PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. nakamichi cd changer 1995 ls400
  2. Lowering Ls400 questions.
  3. Which Tire to get for my 00 LS
  4. Dual Supra Fuel pump for LS400
  5. shifting manualy - bad for the car???
  6. Recommendations for 15 inch rims for 92 LS4
  7. Tire size questions
  8. 60K mile tuneup
  9. Just changed power steering fluid
  10. 98-00 Ls I found on VIPsylecars
  11. Gear Shifter Schematic for Gen 1 LS
  12. Filling my A/C - How??
  13. '90 ls problem "dies" please please help
  14. timing belf & water pump
  15. Wings West and Veilside Body kit combination
  16. 90LS air suspension prblm
  17. Is '98 LS400 "generation two"?
  18. Power Steering Issue
  19. Transmission replacement 92 in a 93
  20. Navigation on 98-00
  21. Question about fuses underneath driver side headlight?
  22. Trying to find low pressure port for A/C
  23. who needs lexus manuals?
  24. 1st gen LS400 temp gauge malfunction...
  25. Keyless Entry - Faulty Key??
  26. Not buying an LS400 anymore
  27. GS ride V's LS?
  28. Suspension question
  29. A/C, Heater problem, please help.
  30. Need to install springs on my UCF-20
  31. 95 LS400 Speed Sensor VSS and Kenwood Navigation Question
  32. I just bought a 1998 LS400
  33. TRAC OFF / Check engine light Fixed!
  34. Trenz Billet Grille just installed on my 1st Gen
  35. EGR tube replaced, no more exhaust leak!
  36. Pic of my '92 LS400
  37. LS Aniversary edition
  38. Just gotta 98 Ls; Which bulbs to get for xenons
  39. Removing the CD Changer in 90-94 LS400
  40. Car shudders/hesitates when shifting into park.
  41. 92 LS400 A/C Water Leak - Help !
  42. Replacing Antenna Mast on LS400
  43. torsion bar is bad,,,,,, anybody else have this problem
  44. Radar Detectors
  45. How often should I change the oil?
  46. Father and son
  47. New owner: A/C blower seems a little weak
  48. Deciphering Vehicle Identification Numbers (VIN)
  49. excessive steering wheel shaking after small bumps
  50. Is this too much mileage?
  51. Revving High Idle Problem Solved
  52. caliper loose, squeaking brakes ?
  53. Intake Manifold
  54. What!!?!?! LS 400 at the Nurburgring !!
  55. Tell me this aint sexy (monotone LS)
  56. LS400 with Amistad Type F
  57. Aftermarket headunit.
  58. Congrats to ATSOU: June's COTM
  59. Will RX330 Shift Knob Fit?
  60. when to replace air struts?
  61. Hard shifting into gears
  62. 18" 06 GS wheels on a 00 LS400 ??
  63. buying a 90-92 ls400 within a week or so
  64. Replacing the Navigator DVD on an '04 LS430
  65. LS400 + Army Truck *Pics*
  66. What Headlight Bulbs do YOU have?
  67. alternator prob.
  68. Amistad LS400 Body Kit - NEW!!!
  69. Need some help here about my ls 400 power steering pump
  70. 1990 JDM Celsior Pics
  71. 93 ls400 electrical
  72. Strut bar, is this a good one? 1990 LS400
  73. license plate screws needed
  74. Front End Shimmy LS 400 2000
  75. Transmission Cooler
  76. Having problem with my LS400, need some help
  77. LS Bike Riders--need your help!
  78. 92 LS 400 running rough
  79. Air suspension
  80. Help!!! How to change the rear brake light?
  81. LS question
  82. 2nd gen namakmichi ?
  83. 2000 LS400 wheel size ?
  84. instrument cluster lighting replacement 1990 ls400
  85. VIP Car DVD
  86. Just Installed custom JDM red/clear tails on 99 LS
  87. need some advice on a 1993 LS400
  88. 1st and 2nd Gen must check this page. Lot of info
  89. Ebay Hood/Trunk shocks?
  90. ebay Key question?
  91. 91' Ls 400
  92. Time for the LS to get a custom Trunk
  93. Is this a good deal??
  94. Driving on Dirt Roads
  95. ***Upcoming changes to forum lineup***
  96. Gen1 Alarm Question
  97. 18" OEM wheels on a 2000 LS
  98. Steering Wheel Deterioration
  99. 96LS with 2000 Identity
  100. Mirror Signal mod?
  101. Foglight mod for 98-00 LS COMPLETE!!
  102. sneek peek on Stefwilli/D2autosport LS
  103. New Toy - T04R
  104. L-Sportline Dual Exhaust?
  105. How rare is my Lexus...
  106. 1st Gen. Clear tailights leaking!!
  107. 1st Gen. Gear Shift Cover
  108. Is this 1995 LS400 a Good Buy?
  109. any time I depress the brakes my car shuts off
  110. info
  111. Lowered frontend uneven....here's cure
  112. My WALD KIT is installed *pictures!
  113. Dual Exhaust Question
  114. What's your opinion on Axis Wheels?
  115. pneumatic electronic suspension - replacement alternatives
  116. Integrated cell phone option
  117. LS400 19 in rims question
  118. ATF for my A341 automatic?
  119. Replacing AIr susp with regular susp? 90 ls400
  120. Getting really sick of the LS
  121. Xxx Lex Ebay
  122. Brake Pad Installation-Reasonable Cost?
  123. My Wald Body Kit
  124. dashboard cover
  125. Clear Headlights
  126. Major brake caliper problem.....(HELP)
  127. Crown Athlete UCF10 conversion?
  128. I found Cheap 20" Chrome Rims for a LS400 Should I?
  129. rotor installation..
  130. BRAKE & WHEEL QUESTION???
  131. 20 inch rims
  132. Switch behind tool compartment ?
  133. Stinky AC Vents
  134. ??SST tools for timingbelt/waterpump/oils seals??
  135. Noise when backing
  136. Factory Phone on '92 LS
  137. Where is the AMP?
  138. stock stereo question?????
  139. Suspension/driveline
  140. Looking at 1990 LS, Your input needed!
  141. interior differences....
  142. "lot of nuts" chrome wheel-anyone want one
  143. HELP - noisy AC compressor - again!
  144. need lexus mechanic in connecticut
  145. New 1998 LS Owner and VIN Location Question
  146. Is there a LEXUS equivalent?
  147. LS400 Comparisons
  148. Fuel Door -Dash Switch broken
  149. L-Sportline shocks: default height setting?
  150. $125 for a spark plug change?
  151. 1995 LS400 Paint Colors and Interior Colors
  152. 1995 Headlight Differences
  153. Looking for member named Khang
  154. Comparison Legend vs LS400
  155. High Idle on cold
  156. LS430 in Star Shield Armor booth at LA Auto Show
  157. test drive appointment
  158. PSI on bigger wheels
  159. LS Aero parts fitment FAQ
  160. Oh No!
  161. 150,000 Maintenance
  162. Anybody experience California Custom springs?
  163. Why do they call it this???
  164. Airbag wiring Gen 1
  165. Airbag schematic for Gen 1
  166. Pics (finally)
  167. LS done, finally (pics)
  168. Lower gas mileage after K&N and exhaust upgrade
  169. 7 seats white LS400
  170. Climate Control question
  171. 99 LS400 Dash Light malfunction
  172. WOT Switch under Throttle?
  173. Battery Draining
  174. Thanks To OVERSTEER!
  175. CEL Light Situation - WEIRD!!
  176. Spy shots of New LS430 (update Toyota Crown pics)
  177. DIY Celsior/LS website
  178. Should I get other stuff replaced when lowering?
  179. About my engine coolant...
  180. How much can I get? 93 LS400
  181. 90 LS400 Idle speed problems
  182. A very curious question about my LS...
  183. Two different ball joints made for the LS400?! (Need Advice)
  184. LS first gen '92 wheel/tire recommendation
  185. Stock LS400 owners..at how many miles did you replace shocks?
  186. Too much feeling in the steering wheel? Help?
  187. Door drain holes
  188. 96 LS front brakes
  189. Help Boot leg cds wont play in my 95 LS400
  190. Nice weekend for DIY
  191. 2007 (4th-generation) Lexus LS model plans
  192. Cool Interior mod
  193. Struts Koni or Bilstein?
  194. Speedo inaccurate need help
  195. Climate control help!!!
  196. Please when you make a Thread put the year of your car and make!
  197. LED Globes for LS
  198. My car died
  199. center dash light
  200. 1990 LS400 proud owner
  201. 98- 00 Ls400 L-sportline bodykit
  202. How can I remove the indash cd changer Help!!
  203. Help....LS430 Wheels on LS400??
  204. Q's from a new owner (94)
  205. Replace Speakers
  206. Tailight facelift for Gen 1 LS
  207. ls400 power steering noise
  208. 100 Octane
  209. Factory vs. Non-Factory Chrome
  210. 98 LS400 with 04-05 18" Wheels?? Anyone?
  211. JDM strut mounts
  212. Loose seatback....?
  213. Lowering Springs
  214. Low tweeter volume both sides 94 LS400
  215. Starter Question
  216. should I lease or should I buy?
  217. How to fix angled seatback?
  218. Fuel Pump replacement on Gen 1
  219. New JDM Type C-F Celsior
  220. Brake Issue revisited
  221. MAF Screw
  222. Thinking of buying a '96 LS400
  223. Small (economical) lip spoiler for 98-00 LS?
  224. Tie Rod Ends?
  225. No 6x9's!?:eek2:
  226. Celsior/LS 400 Stock Radio
  227. So my car wouldn't start today...
  228. Which LS are you in?
  229. Painting bottom cladding black and black grill.
  230. IS300 wheels on the LS400...and other misc pics...
  231. OH NO! p/s problems with my 1990 LS400
  232. Strut Bar Performance
  233. Question For New LS 400 owner
  234. 1990 LS400 stereo installation? HELP PLEASE!
  235. air suspension conversion
  236. 90 ls 400 inter bad radio code lock up
  237. The "pinstriping" alongside the LS400....painted or vinyl?
  238. New way to mount cargo net
  239. ??93 LS400 with no CD changer??
  240. What JIC model is this?
  241. What is your #1 favorite feature in your LS?
  242. Theft Deterrent System ECU
  243. IS300 wheels on 1st-gen LS400
  244. Installed Sylvania Silverstar headlight bulbs and did the H3C to H3 conversion....
  245. Oh great, my car stalls in standing water
  246. The original 1989 Car and Driver Comparo!
  247. If there was no LS 400 what would I drive?
  248. Theft Deterrent System Fail
  249. Brake Pads
  250. 91 Ls400, Good buy?
