- Intake
- Blitz Exhaust question
- 3" Piping for GS300 N/A????
- FI GS question...
- where to order replacement pads for Stoptech BBK?
- O2 sensor questions on safc
- NA-T on the GS300
- (Noise coming from) Exhaust heat shield.....?
- GS3 SRT intake
- How Different are GS400 and 430 Heads
- GS300 VVTi cam upgrade .....
- custom Accufab TB setup?
- lightweight pulley
- Damn Mystery Denso Plugs!!!!!!!!
- Emissions Inspection Issues
- draining transmission
- Pros/Cons of Changing from a 3.26 to 3.113 LSD Ratio
- Now squeeling noise coming from rear only during turns.
- Kaaz LSD unit
- car is bogging and cel light blinking
- PI TC and LSD install...Guys, please help!!
- I used the wrong fuel...now what?!?!?!
- Supra LSD Question....
- SRT filter cleaning
- tranny slips
- Pulling Heads
- What exhaust is this...Pic inside
- De Cat Lexus GS 300 exhaust
- Anybody with Nitrous??
- where to get new exhaust hangers from
- Exhaust heat shield
- Dark tranny fluid...am I screwed???
- Need a Wideband? Take a look.
- greddy bcc help anyone?
- Fuel gauge problem with upgraded fuel pump...anyone?
- Blitz Twincharged (Super and Turbo) GS!!!
- choosing stall speed
- tranny cooler behind intercooler question
- How much boost is too much boost
- K & N intake want to replace filter but not with K & N.
- Boost with O2 sensors? How do I do it?
- NA-T Transmission Requirements?
- Exhaust - What should I Buy and Where!
- Annoying very high idle after swap
- I want to change the differential oil..
- Exhaust identification
- Which O2 sensor is this
- Wiring in injectors - SUGGESTIONS - Resister or AEM Injector Driver?
- Need Some Help
- OE TC vs. PI TC?
- 2jzgte ENGINE SWAP
- DAAZ LSD's
- RMM exhaust with Injen intake
- JP exhaust
- Official Tranny Cooler Thread for the 2GS
- Weapon-r, secret weapon intake install
- Stock Exhaust Fitment
- oil changes w. Supercharger???
- Vacuum line confusion!
- So how much hp did ppl gain by going w/ the headers?
- Injen Intake?
- Any Updates On The "Revised" S&S Headers?
- 2nd Gen Aristo Front Clip?
- why add an x pipe to your exhaust? please explain...thanks
- Valve spring upgrade why?
- Opinions? Wepon R short ram CAI?
- After accident...vibration problems?
- 2000 GS400 where is my air intake tempertature(AIT) Sensor located??
- SRT Intake problems
- injen intake and correlation with dash lights
- spark plug wires
- i need some ideas on how to set up my Nitrous Kit
- Supra Tranny Options
- Rev limiter...
- What are your 1/4 mile times?
- PROBLEM! have no idea
- SAFC or Stock ECU Wire Gauge?
- HP Header
- Cylinder order: Is cylinder #1 closest to the radiator?
- want stock exhaust back
- Fuel Supply Questions..A lot
- Tein CS V2
- CA drivers with a turbo
- GS400 Throttle Body Part Help needed
- aristo tt vvti torque converter question...
- will this exhaust tip fit? advice pls!
- Curious
- Converting to Synthetic
- SAFC Question
- cars 1/4 miles time/speed chart, where is it?
- Does this quote seem to be "on the money"?
- Turbo Flange Question
- 1999 gs400/vvti tt swap
- getting a tc installed and transmisson cooler too
- GS460 Vs. LS460
- Finally got my exhausts put on!
- New with a Supra.....but its VVTI
- Headgasket
- oil and transmission coolers
- Tranny Cooler...
- Motec MLS
- Throttle Body Coolant By-pass DIY instructions??
- New Pics: Put in L-Tuned exhaust + some questions about it
- HKS or Blitz exhaust
- air intake system
- THE S-AFC nea!!!
- Mechanic added too much ATF!
- New HKS installed and ?'s
- SRT 'ecu' ?
- HKS Exhaust or Keep Borla???
- good underside pictures of a GS400 (specifically exhaust from headers back)
- L Tuned Exhaust
- Torque Masters any good?
- Quick install ques...how much???
- megan racing downpipe question
- GS400 thinking of getting a dragon TC what do you guys think?
- here's my dyno sheet [sad face]
- Opinions On Exhaust ( please comment on which exhaust you believe sounds deep)
- Opinion On Exhaust (please leave opinion of what you think )
- SRT Intake GS430 Question!
- Wheel size vs fast start
- exhaust
- HLS exhaust
- 98 gs400 wont start after K & N intake installed
- Can hitting the redline for 1 second cause damage?
- Defi Gauges?
- 2jz-Gte Aristo motor.. same as supra?
- aristo tt vvti question
- Got a crazy idea and need your help...
- Dyno Tomorrow!!! any estimates???
- Yes, Another TC Question Regarding CEL..
- NA-T Questions
- Which one is the best 2JZ for a GS300
- Borla Exhaust Tip Length
- help me diagnose this problem please?
- Magnaflow it is....now about tips?
- NA-T Sparkplug info...
- what should i get??
- Q about OEM exhaust...2G300
- What Gauges to Get??
- Borla vs. Magnaflow for '03 GS300?
- Supercharger questions...
- Anyone have any experience with........
- S&S Headers
- Its ON six speed swap and all = Grip Industries
- DIY intake ques...If you were going tp buy an SAFC-II
- Quick question. Cylinder #1 and #3 location
- How to get some extra power
- Turbo's
- Custom Exhaust specs
- Turbo GS doing donuts
- Other options instead of K&N air filter
- ***Dyno results***
- Non-OEM Rubber Transmission Gasket - Any experience using one??
- 350 - 450whp buildup
- Final Drive, which is best for YOU ... Gear ratio mph/rpm
- Custom or Not? Exhaust question
- Turbo stopped boosting...
- Diagnostics showed a tranny selenoid sensor
- synthetic transmission fluid question
- What do I need to get better acceleration?
- What is the GS400 tranny model #
- Transmission gear ratios ??? Anybody know what they are???
- GE vvti questions
- Exhaust Odor While Driving
- tunning with safc II
- for 2g gs300 are the exhaust systems interchangeable??
- Help: Tanabe Exhaust dilemma (Touring vs Hyper)
- My new toys
- Installed Headers yet? How are they holding up so far?
- New Exhaust Pics
- Oil Drain Line for RMM S/C Kit? SAF-C II?
- Any ideas what Team Lexus does for a tranny
- 1SICK**Write-Up** Drop in K&N filter for 2GS (98-05)
- Attn: Gurus! Engine codes; not present when something is wrong?
- Turbo Build Diary
- Don't hate me because i'm beautiful...
- H=torque or X=HP what would U do?
- NA-T conversion
- Who sells... (a supercharger for the GS300?)
- s/c '00 GS4 v. s/c '05 M3
- NA GS300 with all the bolt ons
- Requesting shop manual pages for differential swap
- JIC Twin Spartan Exhaust?
- GS4XX and the IS350...
- Help with Turbo selection
- 2JZ-GTE....forgive me for asking this. One word answer.
- Transmission Strength GS3/GS4
- Intake Manifold
- Good performance shop in Texas?
- srt intake CA legal?
- need facts about turbo vvti head on gte block
- Greddy Exhaust
- Some performance questions
- Aristo swap
- 98-99 and 01-05 air intake difference?
- Super Charged GS pics????
- Need a GS400 tranny reccomendation
- Questions about maintenance
- hg and stud question
- $2k to spend on boosting GS3 power. Advice?
- spark plugs
- boral exhaust question about gs400 & 430......
- question about innovate motorsports lc-1 standalone gauge kit
- oil cap
- SAFC + SRT intake?
- GS430 exhaust REAL performance data
- question about LSD's
- non-VVTi 2JZ-GTE swap in 2nd-gen GS300?
- T Belt tensioner part #
- Greddy V-Manage
- Does Anyone Have Headwork???
- 2nd Gen GS 3 E Shift and 2JZ-GTE swap
- Crank Seal help!
- Supra TT auto LSD for 99GS300
- Turbo dyno with vid
- My GS300 Turbo VS 12 second Mach 1
- GS3 handbrake conversion?
- What Intakes
- What Intakes
- Why should I buy an aftermarket exhaust?
- Video of 01 GS300 TURBO - MUST WATCH.....
- Installing a Borla Exhaust
- Getting a GS4 soon have some questions.
- The Best GS300 Exhaust?
- Fuel Management for RMM SC
- **SAFC II Install Instructions for GS 400's**
- Borla Exhaust Hangers
- TRD LSD Noise
- I'm more of a fan of dual-tipped exhausts - think this would look decent?
- Dyno Results Post Safc-ii Tune *+16hp/+42tq*
- Previous Cobra Owners: GS4 Exhaust Note Question
- High idle after throttle body cleaning.
- How many O2 sensors does the Aristo VVTi have?
- OBD2 Code P0505...Help!!
- XS power turbo kits?
- SRT Intake Install Help
- srt intake installation problem!!
- gs300 headers ????????
- Valve Body upgrade ??
- SRT (no race ecu)=CHECK ENG LIGHT
- Carbon Fiber Hoods
- starting my research
- Supercharger vs. Turbocharger
- help! CEL, VSC, VSC OFF lights on! no acceleration...
- Gathering interest on V160 Adapter Kit for GS400/430
- lms supercharger question
- Forged 1uz rods, where.....
- wideband sensor
- 99 GS400 , Need help: Both VSC & CHECK ENGINE LIGHT=ON
