
- GS430 + 3.76 lsd + Snow & Sleet
- Tranny Time...Fluid Type? Cooler Type?
- Squeal At Cold Start
- How to get L-tuned tips centered.
- tranny additive
- ***Want to hear intakes***
- 3UZ HKS supercharger
- GS 400 forced induction problems
- Nine Horsepower In A Bottle
- What kind of exhaust should i get
- faster 60-100 w/tc or without?
- SRT ECU Installation Instructions
- Fyi: Rmm Supercharger Is No Longer Available
- Intake for GS 300
- Question for Optima battery owners...
- Injen Intake System for GS430
- where to buy 3.76 differential w/o lsd?
- Strange LSD Question
- Looking for intake ideas
- Intake for GS 430
- Gutted cats VS straight pipe
- Price on Supercharger
- Supercharged GS Questions...
- LSD Option
- SRT Intake and ECU Questions.
- Anyone ever pass smog in CA with SRT intake?
- Another Turbo GS for Sale
- Does the Torqueconverter make any noise?
- Standalone ECU questions
- Jdm Toyota 2jgte Twin Turbo Engine
- My new Twin Turbo Kit
- Borla Vs. Other Brands
- Who'd be interested in a Turbo kit?!?
- Supercharged GS400-Next step
- Engine Replacement/Repair Questions?
- Just got my used TC! some questions about manual
- changed oil in LSD u might want to do it too!
- Airbox, intake, cleaner Q????
- How long should it take for a shop to install a Torqueconverter
- Why is the SRT intake 100 less on a GS400 over..
- Dyno stock 98 GS400
- Quick question on v300 front clip swap
- transmission additives
- Update on my blower at Vortech
- What is the difference between the Apexi WS over WS II?
- exhaust diameter / layout question
- Supercharger 430?
- feathering torque converter?
- Update Ported 1UZ-FE heads/GS400
- Rearend Question
- SRT Intake Video
- Airbox intake Question
- 1jz in a 2nd Gen GS300?
- Electronic shift improver
- unorthodox racing pulleys
- Cold air intake
- Transmission drain plug torque value
- Video: Gs/Aristo Taking out turbo supra
- gs300 exhaust header?
- Rod Millen Supercharger
- Turbo for GS4
- New member with twin turbo GS
- SRT Intake Installed
- Transmission Problem? Help...
- Lsd..??
- Supra motor and tranny question
- Headers?(GS300)
- Turbo 430
- transmission slippin?
- Throttle Body and Fuel Injector Clean
- Cost for 3.76 lsd install
- GS300, O2 sensor- bank 2,sensor 1. help
- more hp for the gs300
- GS 400 Trans Slipping
- aftermarket lsd's???
- Headers for the GS300. Where to get?
- clicking noise!
- More Horsepower
- Forged internals
- Where did you Borla owners buy your exhaust?
- Shift Solenoids
- Question about GS400 Diff
- Has anyone got the CarsonTuned Full Cat-back exhaust on their GS400/430?
- What Intake for GS300 '99
- Carson Tune Exhaust w/ B-Pipe
- SRT Intake Build Quality Issues
- Shift improvment on a 98 GS400??
- Upgraded MAF sensor??????
- K&N FIPK for GS 3 in '05
- 1998 GS4 Spark Plugs
- anyone heard of turbo east?
- My 99 GS400 w/ 65k miles sounded like it was about to blow up today when starting up!
- Dragon TC + Icy Michigan Roads = ???
- Can any one guess (new toys)
- Dragon T C & TRD LSD
- D.I.Y. Oxygen Sensor Replacement
- 3.76 lsd
- looking for exhaust pics
- Leaking GS300 muffler?
- i want some tips for my mufflers
- exhaust tips
- Supra Torsen LSD in GS300
- gs300 turbo potential?
- gs 430 turbo? supercharge?
- car over revs just before it hits 2nd gear?? cold out though
- Tanabe Hyper?
- SRT Intake
- shift solenoids
- need to get a compression test.....
- Question to all with PI TC
- Transmission woes
- Exhaust help for GS300
- 2JZ-GTE question
- Lsd
- Dirty air filter... Need to replace... Sugestions?
- TM plug owners...
- Quiet Intake Box
- is 130amps enough from the alt?
- Is this normal for transmission?
- Price for a 2jzte swap?
- Which synthetic differential fluid for LSD
- '01 Gs300 Spark Plugs
- oil leak
- Aftermarket UDP??
- what Mid-pipe is good?
- Dragon TC installed! (FINALLY!)
- Carson tuned Pictures and Vid
- The Weirdest Thing I've ever seen
- Transmission Fluid Change
- Throttle Position Sensor Question / Problem
- Does anyone have this or their GS300?
- what size pulley is all RMM supercharger owners running?
- Turbo questions
- What type of fuel management with RMM SC
- RMM Supercharger Owners Please Read
- Slow and rough start
- torque converter for 2jzge
- Scratching 2nd gear with LSD
- Owners of RMM Sport Mufflers.......
- Attempt at removing stock exhaust
- Installing RMM SC kit
- TurboEast Electronic Shift Kit
- Does anybody else's transmission 'jerk' occasionally at very low/idle speeds?
- Installed L-Tuned Exhaust
- exhaust
- check engine light problems
- Mahdavi Motorsports Turbo
- actual intake manifolds-not air intake
- Anyone ever had tranny problems?
- Carsontuned exhaust on GS430?
- Wald Supercharger
- engine fan always going off
