- Who the heck is this?????
- Intro~
- Replaced my front pads and rotors, now the accumulator is making noise?? help!
- Custom interfacing, fuel management
- VSC possible battery issue.
- How do you adjust the RIDE HEIGHT SENSOR?
- Quick Question about Ichiba vII 20mm Spacers
- Update: MRR GT1's
- SIGH New creaking noises PLEASE HELP! =[
- Tire Q...need to confirm my suspicion
- TRD Japan vs TRD USA
- Some advice on 20"s
- Oil Filter sizes
- Found a gs 430 need advice
- Question for LMS CAI owners GS300 01-05
- Fuel Gauge Never Full Now
- Battery drianed over one night.
- To paint or not to paint?
- I Got Rear Ended!!
- Help with wing install
- I LOVE my GS300
- rear tables
- Had some work done to the car yesterday...
- Suspension Estimate
- 98 gs 400 upgrade navi 01+
- Venza 20x7.5 wheels on 2GS?
- new signature =D
- Slamming in 2nd gear? n window prob.
- Pic Request: specific Trunk setups
- New pic white on white
- GS/Aristo Trunk Carpet
- Airrunner GURUS!!! setting Airrunner dampening????
- Complete list of service bulletins
- --side skirts review--
- Well its about damn time.
- Is this car woth the money? link inside
- 16" to 18" wheels, get another alignment?
- Vibration & Rattling
- Well its time to finally fix my car(56k oh no)
- What color are your hid's?
- Audio question for you guys.
- How about these 20's on Green GS?
- 245-30-20 vs. 245-35-20 - any rubbing issues in the front?
- GS300 sticky gear (auto)
- Hey, my battery died last night after 145K miles and 8 years....my only concern is...
- What to do with the GS3
- Noobie needing help identifying a GS430 or 400 ???
- All Lexus GS300 Sport Design Owners Post Here
- Door lock/unlock problem
- euroline dh offset
- 2Gen and 3 Gen Center Caps Interchangeable?
- **Need Wheel/Tire suggestions for new set**
- should i flat black my 2gs?
- Jzs161 aristo(gs300) gs350 fcs
- 99-00 Nav system into 01+
- Halo question???
- PSA : Anyone looking for a white GS400 near Boston MA area
- Farewells, for now =*(
- Air Bag Sensor
- Gas flap wont stay open!
- Fog light stay on only ?????
- Door acutators.
- Picture Request...>White 2gs With BLACK headlights.
- Play in steering wheel after caster arm and daizen steering rack bushing install
- 20x9.5 +39 non staggerred???
- **look**led blue gauge cluster.very blue
- ugo spoiler?
- CEL on after alternator and battery replaced.
- my taillight mod. yay or nay?
- hmmmmmm 19's or 20's
- Special Service Tools or Not: timing belt change
- 1st time on CL, Bad AC problem help.
- who has one?
- Repolish Trim Around Car
- Rim fitment?``
- Side view Mirrors
- Where can i purchase some Work VS-XX??
- HELP Please. Climate Control
- Check engine light, code PO171, GS 400 need help
- Which Lexus to start out with?
- 1st post, new ride, my goal, your suggestions?
- 03' ECU into 01' body, can it be done?
- Vent Visor Question
- spark plug replacement @ 90k or 120k???
- after market steering wheel adapter???
- 19x8.5 Sevas S star Chrome...PIc request and suggestions!
- Transform Black Leather into Saddle Interior for 02 Lexus Gs300 Sport Design
- rack and pinion line broke
- hello am a newb got question about las vegas members
- CF tach
- Car is SMOKING! But not overheating...
- Need part # for headlight washers.
- D2R Bulbs from v-leds.com - anyone use them?
- Mild update and question
- Planning to do a major tune-up. Please help
- VOLK GT-S 19x8.5 & 19x9.5 - any1 have it on their 2GS?
- Best mod I ever did since owning my GS430
- Clean wiring setup for fogs
- O2 Sensor
- SC300 Diff same as GS300??????
- Wheel fitment -
- Remove cover on steering wheel audio control
- Moved on up to '02 GS430
- no more 01 harness!
- what changes were made in 2001?
- Hope to new owner with a few questions
- 1jz swap into a 2gs ftw or ftl?
- AC code 31
- What happened to new headlight lenses?
- Cel p0154
- Help with tranny drain bolt..
- Just got my JP Neck Pads
- Green tint on headlights
- cranking noise in low speeds and cold temp?
- Front Bumper removal
- New To CL...MY 02 Lexus GS300 Sports Design
- TTE lip finally installed.
- A little late intro...03' GS300 SD GGP...
- Lower Contol Arm #2
- MRR Wheels.... Yes or No
- Please help!!!
- dropped my car and now having different engine sound?
- How much do you love your GS?
- junction produce neckpads
- Spark plug wireset
- pic request!: modified dark green 2GS's ??!!
- Complete loss of power randomnly when starting, now have to jump start?
- need seat motor for 98 gs400
- Upgrade suspension with bushings too????
- **HELP** 03 GS3: Passenger's Air Climate Differential
- Which Fuse Did I Blow?
- Electrical Problem?? Please help~!
- new member...
- Please help! Climate Control wont turn off. Please help.
- Save me $500...
- Newbie here!
- gas pedal stiffness modification
- 2IS F-Sport 19" on CW 2GS. Need your opinion! :)
- Question In Car Phone
- boredem = IpHoNE photoshoot of the GS lol
- catalytic converter replacement
- Are 98-05 Interior colors the same?
- Help, my 98 GS400 won't start
- Interesting things to do with Ashtray?
- In for tire work... out with many more problems.
- Clear Bra On TTE LIP?
- Clear Bra?
- help! cluster not working!
- which side skirts are these?
- Belt replacement
- Seat Belt Light
- Cheapest way to replace a key?
- My doors lock automatically
- Failure of these parts common?
- Best Places to Buy Bilsteins
- Oil in the spark plugs
- Lower Ball Joint & V-Belt
- smuv gs3 CLEAR YOUR BOX!! you got a PM
- Boost problems
- GS300 Cluster
- New here have some questions
- Weird noise
- Radio Display
- Another retrofit question
- Weird problem. Need HELP!
- Help with finding rims
- Yellow Fog Lights
- '98gs4 front door molding . . .
- Extended Warranty Question
- Loud SQUEEK! @ rear lower control arm/spindle
- The right GS400 seem to be rare in my area...
- Best way to match inner headlights with outer OEM HIDs?
- Is swapping 2jzgte vvti into 1998 GS300 that simple???
- Lexus is voted #1 in JD Powers
- Check this out LOL (Video of green LEXUS GS300 ON spinning 24'S)
- Where's the cabin filter?
- red out
- Questions: TTE lip and P0420 CEL
- Your thoughts please..
- rattling noise at 20mph???
- Help: P0430 CEL fix?
- What do you think these are worth?
- VERTEX GS Video and Tribute Thread
- Looking to purchase MRR GT1 19inch
- Crank pulley holder
- OEM wheels refinish DIY, where is that thread??
- Upgrade 98GS4 with GPS??
- Advice for Fender Repair 1998 GS300
- Washed Car, Few Pics
- White 2GS4, Black Roof, Black Wheels......black mirrors?
- D2FORGED VS4 on SOCALSC4 GS400 {Video**
- Debadge, Bezel installed and Strut bar.
- window visor removal
- please help me sourcing the leather....
- Need Help With 2 Separate Things
- 20x8.5 39 offset and 20x9.5 34 offset will they fit
- Recommendation on Daizen bushing?
- Alternator Housing?
- first Lexus, first time with pics.
- Seat Belt Problem
- GS with sc430 wheels???
- I have big feets 8D
- should i buy gs300
- Leatherseats.com ... Anyone used them?
- Wringo you are the man
- How easy is it to access the timing belt, GS400
- laggin at 4000 rpm
- Fatter tires or go lower?
- what is the size of the sunroof?
- where can i get the same leather hide?
- 20x9.5 and 20x11 +15....will it work?
- a&e jacked, stolen lexus gs
- Darn Dealer!!!
- some updated photos
- need help with code reader not sure what to do now
- CEL Codes....what to do...
- GS HID Ballast clip/ Front bumper removal
- Best Prices on Parts?
- Front fender roll...
- DiY DRL disable failed
- Leaking Valve Cover? With Picture
- WoW!!! this is great....
- Look what dropped in over the weekend
- need help!!!
- ready to take the plunge
- How long will OEM HIDs last?
- GS4 im looking at buying.
- cars and coffee meet, plenty of pics inside!!
- Hood Insulation Removal
- Need help with wiring for GS300 99 stereo
- My GS gets Caged!
- Buffed Her Nice & Slow
- Looking at a used 250 and need your help!
- First pictures..
- Paint PEELING on my new LExus!!
- Transmission slipping/reving under mild load?
- LED mirror covers 01-05 GS series >>Doesn't fit<<
- I'm new so I wanted to say hi
- damn you friday the 13th curse!!!
- Ok tell me what you think..
- Another Victim of Friday The 13th!
- someone please help a noob.
- Is this a GOOD DEAL?
- Wooden steering wheel for GS400
- Are all sportdesigns GS300s?
- bluetooth?? :uh:
- help here!!!!!
- Friday the 13th Curse! =(
- Q: Steering Wheel Controls
- Switching to a Lexus
