- code p0155...bank 2 sensor 1
- gs300 measurements
- Newbie here need advice
- remote auto start
- which tire should i run?
- My GS300 here in the UK
- HID Question
- a/c issues
- 2003 GS 300 Radio Display Gone Wild
- put the Megan coiliovers on this weekend.. couple quick pics
- Replacing Radio Head Unit
- What model year is this GS??
- Buying on ebay??
- door lock problem after replacing actuator motors!!!
- New to club lexus let me see yours!
- Removing the spoiler LED light bar
- HELP! What to use for converting to Single Din Radio?
- 01+ GS300 got T-boned today
- Help with color scheme choice
- wheels ...lug nuts??????
- GS400 lower oil pan removal
- Camshaft/VVTi Oil Leak AFTER Mechanic Worked on Car *Super Mad* - Help!
- Can someone indicate this plug? *PIC ADDED*
- question on curtains?
- Should I go with oem or high quality upper control arms GS400
- Trunk light question
- looking for a trunk moulding/spioler
- CRACKED radiator which leads to BLOWN head gasket
- Anyone has good or bad experience with after market Moog ball joint?
- Hi Im having a hard time getting my GS smog with an intake
- need some pointer
- spark plug change now car wont idle
- Hi.. I'm back
- 2001 GS430 - Should I buy it?
- bent my valves 03' gs430
- Just got my car back check the pics!
- Another GS LudeNsoL
- 2GS Elevel owners please chime in!!!!
- Best Mufflers?
- Guys ive looked everywhere!!!!
- squeaky noise
- Hey guys I need help with my rear passenger wheel...
- So what do you guys think?
- Please Help With Upper Arm Control!!!
- How's this for some gas mileage?
- Nakamichi subwoofer bass distortion and possible flatulence?
- Chrome center cap for 17" wheel
- Help! Rear Passenger Wheel *Video Inside*
- please help.. my transmission shifter is lock
- Temperature level only at 1/4 while driving, RPM's seem to be high at highway speed
- Stereo Display Burned Out On '99 GS300, How To Replace?
- help - passenger side driving light out
- welcome me to the club
- Poll: what is the coolest color for a 2g GS?
- strange power lock/unlock issue
- Spacer question.
- JDM Double Din.. how does this work??
- intake help
- Aristo TT - worth it?
- gs300/400/430 gauge cluster bezel
- Goodies are here !
- Floor Mat Anchor Repair
- how remove the dash form my car please help
- My GS Four Double Oh
- Mark Levinson work around upgrade issues
- 92 SC Control Arms on 98 GS - Will they fit?
- photoshoot :) hellaflush
- car won't start!* :(
- 20's are too big...
- Subwoofer 8 ohms or 4 ohms
- BIGGEST REAR TIRE 20" wheel
- GS Tein
- New Member :D
- is wheels
- nice weather y not wax the G(s) Ride !
- PhotoShoot off my Vip'd 2GS
- where to get kazz grill new or use
- Transmission Question
- Name that wheel
- No O2 Readings?
- Toyota UR-series V8 swap in a GS400
- my navi stopped working.. please help
- New Wheels!!!
- Guys that roll with BMW 7 series wheels, need input?
- What is the inlet diameter of the stock GS400 exhaust??
- chrome trim thingys for the bumpers
- full interior swap ?
- Anyone? Need help on measuring resistance on solenoid
- 5mm on a stock studs??
- Cleaned TB + IACV , idle is good but now cold start shaking
- If you could change your license plate to something else what would it be??
- Can this be powder coated?
- anyone in/near portland oregan area willing to check out a gs430 for me??
- My GS400
- ls400 brake upgrade kit on 2gs what all needed
- Suggestion for Mounting ALL Air Equipments in Spare Wheel Well
- help questions spacers n rim size
- air suspension question
- Fender ?
- Replaced Foglights with OEM
- Moisture getting through headlight lense, wax or sealant?
- pasenger side driving light?
- 50% system almost done
- How many miles has your 2g GS lasted? ...or met its death at?
- hide away license plates ?
- cant find shift solenoid "c" in trans. gurus where you at?
- New member from Florida
- pics of your custom trunk setup
- New proud owner of a GS300 NEED HELP!!!
- kinda new guy
- New member
- pioneer double din
- Supra Springs on a GS300?
- 19s" or 20s"
- new guy here!
- New to CL 98 gs400 DWP
- 2000 GS3 makes squeaky noise
- Thinking of selling the GS
- Testing Waters 2000 GS300 120k miles
- whether or not to buy a GS
- Name That Part
- A different kind of retrofitting *check this out!*
- car bogs out under throttle....guru's please help
- hi im new here
- My GS400's new wheels and stance... feedback pls.
- Changed Transmission now I have slight vibration
- Quick question - height measurement
- new noise from the front end...
- gs300's with exhausts! chime in!
- I need a little help with spacers!
- doors won't lock from remote
- new member
- Window switch replacement
- Drivers window issue
- Painted fogs opinions! Pics added
- Has anyone done the BIG THREE upgrade to there GS?
- 98 gs400 moonroof problem please help!!!
- Rim question?
- Passenger rear window doesnt work
- gs400 question
- stock suspension height
- poured a bottle of lucas deep clean fuel cleaner = TROUBLE
- When is to early to mod you GS?
- any vendors for jp curtains etc.?
- cigarette lighter socket diy?
- Help with 2001+ reverse bulb socket?
- My GS400
- Anyone got pictures of a JL 13Inch sub in a GS300?
- 2012 Setup...:)
- Bilstein Sports
- Anyone using stock sub location for different subs?
- My New Ride!!
- coilover help!!
- Gs300 ecu question
- Need Help! Leather steering wheel wrap
- any 1 know a good shop in cali to do a 90k service on a 99gs?
- To tint or not to tint?
- Hear some popping (TPS?)
- New stance and wheels...let me know what you think
- Fuel damper issue ?
- Aristo Fogs
- Need help with exhaust tip with factory muffler!
- Aftermarket TPMS
- 98 gs 300 low miles or 2000 170+ miles help!
- Spoiler does not turn on??? GS300 2001
- Air Filters on 2001 GS300
- Proud new owner
- 2003 GS300 Sport design
- Overheating experts help me out.
- new to site from charlotte nc
- ProEfi GS300... My new setup!!!
- another tx gs !!
- MJM Auto Innovations Door Speaker Adapter Brackets - Review
- Service Rip-Off?
- new here!
- Got My Led Mirrors Installed
- where to get OEM 17" new Rims
- Help!!! Alignment issue Tein Springs
- Photoshoot of my GS300
- Sunday's shoot with a G-friend
- Htown import reactor 2012
- changing a spoiler brake light
- Tire Size HELP!
- Quick Question guys!!!
- GREASE ON ABS SENSOR? 98 gs400
- LS\Celsior Brakes to GS II
- Summer time! New wheels....
- Is this a reasonable price for parts and labor? v.some maintenance work
- 1999 Lexus GS300 Stereo Upgrade
- Cranky Ball Joints...
- Does anyone know if the stock Aristo V300 (160/161) have factory lsd in the diff?
- Where to buy paint?
- Led tail lights
- Thud/ clunk while rollin down driveway in reverse to neutral
- Does anybody has a spare abs sensor for 98 GS400
- ebay tte style polyurethane lip hows the fitment?
- door pillar art wrap pics? anyone?
- New wheels on!
- Can chip in remote key drain the battery
- CEL P 0171 lean code gone by its self , thoughts and opinions needed
- vibrations (driveshaft)
- Shifter Help! NOOOB
- Help!!
- Help needed with uca torque specs
- Swapping mufflers from my old GS to my new GS gasket?
- anit theft device
- Replaced Starter Now Car Won't start
- Mirror Cover What does this fit
- I need some help please
- I finally dyno'd my car. New world record? Pix and videos inside!
- Coilovers
- Gs-400 p420 only!!!
- help with hid conversion kit
- Sport Design/Ltuned 430!
- 02 GS300 P0430 Code - intermittent CEL?
- 1JZGTE swap in to a 2GS ?? ??
- Headlights and fog lights?
- Tire fitment
- Throttle shoots up but car slowly picks up speed
- HELP!!! having problems with the climate mode control
- Will taller front tires on my 2nd generation gs mess with the VSC?
- lower control arm bushings
- pics of front lip molded on stock front bumper? anyone? need ideas
- does our car not have a rear camber kit besides camber bolts upgrade?
- What do you think of these wheels for the GS
- GS400 Performance Chip
- Alarm issue
- lights on, door lock problems
- Putting Volk SF Challenges on a 98 GS400
- New member from NJ pearl white gs300
- Need new shift knob and center console lid
- need intake
- '99 GS400 Nakamichi I wanna install A after market Navi is it possible? Please help.
- GS400: Is my transmission going out??
- new member
- New member with 1 pic for now
- Will these rims work?
- Just got her back from the paint shop
- Shaking when breaking at 65mph or more?
- Tilit is not working on my 1998 gs
- FS and WTB posts go in the classified forums only
- Steering wheel not centered after alignment?
- Brake issue HELP!!!
- my new 1400hp gs300 getrag.
- m35/45 vs Ls460
- Need Help to make 17s look better
- My attempt using a Canon EOS 7D
- Lowest Offset
- sound with curve
- What is it worth?
