PDA
View Full Version : Performance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23
  1. Best Spark Plugs?
  2. Aem EMS for 1uzfe
  3. Fuel System Cleaner
  4. Denso IK20 Iridium plugs for '99 GS400???
  5. 99GS400, 120K miles, need your help on timing belt install
  6. Borla on a GS300
  7. Jp exhaust question
  8. Changed out to torque master plugs!!!
  9. Magnaflow Mufflers....
  10. re:help with 2jzgte swap
  11. Large gas cloud on startup (SRT?)
  12. Greddy Power Extreme Exhaust
  13. Nirtous on 2000 GS4
  14. somebody familliar with AN fittings and such help me with this.
  15. Anyone know the length of the GS400 drive belt?
  16. Carson Exhaust vs Tanabe Exhaust !!!
  17. gte swap clearances. attn: epik/craw/bluelex
  18. Magnaflows on a GS3?
  19. TC installation...
  20. Intercooler Preference/Suggestion and Poll
  21. Can anyone confirm the size of the fuel rail plug fittings?
  22. a GS400 burnout video
  23. Help: GS300 with 1Gen SAFC
  24. GS430 Mods concern...
  25. Torque converter/3.76/LSD vs built tranny?
  26. Nitrous in a GS 300
  27. PLP Intake Or SRT Intake?
  28. Question on catbacks for GS430
  29. Supercharged 1999 GS400 - DONE!!
  30. 2 questions: Concerns Both engine and Transmission
  31. magnaflow cat??
  32. Exploded diagram of a GS400 fuel tank?
  33. Anyone running 440cc injectors and piggyback?
  34. How do you like your Apexi WS2 Exhaust?
  35. Is it really necessary to change differential oil?
  36. Need Reliable HP out of my 02 GS300 Need expert Advice
  37. AEM EMS for 1uz-fe
  38. Gs470
  39. Porting my N/A 2JZGE head(BIG TIME INTAKE PORT)
  40. SRT Intake Problem, CEL+VSC ON!!!!!!
  41. Intake suggestions for 01 GS430?
  42. Supra 6-Speed LSD into 2G GS3 Pumpkin?
  43. HKS Cam Gears?!
  44. Is there a performance starter for the GS400?
  45. Turbo GS3 or go with GS4?
  46. Which is better SC or TT a GS430..?
  47. Rearend gear changing ?
  48. IS300 Diff in GS
  49. Rear Diff./tranny issue
  50. $1000 for a timing belt replacement at Pohanka Lexus?!!
  51. LSD / Torque Converter
  52. Should I build another GS or should I build an IS?
  53. Instructions for removing belt tensioner GS300
  54. So tell me about importance of timing
  55. New short block
  56. AEM EMS or GReddy Emanage for GS3?
  57. How much did you pay for your INTAKE?
  58. Help with choosing exhaust and air intake
  59. Price ??
  60. How many and location for '95 GS300
  61. Totaled Turbo GS Update
  62. Blitz Nur Spec...?
  63. VIDEO CLIP of gentlebouncer's custom exhaust!!!!!!!!!!!!
  64. SRT Intake Install
  65. 01 gs300 drive belt
  66. Any GS430's install the headers yet?
  67. o2 sensors
  68. Sound clips of Borla exhaust on a GS300
  69. SRT Gs430 - stuck..
  70. CL members with clutch-type LSDs
  71. Supercharged / Turbo'd GS's
  72. OH NO! I need advice
  73. I'm singing the praises of this fuel additive!
  74. My NA-T with TT intake manifold
  75. GS400 Engine MOD's?
  76. fuel filter change help!!!!!
  77. Waterpump/timing belt QUESTION
  78. Help! SRT Intake installation gone terrible wrong
  79. Timing chain/water pump question!!!!!!!!!!!
  80. Turbo/Supercharge 3'rd GS anytime?
  81. Carson Exhaust rattle?
  82. Poll - GS400 owners with SRT w/ECU Intake
  83. **Need help! Parts for starter install.......
  84. Awesome GS 300 Turbo on ebay...
  85. Got my Phillips 6000k today, woot
  86. check engine, vsc, vsc off lights, came on
  87. Need Horses - Supercharger/Turbocharger for my 1999 GS400
  88. Tragic Engine problem
  89. Best Performance mod for stock N/A GS300 daily driver?
  90. Some thoughts/questions on GS HP
  91. Installed L-Tuned Exhaust (question)
  92. Just installed SRT intake and.....
  93. muffler bolts
  94. Quick SRT intake install help...please
  95. Royal Purple 9 horses?
  96. Needs instructions to install HKS SLD (Speed Limit Defencer) Type 2 on Aristo TT
  97. Rmm Lsd
  98. Where did you connect your Blow Off Valve/ Boost Gauge?
  99. Intake Dispute?
  100. P0115 Engine Coolant Temperature Circuit Malfunction ?
  101. Disabling No.4 solenoid in tranny
  102. air filter vs Cold air intake
  103. Gas Mileage comparisons! V8's
  104. Fuel pressure regulatar steps to install w/ pics
  105. How much HP can my transmission handle?
  106. RMM Intake
  107. Will the IS300 LSD fit in the GS??
  108. Almost done, choosing turbos, computer, trans. Ideas?
  109. Coil pack gone bad?
  110. HELP I double started my car
  111. I Just Broke This Part Whats It Called?
  112. SRT Intake ECU Diagram?
  113. 2JZ-GE Turbo question.
  114. AEM vs. Greddy ultimate....any break downs?
  115. Replacing Injectors how do I remove this $^#$ thing?
  116. possible cold weather probs>>? CEL VSC light.
  117. I need to find a supercharger for 98' gs400
  118. Fuel Pressure Regulator
  119. problems with SRT install
  120. Supra LSD 0-60
  121. Supra LSD with Std. GS4*0 Final Drive
  122. Show off pictures of your Blow Off Valve
  123. ABS light on, Can't get out of park HELP!!
  124. URGENT.. need tranny info.. GS300
  125. will supra radiator fir the 2nd gs 300?
  126. RMM exhaust w/o resonators
  127. Torque Converter Picture installed, anyone?
  128. magnaflow 14829 vs 14851
  129. Forced Induction Poll
  130. Split Second......Hmmmm?????
  131. BA's Header Installation Steps
  132. INTAKE installed, now getting code PO171 lean mixture
  133. just install magnaflows today
  134. Still hitting the limiter
  135. Another turbo GS back in the CL family....
  136. Header Install HELP
  137. Help! S&S Headers, now no Start!
  138. used supra lsd... what to do before install?
  139. Torque Converter or LSD?
  140. intercooler mounting question
  141. Carson Tuned Exhaust Owner - Come Hither
  142. somebody answer this A/F question please
  143. magnaflows 14829
  144. Aristo Intake Without ECU Mod.?????????????
  145. magnaflow exhaust
  146. rear section vs cat back
  147. oO Tanabe catback exhaust sound clips
  148. TRD lsd in 3.26 pumpkin...
  149. First CEL on the GS4
  150. S&S HEADERS ON EBAY - starting bid $250
  151. Transmission
  152. muffler choice - can't decide
  153. Problems with BOV
  154. Speed for my GS400????
  155. SAFC Installation Help
  156. the infamous dead gs starter strikes again
  157. Oil change time.. which oil?
  158. Magnaflow w/ and w/o resonators
  159. 98' Gs300 Engine Uprade Parts Needed
  160. Help with Fuel Management
  161. GS300 NA-T conversion in 4 hours
  162. 3.76 lsd running on 20inch wheels questions!!!
  163. How do you Regap Iridium Plugs
  164. How do I install a Blitz DC2 EGT Sensor on 98 GS300? Any gauge mount recommendations?
  165. Realistic, well made turbo kit or motor swap
  166. Supra turbo motors on eBay??
  167. oil drain plug crush washer?
  168. 2nd gen GS300 with 2jzgte swap? ANYONE???
  169. TRD motor/tranny mounts???
  170. Fuel Pump ECU
  171. Supercharging GS430?
  172. Has anyone tuned their cars with SAFC/I/E?
  173. LMS Fuel Management Unit- I-Manage
  174. Srt Intake Install
  175. Need part #!!
  176. High output altenator
  177. oem oil filter part number for gs400?
  178. Need an advice from professionals.
  179. Question about external wastegate...
  180. GS400 Starter Diagram
  181. How much HP does SRT 99 GS300 w/ ECU add realistically?
  182. LMS SC results/NEW UPDATE w/jbrady Headers
  183. need some swap help
  184. Installing Air Intake On Gs300
  185. 98 GS300-Need Help
  186. went synthetic and now it smokes... what have i done?
  187. You like my l33t built 1uzfe?
  188. SRT ECU with LMS CAI.
  189. Haltech F10x users on 4.3
  190. Nitrous WOT switch on throttle by wire
  191. Need Help: 2jzge/2jzgte turbo setup
  192. L-tuned/RMM exhaust
  193. RMM exhaust installed
  194. Review - Valve Body Upgrade
  195. what you guys think
  196. HKS Exhaust Installed
  197. RMM exhaust installed..
  198. diferential fluid
  199. Head Gasket Part Number
  200. Header Update
  201. srt intake
  202. For S/C owners what injectors size do you recommend
  203. Rattling tin noise?
  204. auto tt 3.76 lsd question
  205. R there NEW dyno numbers for JB Headers?
  206. Underdrive pulleys for GS400/430?
  207. How much fluid after cooler install?
  208. How much can it HANDLE????????
  209. Blitz NUR-Spec & TOM`s 6-piece -clearance issues
  210. LMS cold air running to lean.
  211. Anyone heard of these new systems?
  212. Tranny fluid in pan?
  213. GS Transmission Fluid, Spark Plugs, Tools
  214. Exhaust diameter
  215. Transmission Questions F/I with High HP
  216. Engine Q
  217. Headers for GS400, LS400, SC400 condensed thread
  218. 97000 mile timing belt
  219. Question about Turbo GS400's
  220. 2nd gen 1jz-gte vvti swap............
  221. only one picture today ^^
  222. new intake help needed
  223. Where to locate a valve body for a couple of days>?
  224. New 4.7l V8 for my 95 GS400
  225. yet another spark plug poll
  226. dumb question about spark plug wires on a gs400
  227. Boycott Big Oil Pt 1
  228. Exhaust question for the GURU's
  229. LMS GS430 S/C update
  230. URGENT Torque Converters URGENT
  231. Transmission Shift ECU?
  232. cold air intake
  233. headers for gs300
  234. Well ..the bell has tolled ..FI reversal questions
  235. 99 GS300....needs more power :)
  236. Ignition Amplifier
  237. SRT Intake for GS400/430
  238. How much NOS spray can this block take?
  239. My new mods update
  240. Diagram to install S-AFC on GS400
  241. Quick ? about installing an exhaust?
  242. thinking about getting srt intake
  243. 98-04 gs300, which motor best for swap ? Non-vvti or vvti 2jz-gte ?
  244. My new mods
  245. srt intake & ecu on a 135k car??
  246. SRT Acting up?
  247. Another TC question
  248. oil leak problem please help!
  249. IMPORTANT SRT Question!!!! (does it pass smog)
  250. Nos
