View Full Version : Suspension and Brakes
- Mini review: TRD sways, front LCB & Tom's rear LCB
- Coil/shock/springs vs. braces/bars: Ride quality question
- Coilovers: height vs. dampening
- Wheel fitment question...
- my ap racing 6 piston big brake upgrade
- some pics of my car after the brake install
- I've got a recommendation...
- 2001+ GS300 and front-upper strut bar? Suggestions?
- Springs
- my impression about my GS so far....
- Springs???
- another L-tuned?
- L-Tuned and 19" setup
- Tires
- Calling all GS owners riding on 19's Multi-Piece wheels
- TRD strut bar
- AP GB Brakes installed
- TRD sways and lower brace are finally on the car
- Tom's Rear Lower Chassis Brace
- Clunk from rear end after braking
- Lack of stability and weak brakes on GS430
- Finally my Michelin Pilot Sport Tires are in!
- CS vs. Flex agaiin
- How much should I pay for Bilstien shocks?
- Prices on TEIN coilovers
- H&R/Bilstein Installation
- Damaged Disk
- HKS Hipermax LS vs. Tein CS
- L-Sportline Suspension
- What could this noise be (Tein Flex)???
- TRD springs?
- Hawk or EBC pads?
- Loss of Yaw Control with TRD/L-Tuning Suspension Package!
- Are sway bars really needed if car is dropped w/19s
- need help on what to do next?
- GOT DUBS and Tein CS installed .. RESULT "HAPPY" but..
- Tein HA Coilovers
- What Endless brake pad is available for the AP or Brembo setups?
- I want to go to coil-overs but do not know which ones?
- irotors.com
- Impression of the Polyurethane sway bar bushings
- Installed L-Tuned ECU over the weekend!!!
- TRD bar bushings question...
- Will Big Brakes increase performance? Will it affect ABS? Etc., etc...
- L-tuned Ecu ?
- Sways are in at Carsons
- supra calipers
- Opinion- CS. HA or Flex
- rolling on corners
- Wilwood 6-Piston Full Brake Setup
- My Girlfriend Says my GS430 Brakes to Hard!
- Suspension of a Sportdesign
- GS3 and GS4 rotors thesame?
- Manaray's Big Brake Kit
- TRD Components – New Find?
- Painting Brake Caliper
- steering ecu ?
- 2001 and up GS owners.....any problems with your cars??
- Last Day of AP Racing brake GB
- Updated PICS of Brakes
- ***** Wilwood Pics *****
- Did I Get A Good Deal On Rotors?
- Polyurethane sway bar bushings
- Brake Question - GS Stock Pistons?
- Tom's rear lower suspension brace or rear lower chassis brace, or both?
- What shocks to get to go with Tanabe springs??
- **** Wilwood Brakes ****
- My Supra TT brakes driving me Crazy!!
- Removal of rotor splash shields and brake dust???
- More crazy? brake ideas...
- Sways..
- Brake Assist is for wusses...disable!?!?!?
- Brake Question ?
- clunking noise in rear after upgrading springs?>>>
- New EDFC install.....
- Which company is the best overall Lexus Tuner
- First Gen Brakes Suck?
- New Brembo Brake Package....
- my ONE word on the AP Racing brakes: must read
- Sportivo = TRD?
- Master Cylinder Stopper on GS4??
- some good info on brakes upgrade (spec)
- Another Converted L-Tuned Customer - Comments
- question about l-tuned springs and shocks
- difference in drop height between eibach and L-sportline
- Suspension Upgrade Done :)
- Winter Tires
- Multiple HKS coilover models for GS??? Help quick.
- Brake Pads: Is it the same for GS4 and GS3?
- L-tuned or Eibach Springs: Which one is REALLY shorter???
- stock GS caliper vs Supra TT caliper...
- Tein Flex dampening adjustment question?
- Questions Before Install of Goodies :)
- Lowering Issues / Questions ... Please Resond!
- Where can I get TRD sways, and whats the average cost on them?
- Tein Flex/EDFC question
- pics after l-tuned springs and shocks
- AP Brake Group Buy
- curious if hks coilovers are good?
- ***Tein CS vs. Bilsteins PSS***
- Which Spring is good for GS430
- Just installed Toms 6 pc links! I like em!
- Bilstein TRD, etc. rocks!!!
- my review on the trd stb and the lcb
- Question about H&R Springs
- hks sf5 spring info ?
- Need some advice on the TEIN CS and Brakes&Rims
- Black Caliper's Rock!
- Need help ! Shacky suspension 2001 GS
- STB install question
- labor charge on installing l-tuned springs
- Looking Good-Wilwood 4 piston brakes
- Anyone have Stop-tech brakes?
- l-tuned stage1 and stage 2 shocks
- Stillen Dealing AP Brakes
- Alignment - Toe
- Okay, Finally Installed TEIN HA Today.
- coilover owners...HELP
- 19" wheels with L-tuned? Problems?
- Toms rear lower suspension brace how-to
- L-Tuned Shocks
- post a picture
- Pics of my car
- 18s, Suspension, Ride, Comfort, HOW?
- Cant wait for install of L-tuned
- TRD lower suspension brace. (installed now)
- Anybody know's on L-Tuned Shocks
- Caliper Painting
- need help with vibration
- Torque spec (sway bars)
- Hard tires...
- Brake Bleeding Question
- Tein Flex
- Recently had suspension modified...
- Bilstein PSS arrived today!!!!!
- Tein
- torque setting
- good brake shop
- Update on 4 piston Brake package
- TEIN Flex...how many "clicks" are you running?
- Who makes the best strut tower bars for the GS, front and rear?
- Adjusting TEINs
- a tale of my new springs
- Shocks or Struts???
- help on brembo brakes (and people from south cali)
- Brake Line ??? Rod Millen Brakes...
- Just installed H&R / Bilstein combo...
- RS*R Down springs VS Eibach
- Need some input.
- Question on Shock/Coilover installs
- My Review on Tein HA
- Thinkin about GS
- Rotor Warpage
- Installation Of Coilovers !
- Brake squeak
- Pop/Clank sound when first moving wheel?
- How low can you go?
- Question about ride and handling in a GS430 versus a GS300
- options by l-tuned
- Help in finding out the name of this kit??
- 1993 gs300 shocks, springs?
- Got Caliper Stickrs !! Pics
- HKS coilovers
- L-Sportline springs
- Steering Wheel Vibrates When Braking!!!
- Opinion on Cross Drill/Slotted Rotors.
- Noise over bumps
- KVR Brake Pads
- Big Brake Kit upgrade
- Power Steering Modification?
- Tom's rear lower brace ?
- Rotor noise
- TRD sways (install and impressions)...
- Anyone got a DIY Brake pads....
- Question about Brake Noise
- L-Tuned Install at Lexus of Glendale
- Can't set CASTER?\\
- sways r squeaking
- Cross Slotted/Drilled more prone to warpage?
- Coilovers...basic question
- Wilwood brake upgrade group buy.....
- Attention Supra brake caliper/stoclk 17 incher folks
- For those w/ brake caliper stickers
- Question about anti-sway bars
- Ever install L-tuned suspension at home?
- ATTN: GunnerMac...How do you like your new brakes?
- installing sways
- Help! Tein Type " Stuck HA"
- Ride too uncomfortable, questions.
- ideas on caliper's color
- Sticker Removal
- Adjustable Suspension components for GS cars
- GS400 steering vibration
- my review on the Tein HA coilover setup
- Tom's STB on stock GS400
- TEIN FLEX/Group brake buy and my review
- Upgrading steering ECU questions
- GS430/L Tuned Question
- Powerslot Brake Rotors
- $ Broke but need new pads
- Shocks
- Sways Or Stb ?
- DIY upgrade to changing brakes
- Supra TT brake upgrade on my 98 GS400
- Attention: All TRD Sway Bar Owners
- Need help! STB for GS430
- TEIN FLEX - have a few questions
- GB brakes installed.......
- Broken Toms link
- supra tt brakes / rmm brakes with stock rims?
- Squeaky Brakes???
- TEIN HA's Installed - Pics
- lowering question.
- Max Drop on the HA's
- Coilovers = Not Street Legal
- Question for those in the brake GB....
- Any suggestions?
- What is the best bang for your buck
- Has anyone upgraded to the L-Tuned 18" rims?
- Tire question: Sidewall flex vs. width
- Price on tein flex
- Tein Flex
- H&R Coilovers
- Where can one find those Lexus caliper stickers?
- Need to try somebody's tein suspention in So Cal
- Speedometer/Odometer Reading
- Broken Sway Bar Linkage!
- Just put on Chrome Brake Caliper stickers...wooo hooo
- Squeeky Shocks ??
- 1 Stop Powder Coating and Brake Installation
- what struts should I get?
- spring question
- GS4 ride with Tein H/A's vs. Supra ride
- my comments on the tein HA
- Recommeded place to install TEIN in Bayarea!
- Question about L-tuned shocks & Eibach springs
- Greddy Strut Tower Brace
- Finally got my Tein "Flex" installed...
- Tein EDFC
- Anyone driven on Ltuned vs Bilstein back to back
- Info on B&G springs
- Who Makes Front Rotor?
- Pics of the Rear cross/slotted brakes from Steve Ganz!
- ABS and VSC light on after upgrade, help!
- coilover clanking
- GS430 Brakes Saved Me by a Short Hair!
- Suspension suggestions
- brake calipers
