View Full Version : Suspension and Brakes
- Anyone have the FAMOUS WHEEL SHAKE-after new wheels, hubcentric spacers, tire, lower
- best coilovers for daily driving
- Drop **question**
- Stance LX+ coilovers?
- Best lowering springs for my gs400
- Picquest: "F Sport" decal on LS400 calipers
- Tein EDFC
- Lexus service tech told me they only change the brake fluid in the reservoirs
- Hawk HPS Brakes
- Brake Caliper Decal
- brake fluid flush and ABS method
- Experience with tanabe sustec S-OC coilovers?
- Best price on df210's
- VSC light after tein cs coilover
- Coil Overs
- Put on the new rotors
- Suspension ?'s Need Help with Custom Air Ride Build
- What is the best air compressor?
- i need a ? answered before i buy some new toys
- dropped gs300
- 99 gs300 uas suspension
- clunk and popping noise
- Car and steering wheel shakes under hard braking in rain?
- omg, thats all i could think when i say this
- 19x10/10.5 SSR SP1 on Tein CST, finally installed :)
- Knock in front end when quickly turning right
- does the brake fluid in the reservoir flow into the brake line and vice versa?
- Popping/Clunking Noise when going from Reverse to Foward
- Wilwood 4 piston package
- cracking daizen sway bar bushings
- Are these what we need???
- Brake Fluid flush/bleeding question.
- New Eibachs - GS400
- new coilovers.. which to get
- Pic request: 245/35/20 on 20x10s (and camber question)
- Cutting Holes for Upper Control Arm????????
- Brembo Brake Rotors - 25555 Vs. 25603
- Finally did my ls400 brake upgrade!
- Possible to install front springs to rear and rear to front by mistake?
- KYB-GR2 w/Tein S-Tech springs
- New Brakes
- Tein flex broken - suggestions for replacement tough suspension?
- Only One Way To Diagnose Bad Wheel Bearing???
- Brake Pressure problem
- Correcting the suspension geometry.
- question about spring? needs advise?
- Brake Pads wearing uneven in the rears
- Please HELP! (Daizen sway install!)
- what to get? plz help
- Heard of NEX Coilovers on Ebay
- Street ride pro air ride
- clunk n clink noise coming from the rear of my car.
- Question about Iforged Senekas
- Coilovers?
- bilstein pss/ tein cs coilovers??
- My Coilover Debates
- Rear Strut Bar
- Warping Rotors
- Need Help disconnecting Upper A from Spindle/Steering Knuckle
- Rubbing Issues after new set up.
- Exact Motorsports RCA Bolt Failure!!!
- question bout slamming car
- Stock to Eibach Pro-Kit
- Need Struts to go with L-Tuned Springs.
- A couple simple questions
- kyb after effects...
- 99 GS300 "Brake" "VSC" "ABS" "VSC OFF" light on
- Sway bar install question
- Pic request!: Tein CS (v1 or v2) all the way down
- Brake Sensor Damage?
- do pads wear faster w/ bigger wheels???
- Grinding from right front wheel please help!!!
- Still getting a poppin sound when braking and turning out of driveway and corners.
- brake rotor life
- UAS or AR?!?!
- I need a camber kit asap
- question: why does my staring wheel shake 50-60 mph?
- 98 GS4 Suspension update
- whats better?
- Installing coilovers for 2gs
- Little issue with install (spring+shock)
- Anyone seen this yet? K-sport inside
- Squeaking noise from front end
- Bought JeffTsai's old grille. Lower on coilovers. (9 pictures; 804KB)
- drop with tanabe, too much negatice camber
- Rear Espelir springs are making croaking sounds
- Slotted/Drilled Disk's
- Not another coilover thread but....
- Dot 3, 4, and 5.1 brake fluid
- Opinions need on Ebay drilled and slotted brakes!!!
- Got a Clunk noise from Passenger Wheel.. NEED HELP!!!
- NEED HELP!!! GoT a Clunk Noise Coming from Passenger Susp.
- How to check for water in air suspension system?
- My after alignment specs
- Lower ball joint UPGRADE?
- Lower Ball Joints Replaced
- how many have camber kits?
- Changing Rotors......quick question
- GS400: handle like a 3-series?
- Aftermarket Sway End links...front and rear
- bad wheel hub/bearing?
- i want air rides
- UAS air with KYB vs. Stocks?
- Trouble installing camber bushing
- Can't get car to drive striaght!
- help help help nf210 for gs300 sags lower than expected
- Air Force Air Suspension Group Buy Interest?!
- Help....
- HKS discontinued all coilovers for 2GS?!?!
- How Low Does U.A.S. go on '99 Gs300???
- Best spring for new stock strut setup?
- Installed coilovers this weekend.
- Adjustable front control arm $350
- What springs are better? Tien, Tanabe, or Eibach?
- Rotora BBk owners.. please chime in
- I want to add a second air tank (air ride)
- Where to get stainless steel brake lines?
- Brake bracket on coilover question.
- What to do to make these wheels fit?
- Advice on Espelir ASD springs?
- new brakes still noisy
- what's different in 2000 and 03 GS3 suspension
- 18" Tourmaline clear Supra TT BBK?
- Fixed my tein rattle
- Whats the lowest you can go to keep the Alignment in Spec?
- Footworks? Tons of Suspension parts
- Good deal on Bilstein Sports
- fixing camber????
- $700 for Lower Ball Joints??
- DIY Daizen Bushing Install Tips
- Will these clear BBK
- Tein springs(Is $225 too much to install)???
- Spring/wheel/tire size combo that works without mods 98 G3
- any opinions about D2,megan,ksport coilovers?
- Is it possible to burn brake fluid? (like engine oil) LoL
- K Sport Pro and Cons Feedback Please
- blown tein HA
- Umnnn...How do I install this "SPC" Camber kit?
- Re-use endlinks?
- Putting KYB GR-2 and DF210 this Friday
- Any Tein coilover owners with EDFC willing to part with their click assy kit...
- Will a 98 GS400 Master Cylinder fit a 2000 GS300?
- 65 degrees F in Dec.! 6 pictures before coilovers.
- How many ft.lbs torque for the bushing on a Daizen front sway bar
- Daizen grease substitute
- Question about Coilover Height Adjustment
- Bilstein shocks? What else do you prefer with my setup?
- How far apart..? and Brembo question.
- Stock or Not
- Lower Springs / Coilovers
- Excuse my ignorance, but quick question..
- Where Online Can I Buy R1 Concept Rotors?
- Tanabe DF vs GF Springs.
- Anyone with JIC SF-1?
- Brake pad and rotor replacement question
- Need help badly with brake pad change, i have run into a problem (pic)
- 98 gs400 air suspension question
- audible "clunk" noises from floorboard area, especially when turning or backing up
- Where in GA can I buy EBC or Hawk brake pads, summit racing is out of stock.
- OMFG my sway bar mount broke.
- coilovers for 99 GS 400
- Need some input on painting brake calipers
- Eibach Springs Pro-kits any good?
- Rear Adj. upper arms.
- Hypermax II
- Are these springs any good?
- caliper extenders?
- HKS Hipermax LS+ height adjustment
- Painted Brake Calipers
- Suspension / Body brace
- I'm lowering my car... What do I need?
- Problems!! Need Help figuring out ABS Brake Issue!!!
- Stiffer Springs on Coils = Damaged Balljoints?
- Aristo question V300
- Want to cut my tanabe df210's, only the fronts, need guidance!
- GS feels like a boat ? ? ?
- will this strut bar ...........
- noise when brake depressed while car is parked
- air force air suspension ?
- Upper Cntrl Arm - Mevotech
- tein s-tech
- Tanabe DF vs. NF
- So I got some Tein SS's for free yesterday.
- tanabe f210
- H&r spacers or no name brand
- Do stech springs sag
- Brake Booster Issue.....
- Coilover rebuild
- I NEED HELP!! Brake Pressure is soft....
- stech springs with is2 18*8.5 with 25mm spacers
- Toms vs Trd
- Are these Ebay Rotors/Pads Any Good?
- Tein front strut tower bar on my 430
- Toms Rear STB post install question
- New rims + new coilovers= sexy pics
- need help car shaking after coilover install
- Best springs 4 a drop
- Supra Calipers - New / Rebuilt ?
- Another wheel fitment question
- Does this sound like a deal? rotors
- Rear Stabalizer bar; Maybe?
- Tell me which pads to buy
- Quick Question
- Reviews on HKS Hypermax Coilovers
- a question about a drop
- Camber question
- Anybody know how RCAs work?
- Busted Rear Upper Ball Joint!!
- spring question
- Tein ss
- How much does brake service cost from the dealer?
- need help/advice with brake problem
- how do you know...
- Torque Spec. for Wheel bearing nut?!
- How to change wheel bearing
- Question Regarding Brakes
- K-sport coilovers Anyone?
- Soft brake problem solved
- rear camber adjustment
- urgent help needed tanabe install
- 2nd gen gs400
- Skidpad numbers
- daizen sway bars
- Tein Coilovers
- Putting on Springs = $750!!!???
- 4 Piston Vs 6 Piston Vs Stock?
- Eibach and l tuned springs
- time for new brake pads!
- Strut Bars, Im Having A Hard Time Trying To Find One.
- Problems with braking system...HELP!
- Largus Sway Bars
- 97 sc300 Slotted/Drilled brakes
- CALIPER PROBLEM!?! First gen brakes on a second gen?(98)
- Coloring the Calipers But No Decals
- Tein SS
- squishing noise on Tein Coilover!!!!!!!!!!!!
- Got some new suspension toys...
- Ball joints!! Replaced! yea!
- Brakes.
- Steering shimmy - Help please
- ball joints binding when laid out
- Tein SS question
- Toms 6link
- Tannabe NF210's
- Ball joints & Tie Rods
- Need oppinion on coilovers
- Sway bar brand
- Coilover Question?
