View Full Version : Suspension and Brakes
- My RF clanking noise
- lower ball joints
- Finding Megan EZ Street Coilovers?
- Supra TT Brakes + 2GS OEM Wheels = Spacer size?
- First Time Lowering
- Suspension..05 GS430 lowering
- advice please.....rca vs springs
- Clunk sound
- Front UCA proto pics
- ball joint, caster, damaged wheel, abs, etc
- LS400 brake users. come on in
- New Lower Ball Joints = AWESOME
- Gearshift will not come out of park when depressing brake pedal
- Coilovers and lower ball joints
- It Pays To Be A ClubLexus Member!
- Brake Sensor Front Passenger Side
- DIY - Rear Axle Carrier (Knuckle) Bushing Replacement
- hit a curb today!
- Ball joints, early failure
- Has Anyone ever had their springs torched ?(lowering purposes)
- Chassi refreschments...
- Replacing Lower Front Brace. Spec?
- Late to the party; L-tuned suspension (from dealer)
- Control arm compatibility
- So who knew coilovers would be this good?
- Front End/Rear End/AND Brake Q's
- Suspension experts chime in
- what coilovers should i use ?
- Soft brake issue.......
- Feels like breaks are "slipping" ?
- Anyone make 2-piece rotors for the 2gs?
- dampening Vs spring rate???
- To all you slammed guys
- UAS Air bags- front right after parked is at lower psi levels? Leak?
- Vibration in under carriage at higher speeds
- Brake pads touching against the rotor?
- Does this look right to you?
- Average price for coilover installation?
- 99 GS300 rear suspen making sounds.
- Cup kit for our cars..
- UCA HOLE CUTTING...Thoughts?
- Brake rotor screws - are they necessary?
- What coilovers would you choose?
- Megan EZ Coilover Settings???
- E-brake pictures
- Brake pedal sticking
- Rear Brake Pad installation question
- Tein vs. Megan
- EBC 3GD Series Sport Rotors F&B, RED STUFF PADS F&B (Non LS UPGRADE)
- d2 coilovers question
- For those with suspension knowledge or have replaced their caster arm or bushings
- Front RCA dimensions
- Rear Brake pads
- Question about my Lexus gs300 lowering springs
- Megan ez coilover review???
- d2 racing coilovers for 98 lexus gs400 hellp
- Any Idea on what this is? HELP
- LS400 brake upgrade / photoshoot!!.....
- UAS Airbag problem (clunk) sound and sway
- Recent ball-joint change now squeaking?
- Daizen alternatives
- can you put a "lexus" decal on the brake caliper for 1998 GS
- cambet kit ?
- want negative camber!!!!!!
- I need some thought on my suspension issue.
- Anyone in NJ/NY area Know a place where i can shave down my adapters??
- Tein cs UAS
- UAS REAR brackets Teincsv1 Problem
- Mystery noise from the left?
- IS350 brake calipers on a GS300?
- GS300 UAS on teinSS?
- Modify my BCR kit.
- I need help Air install going on
- Best quality upper control arms
- Sport Design Upper Control Arms (Ball Joints)
- meagan street LP question???
- Pics of gs slammed on regular BC coilovers??
- Sage 30 mm rca install before and after
- Need help air ride leaking air
- Need help with coilovers!!
- Need to replace rear axle carrier a/k/a knuckle
- Strut bars and braces
- GS400 Front Calipers Bolt on To GS300 ?
- Rear Suspension
- 2nd Gen on 3rd Gen springs & shocks
- How to make the GS300 handle like a monster??
- Rear Adj Toe Arms? Will IS or SC arms work?
- new shocks, big difference
- Help....Im a noob....soft brake feel
- Non-pillowball coilovers
- Used Coilovers and Ebay
- soft coil over???
- 38-40mm Front RCA work with 16inch wheels
- Abs / brake issues?????
- K sports coilover help?
- Front end still popping.
- Brakes and AC Problem
- ABS VSC light on
- Rear camber adjustment
- Dot 5 brake fluid.
- Replacing inner and outer tie rods..
- anyone has a diy on removing rear sway links?
- Bilstein Sport Shocks
- Need to fix camber issues
- Brake Failure - Diagnosis help (BMC...?)
- SC430 Coilvers for 2GS?
- Are brake shims necessary?
- How low can Megan EZ's go?
- Recommendation for Rear Brake Pads
- Help !! Abs/asc/brake/ and beeep noise!
- What is the Toyota part number for brake pads?
- JZS147 rear BBK 13"
- KW V3 for GS300? If not, can I use IS300 application or another alternative?
- Is Daizen still making Sway Bars for the GS400
- Rear control arm
- coilovers arrived
- Suspension help pleeeease!!!
- Bc coilovers help!!!
- parking brakes / E brakes
- stance coilover for gs300
- Master Brake Cylinder / Rebuild Kit?
- Stock wheels that clear LS Brakes on a 2GS?
- Ordering Parts For Suspension Refresh...Am I Missing Anything?
- MODS for my GS300
- Bilstein HD
- Rca help???
- Please Advise
- Still chasing the "clunk" over bumps!!
- Steering wheel shake, but braking and possibly wind related??
- right rear suspension noise! =/
- In a STB Bind Here
- ISC coilovers
- 2 BRAND NEW struts DEFECTIVE?!? LEXUS TECHS PLEASE CHIME IN!
- Did RCA spacer & LS400 brakes on my 2GS
- SPC Caster Arm/Camber Front & Rear kit is on (data adjustments included)
- New coilovers and wheels, what else to replace?
- Tein EDFC Install
- Clunking noise solved!!!!! :-)
- Lexus calipers question?
- Cheapest Upper Control Arms
- Does the 400 have bigger brakes than 300?
- YAY i finally slammed(:
- GS430 Master cylinder interchangable with a GS400??
- Squeaky Rear End
- ABS comes on unintended!
- I can't adjust my stock toe?
- Lowering Springs for 03 GS300 ?????
- Anybody know actual part # for OEM Lower Ball Joint & Outer Tie Rods?
- f sport spring..shock question.
- help with coilovers (pics)
- Wheel spacer fitment
- Tie Rod issue?
- XXR 522s on my 99gs300
- Blew LS400 Callipers.
- Megan Racing LP coil question.
- Alignment results...
- Anyone ride with the ABS disabled?
- lowered car + fig toe arm
- Would something like this fix my camber issue in the rear?
- What do I need for full suspension replacement?
- Is this the lower control arm #2 problem?
- Lowered car but have negative camber in rear! HELP****
- Alignment problems
- GS400: Purely Performance-Oriented Cost-Effective Wheel/Tire setup
- New suspension, ball joints, caster arms...
- coilovers
- Stripped bolt/nut
- Stripped my caliper mountin bracket
- Upper ball joints & lower ball joints
- lower control arm bolt stuck
- i want this brakes calipers!!!!
- Rotora big brakes kit
- brakes / rotor question
- EXPERTS HELP!!! 2GS Tire and wheel fittment question
- Creaking suspension
- Brake problem, works when stepped all the way to the ground
- Steering Vibration Poll
- My suspension woes. Front fixes and Rear fix on the way.
- Noob coilover question.... (Megan EZ)
- brakes
- brakes
- Can I get WILWOOD BRAKES off a 2001 WS6 to fit a GS300
- Excessive toe wear
- Negative Camber (static guys)
- How does everybody adjust their coils?
- Rear suspension part
- ABS light on!
- springs not even now
- BC-Racing Coilover Kit good and bad
- HELP with brake rotors PLEASE
- Uneven Brake Pad Wear
- l-tuned spring height
- Are back brake pads suppose to rattle when low?
- ideal suspension?
- I need new bushings asap
- I got the rear squeaks!
- For those of you with Daizen Bushings...
- Lowering Question
- Quotes I received for some suspension work, opinions please.
- Taillight Issue after brake job
- For all the member installed coilover !! Help
- upper ball joint replace
- Stance Coilovers Website?
- Tein EDFC and general tech question
- Fixed soft pedal / pumping brakes today
- tein flex coilovers????
- need advice:: looking to....
- 2002 SC430 Control Arms + Daizen Bushings = ???
- New bumper paint, new fogs, new brakes, pics
- rear suspension help
- Getting ready to drop the GS on BC's... advice?
- Brake Master Cylinder leakage
- Regarding Lowering My Lexus
- used brakes
- Installed FIGS rear tie rod end links
- Steering wheel shakes when I brake...
- 1st gen top hats on 2nd gen?
- recomendation on springs..
- Anybody in the Bay Area ridin' on BC's?
- Short Review: Brembo Blanks+Akebono ProACT Pads
- help a n00b understand coilovers
- Brakes
- daizen rear sway fitment issue
- question for my alignment guys
- New Stance and shoes teaser lol
- Roll VS Cutting/Shaving
- tein coilover blown out
- Help me define .
- Brakemotive Rotors
- Which coilovers to go with?
- dumped flushed out owners, whats your alignment specs??
- special mount for uas/bilstein needed?
- LS brakes polished?
- Clunking noise
- front upper arms
- Car was previously on Air Ride Suspension.. what to make sure now?
- Ksport Airtech review
- TRD brake kit - does anyone have it?
- LS 400 BBK pads?
- Some advice with lowering my car.. Megan coilovers
- cracked sway bar bracket! <<<diagram attached>>>
- members who have BC Coilovers, I need some adive!!!
- JIC coil overs, rear shocks busted.
- LS400 BBK conversion on 99' 2GS..
- Replacing Front Caliper Lower Guide Pin
- Question about Rear sway install...
- Front suspension advice?
- Rear suspension upgrade / modifications
- any one rocking bc er series coilover ?
- Ugo Ukyo Carbon Fiber Upper Strut Bar Install with Engine Cover
