PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. warm and cool air at the same time (1996)
  2. Considering 95-97 LS400, common issues?
  3. green glass
  4. interior and exterior ls400 2000
  5. After a rain, the car runs horrible(?)
  6. Saying good by and hello RX family
  7. 1995 LS400 wiper arm access
  8. Stereo wiring Schematic '99 Celsior
  9. General Questions
  10. Some cluster lights comming on?
  11. Looked for exhaust leaks, now car pulsates
  12. JDM vs USDM 1UZFE VVTi questions
  13. Car Overheating LS 400
  14. New here- first LS!
  15. Question about wheel bearing
  16. 92 LS400 Rear Susp. Bushing
  17. Gen 1 front suspension
  18. how to compress the front caliper pistons
  19. Need Help-LS400 stuck in park, dash lights out
  20. 1994 ls 400 : Front coil springs
  21. Road noise
  22. Flickering Cluster: Does Anyone Repair Them?
  23. My 1st lexus - '98 w/200k
  24. Dashboard electrical problem. (Vid included)
  25. Turbo sizing
  26. ucf11 steering problem
  27. LS400 outside Door handle
  28. Cluster Change 90 to 93-94
  29. It feels like the transmission jumps into neutral
  30. TOYOBD1 and its wonders.
  31. 93 running rough. Need some insight.
  32. Labor cost 94 ls400
  33. Best aftermarket LBJ?!?
  34. Yamae question
  35. 1999 Celsior Radio Cassette Part number
  36. 1UZ swap looking for new dif setup
  37. Are mismatched tie rods OK?
  38. Interior Interchange???
  39. Alignment necessary after strut replacement?
  40. Compressor problem or leaky ECU caps?
  41. First gen vs. second gen front bumpers
  42. Power Steering Geyser From Reservoir
  43. What are the beginning signs of power steering pump failure
  44. 1990 Celsior UCF11
  45. Coilover tool help
  46. HELP: Fender removal
  47. Power steering reservoir question. 00' LS400
  48. timing check on '92 LS400
  49. 1997 LS Crankshaft Position Sensor Help
  50. First Time Buyer Tips
  51. 94 radio bull****
  52. UCF-10 Car Phone?
  53. Need help -Error Codes on ls400 1998 - p0420, p1126, p1129
  54. 1992 LS400 factory camber adjustment
  55. Avid.1 AV50 on the 1992 LS400
  56. UCF21 Climate Control Unit Smoking !!
  57. ls400 acceleration issues
  58. What Does A Million Miles Really Tell Us?
  59. Wanted: feedback from those running aftermarket UCA's.
  60. '92 LS400 -motor has missing problem
  61. 96 lexus ls400
  62. Anyone have a pic of the Low Beam cannon plug/connectors on a 95-97?
  63. Just a bought a new LS 400
  64. Rear Strut replacement cost
  65. 99 LS400 Upper ball joint replacement: control arm needed too?
  66. '99 Celsior. Changed battery now won't start
  67. Oil Change--They put in wrong kind?
  68. 17 years of great service from my 1991 ls 400
  69. Limp needle fix (impact)
  70. LS400 valve adjustment shim diameter?
  71. New struts - buy whole assembly or just cartridges?
  72. 98+ bumper On 95-97
  73. '92 LS 400 firing order needed
  74. Maintenance Question- 41,000 miles, TB/WP never replaced
  75. help finding a part number, or name! ls400 trans sub-harmess
  76. No matter how huge the wheels.I love this
  77. Headlights come on by themsleves...ideas?
  78. Invisible Audio Elves Fixed My Nak
  79. Need help finding intake torque specs
  80. Transmission groan/whine. Strainer clean.
  81. 1998 LS 400 Headlight replacing/removal tips NON-HID
  82. Fully Loaded !
  83. Changing it up a bit
  84. Car starts runs for an instant and dies
  85. Fog lights
  86. Speedometer Diagnosis
  87. Ticking/tapping/clacking 1UZFE?
  88. need new seats? 1990 with cloth seats
  89. H & R Springs question
  90. Fuel pump relay resistor
  91. El Cheapo Parts On eBay
  92. Tire Help re: 2000 LS400 with 18 Inch LS430 Wheels
  93. cd changer error 21, now working
  94. 1995 LS400 differential bushings shot? with pics
  95. Brake/stop light bulb in tail lamp - how to remove?
  96. 90 ls4700 - stall out every 5-6 secs
  97. Coolant bubbling in reservoir
  98. Help: Rear brakes and rotors
  99. Radio Fuse Location
  100. What do you think I cooked this weekend? (Electrical)
  101. Changed My 1995 Ls400 Fuel Filter Today
  102. Power tilt steering wheel noise
  103. Identifying leaky EGR pipe
  104. Different Power Steering Failure! New Unsolved Topic! Help!
  105. Hello going to look a 95' LS400 today
  106. Blowing 15A fuse #36 1995 LS400
  107. Hello everyone, I'm Jon
  108. Rob Ferretti driving my LS
  109. LS400 98 vvti engine swap to 95
  110. going to look to buy LS400
  111. Question about front corner lights
  112. horn wont stop help me diagnose
  113. Oil spewing in front of oil pan, bad seal?
  114. Wait... Did my AC just suddenly go out???
  115. Steering Linkage Question
  116. Timing Belt Hack - 1995 LS400
  117. 1993 ls400 oil pressure
  118. 96 lexus ls400 - 22's fit?
  119. Ignition Switch..I think? HELP ME PLEASE!! NEED INSIGHT!!
  120. Blowing Alternator Relay - LS400
  121. Tilting wheel kills car
  122. Tune up parts ?'s
  123. 99' Cracked Outer Door Handle
  124. Considering purchase of a 1994 LS400
  125. I can only go in reverse
  126. Coolant blocking plate leak, 1999 LS400
  127. Good places to buy 98-00 LS400 and Timing belt questions....
  128. from 1 acura to 2 lexus! new guy here!
  129. 26th Anniversary of LS-400
  130. 98 LS400 broken airbox/vacuum leaks
  131. Tanin electronics
  132. LS400 Tranny Solenoid Cleaner?
  133. Help with possible timing belt poor installation
  134. Cluster board giving out ??
  135. so I think I'm going to need a power steering pump soon.
  136. Stereo -Pioneer to Nakamichi?
  137. Burning smell in the Cabin of 1995 LS400
  138. Unable to get obd2 codes on 96ls400
  139. Steering Wheel Problem
  140. Cat converter, exhaust leak, or egr tube?
  141. 1991 Lexus LS400 CEL after work done
  142. Help with part #
  143. Weird electrical problem 95 ucf20 HELP!
  144. 1993 to 1996 ls400 interchangeable ?
  145. '90-94 Factory Hubcap Removal
  146. What is considered the normal for a 94 ls400 to idle at in park
  147. help with air suspension diagnosis
  148. P0773 - Shift Solenoid 'E' Electrical bad ecu?
  149. New 1998 UCF20 owner....with a miata too :-D
  150. i think i might have found something super rare!
  151. Talk me out of buying a 1993 LS400 !
  152. Load Rating question
  153. Strange shifting at high rpms
  154. new owner '93 ls400
  155. Hello. My '93 LS400
  156. Center armrest/compartment latch broke on my 98 LS400
  157. Another new owner that MIGHT stick around...
  158. 1995 LS400 Gauge Cluster
  159. Timing Belt Replacement Question
  160. Shifting problems
  161. Dead Battery?
  162. Opinions on changing the pinion seal. 91 ls400.
  163. What is't ?
  164. 1998 LS400 Overdrive
  165. Help: 95 ls400 rack & pinion, front lower ball joints
  166. Camshaft Oil Seal Replacement
  167. How long is the original wheel studs
  168. New Owner 1994 LS 400
  169. HELP: LED Corner Turning Signals
  170. 1994 LS400 Transmission Flush questions
  171. Turns over but will not fire!
  172. 94 LS400 - Code 28 - Upstream O2 Sensor Rgt Bk?
  173. VVT-i Question
  174. Worn leather - How should I fix this?
  175. Are Lexus OEM shocks worth it?
  176. Catalytic Converter Advice
  177. A/C condenser fan question
  178. 94LS400 Code 35 (HAC) sensor signal ?
  179. 99 ls400 fuel range issues
  180. 94 LS400 Code 35 & 47 Car Bucking/Shifting & Dies problem?
  181. Code 12
  182. 91 LS400 car starts after 2 seconds dies
  183. Bought a '92, been under the hood all day.
  184. Automatic setting of alarm
  185. Odometer hidden menu
  186. Can $4K buy a well-maintained/good cosmetics LS400?
  187. Is this a good buy?
  188. mass air flow sensor problem
  189. '00 LS400 OEM Engine harness availibility?
  190. 1997 LS 400 alternator replacement help needed
  191. 2,400 Mile Road Trip Observations
  192. That 3000 mile LS ?
  193. My "new" car
  194. UCF10 offsets
  195. cooked alternator?
  196. U.S model ls400 vs Canadian ...any diffrence
  197. Rear wheel bearing replacement with knuckle on car
  198. Gas Mileage Lexus LS400 1997 4.0 Liter 260 HP V8
  199. 95 LS LED tails and clear blinkers
  200. Loss of power, both cats glowed red
  201. Adjustable Upper Control Arms
  202. '93 LS400 OEM Wheel + Tire Swap
  203. Fuel pump relay location 1994 LS400
  204. Question about 1999 LS400 suspension
  205. Code 0500 along with vibrations from rear end?
  206. 1990 LS400 instrument cluster help
  207. can these wheel still be mounted
  208. Good aftermarket headlights?
  209. P0135, p0420, p0430
  210. Need you guys opinion on what tire size I should get
  211. Replacing alternator brushes
  212. 2000 ls400 Instrument cluster & hi beams out
  213. Need help-93' ls poor idle, no acceleration and running rich
  214. NEED HELP - CD Changer ideas
  215. Largest tire in '92 spare wheel well
  216. Black Gold - Out of Bounds
  217. OBD port in 1993 LS 400?
  218. Ls400 2000 belts ??
  219. control panel a / c
  220. 1990 LS400 in Georgia
  221. My new ride is here!
  222. steering/front end rattling sound?
  223. Initial Impressions of my '95 and p0420/p0430
  224. 95+ brembo rotor blanks
  225. Speedo inaccurate, other weirds
  226. 92 lexus ls400 tsm?
  227. Would the wheels fit my 1998 LS400 Celsior
  228. 98 LS400,Driving around fine, then super rough idle and car dies
  229. need help- electrical problem-radio cutting out
  230. Help! I need tips to weld together a broken piece from water pump inlet
  231. 95 Lexus LS400 Bluetooth Add-on w/Pics
  232. Help Airbag Code 14
  233. E60 M5 Wheels
  234. How often do you change oil & filter? What brand oil & viscosity?
  235. '96LS400 misfire and p0115
  236. help pls- radio shuts off when braking
  237. KeyLess Remote Case for Lexus LS400 1997
  238. Play iTunes Music from iPhone 6 in LS400 1997
  239. A/C Compressor
  240. STP Fuel Additives
  241. 99 ls400 overheating
  242. 1994 ls400.....coolant leak
  243. new owner
  244. Crown Majesta V8 alternator under charging
  245. Expensive to tint an LS400?
  246. New to Lexus
  247. Need help identifying this part in a 94 ls cluster!
  248. 98-00 Serp Belt Tensioner Removal
  249. LS400 Ideas on how to tighten Crank Pulley....
  250. New bushings causing creaking noise?
