PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. cheapest way to get a 1995 LS400 into the 13s
  2. Disable telescopic steering wheel tilt-away feature?
  3. Anybody have an "Carfax" Acount?? Help Plz!
  4. Generations: Difference is softness over bumps
  5. Cumbersome Glove Box
  6. seat help
  7. Problem finding a Platinum Series
  8. Odd Vibration- Possible Transmission Problem?
  9. I'm new and about to purchase a 1998 LS400
  10. give me ur suggestion please
  11. radiator fluid flush?!?! was he for real?
  12. is ls400 w/ es300 seat swap possible?
  13. What kit is this?
  14. Noise problem Solved!!!!
  15. Height Control / Auto-ride system
  16. need help ASAP !!!!
  17. bodykit
  18. weak horn
  19. How to make alarm beep?
  20. 90 LS400 vs 94 ES300
  21. '00 corner lights
  22. Trouble code confusion
  23. WALD Executive Line PRICES Lowered
  24. Climate Control
  25. stiff steering wheel
  26. Lexus-parts.com
  27. JIC have new VIP coilovers?
  28. ordering upper control arms from USA for shipping to UK
  29. battery for key in 1992 model
  30. Lease used lexus?
  31. engine knocking
  32. Frustrating: please advise if possible
  33. Is 10k for a 93 LS400 w/ 95k miles Reasonable?
  34. Cartrdige replace time
  35. O/D and ETC power
  36. Need help changing brake light
  37. My 3000 miles trip and 1 problem...
  38. Need to repair stock Nakamichi deck...help needed
  39. Engine Squeaking
  40. How Much To Purchase Decent (older) LS 400 ?
  41. Is the idler and the idle up valve the same?
  42. Check engine light.....code No. 25
  43. Input on when to Replace Struts
  44. Found cure for the common problem...
  45. Help! few things failed to work same time
  46. Smog Test with Injen intake
  47. Tire Suggestions
  48. vibration between 55 and 65 mph
  49. 2 weeks left for stage 1...pic
  50. Is LS400 alternator connected to starter instead of to battery?
  51. Drivers seat belt
  52. Anyone know what these things are? They're not in my manual.
  53. 1992 SC differential and 1990 LS
  54. Where can I get one of these orginal parts ? For LS400
  55. Help (missing 'l' from engine cover)
  56. Egr Pipe Replacment
  57. How to read error codes on 92 LS400
  58. Steering bushing/Damper
  59. I can't take it anymore...
  60. free mod? traction control removal
  61. ATTENTION all LS400 Owners !!
  62. pics
  63. New Member
  64. Cabin Filter
  65. How the Tire Pressure Monitor Works
  66. O/D button failed
  67. Air Suspension Conversion
  68. EMERGENCY!!! Need Help ASAP!!!
  69. ok guys help me out a lil bit.. need expert advice
  70. interior colors on 99-00 LS400 ??
  71. can one drive w/o instrument cluster in?
  72. Armrest Mod Help !
  73. warning lights keep coming back
  74. What do you guys think ? ?
  75. Removing door panels
  76. LS400 Floor Mats
  77. Sagging Sunvisor
  78. Smoke at startup
  79. leather shift knob
  80. LS stalled today
  81. Can I Get A Suggestion?
  82. electric water pump
  83. Windshield washer motor
  84. Iridium spark plugs
  85. Pearl White/Black Leather LSs????
  86. 1999 Brochure
  87. any pics of the strtut bar nushing
  88. thinking of buying a used ls400/430
  89. EGR Vacuum Modulator
  90. K-Break has a web page now.
  91. 1990 LS400 Tranny Problem
  92. ls400 worthless in snow!
  93. Original 1988 Lexus LS 400 Crazyness
  94. 1998 AutoLocking
  95. Happy New Years - New Pictures
  96. more problems with my LS
  97. Grounding kit
  98. Strut bar w/air suspension
  99. XM Radio for 1990 LS400
  100. Location of amplifier 94 LS400 + mystery sensor light
  101. Brakes are bled, but still feels like mush.
  102. Side View Mirrors w/Turn Signal Lights
  103. is my air suspension bad ?
  104. Timing belt change How?
  105. idling problem
  106. jim walker/dash repair
  107. Jan VIP Car mag UCF10/11
  108. Consequences of oxygen sensor and throttle position sensor malfunction?
  109. Headache!PCV valve change
  110. Traction Light
  111. How do you lubricate the bushings ?
  112. Strutmaster uses Tokico Blues!
  113. Keyless entry ECM chip
  114. Major rattle on front end of my LS - HELP !
  115. Check it out
  116. Anyone know what this is
  117. what are the consequences of having a bad coolant sensor?
  118. Folks, maybe you can help this dude
  119. Recommend your Lexus Mechanic in the L.A./Orange/San Bdo. counties
  120. noise during idle??
  121. Shift lock
  122. Car is Hesitating
  123. Location Of Interior Light Delay Module
  124. Does everyone have their LS serviced at Lexus?
  125. present for an LS400 owner.
  126. Any Pics of 1st Gen/2nd Gen LS400 with 20" Rims?? Post Pics Please
  127. For what reason does an LS owner drive his/her car?
  128. Does extremely-dark tint affect the GPS/Navigation system?
  129. Tail Lights
  130. help with keyless entry programming
  131. Rear end sags when "loaded"
  132. NEW ITEM........ UCF10 wood shift cover
  133. RPM vs. Speed
  134. Are these the original annversery rims?
  135. Importing a Celsior
  136. suspensin noise and anyone try Eibach springs?
  137. BG Products
  138. gold package passe??
  139. Stuck vent motors
  140. not enough power...
  141. oem wheels fit?
  142. RPM's and repairs
  143. pics
  144. How do you fix a mirror
  145. 94 ls400 headlight replacement
  146. i was wonderinG?
  147. 91 vs. 2000
  148. how much is TOO much tranny fluid?
  149. low idle...potential for damage?
  150. My aerodynamic LS
  151. Factory "Lexus" (Toyota) struts say "KYB". Thought KYB was different?
  152. How Do I Change My Starter In A 95-97ls400
  153. Where Can I Get A Repair Manual From
  154. Retractable Rear Window Shade
  155. My Engine Mounts Broke On The Freeway!
  156. new LS owner
  157. Where can i get a repair manual on CD (ASAP)
  158. Speedometer
  159. Trouble Starting
  160. parking brake light won't go off
  161. 90 LS 400 Warning Lights On
  162. best dealer for oem parts?
  163. Drivers side mirror does not work right
  164. Question on coolant & plugs for '95 LS400
  165. 1st gen OEM rims
  166. Nokian WRs...First Report GOOD!
  167. Chirping Sound From Speedo?
  168. Need help with the "beep" and remote entry
  169. aftermarket keys?
  170. problems with outer taillights
  171. Suspension question-95 LS400
  172. Feedback on Strutmasters conversion to LS400 Air Suspension
  173. Steering wheek vibration
  174. 1990-1994 owners - what options does your car have? Anyone with a LS400 with cloth?
  175. Moderate Braking Causes Shifter To Move
  176. please some advive!!
  177. AFTERMARKET spark plug wires.
  178. Should or should I not drive 1000miles with a 90?
  179. where to find lug nut .
  180. Resetting ECU
  181. 1990 Suspenion Upgrades
  182. drop and your ride
  183. no heat at idle
  184. how to reset memory
  185. More Pics
  186. Smoked Tailights
  187. Who said a strut bar wont fit on a 1st Gen LS?
  188. 91 LS400 suspension noise
  189. crankshaft breathers, where to put them
  190. Pioneer Head Unit, '95 LS400
  191. Instrument Cluster, 1995 LS400
  192. rear window blind.
  193. Finally got the LS!...First problem found...fuel gauge.
  194. Sunroof Question (kind of a goofy one)
  195. How Do I Change My Starter--95ls
  196. BFI and later turbo?
  197. SC 430 rear muffler?
  198. clunk sound
  199. Emblem Set
  200. Does your airbag warning light illuminate as normal?
  201. Time for fuel system cleaning?
  202. Oil Leak!!!
  203. Turning my LS400 into LS300TT
  204. front suspension 1996 LS 400
  205. High Idle speed
  206. Power steering pump - leak at hose
  207. Total electric sutdown
  208. Last Call Dec 7 Show
  209. happy thanksgiving ppl..
  210. Considering a 97 LS400
  211. Production #'s for US spec 03 LS 430
  212. When was timing belt changed & engine lifter noise on some LS400s
  213. 2004 custom grill
  214. remote keyless key
  215. "Airbag" and "door open" lights not illuminating
  216. Odometer/Speedometer Recalibrate?
  217. Blacked out climate control LCD? Here's THE FIX!
  218. good price IYO?
  219. air bag sensor is on?
  220. Are the remote entry keys waterproof?
  221. Interior Light Delay 91 Ls
  222. floor mats
  223. Damn rock!
  224. Production #'s for 03 Black Cherry Pearl/Bordeaux UL
  225. Led for climate control
  226. Brake pads wear out every 15K on 2002 LS430
  227. Headers for V8 cars, Please read
  228. DAIZEN control arm bushings installed!
  229. Anyone ever replace rear struts? What strut did you use?
  230. Just bought my first Lexus a little while ago
  231. Rod Millen Intake system?
  232. cigg ligther does not work!!
  233. Notice the lighting upgrades?
  234. Turnsignal Mirrors
  235. Paint Code Help Please!
  236. 2004 LS430 Downshift
  237. Replacing Struts on 2nd gen LS
  238. Crashed my LS400
  239. Wheel
  240. Need help for installing a Power steering pump
  241. LS430 Wheel styles pics
  242. 1990-1992 question
  243. VIP Garage
  244. New LS4 pictures
  245. Question about Rotor Bolts
  246. Noise on startup ?
  247. magnetic oil drain plug
  248. Bluetooth Nokia 8910 for 2004 LS430
  249. another alternative to shot air struts
  250. Engine Misfire!!!!!!!!!!
