PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Zaino Effect
  2. Looking to get a 93 LS, tips and advice?
  3. major power lost, cats glowing
  4. 2nd GEN diamond cut bumper lights!!!!!
  5. Anodize the STB?
  6. starting new project
  7. 96 LS 400 purchase - what to look for?
  8. Ca Supra TT F rotors fit LS400 one?
  9. How much is to much
  10. Do all air susp have a height switch?
  11. Junction Produce Clear Corners for 98-00 Lexus LS400
  12. Looking for aftermarket parts
  13. Blower motor not working in low or med speed
  14. Want a smoother running engine?
  15. Tein CS available
  16. Creaking Noise From Drivers Seat Back
  17. upgrade air suspension
  18. Where is this oil leak coming from?
  19. Seats
  20. '95 Starting...take two
  21. key fob cracking
  22. Windshield Washer Sensor Replacement
  23. A question For all
  24. Smoke
  25. Car Phone without a purpose
  26. my worst fear has been realized...
  27. Trunk Question
  28. HELP please: engine problem now after i cleaned throttle body
  29. 95 Ls400 Headlight aim
  30. rack solenoid filter removal
  31. Repair Manual
  32. Quick Question - Wheels Tilting back.
  33. Vehicle Weight
  34. How to get back that door "THUD".
  35. snow wheels
  36. broken seat
  37. Engine Warning light on
  38. Cooling fans not running
  39. Colder=smoother? Go figure?
  40. Talk about Lexus on Lexus violence...
  41. A/C hose replacement?
  42. Sewell Lexus Touch Up Paint.
  43. Colors
  44. Second gen LS400 owner (need your help)?
  45. LS 400 and 430's 98 thru 02 Wholesale Transactions
  46. Airborne debris hit my '98 LS
  47. Hit Head on in my '95 LS400... totaled the car
  48. Auto Dimming rearview mirror in 99 LS400
  49. removing rear view mirror
  50. Would L-tuned GS shocks/struts fit 98-00LS?
  51. Aftermarket parts....
  52. dead spark plug wires
  53. Inner Rear view mirror "knocked Out" in a 99LS400?
  54. Need help
  55. reading codes
  56. whinning noise
  57. My '94 LS400
  58. Help, where is the transmission fluid return hose to the radiator?
  59. Clunking noise when braking
  60. Lowering an 1994 LS400
  61. Bent seat frame or Bad motor or gear?
  62. Please Help: need definitive answer to replacing ball joints
  63. clears
  64. Rear bumper removal?
  65. to upgrade or not?
  66. 92 LS 400 - Brake is getting stuck
  67. Need definitive answer to replacing ball joints
  68. O2 Sensor replacement
  69. headlight housing rusted
  70. air suspension
  71. TRD Radiator Cap for LS400 1st Gen.
  72. Will a 95-00 rear bumper fit in a 89-94?
  73. Where can I buy white signal lamp-glas for LS 400 -96?
  74. Swap Lexus Premium to Nakamitchi Sound Systems
  75. vacuum Testing
  76. Help !!! Got error code 41 (TP Sensor Signal ) on my 1994 LS400
  77. Where is 1994 LS400 diagnostics terminal?
  78. 95 or 96 LS400 w/ Engine Stall Problem?
  79. Never Seen So Much Wood In A 97' LS Coach - SEE PICS
  80. What do you thing about these mufflers???
  81. 1995 LS400: remote key or just remote fob?
  82. LS 400 Air Suspension Conversion
  83. A Lil' Something Something : -)
  84. Programming a remote off Ebay?
  85. Trany switch?
  86. Some great Press releases on LS400 and LS430
  87. LS400 High Speed run Pic
  88. Chirp chirp sound!
  89. Where to Buy Ball Joints? quick question
  90. Remote Starter Kit for LS400??
  91. New Owner - Heated Seats Question
  92. has anyone done this mod to their LS?
  93. Pics of my project...anyone got an OE lip?
  94. Headlights and A/C weakening during braking
  95. Which parts to replace?
  96. How To
  97. 89-94 Celsior Intrusion Bar
  98. engine serial number location for ls 400
  99. air suspension
  100. 2nd LS400 photos
  101. JDM Celsior 1990 features...
  102. spacers
  103. need a little guidance
  104. 94 LS400 Instrument panel lights fixed!
  105. Traction and Check Engine Light Coming On
  106. Acceleration = Vibration?
  107. persian451 !!!!! (smoked tailights)
  108. Wood Shifter Knob
  109. headliner falling
  110. random things...
  111. First Car...What Too Do With It???
  112. TEIN CS finally mounted!
  113. Gen 1 LS Leather/Wood Steering Wheel Conversion
  114. alternator fuse melted
  115. Air condition just shuts off when car is idling
  116. Solved TRAC light on problem, might help to older LS400 owners
  117. carrier bushing Help!!!
  118. Cluster needles and guages
  119. 1st generation question
  120. All 95-97 LS owners
  121. window regulators
  122. TDI Supercharger system
  123. 1996 ls400 light question
  124. Glove Box light
  125. New mod for my car, what a difference
  126. SS brake lines info needed
  127. C's Shift Set for 1st Gen.
  128. Win Aluminum STB
  129. Confusing if you ask me.
  130. Sport Mirror's
  131. need headlight for inspection
  132. What Is The A/C Filter?
  133. Euro Suspension (Taste of Luxury Event)
  134. 95 LS400 Engine Pulsing?
  135. free owners manual
  136. Another LS400
  137. 1st gen. accessory question
  138. Questions on LS400 Mods
  139. Manual
  140. airbags
  141. Class Action: Luxury Car road test
  142. Platinum Intake Twister?
  143. Need Kit For PS Pump
  144. Help! 99 LS400 fog light won't go off!
  145. LS Chrome grille
  146. Adding to the Stables
  147. LS430 prototype?
  148. Bose suspension video
  149. Car Info on door tag ? ? ?
  150. Why get the Ultra Luxury?
  151. Need Airbags For My 96 Ls400
  152. Replace shock/strut mounts??
  153. Simple Question, Help please (Where is the oil filter)
  154. new suspension has been retrofitted into a 1994 Lexus LS400 sedan
  155. good+cheap intake for UCF-21
  156. LS400 Radiator Replacement
  157. 2jzgte swap???
  158. Cheap Body Upgrades?
  159. Bang in driver rear side over bumps
  160. Replaced Engine and Transmission Mounts
  161. Airbag electric adapter???
  162. 1990 Air-Ride Suspension Problem
  163. Seat Heater install
  164. Collateral
  165. Window Switch Auto Up/Down
  166. Supra TT Brake
  167. No Power At All - HELP
  168. Installing new steering wheel
  169. LS 400 Overheating
  170. Best wood trim kit?
  171. question about what to check in a car that hasnt been serviced in 28000 miles
  172. Please Help!!
  173. 02 sensor
  174. Addco sway bar issues
  175. Finally a pic-BIG PIC, sorry
  176. LS strut bar
  177. Windows & Sunroof Stop Working Help!!!!!
  178. Need some advice. Another stater problem?
  179. 1st gen gear shift
  180. Need help with Half working suspension
  181. changing headlights
  182. Click!click No Start
  183. New to the board
  184. $5 Project - Painted Corner's (pics attached)
  185. low tire
  186. Chrome or Pearl Black? - Pics
  187. ls400 or economy car???
  188. Fixing a 1990-1992 LS Instrument Cluster
  189. Where to attach Cargo Net??
  190. Engine & Transmission Mount$
  191. How can we LS/Lexus owners protect ourselves from criminals?
  192. Help On 96 Ls400 Lip/roof Spoilers?[/
  193. Questions Comparing 98-00 LS400 vrs 01-04 LS430
  194. Replaced Rear Trans Mount Replaced
  195. 1990 LS400 A/C recharge
  196. A couple of GPS 2004 questions
  197. Help please
  198. bad solenoid switch on accumlator
  199. Red 1st Gens
  200. Pinstriping
  201. Lexus dealership troubles
  202. read the manual but...
  203. Exhaust tips
  204. source for uper control arm bushings
  205. Chrome tips
  206. Daytime running lights weird?????
  207. Lsportline for the LS
  208. muffler tips
  209. Need Rear Coil Springs
  210. keyless entry - LS400
  211. How to replace signle sidemarker bulb on a 98?
  212. Light Configuration
  213. How to take off Front/Rear bumpers ....
  214. New LS400 owner
  215. Major Repairs Needed... Help
  216. LS 400 sounds loud
  217. Stalling Problem
  218. Yes or no to Extended Warranty
  219. any1 ever had a problem with the rear main seal leaking?
  220. My Transmission has complete loss of power!
  221. 3rd brake light
  222. Help Who Makes This Spoiler ? ?
  223. 1st gen. LS400 Exhaust
  224. changing serpentine idler pulley
  225. Knock Sensor and Trac Light
  226. Fuel Gauge Needle
  227. 49MPG Current Fuel Consumption Reading on a 99LS400
  228. 99 LS400 with Bad radio LCD
  229. door problems
  230. retrofit to 134a: need to drain old oil?
  231. 2nd Gen Crossdrilled Rotors
  232. Rotors and Pads
  233. L-Sportline Springs for 2000 LS400, what is the rated drop?
  234. Please Help Power St. Pump
  235. Need a gearshift knob FOR 1994 LS400
  236. Need opinions (Exterior)
  237. Do you have REAR aircon in 2-nd gen LS ?
  238. navigation system light dim
  239. Rough Start
  240. Clearing the amber out of the taillight??
  241. LS400 Rotors/Brakes
  242. Steering noise on LS430
  243. Brake light on
  244. Place to buy replacement antenna
  245. 95 ls400 with 99 eng $5500
  246. help with xenon kit
  247. 98-00 Steering wheel controls; what do they control if you havr NAV?
  248. Would you jump into this boat?
  249. vnt turbos
  250. questions on hilltop lights
