View Full Version : Suspension and Brakes
- Tein Flex ?
- I need help guys, Brakes problem-->
- Bilstein SP shocks
- l-tuned shocks/springs vs. tein cs
- handling
- need techical expertise on tire wear
- Springs
- Experience with iRotors or Rotormasters?
- When I hit the brakes I hear a weird eletrical\mechanical noise! What is it?
- just curious?? install price on h&r coils.
- Goods Have Arrived
- Will the Tom's 6-piece suspension bracing kit help eliminate chassis flex
- H&R Bolt Pattern Spacer Spec - 5/114.3?
- Tom's VS. TRD front lower suspension (chassis) brace
- L-tuned steering ecu installation help
- Will 93-97 GS springs/shocks Fit a 98-02 GS 300?
- l-tuned shocks with OEM springs
- sway bar and strut bar
- Need Help
- Seeking experts' opinions
- Brakes that squeal
- Anyone use OEM Lexus (Toyota) brake pads?
- trd stb and rear bar
- installing lowering springs only, bad idea?
- Tein CS vs Tein Flex
- 98 & 99 GS400 lower?
- hey guys ball joint problem on a 2001 GS430
- Tom's Lower Front and Rear Braces
- How low do the Tein CS go?
- L-Tuned steering ECU
- (Temporary ) Link To Brake Question
- Brakes Are Out After Dealer Service
- 1st mod decision
- Clunking noise with my Tein Flex???
- Quick review - EBC Greens and the AP 6-piston kit...
- StopTech Brake Discussion
- Rattle revisited
- trd sways review
- Tom's or Cusco Rear STB???
- Question about GS400 brakes
- How can I stiffen up my GS400's chassis? Subframe connectors? Strut tower brace?
- Solved GS problem with steering
- Can anyone name a list of Strut Bars for GS400
- coilovers vs. springs/shocks
- Just purchased H&R Coilovers
- TRD Sportivo sways report
- How do Sprint Lowering Springs
- Painting brake calipers
- Need a Camber Kit for your GS?
- Please Help Rock
- Got my first mod done!
- Dropping a GS with Rims and a bodykit, what are the clearance issues with doing this?
- Calipers Are Painted
- Where To Buy Stock Pads?
- Daizen Problem?
- Removal of rotors during shock and spring installation???
- L-tuned, Daizen, Sportivo sway, opinions requested
- Limited slip differential (LSD) questions
- cross drilled rotors/EB lights
- Supra TT rotors and what wheels?
- lowered suspension tire wear?
- To STB or not to STB?
- Question About EBC brake Pads?
- L tuned suspension vs L sportline suspension
- EBC pads and rotors installed
- Who Has Tried Do-Luck Rear Cross Bars?
- TRD Pads only last 15K miles?
- HIGHWAY VIBRATION could this Fix it??
- l-springs/shocks
- Wilwood 6-piston Brake Kit **UPDATE 02/03**
- TRD Sportivo sways on Results!!!!!
- H&R springs with which shocks?????
- L-Tune tips
- Question about L-tune in S CA
- Tires
- Replace OEM brake pads with new rotors??
- Wheel spacer installation
- Brake Upgrade / Replacement – Part I
- Replacing brakes
- Inside tire wear
- Pics stock height vs Espilier Spring/L-tuned shock height
- Hey I like these...( AbFlug STB)
- jusy got new sways!!!!
- Tein S. Tech/l-tuned Setup
- Question about spring/shock combo
- Tanabe Springs
- Tanabe 2 inch drop on stock 17's
- Misfit of Tom's Rear 6 Point?
- bad shocks--how do you know?
- Steering Pre Tensioner
- Any thoughts about bags on a GS?
- Uhhh..."Service Bulletin" for GS suspension?
- Ongoing steering-wheel shimmy
- Aftermarket Brake
- is 2" drop too low with stock 17" rims??
- Keep An Eye On Your *TRD* Rear Pads
- Need Some Advice On Alignment Issues.
- Supra brakes
- L-Tuned installation cost
- Uneven Tire Wear
- Caliper Colors
- TEIN EDFC installed with RMM STB
- A Definitive Rotor Break-In Procedure?
- Issue with SS brake lines bursting the calipers?
- 25mm wheel spacers
- Brake Fluid Replacement - OEM or Other?
- Brake warning light in dash comes on when applying brakes
- Coilover Users...Height problems? (TEIN FLEX)
- Just got my a new (to me) 99 GS400 and noticed something weird:
- Brake lines: only front or front and rear?
- Taller wheels/tires
- TOM's STB installed with TEIN flex -pictures
- Tom's Rear Lower Suspension Brace: Anybody With Experience on These?
- master cylinders
- Rotor Break In?
- Stupid Question
- pictures w/ l-tuned shocks/springs
- "harsh" road noise--tires only source??
- suspension
- proper drop
- st lowering springs? 2 inchs?
- tein cs's
- Tapping on Teins
- Just installed my Apex WS coilovers
- Suspension and Handling gurus, let's write down Stages for us.
- who makes 2" dropp
- l-tuned springs/shocks
- Just placed my first handling mods order!!!
- New L-Tuned steering ECU and shortly TRD sways believer
- calipers
- Flex's on and still too muc roll 4 me
- Skipper Height Adj. Coilovers (not for handling necessary)
- Espelir/Rims installed.
- correcting body roll
- Possible to fir a larger rotor with the standard calipers?
- Any experiences with TRW and PFC brake pads
- fitment
- H&R/Bilstein vs. L-tuned springs/shock set
- H & R Springs
- Reasonable cost For L-Tuned Suspension From Dealer?
- L-tuned springs w/ stock shocks?
- front strut bars
- Question for a GS newbie about SUS and Wheels
- Experience with Apex WS, Cusco Zero-1 and Zerox-2
- It won't be long......
- trd strut bar ?s
- Can I run 255/35/20 without spacers ?
- L-Tuned Steering ECU Instructions
- when it just isn't low enuf...
- RaceTech Rotors
- Tein S. Tech Lowering Springs
- Rmm front strut bar
- Race Tech Rotors
- still hear rattling???
- Help with Recommended Tires.
- l-tuned noise
- GS 430 Brake Conversion
- Do I need to aligment after lower my car.
- Is An Aligment Needed After ...
- Replacing Rotors. Need Help Bad?
- Slammmmmmm!!!!!! Tein Flex's
- any info on replacing break pads
- Powerslot rotor price
- new guy. 16" vs 17"
- please help? sway bar difficulty
- Eibach springs
- Question for CL Members with H&R springs
- Tein Lowering Springs
- gs vs bmw
- STB for '01 GS430
- GS 300 pulls to the left, what do you think? i was thinking about buying the car
- My l-tune shocks Squeak
- Lowering 1999 GS300
- Front Stabilizer Bar Squeak Courtesy of Lexus
- Has this happend with your Tein HAs ?
- Tom's rear lower chassis brace (pics)
- gs sway bars install questions
- suspension question from the new guy
- Cost for sways installation
- Who make the original Lexus and L-tuned suspension
- Question about L-tuned shocks and springs
- GS430 Steering Issues
- GS Brakes SUX
- Is Toyota Racing Development slowing down?
- New Suspension Going On As I Type!
- Is the brake system for the GS300 and GS400 the same?
- FAILED 4 piston Wilwood brakes
- Coilovers or sways,X brace and struts
- Daizen Sway Bars
- trd front brace
- steering ?s play in steering wheel?
- Zeal Endless, LS, TRD or PSS
- Fender Rub & 20's - Ouch!
- Big time noisy rattling from suspension...
- camber kit from H&R???
- Sportivo sways coming...
- Cracked sway bar brackets
- need suspension help
- Need HELP! Espelir Springs/L-Tuned shocks.
- L-tuned For 2002 Gs430??
- Update on Zinc Plated Rotors
- DIY: Spring/Shock Change-- Tool Selection
- EBC green pads impression
- Steering Vibration
- Tein Flex's: Install
- GS430 L-Tuned what do I have?
- Intrax springs
- Question on the Teins
- Which STB will work with EDFC?
- Brake system making gurgline noise
- Another Saturday Morning
- Missed the AP GB?!?
- Need help on Tein's. . .
- ***I've got NEW SWAY BARS***
- HELP ASAP!!! Question about AP Racing brake installation
- Squeeks
- I need help with vibration when braking
- Wilwood 6-piston brake setup UPDATE (12/05/02)
- New GS4 pulls to the left
- Had to adjust headlights after new shocks?
- rod millen brake pads
- my review of the trd sways
- Need info on Ride/Drop on 20's
- Pictures with 25 mm spacers
- Big brakes and gas mileage
- TRD Sways Installed - Thx Todd !!
- cupping tire question
- Buying used Tom's Coil Suspension good idea?
- Install Pics - TRD Sways/LCB
- need help with suspension noise
- Daizen sways.....
- RMM Brake Upgrade
- My Review of H&R spacers for the GS
- Monoblock Brake Kit
- Need Key to adjust my coilovers?
- The Crappy Lexus Suspension
- EDFC error code, HELP!
- What is it?
- TRD Brake Pad - How long do they last?
- SICK has SWAYS (factory springs/shocks), the roads will never be the same...
- What pads does Brembo Big brake kit include?
- Shocks/Sways vs TC/LSD..What would you do?
- Hey guys look what I just came home with from the BodyShop...
- strange steering wheel..
- maintaining big brakes
- Stock wheels/Tein Flex
- Handling/ride question for GS4??
- Just another thumbs up for Toyo T1-S tires...
- supra tt brakes
- Mini review: TRD sways, front LCB & Tom's rear LCB
