View Full Version : Suspension and Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20
  1. Lowering advice
  2. Softest suspension: CS or L-Tuned?
  3. gs300 brake pads
  4. Is it possible to resurface slotted rotors?
  5. Where to buy spacers?
  6. Spacer Q: Grinding 10mm spacers to 7.5 mm
  7. teins flex
  8. Bilstien PSS or Apexi WS Coilovers?
  9. springs
  10. Supra TT brake question
  11. best springs
  12. THUD noise after installing HKS LS+ coilovers
  13. Airbags? Experiences anyone?
  14. Camber Kit...ETA!??
  15. Does it take longer to install coilovers than S/S on GS430?
  16. My first suspension mod.
  17. Will any big brake kit fit me?
  18. Anyone heard of D2 coilovers for Lexus?
  19. How low without camber kit?
  20. alignment w/l-tuned
  21. L-tuned Spring/Shocks Problem
  22. Front suspension change procedure
  23. Have had the car 3 weeks, NOT enjoying the car already.....
  24. L tune steering ECU
  25. How much drop with L-tuned?
  26. tein CS
  27. Aftermarket Struts with L-Tuned Springs
  28. Cheapest place for L-tuned
  29. TOMS Front Lower Chassis Brace Installed
  30. HKS LS+ coilovers and Defi boost gauge installed....
  31. Bilstein PSS Coil-Over Kit
  32. Installing Tein Flex
  33. sway bars
  34. Tein S-tech spiings help!!!
  35. Rotora Steel brake lines....are these good?
  36. BIG BRAKE questions
  37. A friend of mine is selling his IS OEM rims...
  38. TEIN CS, Daizen sways installed!!!
  39. question on Tien Springs..
  40. E brake, VSC on/off, and ABS indicators ON!!!!! Help
  41. Where to install the EDFC controller
  42. JIC coilover review
  43. Question about Tein Ha's (turn clockwise or counter clockwise to change stiffness??)
  44. What gap did you set between your tire and fender with Tein Flex setup?
  45. mounting EDFC
  46. help: Post before and after pics of your suspension drop
  47. Happy Thanksgiving!! Do I have to raise the car to install the TRD STB..Help please..
  48. question about dropping...
  49. Pic Request: L-Tuned sus on 19"/20"
  50. what are some good suspension products out there?
  51. VOGTLAND springs
  52. how I spent my Saturday...pics included
  53. Installing the OEM front 2-pot calipers in the back?
  54. supra brake question
  55. L-Tuned ECU Installed
  56. Warranty Issue with aftermarket part installed
  57. TRD front strut tower bar?
  58. eibach or ltuned springs
  59. Supra Tt Rear
  60. For those with the Tein Flex, can you still have the TRD stb on the shock towers?
  61. Would adding Daizen sways void the warranty..if yes woudl it be susp warranty only
  62. supra brakes and stock rims
  63. GS400(slow) is no slow dog..A bit surprised today
  64. PIC: SUPRA BRAKES and TEIN FLEX/EDFC
  65. OK..Just been told that I can have new TRD shocks and struts..My budget is very tight
  66. bilstein and eibach
  67. Are Axxis Pads good for our car?
  68. what do u think of trd brake upgrades?
  69. So L-tuned discontinued..Can I get eibach instead..can I change just springs for now?
  70. GS4 Newbie..been searching forums every night..got some ?s
  71. Best price for Tein Flex?
  72. UGO Front STB Arrived, Installed, Tested
  73. Tein S-tech Springs Fit Gs300?
  74. tools needed for brake job
  75. Bilstein PSS backordered
  76. New Rotora Brake Rotor setup
  77. is this a bad rack and pinion????
  78. question about stock Front brakes....
  79. L-Tuned Steering ECU-Discontinued?
  80. who has a lowered GS?
  81. Are the TRD sway bars and strut braces worth it?
  82. Is L-Tuned the Same as KYB?
  83. Lower Control Brace Question?
  84. Opinion..25mm spacers on the rear
  85. Supra TT Brakes Installed- Pictures
  86. supra brake upgrade
  87. ? about lowering
  88. UGO Front STB on Stock Suspension
  89. supra upgrade pad spacers
  90. 2003 GS300 Sport Design Suspension Setup
  91. L-tuned struts?
  92. Finally, L-tuned struts w/ eibach springs getting mounted on Wed.
  93. Another Supra Brake Upgrade Thread w/ PIC
  94. bleeding of brakes
  95. Porterfield R4S Pads?
  96. brakes (how much brake fluid do I need?)
  97. Tein CS and TEIN EDFC Combo
  98. supra upgrade
  99. traction in rain with new sways
  100. Tein S-tech pics?
  101. Got da socks on!
  102. If I want my TEIN CS Coilovers to ride like stock...
  103. Random Brake Noise
  104. Daizen Sways, TRD Sways, OR Toms Sways :Which is Recommended?
  105. The definitive Weight Reduction list..........
  106. Warped Rotors
  107. Anybody here with LS 430 brakes?
  108. New GS3 w/ front end vibration
  109. Strut Bar
  110. How many GS owners have uneven rear tire wear?...
  111. Is a brake upgrade really required with upsized wheels?
  112. Will my GS300 suspension look funny with 19" rims?
  113. Bouncing around like a rabbit in heat.
  114. My new DSR Monoblock big brakes!
  115. Coilovers
  116. Has anyone else tried the L-tuned struts w/ Eibach Lowering Springs?
  117. Problem - Groove in brake rotors
  118. Super suspension
  119. Adjusting Tein Coilovers
  120. Best deal on Bilsteins????
  121. Supra TT brake upgrade ?
  122. TRD brake system?
  123. cross drilled and slotted
  124. How doI remove some rust on my brakes?
  125. Need advice on ECU for steering
  126. does anyone has outside wear on front tires
  127. L-Sportline Suspension: anyone had it before?
  128. suspension suggestions
  129. Brake Pads
  130. comparing springs
  131. Track test Sway Bars Results
  132. Tein HA , English installation manual !!! where do i get it!! help!
  133. tein springs
  134. What do you guys think of these springs?
  135. front STB on '03 430
  136. Specs needed for proper alignment. Purchased L-tuned Struts & Eibach Springs
  137. Difference between Pro and ISD ceramic brakes
  138. how miles do you have on your L-tuned suspension
  139. Whats the life expectancy of the L-tuned struts
  140. STRUT BAR Suggestions
  141. Shocks Question
  142. Need Help Guys (rattling from rear after brake job)
  143. coilover upkeep
  144. Sportdesign suspension question
  145. How Low is Everyone
  146. will eibach spring & kyb shock from MKIV TT work?
  147. Tein's Stuck--
  148. "LEXUS" machined brake calipers
  149. EBC Green stuff V4 Brake pads
  150. help gs400 owners (steering feels loose and wheel trembles)
  151. TRD Sways...is there 2 different kinds?
  152. Axxis part #'s
  153. Camber Kit???????
  154. Increased tire wear
  155. wheel offsets
  156. TRD Sportivo Sways
  157. Cannot remove one of my wheels!!
  158. sways
  159. Baer EradiSpeed+1 Rotors
  160. Pics After Daizen Springs & Sways
  161. question on 19in
  162. What big brake kit do you have?
  163. Big brake upgrades
  164. Why Big Brakes?
  165. Groaning noise from Driver side front suspension
  166. Will Low profile tire Strain the …!!?
  167. Good steering fluid ??
  168. Should I spend the extra $$ for coilovers?
  169. Alignment issues?
  170. Wheel spacers AND front caliper clearance?
  171. 2000GS4 Ride Question
  172. brake comparison
  173. ? about going bigger rims
  174. SUSPENSION: I'm confused.
  175. can gs4 be lower with 20's
  176. L-tunes or Bilsteins
  177. Eibach L Tuned Suspension...from Rod Millen...will this damage my car?
  178. SC430 BigBrake kit does it fit on GS?
  179. ** TRD Suspension Bushings **
  180. Lowering my GS300
  181. semi-metallic vs. ceramic brake pads
  182. Those with painted OEM calipers
  183. Tom's Racing Lower arm strengthening plate / upper arm support bracket
  184. supra brake uprade offset
  185. Best Handling GS On Clublexus?
  186. Question about brake fluid.
  187. Axxis Metal Master brake pads + OEM rotors
  188. differences between TEIN models
  189. serious problem..
  190. Teaser Shots!!!
  191. brakes
  192. GS400 front end rattle
  193. L-Tuned & KYB
  194. How to install the TRD STB
  195. brakes
  196. tein reliability?
  197. L-Tuned Shock leaking oil
  198. center of gravity??
  199. springs and shocks
  200. Why does my car shake while breaking?
  201. average price
  202. upgrading rotors and pads...any advice?
  203. Brakes Scraping
  204. The Race is On
  205. PART# for TRD swaybars ?
  206. Finally changed my Teins...
  207. Quick lowering question..
  208. 94 GS300 -- about to lower but need advice!!!
  209. stock 16" rims...........99.....widest tire?
  210. Camber kits for GS4 and 3...in sept.
  211. **Brake rotors choice?**
  212. front strut bar for 1st gen gs3
  213. Recommendations for Camber
  214. Front Seats
  215. tire wobbles at 60mph??
  216. upgraded steering
  217. Tein S-tech Springs
  218. is alignment needed?
  219. Daizen Lowering Springs
  220. When you lower your car, why does the drivers side sit a little lower? maybe .25"
  221. Great New Tires On My Gs
  222. Daizen sway bars..opinion(s)
  223. What's up with the new GS brake pad design?
  224. Bilstein Sports and L-tuned Shocks: Pics side by side
  225. L-tuned Springs: the end of the speculation
  226. Camber kit for gs400?????
  227. GS430 Strut Tower Bar - Keep the Cover!
  228. L-Tuned Suspension+ Alignment Issues..Help!!
  229. trd lcb, front rear sways, stb installed and...
  230. how low till you need camber adjustment
  231. Are these any good?
  232. tomorrow is the install.
  233. Got my APEXi WS coilovers installed ... My thoughts and feelings
  234. Newbie question on sways, shocks, and braces
  235. Camber kits for gs 300
  236. help w/ rear Daizen sway bar installation
  237. Do the new Gold LS430 fit the GS300/430?
  238. Brakes making noise
  239. Adding New Springs -- Alignment Needed?
  240. EBC Greenstuff upgrade - need to resurface rotors?
  241. Difference in stock suspensions
  242. tein HA'S
  243. curious install $ control bar, front and rear sways
  244. Do I need to take off my TRD STB to remove the engine cover?
  245. how low is low?
  246. Ohlins coilovers?
  247. APEXi World Sport Coilovers - Thoughts n' Feelings
  248. Does anybody have HKS LS on there car?
  249. shock+springs shop near Germantow MD
  250. somebody please help (handling issues)
