- New to me gs400
- Steering wheel shaking at 55mph and up
- Anyone Interested in selling or know of a gs400/430 for sale?
- Retrofitting head lights question plz
- Seat belt help...
- New problems
- Delete abs
- GS4 Cylinder misfire + oil leak. Details inside...
- New Member new to the game
- Overheating
- New headunit recommendations
- GPS Software
- Rear taillight Resistor
- To flush or not to flush.. (And when)
- 2001 GS300 vs 2005 530i
- Its a secret society....
- new wheels, finally
- gs400 staring issue
- Hood support question
- Bad mounts or bad differential bushings?
- GS400 CEL P0446 code
- Is this a good deal?? New member need help!
- 02 Simulator
- A/C issue
- 2000 Gs400 Platinum Edition Woodgrain
- BC Coilovers question
- Making a come back
- Valve cover gasket getting replaced - What else?
- Amp / subs connection
- Please help... Starts then shuts off
- 01 gs430 CD player issues
- Fog light help
- Small fender gap 😑
- My new baby!!
- gs 300 98 running rich .
- How difficult to replace front cat - 2002 GS300
- Brakes pop after tie rods changed?
- Rev Limiter?
- 2001 GS300 P0420 and P0430
- vvti oring/gear
- Sold my GS400
- need help decide between two cars
- Balancing drive shaft
- Bought a $700 01 GS300 w/ blown engine, what to swap in it?
- Metra or Scosche double din kit?
- Taking care of your headlights
- 96 GS300 Horn problem
- Thule Roof Rack
- New to the club,sold my gs400
- 1999 Service Manual
- rear brake pads
- creak after coilover install
- Looking to buy an 01 or 03 GS...any issues I should be aware off
- P0770 e shift selenoid dsl problem! Hard shifting help!!!
- 99 lexus gs300 gets crap mpg.
- Climate control q
- Issues after battery poles mixup - trunk switch faulty, no sound from speakers
- GS300 Pulley Question
- need help
- HID to LED
- Need a new CAT
- Radio cuts out every time I brake
- GS430 with Blitz NUR spec
- clunk at low speed?
- Famous Rear Sueak (video)
- Am I crazy for wanting a GS?
- Courtesy Light
- Is there ANY aftermarket GPS/DVD w/ functioning factory HVAC controls?
- Question on pinion gasket leak.
- P0441/446 Code
- New Tires leaking down.
- P0420 Catalyst Converter location
- P0430 code which O2 sensor?
- Wtb gs300 srt intake
- Weird vibration problem.
- Which one of you Texas 2GS owners was this?
- Rear tail light wireing
- 01 Gs300 misfiring
- Cracked window visor fix?
- Gs300 Trans mount questions
- OEM side skirts for 2001 Mystic Sea Opalescent GS300
- 12V source
- 225/50/17 on stock 17's?
- car was broken into, nothing stolen
- New to Forums!!
- My Nexus 7 Install
- Driver window control doesnt work
- 98 GS400 Hard Starting Issue
- 98 gs400 passenger door won't lock
- 2002 gs430 ac problem need help
- My old and new gs400 engine
- where to buy tan leather paint
- Bagged the gs
- Need Help with wih ABS Codes C0226, C0236, C0246, C1223
- New to forum!
- steering wheel airbag question
- Fog light LED DRLs
- P0430 code; how to approach
- 98 GS300 - routine maintenance (plug change)
- Something Wicked This Way Comes...
- 2001 Lexus gs300 does not acceleration properly CEL p1349,p1656
- Has anyone changed the turn signal mirrors leds?
- 2JZGE vvt-i only interference engine when vvt-i activated?
- New to the Gs forum
- Any write-ups/diy for cam seal replacement?
- Inner tie rod lock washer issue
- Replacing headlight lens only
- Leak from cams?? New to forum and lexus
- VVTi GS400, in need of MAF pigtail schematic
- Oil leak question URGENT
- LED Signal Rapid Flash
- Brake system wiring
- Stealth Sub Box for 2GS?
- Need a new CAT I think
- Rear Suspension 'popping'
- 18x9.5 et 22 and TT calipers
- HID and Auto leveling aftermarket headlights
- 1198 GS 400 17" Chrome Rims - slow air leak from corrosion
- looking to buy a GS400?
- How do I fix these issues on my gs430
- Bee*R~~ (HELP PLS!!!)
- downpipe for aristo swap
- Is a factory trans swap plug and play?
- steering rack questions..
- Is it worth it to fix 2001 GS300 Front End Damage
- New GS430 purchase!
- Help on the location of an oil leak guys
- Fuel Filter Orings
- jdm climate control panel wiring
- New Fenders for the GS! (Finally!)
- Alternator issues
- Headlight Wiring Diagram
- Possible wrong ECU?
- ideas for go-pro placement in the gs
- Still have P1354, replaced OCV
- FS and WTB threads go in the classifieds
- Loud noise when braking and I mean LOUD
- Noise When Making a Hard Turn
- Key fob ?
- Funny video of GS4 vs S2000
- 2jz-gte swap questions
- Disable interior lights
- Can't open 98 GS trunk
- Lexus GS300...worth it?
- New Look
- Need help from someone with factory spoiler
- Replaced VVT and Timing Belt..car wont run now?
- wierd navi screen\gps problem. what could it be?
- 2nd gen gs tech in the dmv area
- Thinking of Getting another GS300
- Traction Control light W/ Soft Breaking
- DTC Code P0440 Repair Video/Link
- Foglight Rewire
- Slipping when accelerating
- 99 gs400 engine
- sensors in the grill 01gs430
- Gs430 with 2jzgte swap speedo issues
- Cleaning engine after leaky valve cover gasket
- Show me your drop!
- driver HID headlight operates for 30 seconds before turning off
- Evap not ready,bad fuel pressure sensor?
- Louder?
- Interior swap
- Rear License Plate fastening
- Help ! 1999 Lexus Gs400
- 2jz-ge Question!
- Need help with 99 gs300
- My buddy's GS ...
- Best "mode" to drive in
- aftermarket deck with stock navi!
- Take out cat converters?
- Just steamed cleaned the engine, now is f***d
- E-brake / Handbrake light staying on.
- Strange Noise Coming From The Front Of My GS
- JZS160 and GS300 Compatibility?
- lowering rims and camber kit?
- Non modified body/stock suspension
- Negative caster after alignment?
- ABS Sensor/Engine Harness
- Local CL Meets?
- Used Muffler on Ebay?
- There is no aftermarket sub+amp with stock headunit install thread
- Has anyone used these brembo rotors or pads?
- Air intake
- Moog EV80600 Tie Rod Needs To Be Greased?
- Just got her out for the spring!
- fuel pump return question
- Questions about electrical mods
- Step By Step...Removing Steering Wheel on 2GS
- 945 Garage: 4 Door Hero Kit
- 2001 GS 300 Need Help
- 2jzge
- Morimoto XB H.I.D Write Up
- 2000 Gs 300 hesitation
- 99 GS300 Aristo Swap
- Sunroof Motor
- Does this seem like a good deal?
- Dual Alternator Setup
- Help on correct lug nuts? Beveled or flat?
- paint matched grill pics??? white
- My GS' First Check Engine Light
- Weird Reverse
- Also popping noise, spent money, no fix
- Serpentine tensioner
- light polish+meguiars wax turned my paint into glass
- 1999 GS300 Radiator Fan Issue
- Xenon in Fog Lights?
- Will a 2003 auto is300 lsd rear end bolt up with a 1999 lexus gs300
- Climate control issues
- Immobilizer Problem Anti-Theft won't let me start car
- 2nd gen gs430 or 3rd gen gs350?
- Warning light issue
- Anti-theft not turning off wont start car please help!
- Tail light failure with a twist!
- Aftermarket front bumper?
- power restrictions Gs 300
- What should I look for when buying a gs?
- Where did you mount your AMP
- Escort 8500
- Moving on from my GS300
- Lifespan of a GS300?
- Battery died & now the a/c isn't working all of a sudden
- 02 GS300 What do these codes mean?
- 02 GS300 How do I remove the emerg trunk release
- High speed clicking (not brake booster)
- Beginner Project Advice
- Desperate! Car wont hold charge!!!
- weird lawnmower jet engine sound when letting off gas!
- inner tire wear and noise when turning
- Anti theft mechanism problem please help!
- Starting problem
- curb weight of 2 gs
- ichiba wheel spacer question
- A/C problems
- Strange and haunting electrical issue
- 99 GS400 engine, what CAN cause limp mode?
- 18" offsets work?
- Anyone ever see these infiniti wheels on a 2GS?
- Can I fit 245/50-16 on the stockies?
- heating issue
- Does anyone actually own a saddle interior GS?
- Freaking headlight problem, car look possesed.
- Aftermarket ballast?
- CV Driveshaft Question
- Tape deck problems
- HELP? aftermarket radio connect factory sub-woofer.
- Bigty / Liberty / Mod Parfume
- to Jeff Tsai / anyone that can help
- My new 03 GS430
- Someone have OBD II Problem before
