PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. LS430 6-speed transmission on a 2000 LS400
  2. Can the camshaft position sensor be affected/damaged when working on the radiator?
  3. OCV Problems
  4. Nakamichi audio no treble nor bass??!!
  5. 93 LS400 Engine Temp Indicator at 40%
  6. Brake light playing peekaboo
  7. rear diff movement?
  8. I've made my decision
  9. 1uzfe vvti cooling issue
  10. new ls400 owner
  11. Help me read Freeze Frame data for P0125
  12. LS400 photoshoots?
  13. Sticking caliper?
  14. Wheel Fitment
  15. HELP 91 LS400 Suddenly died
  16. 1990 LS400 power steering nightmare
  17. 93 ls400
  18. Engine Code 25
  19. 95-97 Reverse signal in dash area?
  20. Just purchased a '94 LS400, what have you done with yours?
  21. Driver side abs sensor
  22. New Lexus Owner
  23. Help! Cold slip & smoke after trans/motor mount replacement
  24. Alternator Over Charging
  25. 96 LS400, annoying whining coming from trunk, slightly extended crank
  26. 91 Speaker question
  27. LS400 Seats
  28. Trac light flashing after I cleaned throttle body
  29. Engine Splash Shield Repair
  30. Heat does not work properly in my car
  31. LS 400 warm up time.
  32. Need help Throttle Body & Air chamber cleaning/Torque specs
  33. How an LS is supposed to drive? Advice needed please
  34. Junkyard Find!...Mikado Fixed Climate Control!
  35. Alternator Bearing Replacement
  36. Can I use super tech carb/air intake on throttle body?
  37. 99 with P0715 P0763
  38. Want to lower 91 LS...Tanabe Springs with Meaty tires...Thoughts?
  39. 95- Wheel fitment help please!
  40. Tire size help '95 LS400
  41. I bought my first LS!
  42. Classic Review: MotorWeek Simply Loved the Lexus LS400
  43. !Please Read! Sewell Lexus Parts Petition
  44. 91 Ls400 starting issues
  45. 91 Ls400 starting issues
  46. Looking for a nice LS400
  47. fuel tank top off problem, 2000 LS400
  48. My 96 is gone (totalled)
  49. Squeaky front seats - leather rubbing plastic
  50. Retro Review: '90 Lexus LS400
  51. 1993 Lexus LS400 Wont do nothing
  52. Shift solenoid p0770 code FIXED!
  53. swapping out the ECU on my LS400 (96
  54. Vogue center cap missing on '97 LS400
  55. What colour is this?
  56. 95 LS400 w/81k orig miles
  57. Need part number Thermostat 2000 ls400
  58. automatic transmission slipping
  59. Dome Light Removal - 2000 LS 400
  60. New LS Owner/Interior Question...91 LS
  61. Lexus LS400. Louder exhaust or stock quietness?
  62. That New Car Smell On A 95 LS400!?
  63. PLEASE HELP--fog lights and driver seat--
  64. Help Check VSC
  65. 235/55-17 tires
  66. Across the country in a 900k-mile LS 400...
  67. Shortened spindles
  68. 2000 LS400 foglight removal
  69. Saw her on the corner and decided to pick her up...
  70. Am I seeing this correctly?
  71. rims without rolling fenders
  72. Officially A Proud New Lexus LS400 Owner!!!
  73. oil leaks 93 LS400
  74. UCF10 beeping
  75. '98 LS400: question on coolant filler plug
  76. LS400 MY 1995 AC Bypass Belt to use PN KO60630 6K630
  77. Trailer hitch with extra attachment points
  78. 96LS400 Cam sensor #2
  79. Another LS Radio Problem
  80. Thank you guyz!
  81. How to Play iPod, iPhone in my '98 LS400
  82. noise from the vent and sunroof while driving...
  83. Gas tank location 93 Ls400?
  84. Moisture / water in lights
  85. Coilovers vs springs/shocks ride comparison
  86. Need help asap transmission gasket leaking.
  87. Front Bumper cover
  88. Looking for ideas...
  89. Suspension questions
  90. Puzzled
  91. Minor Fender Rolling on 98-00
  92. Molding Paint Color: Black Onyx & ?
  93. 1994 Lexus ls400 Nightmare!!!!
  94. Sooo this happened today. 90 LS 400
  95. 98 LS400 electrical problem
  96. afm mod 92 ls
  97. 98 LS400 Keyless
  98. Ideas
  99. 95 LS400 help
  100. Some questions about struts and lowering springs
  101. UCF20 Complete DIY Rack N Pinion Tutorial
  102. 1991 LS400 Project - Question...
  103. 1st Gen vent visors 4 piece
  104. Bad gas from Kroger, anyone?
  105. Check your engine & transmission mounts
  106. Transmission Solenoids Gone Bad?
  107. LS400 Passenger Foglight (Well side to foglight)
  108. Picked up another blk/blk ucf20 last night
  109. Reliability?
  110. Major Electrical PROBLEM
  111. 91 Ls400 died while driving
  112. HELP 1995 LS400: Did i bend valve/s?
  113. New Power Steering Pump on 99 LS - No Steering at Idle - Air in lines??
  114. Random Wierdness: temporary stalling
  115. GS400 engine in LS400?
  116. front air shocks interchangeable from 94 - 99?
  117. 1991 LS400 for daughter
  118. Crashed LS--Dilemma
  119. Help with front strut bar bushings (48674-40051)
  120. Transmission fluid in coolant
  121. Rpm reading low
  122. Blitz Access ECU
  123. Need Help
  124. Fuel Tank Capacity
  125. Wheel fitment Question
  126. 98 ls driver side mirror replacement help!
  127. 1998 ucf20 ls400 single exhaust system
  128. Air bag ?
  129. First drive and couple brakes squeal
  130. Air Suspension from a 93 LS400 in to a 91
  131. New to Club Lexus. Strange noise above 3k RPMs.
  132. Please post side profile H&R + Bilstein
  133. Proud LS400 Owner :D
  134. advice on rear brake discs
  135. Cylinder locations, miss fire
  136. 90 ls 400 idle problems
  137. Easy way to check timing belt on a '99?
  138. Best online dealer for OEM parts?
  139. Hello from new owner - 2000 LS400
  140. Weird '98? No heated mirrors, only wood shift lever
  141. power antenna replacement
  142. Garmin in an LS400
  143. questions on driving habits
  144. Best setup for ride/comfort
  145. Correct Center Caps for 2000 LS400?
  146. Observations from 2000 mi. road trip
  147. Nakamichi Amp? 1999 LS 400
  148. Passenger heated mirror
  149. LS400 differences in years
  150. 96 LS400 wiring for horn with nardi
  151. 96 LS400 - Conversion from Air Sus to Spring
  152. 1991 LS400 Randomly won't start, just cranks and cranks?!?!
  153. Engine mounts - how subtle can the symptoms be?
  154. used car quality index
  155. 98 Ls400 opening door with broken spring tutorial.
  156. A650E gearbox mods
  157. Transmission oil temperature
  158. Power steering pump whining
  159. Caster arm rubbing on inner wheel
  160. Water spewing out open near gas filler
  161. check engine light
  162. Shift lever problem
  163. Right rear door does not unlock by remote or unlock switch
  164. Carfax vs Autocheck problems on LS400
  165. trunk release switch not working
  166. Fuel Gauge Problems 1997 ls400
  167. New to Club Lexus and finally a LS400 owner
  168. Groan/whine at idle. Not PS.
  169. took throttle body apart, cant figure how to put it back together
  170. P0340 after timing belt install
  171. exhaust leak question
  172. 96 Celsior- Shock leaking
  173. QUICK Q about an Idle Air Control Valve 91' ls400
  174. Reverse Lights
  175. Goodbye to my LS400
  176. replacing headlamp/turn signal on 1994 ls400
  177. Help!! 1996 LS400 Slow Accel, White Smoke, Replaced ECU and Deleted ACV
  178. 92 ls400 interior gas smell
  179. What to EXPECT for a new Buyer. (Your REVIEWS)
  180. how to remove front bumper
  181. Found on Craigslist: An Off-Road-Ready Lexus LS400
  182. Advice for potential 98 LS400 buyer?
  183. Remove these suspension braces?
  184. 91 ls400 diff question
  185. No classifieds access yet.
  186. '99 LS with codes and intermittent rough idle...
  187. UCF20/21 Charging issue
  188. Replacing Pioneer head unit with aftermarket HU (Sub working)
  189. Bimetallic Vacuum Switching Valve Thread pitch and size??
  190. 95-97 corner light
  191. NAK factory upgrade how much and is it worth it?
  192. 1990 ls400 Atf
  193. 1998 LS400, faint burning oil smell
  194. Needed Instrument Cluster
  195. what years front seats the same?
  196. looking for 1995 LS400 exhaust headers
  197. Lexus sc400 1992
  198. No, starter! 98 ls400
  199. Transmission Drama
  200. Battery Woes!
  201. Led conversion kit issue
  202. HELP! :( IACV? TPS? ECM? Dies cold, High idle warm.
  203. Unicorn hunting. in search of early build date 1990
  204. Major discovery on my 92 LS400
  205. HELP ucf10 vs ucf21
  206. UCF20 Blown Head[gasket]
  207. A/C runs in winter with heat on.
  208. HELP-car cutting off while driving
  209. Non OEM power steering pump for my 2000?
  210. key stuck at acc
  211. Broke Radiator. Can it be repaired
  212. Aftermarket wheels...will they fit?
  213. My first Lexus a 1991 LS400
  214. 1996 LS400 EGR questions?
  215. Spark plug wire question (too many?)
  216. LS400 ac not working
  217. Need help for 1996 LS 400 mass air flow sensor
  218. In the market for an LS400 Need Advice...
  219. Corner Running Lights?
  220. Tire Tuck
  221. Center Air Vent Question
  222. replacing rusted part of brake line
  223. NEED HELP: Moonroof Stuck.
  224. need help please - traction control.
  225. Steering End
  226. Modern seats for LS400 ???
  227. DIY negative camber setup w/ adjustable megan arms
  228. How do I replace hood latch on 90 LS400?
  229. Another Vibration thread... Replace the drive shaft???
  230. '93 LS400 removing the phone
  231. Removed Stereo, Strange Issue Popped Up
  232. mashup bumpers
  233. Which Replacement Power Steering Pump to Buy?
  234. cheapest way for better sounding exhaust
  235. Clicking noise from front of vehicle
  236. Hood lift struts 1st gen
  237. The moment you realize... (Feeling the turn signal relay in dead pedal)
  238. 2000 LS400 Nakamichi HELP!
  239. 1Uz Oil Pump, Wrong O-Ring?
  240. How to run new speaker wire to doors
  241. '98 Lexus LS400 issues - sputtering
  242. 93 ls400 ignition coils
  243. HUGE electrical heart attack!!!
  244. Is this the sunroof drain tube in trunk?
  245. 1997 ls400, starts and runs for about 10 seconds then dies
  246. 02 pre-cat sensor/s test procedure - Yamae
  247. P.S. Fluid LEAK help!
  248. New LS400 owner with questions
  249. Old School - Lexion 201's
  250. Heated seats ?
