View Full Version : Suspension and Brakes
- Sway bar, Strut, spring installation Q's
- TRD strut tower bar fitment problems?
- allignment problems!!
- Big brake guys - fluid choice (ATE Super Blue or Motul)?
- edfc mounted in ashtray ???
- What is the part # for the clip that holds rear pads in?
- Strange noise after installing TOM'S rear brace
- What's Included???
- What Brand of performace rotors
- ***brake caliper paint***
- brakes & rotors
- Question re bar bolted on top of engine
- Tanabe Springs.... Help
- slotted rotors question
- Bradi Front Brake Rotors
- Strut Tower Brace/Bar
- Brake Pin Shim Question?
- LTuned combo or Eibach/Bilstein setup?
- Alaignment wear
- Tein Coil Overs question on hight adjustment
- Eibach or L-Tuned Performance Road Springs question and input??
- Supra TT Brakes and 1st Gen GS300 ?
- Supra Front Brake Upgrade
- part # for axxis brake pads front and rear??
- for the suspenion folks
- TRD Strut Bar on GS3
- alignment w/ espiler springs?
- need recommendation on a shop to install Daizen sways
- Need Coilovers...JIC FLT-A2 -Good Choice?
- where to buy stoptech...??
- toms 6 piece help
- Aluminum / carbon fiber pedals - brake,gas,foot
- TRD Strut Bar Installed
- Initial coilover installation...
- Help on upgrading my suspension.
- Eibach Springs with 20" wheels
- Latest pricing on Tein CS coilovers
- Destroyed my front coilovers!!!!
- WHAT is supposed to come with my shocks?
- Loose steering 03 gs300
- Springs
- Camber Kit - What is it and What'll It Do?
- Camber Kit
- My StopTech vacation (PICS)
- Latest News On Camber Kit?
- Which springs is closest to stock? Do I need shocks?
- ? re new ball joints
- H&R Coilovers
- Tein Flex Pricing - Is this good?
- TRD STB- do I need to realign front end after loosening strut nuts?
- L-Tuned Steering ECU for gs400
- brake caliper replacement
- toms 6 piece installed
- Clunk from the rear over rough roads
- Front Strut Nut Size?
- Alignment Issue
- **DO-LUCK floor bar review**
- Supra TT price
- Alignment/wheel balance problem? help!
- Daizen sway bars installed: my suspension now sounds like a squeeky bed!
- Clicking sound from center console when brakes applied.
- Need help with wheel fender gap
- trd strut bar vs l tuned ecu (or both??)
- L-Tuned Shock Life
- Speedometer/Odometer Reading
- What brand is good for rotors?
- Does having big brakes mean...
- What is this vibration?!
- Like this drop
- How long will the CS or Flex last. with 19's?
- Ltuned vs Bilstein Sports - which one is better?
- toms 6 piece
- Is it ok to fit slightly lower brake lines?
- Shocks, ectu, and Brake Lines
- My new suspension set-up (semi-write up)
- edfc lowering the car?!
- Need help on choosing and selecting big brake kit...
- Lowering Springs...?
- What is a ball park cost for installing new brakes?
- Front Lower Suspension Brace
- Clunking!!!
- DIY on EDFC install?
- Help!! Flex install issue
- new location of edfc
- Break Pedal_Problems
- Brake Install in Los Angeles?
- RVM Strut bar
- How low to go with 18s
- 99 GS300 Control Arm rattle/Ball joints Question
- Got a quote for some mod installs today...
- suspension
- air bag kit
- Strut tower brace???
- DIY brake problems...help!
- Loud sharp popping/cracking noise when first going in reverse and hitting the brake
- stupid question with rear stb's
- Desperately in need of your opinion ...
- Please help me with my suspension
- When changing to L-tuned suspension ...
- What is the difference between Bilstein Sport and HD?
- eibach vs. l-sportline springs
- Dealer Can't Fix My Front End Shake!!!!
- shock vs strut?
- Tein s tech
- L-Tuned Installed - Whats next?
- Rear upper strut /suspension bar
- HELP handling, exaust big problems
- daizen sway bar bushings
- JDm Suspension RSR
- Springs
- Front/rear chasis braces - any improvements ?
- How to adjust ride height w/ Tein Flex
- help me !!! H&R or Eibach with Blisten
- Where is the ECU Steering Module
- HKS Hyper D coilover help
- Your experience buying & installing coilovers?
- TRD Sway Bars
- No fender gap = what spring???
- clearence for supra TT upgrade ?
- Brake Pad Question: EBC Green stuff orUltimate ceramic racing brake pads or?
- Need Help! Long term modding plans...
- DIY Suspension Guys...Need help on Upper A-Arm
- Which Suspension
- Thanks
- review of tein HA, Flex, and CS coilvers on GS400
- tein coilsprings-drop springs
- Got Rotors?
- dropped my lex.. do i need alignment?
- Tein CS vs Apexi World Sport
- Heavy sound system, dropped my rear!!
- shaking steering wheel
- Tanabe Coilovers?
- A few newby (to coilovers) questions
- need help with susp.
- how long are springs and shocks good for?
- Lowering a GS400 - L-tuned springs + / - shocks
- Installed TEIN HA + EDFC on my GS400
- Anyone install their lowering coil springs themselves??
- difference in road feel for the TRD racing sway
- The softest lowering springs
- Brake Rotors
- I have stock GS4 brakes... bad pedal feel, noisey, grinding, etc... help!
- DIY Issue with ball joint removal
- Slammed Aristo
- lowering GS 430, searched but still confused
- What rear STB will clear EDFC?
- buying a used gs300, question about lowering
- tein HA yes or no?
- Tein Flex
- Strut Bar
- need help with brakes
- Gotta a Problem (got coilovers, wife thinks too stiff)
- Need help with brakes
- Creaking from Tein CS
- RMM strut bar install challenge?
- whos got the lowest gs?
- Emergency Brake Stuck ... HELP!
- Daizen sways installed...my thoughts
- goodridge brake lines
- Supra TT Front Brakes
- Eibach/Ltuned Springs w/ Bilstein
- tein height adjustment
- Cut Bumpstops? or not! Thnxz
- Which Suspension are good for GS
- springs with the best ''RAKE''
- Front ball-joint failure?
- Apexi N1 World Sport Preview
- How many GS's had Master Cylinder problems?
- Are Sprint Drop Springs the Lowest/Best Available? If not, which is lowest/best?
- Just installed Apexi N1 WS dampers...
- GS on Espelir springs on 255 35 20 size tire?
- Bilstein Sport plus...(Eibachs or L-Tuned springs)
- Bilstein PSS vs. Tein Flex Coilovers
- Thump noise w/ Daizen Sways?
- What's the stock GS ride height?
- did the ltuned springs/bilstein sports
- shock bumper
- Tein Flex and EDFC installed
- silver gs
- Characteristics of 17" Rims/Tires
- Espelir springs - the LOWEST drop? where to buy?
- l-tuned suspension manual...
- Help: Caliper Colors
- bilstein sports
- ** Rotora 6-Piston Front/4-Piston Rear installed......I'm in love!!
- Shim Kit needed...help!
- Cross-Drilled/Slotted Rotors: Question
- picture of my painted brakes
- pictures of my cars
- Got a couple ?'s...
- TEIN Checkup. How Often?
- Adjusting Your Teins
- creaking w/L-tuned sways/struts/coils?
- what kinda of drop do you think this is ?
- Auto Leveling after Coilover Installed
- Tuning your Teins???
- EBC Greenstuff Sucks!!
- Tein CS - My Opinion
- teins flex
- L-Sportline with Bilstein
- Cross Drilled vs Slotted
- bilstein sport shocks
- Question for suspension gurus on my next mod
- GS's on L-tuned suspension.
- Are H&R 5mm spacers hubcentric?
- Help: Spring drop's and how much they drop
- Dress up Form Springs/Tanabe DF210
- Pillow Ball Upper Mounts For TEIN HA.
- Camber adjustment for GS!!
- How hard is it to install supra TT brakes on gs400?
- Apexi WS Coilovers
- Upgrading Teins
- STB Fitment confusion
- maintence on coilovers
- steering wheel not straight..
- Daizen Sways - Review
- Who has pictures of different EDFC installs
- L-tuned Steering Ecu, How Much$?
- Need help Installing the TEIN EDFC on my GS
- bilstein/ltuned setup
- How to flush brake system and swap DOT 3 to DOT 4?
- curious about bushings?
- Need help - clunking noise when braking
- Stock brake piston sizes...Stoptech?
- Suspension Advice
- RE-Lowered my car...
- New Owner, got some questions
- SS Brake Line Installation
- Tein Stech
- abs problem ??????????
- front STB
- Just Picked Up My Tein CS!
- Sway bars
- Eibach with stock 17s
- Replacement shocks for '99 GS400
- How long do the TEIN shocks like on HA,CS,Flex last for?
- Im sold on lowering, now I just need advice!!
- brake pads
- loose steering wheel anyone???
- How to remove rear caliper
- "Brake" Warning-Dash light keeps coming on?...
- Impressions-teins Vs L-tuned
- Please Help - My Steering is very Loose
- need new brakes. any DIY's
- Rear Sways
- Help- Slotted Rotors EBC Pads
- Slotted Rotor size question
- Tein FLex...
- Need brakes
- need some help w/ECU install...
