PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. A/C ports
  2. dealer complaint.. where to call ?
  3. wat you think of this?!?!?
  4. Need help with suspension conversion
  5. my 95 LCD light in the radio is out
  6. Cold start stumble
  7. grill
  8. Power Steering Valve On 91
  9. 91 Lexus Ls400 Front-end Creaking, Creak, Creak, Creak
  10. Harsh Engagement Solved!!!
  11. My Dad's LS
  12. 91 Lexus on 20's...needs a lift
  13. End of an Era
  14. a/c not working in 1992 ls400
  15. Advise please family buying a car....
  16. Oil and Coolant Questions :)
  17. A/c
  18. Vibration gone
  19. About to paint my car
  20. 92 ls400 with a pulsing sound
  21. 11 Mpg
  22. Best Handling Wheel/Tire size combo??
  23. Easy fixes to do...
  24. Control Arm Bushings for 2nd Generation LS400
  25. Carbon fiber hood avail. for 1st gen. !!!
  26. Which is the better buy?
  27. Bad AC Compressor Breaks Serpentine Belt!!!
  28. '95-'00 Stereo button backlighting replacement
  29. AC Unit Guagepod ***Pics***
  30. colour not matching after accident repair
  31. speedo incorrect
  32. a/c????
  33. Ls400 Maf?
  34. R12 to R134a conversion problems
  35. Connecting the idle up valve hoses to each other
  36. self cutting brake pads for the rotors.90LS
  37. Timing belt question
  38. A/C and Clock Display
  39. Hesitation
  40. 2006 LS500GT over $100K
  41. Cigarette Lighter
  42. Starter / Charging Problem
  43. Well...$550 to fix the steering wheel!
  44. Who really wants the wood steering wheel?
  45. Torquemaster spark plugs
  46. NEEDN suggestions and help on my 91 ls
  47. need help for my 91 ls!!!
  48. Sand Rotors?
  49. A/C Compressor
  50. ABS on 93 LS400 question
  51. any experienced auction attendeers?
  52. suggestions for my 91 ls400!!!
  53. Off center steering wheel
  54. Brian V. did sell his LS
  55. Newbie
  56. Keyless Remotes-Which One? Both? LS400
  57. Wipers
  58. PS leak - from cylinder atop rack/pinion - now what?
  59. brake bleeding from service manual 93LS
  60. 90-91 Ls400
  61. Finally got my stuff....:)
  62. Help....96ls400....vibration(tranny?)
  63. proportioning valve / abs actuator
  64. twisted seat
  65. Exhaust Residue on Bumper/Trunk
  66. Oil Filter from Dealer - New Product?
  67. how to replace brake bulb?
  68. Toyota Celsior Emblems, where to get?
  69. 91' Ls400
  70. Door lock actuator problem -locking unlocking randomly
  71. No AC, rear defog, thermometer, clock
  72. 93 LS400 - Fair Price?
  73. 2nd car choice? another 400?
  74. Rpm @ 60 Mph?
  75. H3C to H3 conversion
  76. 1993 LS400 How to Change Cabin A/C Filter?
  77. strut /spring question
  78. winter driving
  79. Celsior (LS) side emblem
  80. First time pics in the gallery!!!!!!!
  81. Newbie Hello!
  82. Incompetent Grease Monkeys
  83. Where to get LS400 badge for trunk?
  84. Damn fool scratches my 400...
  85. Hard time starting my 98 LS400
  86. lucked out and got my LS 400...
  87. Help me locate the trans cooler line
  88. Road Trip In A Seville...Thanks Lexus!
  89. A/C issue
  90. 95LS check engine light
  91. anyone know how to disable auto steering wheele adj.
  92. disabling automatic steering wheel adjustment
  93. any of you guys use a monroe strut for your ls?
  94. Is the power source in the center console suppose to be switched power?
  95. is it possible to upgrade a Lexus key?
  96. LS400 stereo help - head unit backlight
  97. Thoughts/review on JIC VIP FLT-A2 coilovers...
  98. can we use 95SC400 transmission for 93LS400?
  99. Front & Rear Polyurethane Swaybar Bushing
  100. Power everything rear seats
  101. o2 sensor
  102. Fitting Optima Red Top In LS400
  103. Knock sensors ?
  104. pulls to the right
  105. please help a rookie
  106. 91 ls 400 vibrating after engine wash
  107. Spits water from AC duct under steering
  108. JIC Magic FLTA2 Coilovers
  109. How do you reset the trouble codes?
  110. Suspension
  111. Headlight Eyebrows?
  112. bursty feeling in acceleration
  113. Steering system
  114. wood dash kit
  115. Pwr streering leak
  116. introduction - LXU55
  117. Thinking about a 95 ls but what should i do .....
  118. '95 LS wandering
  119. Low idle (down to 200rpm) then it quits
  120. Polyurethane Rear Swaybar Bushings for under $20
  121. Water Repellent Windshield
  122. this afternoon I started up my engine and...
  123. Idle speed control valve
  124. Would you trade?
  125. LS400 compressor failures?
  126. Well it has been a while
  127. That's not fair
  128. Another strut bar question
  129. Fastest?
  130. Bra for LS400? Anyone have one?
  131. brakes pulling
  132. Time to do more mods
  133. Camber, A-arm kits UCF 10-31
  134. engine startup
  135. Alternator Weirdness - Expert Help Needed
  136. wheels?
  137. Lowered UCF 10-21 camber
  138. Pedals/ shift knobs
  139. 1993 LS400 factory alarm problem
  140. "cage house" light comes on
  141. 4 o2 sensors 1990-1994
  142. Fellas, educate me.
  143. Outside temp sensor location?
  144. Feeling some suspension vibrations through Steering wheel
  145. Green fluid
  146. Install Complete! for 93 LS400. But Keyless Entry Does No Work!
  147. on the good side, iam getting these tommorrow
  148. I tinted headlights/corner lights on 90 LS
  149. replacement tweeters????
  150. no seat belt tension
  151. Aftermarket Shiftknob for the UCF10/11
  152. key programming
  153. upper control arm?
  154. I keep popping fuses!!?? (97 LS)
  155. Help! driver window stuck open!
  156. Mad Respect from Toronto
  157. suspension problems.90LS
  158. Lemon Law?
  159. 1994 LS 400 brake squeal
  160. 93-94 LS Yellow Foglights?
  161. S Fla. LS's
  162. dome light problems
  163. Rotora Big brake Kit avaliable for 1st gen LS
  164. Would i be crazy to buy with 175,000 miles?
  165. exhaust......
  166. new LS owner at 173,000 miles!
  167. lighter socket problem
  168. Lowenhart LDR's
  169. Driver's seat problem
  170. Fastest you've gone?
  171. ouside temp readout in Celsuis?
  172. RSR Springs
  173. Interior Color Options for 95-96?
  174. Rear swaying?
  175. checking the air suspension?
  176. smoke at start
  177. Is there a separate ECU for Traction Control? Traction Control & ABS use same ECU???
  178. Timing belt?
  179. Is it possible to fit ?
  180. Blower Motor Question
  181. 1995 LS400, Creaking / Groaning
  182. what is the remote switch for that has the window on it
  183. need some help, headlight question for a 96 LS400
  184. Considering an LS430 - need some help
  185. Modify the Climate control
  186. 1st Gen. Shifter
  187. 150+mph?
  188. counsole disassembly w/telephone
  189. Whats the best way to remove my "Alternator".. I have a 91LS400?
  190. Starter ?
  191. Some info on future LS500
  192. Mechanic Says Replace ECU/ECM - HELP!
  193. trans problem ?
  194. Anybody has Pictures of 1st Gen LS with a Spoiler? Post Please
  195. Lowering my '92 LS
  196. Where to buy ?
  197. All Lexus brakes click, Part 3
  198. stull grilles?
  199. Any black LS owners have tinted windows?
  200. URGENT - Engine light when cold - please respond
  201. De-badged grille?
  202. WISE bumper for first gen LS
  203. swapping headlight assemblies
  204. Crystal Clear Headlights for 96 LS400
  205. engine ping
  206. I got my keyless entry working!
  207. Yet another costly repair. Bye bye Lexus?
  208. Finally - pics of my baby!
  209. What could this leak be?
  210. 1st gen clear headlights
  211. Has Anybody seen this in person (air runner suspension)
  212. Aftermarket head unit dash kit available 95-00
  213. erg pipe leaking
  214. Any "performance" mods for the LS?
  215. Center Wood Consel
  216. What makes the 92 SC400 1 second faster than the 92 LS400?? It has the same motor..
  217. My ABS & Trac Light won't go off?? What could be the problem?
  218. 91 LS400 headliner noise
  219. ouch!tires rubbing against rear fenders
  220. Tail lights for a 00 LS400
  221. Kids.........Celsior
  222. 92 ls400 throttle delay
  223. 1st Gen LS with real wood?
  224. trac control pipes ?
  225. 2002 LS430 bent rim
  226. 1992 LS400 TRAC light
  227. windshield wipers
  228. Recently purchased LS400 98
  229. All Lexus brakes click, part 2
  230. A/c - Help
  231. body kit
  232. replacing alternator
  233. which grill to get?
  234. New LS400
  235. 1st Gen LS Owners - Interesting email, help needed
  236. Finally! A pic and an avatar
  237. All Lexus brakes click
  238. Tein CS vs Eibach Springs
  239. Uh Oh!!! I Made A Boo On My Car!!!!
  240. advice on front suspension issue
  241. Quick wheel question
  242. I need help with tune up info
  243. Who make this lip spoiler?
  244. 90K mile service
  245. Should you take to dealer for alignment?
  246. History of the LS/Lexus
  247. Proud new owner of a 99 LS400!!!
  248. ignition problems
  249. Windshield Replacing
  250. Engine Shuts Off
