View Full Version : Suspension and Brakes
- Big Brake Kit question!!!
- Easy way to raise coilovers?
- megan lowering springs?
- Popping sound when raising airbags...
- Is it all in my head? Advice?
- Daizen frt Sway Bar + Rear Sway Bar Bushings
- Lowering Help
- Where Can I Find These Lexus Metal Gas+Brake Petals??? (PIC INSIDE)
- Weird motor noise coming from the Master Cylinder area
- Broken Spring Perch Fixable?!?
- Autozone LS400 Calipers the same?
- Upper Ball Joints Only???
- Questions/ help me find DBA 4000/ 5000 rotors
- Need DIY for Spring Install on GS430
- My rim wiggles...
- Front Camber Kits on IS350
- OEM wheels w/ spacers question - searched already
- HKS Kypermax LS+ Install
- best camber kit
- question about ball joint brand.
- recommended shock
- One side Lower than the Other??!?!
- My whole car is shaking after 40 mph, ive tried everything..
- Bottoming out w/Tein CS and Stock (Ft passenger)
- Interchange parts
- HELP PLEASE ! Rear E-Brake Adjustment
- Brakes dragging after install?
- k sports coilover
- spring clamps
- Replaced driver's side upper control arm -- YIKES
- aftermarket ball joint??
- anybody with tein cst w/ edfc?
- Tein cs f/s
- Lowered but keeping comfort (and other questions)
- Squeaky brakes/rotors
- REAR supra TT brake fit on a 2GS???
- Can stock height on GS300 fit 20s?
- Rotors won't budge need help!
- ? how low does BC coilover go?
- brake master cylinder leaking
- front VS rear suspension
- When did they come out with Tein S-tech springs for 98-05 GS300?
- STANCE GR+Plus Coilovers - Who has them? Hate it or Love it?
- Lower control arm bushing
- Coilover Opinions
- help with drop
- Best Coilover?
- anyone know where i can in stall my sage rca? LA/626 area
- Oem rotor replacement
- Need help with changing brake pads.
- Brake Fluid levels.
- Full Suspension Setup
- FIGS MEGA ARMS for 2GS, installation and review! PICS!
- Squeking noise after installing Tanabe DF210
- About to install new rotors, SS lines too?
- Stance Coilover Install write up!
- What happens when upper ball joint fails?
- parts.com
- Coilovers came in!
- The reason for terrible accident
- Indep. dealer won't install
- strange incident with rear brake hardware
- ebay upper control arms
- spring question
- how low can i go with 20 inch rims
- Repair Manual
- Toe Problems
- Air Force Cup Kit Suspension
- got a question on g35 wheels
- replacing tie rod on gs300 2nd gen.
- Just bought a 99' GS, whats the best coilover for daily driving?
- Need a solution to fix inner tire wear issue ASAP
- Supra BBK with stock brake lines
- Question to Bilstein PSS owners
- FIGS MEGA Arms for the Gen2 GS camber correction
- Suspension help
- Ok so i got my alignment done and i have a question or two.
- ***Camber/Caster/Toe Alignment Info Thread***
- ____Stance coilover question thread____
- Odd Noises Coming From Brakes
- Brake pad advice for GS400 needed. Thanks
- Any other springs have a similar drop to Daizen?
- turning drilled & slotted rotors
- Problems bleeding brakes after LS400 install
- getting custom coilovers built need spring rates
- Been a while, here some new PICS!
- Sage vs Exact RCA?
- anyone see this yet? new camber kit?
- alignment
- D2 or Megan Racing or Tein CS?
- Rear Brake Shoe Options?
- New shocks?
- Suspension help, Boston, MA
- Removing lower control arm--stuck bolt??
- New Shocks
- The suspension saga continues with bars, bushings, etc...
- *new pics* BBK installed
- TRD sway bars are installed - review
- New suspension review
- springs recommendations
- Daizen sway bars installed, now the car oversteers like crazy
- Looking for opinion on springs/shocks combo
- KYB or Bilstein
- Finally...Coilovers.....
- Where Besides Tirerack Sell Branbo Blanks?
- Bilstein sport shocks?
- TRD sways have arrived
- TTE adjustable suspension vs Tein SS
- Brake pulse problem.
- JDM Aristo Strut Tower Bar
- *help* rims hitting brake caliper.
- brake problem. please help
- Which rotors and pads to get?
- Spacer opinions needed,picture inside.
- ALIGNMENT HELP! - I have no idea what I'm doing...
- Coilover springs are extended?
- Installing LS400 calipers on my GS300
- Rear Suspension Squeeking Noises
- Control Arm Clunk? (pic included)
- Brembo OE Rotors-Don't use them
- Serious Brake Problem!!!
- L-tuned suspension . . .
- A lot of vibration after my spring install
- Should i get the k-sport pro air suspension??
- Has anyone used this company for air suspension?
- GS300-400 coilovers on the SC430????
- Is it possible to make your own RCA's for much less? Here is some ideas.
- Spring sleeve removal question
- Coilovers [What is currently best on the market?]
- Supra Brakes/Spacers Help?
- Anyone running 20s w/ stock brakes?
- Rear brake cover grinding on rotor
- really stupid question.. what is RCA?
- brake and windshield please help!!!
- newbie say "Hello all"
- Help identify noise
- ***BIPPU/VIP Suspension Setup***
- Any old GS ball joints out there?
- daizen sway bars with factory bushings
- Sway Bar combination
- anybody have the d2 air suspension??
- Lower Suspension Arm Questions
- Brake rotors...who's rockin' what?
- Sage RCA's Installed...Pictures
- Making my car lower without air suspension
- Brake gurus....does this mean i have a stuck piston?
- Squeaking brakes!!!! :(
- Controller for hks coilovers????
- Anyone has megan coilover on their GS????
- daizen control arm bushings to Stock
- Problem with my Teins lol
- Brake problem: Rumble when trying to come to complete stop
- 300 ft lbs of torque wasn't enough
- Hydraulic Suspension vs Air Suspension
- potentially big problem....
- Will Megan coilovers off a LS fit a GS?
- electrical issue: hit brakes, CD player turns off wtf
- GS400 Motor Mounts
- is-f brakes can they work on.........
- Replaced control arms; no luck
- is this a good/legit camber kit ?
- suspension ???s
- Got torque specs???
- My air suspension is HERE!! But, Im a noob
- ball joints and control arm problems
- Brake issue - help!
- How many people would DEFINITELY buy RCA's if.....
- need help on suspension problem..
- Noise when turning left only
- replacing brake fitting
- Why don't more people use RCA's
- Supra TT brake conversion
- Ride Height??????
- Wtb tein cs coilovers w/edfc . . .
- Lower Ball joint Nut problem
- Question about lower ball joints and tie rods
- Coilover Question
- Anyone heard of BG Racing Adjustable Coilover?
- Coilover/CA bushing question...ScARY
- NF210s, KYB-GR2 and 18's, any with this combo? How does it ride?
- 98GS4 power steering pump!
- UAS-What did you get
- skid control
- thinking of selling air suspension
- Specialty Products Control Arms
- what could it be !
- Adjusting Damper - Tein SS
- Help Needed on 93 GS3 Tire ware - Control arm bushing
- can we use universal air suspension on tein comfort sport
- which springs are better?
- sway bar end link
- Brake pad question!
- Does anyone have "brake caliper cover"?
- IS350 brakes???
- Front Control Arm Bushes - DIY or not?
- Purpose of cutting the lower bumper off to install Daizen springs
- Strut bar that clears GS3 engine cover?
- lowering car while retaining silkysmooth LEXUS ride?
- Rear Suspension Removal
- Tightening Tein Flex Pillowball mount
- HELP! megan coilovers installed and making sounds?!?
- SS brake line question
- Tanabe DF210 Clunking sound (front right)
- ???whats the best drop with springs???
- Lowering springs with stock shocks??
- Spring clamps
- Inexpensive drop?
- Air Suspension Options! Cheap/Quality?
- mrr gt1 wheels clear a bbk setup Y/N????
- New suspension for '98 gs4
- Noise & Slack Steering after L.B.J replaced
- Help please
- question on TRD stb
- Megan coilovers adjustable camber?
- Rear brake
- AP racing gs430 bbk
- Stoptech 4 corner bbk
- Worn Lower Control Arm Bushings = Floorboard THUMP when braking ?
- Universal Air work on a Megan coilovers?
- What's the difference between Bilstein HD & Sports???
- How can I tell if my struts are blown?
- Vehicle specific DF's
- lower control arm replacement... what else to replace?
- So my rotors..
- SS headers installed 3/14/2009
- Suspension updates
- Brakes dont respond well after front brake change
- why do the rear brake pads of my GS always wear out twice as fast as the front pads?
- Anyone used 400/430 springs on a 300
- Ksport BBK
- chrome calipers
- The "Lowering" Dilemma
- Life of Stock Struts
- I'm going on AIR everyone !!
- The shipping/receiving dude at work gave me a call after UPS arrived
- SAGE Racing Coilovers + Tein EDFC
- Fedex banging on my door at 9:00AM this morning....
- whats the best spings and how low
- What are the disadvantages of SS brake lines?
- WHere to get uas for 2k??
- DIY on Wheel/Hub Removal????
- Can't tighten upper ball joint nut
- My caliper has seized piston - how to rebuild?
- Noise in the Fronts.
- Adjustable Swaybars
- Brembo brake question
- effects of lowering?
- Brake life on these cars is unreal!
- Springs-wheel-Upper Control Arm question
- please please pleas help!!!!
