PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. front end knocking on 99 LS400
  2. Service Manual?
  3. 93' LS possibly power steering issue......
  4. Lip Kit(add-ons) for 90-94 ls400??
  5. 92 LS400 seat removal
  6. Tom's Advox coilover - how to adjust?
  7. iPOD install
  8. Are ASA ST4's any good???
  9. Pioneer or Nakamichi Stereo
  10. Transmission
  11. ACC Cabin Filter
  12. Pinging under hard acceleration between 3000-5000 rpm?
  13. How do I spice up a pearl white LS400?
  14. Ethanol-related Fuel Pump Probs in 1st Gen LSs?
  15. Rear Seat Removal
  16. Issues with 18 or 20 inch rims
  17. New Strut bar.. now engine sounds different?
  18. Just did the paperclip trick (pretty neat)... received a code 13.
  19. JDM celsior cluster on LS400 ??
  20. 2 Cars One Dilema
  21. AC doesn't work. Need a diagnosis
  22. '90 LS400 - Valve Adjustment
  23. Engine runs fine cold, heated not good??
  24. Need help, do I buy the 97 LS or 99 GS?
  25. Purchase : 1999 LS 400
  26. Just got my 99, coilover, suspension questions...
  27. 1991 LS400 Suspension Problem!!
  28. LS pics from NELOC meet 7/22
  29. Timing Belt
  30. Any ideas how to retrofit a cabin air filter for 91 LS400
  31. HID Kit
  32. whats A good coilover setup for 90-94 Ls400?
  33. Question about these tail lights for a 1st Gen LS400
  34. 92 LS Interior Light sQuestion
  35. Just bought a Toyota Celsior...need help
  36. 00LS400 Wind visors from luxurymods.com?
  37. '98 LS400 with Odd option combination
  38. question with ac on and off
  39. LS dies all of a sudden, but is fine when jump started and while running.
  40. Are the lugnuts for 90-94 and 98-2000 LS400 the same?
  41. LS on 20's :-)
  42. Its been awhile....two pics
  43. 20" rims on LS 400
  44. Lexus Transmissions
  45. Engine dies after cranking. Will run w/foot on gas!
  46. replace master window switch
  47. Window Motor
  48. Engine stalls while shutting off AC or switching to neutral
  49. Nakamichi Stereo 1992 Model LS400
  50. help (help me with stock alarm reset)
  51. Just Installed my Tokicos
  52. 93 LS 400 stereo probs
  53. Power Tilt Binding
  54. 98 ls 400
  55. 96 LS400 Panic button issue
  56. Just picked up a 93' LS400 DD'er
  57. DIY guard flaring – My photo’s.
  58. Mechanical Locker – No one knows?
  59. Car jerking at a stop
  60. 1992 LS 400 - A/C problems
  61. question about dash
  62. Moonroof LS 400 '90
  63. 2jz Conversion
  64. Catasrophic paint failure on 94 LS400
  65. question about knob under dash
  66. Car just took a ****. :(
  67. new owner - few general questions
  68. driver seat problem
  69. Need Help for High TEMP gauge
  70. Some Drifting Fun (Video) NWS for language
  71. Simple wheel question
  72. Strut Installation Problems
  73. How much is it to get the L Sportline kit painted and installed?
  74. Will the new Tein CS with EDFC fit on a 00 LS400?
  75. Key cutting in Dallas?
  76. Need '98 LS Purchase Advice
  77. Headlight Wire/connector help.
  78. Gentex Mirror in the LS400
  79. 1st gen drivers side window intermittent, lets get to the bottom of this.
  80. Hood Strut
  81. Suggestions: Going to look at a 93' LS400
  82. Newbie gearbox worry
  83. 91 LS400 shape simple questions
  84. A/C Fans??
  85. need a little help
  86. engine problems
  87. HELP..1993 LS400 Replace Bulb- Tail light
  88. Which of These Wheels Would You Test Fit on My Car????
  89. List of Service - Op Codes
  90. LCD Screens on eBay
  91. 1997 LS400 key program
  92. Does 94 LS400 have an external amplifier, or its built into the HU?
  93. Different idea on installing i-pod
  94. Pinstripe Removal
  95. 98+ Fog Lights!
  96. Does anyone have Stainless steel brake lines on a 95-2000 LS?
  97. Fuel Pump ECU location for bypass
  98. How to fix your speedo needle when it does not work
  99. Help!! Abs Pump Wont Turn Off!!!
  100. LS 400 interior question
  101. Door Speaker Grills / Guards
  102. What do you think of these wheels.
  103. So I'm picking up a 1994 LS400 with 98k miles on saturday.
  104. newbie question : which wheel and tire size for my 91 LS400
  105. 1993 LS400 sound problem!
  106. Replacement Headlight Bulbs for 95 LS400
  107. Whats wrong with this picture?
  108. L-Sportline bodykit instructions needed ..... do you have it?
  109. Just bought a 92 LS400 - Air Shock Question
  110. Power Seats
  111. iPOD Install
  112. pics.......
  113. Trac
  114. windshild washer reservior
  115. Does Any 1st Gen???
  116. Cant Drive At Night....
  117. TUTORIAL: DIY Front Rotor Change on UCF20/21 (95-00) LS400
  118. Gen 1 LS400 heater tap replacement
  119. In the market for a used LS.....
  120. Trunk Jammed
  121. Newbie Introducing myself
  122. Complete PPS Failure
  123. 1991 LS400 Engine Mount Help
  124. Cleared headlights f/95-97
  125. 95-00 LS corner tail and lid light removal
  126. Car won't start, clicking noise?
  127. Where Did The Coolant go????
  128. Shocks...
  129. Installing an after market radio in a 1995 LS 400
  130. Rear strut noise
  131. Original Pinstriping Help!
  132. PCV Valve where is it??
  133. MAF Sensor problem
  134. Strutbar Question
  135. 1995 LS400 Air Suspension Conversion to Strutmaster's "Hydraulic Strut System"
  136. Inconsiderate People (backed into my car)
  137. HID kit on LS400 1991, H1 or H4?
  138. bad pinging between 1000-1400rpm , had code 71
  139. Keyless Entry
  140. will the 98-00 grille fit ....
  141. 92 LS400 suspension
  142. Grounding Points in Engine Bay and Trunk
  143. High Humidity
  144. What's The Difference In These Power Steering Pumps?
  145. Crown Majesta conversion?
  146. celsior grill help
  147. Height Controller Help!!!!!!
  148. Performance mods for 98-00
  149. A/C retrofit & recharge
  150. High mileage engine
  151. new drop springs
  152. Strange vibration, worse when throttle depressed
  153. JDM Light for the LS400 - Help!!
  154. Finally got another Lexus!
  155. Shock suggestions??
  156. Advice on 90 LS 400 Sunroof Issues
  157. key will not come out from a 1994 ls
  158. 1991 AC Problem
  159. Head Unit Problems...help!!
  160. UCF20 CRASH test video
  161. 98LS Rear Subwoofer removal
  162. Any suggestions where to get a timing belt kit
  163. Dash Board messed up
  164. Thinking about going Monotone??
  165. car shuts off while driving
  166. 98 LS4-Taillight, Corner Light, Fan Belt.........
  167. Air conditioning to low??? 94 ls400
  168. The 2 tone ls400
  169. 1990 Ls400
  170. Convert. VIP Celsior Picture
  171. Iridium Spark Plug
  172. Where Is The Pre-amp???
  173. got bored...
  174. Alarm Problems car wont start
  175. Fuel Consumption of LS400 Lexus
  176. LS NAK Amp the same as the GS NAK Amp?
  177. sloted and drilled rotors(opions)
  178. Large Calipers...Please help!!!
  179. Ls-400 Cd Player Removal
  180. Need help with finding posts
  181. Interior Trim
  182. 1992 LS 400 sunroof
  183. Nav System 99 - 00 - Is latest data July 2004?
  184. Pix of my girl before she takes her bath.........
  185. help me !!!
  186. Change In Color Scheme
  187. A L O H A !
  188. wings west bodykit
  189. Celsior Emblem on 95-97...
  190. Stop/Brake light switch
  191. Rocker Panels / Lower side body panel
  192. Would these wheels fit??
  193. new member
  194. L-Sportline Body Kit for LS400 98-00
  195. Shifting from Park to Drive
  196. 1992 LS400 - Brake Light Comes On
  197. How to remove headlamp leveler in 99 LS400 with HID?
  198. Anyone ever hear of the Mythos Bodykit for the UCF10?
  199. height controllers in australia
  200. MotorSwap.. Help
  201. Hey All - Noob here with a couple questions...
  202. Rear View Dimmer
  203. Carlsson UCF20/21 body kit, wing pics?
  204. where is the air suspension computer?
  205. Test fitted 19s on LS400 on the weekend.. opinions!
  206. 3 Rims, which is best for the LS?
  207. opion on xenon body kit?
  208. A/C Cabin Air Filter - 1992 LS400
  209. If you could take one feature from an '04, what would it be?
  210. New member, A/C question
  211. Problem with suspension bushes?
  212. weird stock head unit
  213. What is a 1990 ls 400 worth?
  214. What's my 91 LS400 w/ 175K worth? Upgrading to a '98 - '00 model.
  215. 2 Plugs on Top of Ashtray
  216. Pics of the new LS! (56k prob not)
  217. showtime.post pic of rims,paint,drops,any thing you can about your LS
  218. tis.toyota.com ?
  219. power? button jammed?
  220. Junction Produce “Premiums” Kit
  221. Remote malfunction?
  222. 2001 LS Calipers on a 89-94 LS400
  223. Help!!! Throttle position sensor
  224. help electrical issues
  225. How do you remove headrest 97LS
  226. Occasional problem with keyless entry
  227. rims/tires for 99 LS
  228. how dark is your tint
  229. I am new
  230. Beeping Sound When I Turn Off the Car
  231. Fixing Door Panels
  232. New Interior Color Options
  233. carpet
  234. Tint prices?
  235. Hubcentric rings
  236. Junction produce hood ornament
  237. Anyone replace the fuel pump?
  238. location of coolant temp sensor 90 ls400
  239. Opinion
  240. endlinks
  241. Just purchased a new to me ls400
  242. Stuttering
  243. best dvd/nav for a 95 ls400.......avn5435....avn6600
  244. Water Leak From Sunroof
  245. Dashboard/pad Replacement 92 LS
  246. PLZ help question about LS 400
  247. 1993 LS400 burst into flames...
  248. 3 piece WALD spoiler in
  249. Looking for 98-00 LS400 Engine Cover
  250. idling in the lexus ls400
