- Supra 3.76 Rear end (Auto or 6 Speed)
- Is NOS right for me?
- AEM standalone on aristo conversion
- Pi Tc
- 98 gs w/ supra lsd
- Any header updates?
- transmission goes "CLICK" when shifting gears?
- Make Borla exhaust flush? or extended?
- My exhaust vid
- Parts list for going turbo on a GS300??
- BLITZ NUR-SPEC finally arriving in states!
- Valve Body Upgrade?
- Help with custom exhaust!
- Christian Rado's Turbo GS4 for sale?
- GS 300 transmission questions...
- 3.92 gears installed on Hollywood's GS430
- Oil change with RMM SC
- Quietest exhaust??
- 1UZ-FE engine with ITB's
- Where to get Front Mount intercoolers
- Went to the track last night
- Throttle body cleaning?
- photo request !
- How to make this work?
- SRT Intake $445 Shipped....
- TB coolant bypass on gs300
- amsoil tranny fluid
- recommendations for replacement air filter?
- spark plug wires??
- SRT 0-60 vid
- 3.76 Gears not shifting into 5th
- question on those with HKS exhaust and SRT intake
- Exhaust sound clips
- Fujitsubo
- magnaflow dyno gains interesting read
- Thinking about these headers
- Will this K&N fit an 02 GS 300?
- Need suggestions on Exahust system
- Goal: 0-60: low 5's
- 3.76 /LSD Gears on..but interesting G-tech results
- Look What I Bought At The Lms Lexus Fest
- Loss of power after intake installed
- Transmission EPC question
- GS3 Guys with Header & Y Pip
- Is LSD neede for a FI gs3?
- CEL light on--error code
- jsut curious... what if i put a 4.08 rearend into a gs3
- Ok I researched V8 X pipes, headers, pipe sizes, etc. Here is what I found
- What is the life expectancy on a torsen 3.76 LSD?
- Removing cat converters, O2 eliminator type questions
- Is it for sure that you cant order 3.76 supra LSD anymore?
- Do I need a blow off valve on RMM SC?
- 1st gen Aristo engine into 2nd gen GS300
- slipping transmission in reverse?
- magnaflows caused loss of power?
- Underdrive Pulley
- 98 GS400- rebirth
- Supercharger Help...tuning
- 2jzgte Twin Turbo V Vti Bluetop Swap
- hks intake and CEL
- SRT VS. K & N Intake Info Needed...
- Still need exhaust selection help.
- BPU - Basic Performance Upgrade
- Re-Vote on the LGW NorCal video
- Can someone explain compression ratios?
- F/I Guys with Oil Coolers
- quick magnaflow question
- APEX'i WS exhaust (original not WS2)
- exhaust poll
- need opinions! (which TC should I get?)
- How come no GS300 with TC???
- Apex S-AFC with SRT Intake/ECU
- POLL:Which TIPS look better Mag or borla?
- How many 1G GS300 with GTE swap out there?
- Single disc vs Multi disc TC
- Instructions for 98-00 SRT ECU install?
- Exhaust Question...
- Hitting Rev Limiter
- Electronic Shift Kit (GS )
- 450cc injectors out of eclipse, yes or no
- 2jz-ge injectors
- Lms cold air intake. was looking around on the carson site and seen this.
- Srt Intake Filter Re-usable?
- torque specs for torque master plugs?
- GS300 engine Q
- So which Catback do you like for the GS400
- Just installed SC on 98GS4 Lean code problem
- Need engine light help - PLEASE
- Has Anyone run the 3.76 Gears without LSD?
- royal purple gear oil?
- TC and LSD
- New Turbo
- Blitz having delivery problems
- H pipe, X pipe and Y pipe Application Primer
- last pic of magnaflow's
- more pics
- More Pics Of My Magnaflow's
- Supra TT Auto LSD...install questions
- New Exhaust Setup
- Engine Light On After Weapon R Secret Weapon Install
- Problems after SRT intake install
- Is there a way to increase throttle response?
- pardon my ignorance...
- lag at 3400 - 4600 rpm?
- Is this a modified Aristo ECU?
- Do i need to do?
- Just installed Magnaflows #14829
- i have an offer to buy a supra from a friend
- intake for GS 400
- Tc And Lsd
- some more gear ratio research (UPDATED - 4.27 Gears are ON!!!!)
- Has anyone had problems with Drive Shaft?
- Weird Noise Behind The A/c Vent
- L Tuned or Magnaflow?
- Magnaflow Sound Clips
- anyone recommend a good universal muffler?
- Weapon R Secret Weapon????
- Mufflers
- will the GS400 exhuat and intake bolt on a GS430?
- Intake for 97 SC4 ?
- NEED HELP: magnaflow Question??? ASAP!
- SRT Intake
- GS300 manual transmission
- is300 diff on gs430?
- K & N filter for the SRT intake
- How to install supercharger on Gs430? Help
- Magnaflow's Installed. Pics Included.
- Looking for super charger 2001 GS430
- Resonator removal?
- Pissed! Magnaflow wont fit according to....
- Double XX Pipe Exhaust is Done!!
- Muffler Install Question
- Question for guys with 3.76 AND PI TC
- Stock Intake install !!! Need Help !!!
- Anyone w/ S-AFC on GS/SC 430 motor
- v8 turbo.
- L-tuned exhaust sound
- ? on Borla sound
- sound clip of l-tuned exhaust
- 3:76 Torsen LSD Install
- Quoted $250 For Magnaflow Exhaust install
- Borla installed :-)
- Turbo
- Need Help Borla Install... Stock hex nuts welded on?
- Got Borla exhaust today.. No gaskets?
- Magnaflow Mufflers & Tips on GS 400
- 00 verse 02 aristo differences..
- Ordered 2 Magnaflows for $181 shipped
- *****Exhaust Diameter*****
- Gs400 & 430 transmisions, are they the same?
- Exhaust recommendation
- SC/GS300 2JZGTE wiring info needed...
- 99 GS 400 RMM supercharged on the way!!!
- flowmaster mufflers
- Need Opinion Fast on Blitz Exhaust!
- Eborla Tip Length
- Apexi Ws 2
- Carson Tuned exhaust finally here!!
- So my Greddy PE pipes are rusting through....now what?
- Exhaust prices... where are the best deals?
- low compression pistons buyer beware
- anyone got the RMM exhaust?
- SRT Intake or exhaust first?
- Modding
- Forced Induction Guys... Spark Plug Help!
- Supercharge???
- Installed Magnaflow Exhaust on 1999 GS 400
- Is srt intake worth the price?
- curious on possibilities?
- Camshafts!
- GS430 A/C off Low Idle problem. Gone Now!
- RMM Intake with SRT Piggy Back?
- What are the pro's and con's to removing the Y-pipe from my exhaust system?
- What is port matching about
- Finally have exhaust
- exhaust help, very loud
- 2jz-ge exhaust studs
- Waiting For Borla
- 3:76 Lsd
- hyper madalion
- Quartermile time with TC and 3.76 LSD
- Fuel and timing controller
- 3:76 Lsd
- My one wheel wonder
- Starter Life
- Magnaflow Exhaust for 1999 GS 400
- Exhaust ???
- Apexi Afc
- Differential oil (fluid) - which one?
- Timing belts
- Blitz Nur SPec or Carson ???
- 3UZFE Forged Pistons
- Help! Need opinion on 2800 Torque Converter!
- Ordered Blitz Exhaust and Got Performance Anxiety
- Mods for 2000 GS400 (425 rwhp) ????
- fuel pressure regulator
- ltuned exaust tips dicont?
- Borla or Blitz nur-spec??
- RMM supercharger instructions
- Borla Exhaust...
- Borla tips
- Some new fotos of Aristo tuning process.
- SRT Intake Install Pics
- For petes sake is there anyone that can rebuild an engine
- Good Tranny Shop in Florida???
- Any difference between a 98 and 99 1UZ
- Chrome Tips?
- any GS430 w/TorqueConverter
- '05 GS300 what intake?
- torque converter @ warranty
- stock exhaust
- Torque Converter???
- Help with ECU selection
- what D*m luck
- Torque convertor install questions
- deepest sounding exhaust
- Are Standalones more tempermental than Piggy backs
- Best place to Buy Apexi WS2 exhaust
- Best Stall speed for PI TC ??? Please respond! Thanks
- Average power gain for a catback?
- FI ECU choices
- Part number for AFE Filter from SRT's intake system..
- decreasing turbo spool rpm
- Carson-Tuned Exhaust gs 400
- Tom's Exhaust Finally On
- Who here has No Resonators?
- do they make Koyo radiators for the GS400
- Heat Sheild ???
- Type T-IV replacement from Mobil
- RMM SC reliability
- LSD questions - HELP!!
- Help, turbo project needs new shop!
- Heard of using S-AFC II w/o any mods...?
- Bad News; 4 to 6 weeks out for Blitz exhaust
- Where to buy KN intake for GS430 ???
- K&N drop in installed gs 400
- I am surprised that only 2 GS430 owners signed up for headers....
- Hollywood's SRT Install
- exhaust opinions
- spark plugs
- 2nd Gen GS Exhaust Sound Clip Collection
- Best performance upgrade for GS430 from 60 to 110 mph
- TorqueMaster Star Series Plugs?
- Tightning Oil drain plug? Gs 400
- Turbo Kit!
- How do u remove OEM exhaust tips?
- Changing tranny fluid/filter for the 1st time - Any thing I should know?
- Whats your mpg with your TC?
- Upgrading Engine Hoses
- Exhaust Tips
