PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. '91 blower motor the same as '99?
  2. Street name
  3. my 92 ls400... socal...
  4. "Aero USA" body kit from hyperrev mag
  5. 98 suspension and general
  6. What should I Do?
  7. 2000 LS 400 Platinum or 2001 LS 430?
  8. ECU/ECM question 1st Gen
  9. Check Engine Light Code 71
  10. Score of the Year 98, HID, NAV,Air Susp
  11. Ghetto Fab! Stupid warning lights.
  12. warning lights
  13. Buying an LS400 at Auction, Air suspension busted? Any thoughts?
  14. Questions: 94 Ls 400 Rim Gurus
  15. fuel gauge problem
  16. New Tires...
  17. 1991 LS.. Poor student about to lose my mind
  18. 90-94 LS400 EGR Pipe
  19. My New Interior (large pics)
  20. Just installed Axxis pads
  21. $7k Ls400?
  22. Service Repair Manual
  23. Rear Knuckle bushings - source (pic attached)
  24. Change your cap and rotors! :)
  25. HELP Lost Power
  26. 90LS400 Electrical issue
  27. Inside fan blower not working . HELP!!!
  28. '90 LS400 woes..
  29. Dealer wants $5400 in repairs......What do I need?
  30. More help!!!
  31. Pics of Windshield and Window Glass Manufacturing Stamp Needed
  32. looking for wheel set for 98 ls4000
  33. Some pics of my 1st Gen
  34. A formal introduction...
  35. 1st gen gold grille bezel, anyone?
  36. I want to install these puddle lights.
  37. 95 Ls400
  38. Seat belt retract...
  39. 1991 LS400 for 2000 is that cheap?
  40. I could kick the previous owners ***!!!
  41. What do you guys think of the lextreme tt ls?
  42. Hot wires / spark plug wires for the 97 ls400.
  43. Rear Tail lights
  44. LCD and hood strut question couldnt find it with search...
  45. Trenz Billet grille, what size drill bit for stumps?
  46. Limited slip friction modifier / Differential Oil
  47. Questions on buying LS400
  48. Reseting Factory Keyless Entry On 93ls400
  49. tilt steering wheel problem
  50. S&S headers for righthand drive models
  51. Need Help - Fan/Fan Pulley loose??????
  52. Ls 400 Starting Then Stalling Problem Fixed!
  53. Ordered two new Arnotts Air Shocks
  54. 1992 LS 400 - using oil
  55. Brakes upgrade on 1st gen LS400
  56. Whutzit Worth ???
  57. Park Place Lexus in Plano !! Furious!!
  58. Question about tire cupping!
  59. Idle Control Valve
  60. Secret Hidden Button/switch
  61. LS in the cold
  62. Idle Question
  63. H3C HIDs???
  64. Just installed Daizen CA Bushings and new ball joints
  65. Diy Grill????????? 98ls
  66. Upper Control Arm Balljoint Fix
  67. Miles to Kilometers-LS400 1997
  68. Anyone ever try BG44k???
  69. JDM headlights!?
  70. $665 for a new window?
  71. For The Factory Air Suspension Lovers
  72. Microphone near rear view mirror
  73. Easiest Way to Replace EGR Valve Pipe on 95 LS400??
  74. Changed my exhaust agian *Short Vid*
  75. 1990 LS400 Nakamichi - dead speakers
  76. Coilover noise, anyway to keep it quiet??
  77. Cleaning Mass Airflow Sensor?
  78. Remote starter is killing battery?
  79. 91' LS400 front seats
  80. ATF dipstick help measure
  81. 1994 Ls 400 Cd Changer
  82. Question about air susp. (1990)
  83. Optimum Batter Size for '98 Ls 400
  84. tilt steering wheel
  85. 1990 Sun Visor Help
  86. Transmission Flush
  87. Gap behind rear seat
  88. Is This Bad?
  89. Color Chart for 1st & 2nd Generations?
  90. Replacing Door Weatherstripping
  91. upgrading interior? on UCF20 with Side Airbags
  92. '96 LS400 Steering Column Position Memory
  93. Location of Air Suspension Controller/Computer
  94. Take A Look At This LS.
  95. 1998 Coolant Drain Plug Locations
  96. Rear Main Seal Leak HELP!!!
  97. VIP Garage photoshoot
  98. Ordered black pearl emblems but...
  99. A few pics of my LS400
  100. Performance chip for LS400? What's the best first mod?
  101. Part number for water inlet nut gasket - LS 400
  102. 00 Subwoofer is 8"!! Not 10"!
  103. 2nd gen Daizen bushings
  104. Another example of Lexus quality
  105. 1997 Ls 400 Transmission Question
  106. Lower front strut rubbers
  107. new LS 400 owner
  108. is this possible in a 98 ls 400?
  109. Maintanance
  110. engine light.....sometimes
  111. exhaust systems
  112. 92 LS400 headrests
  113. LS400 error codes
  114. need help with trac light
  115. Common Problems
  116. Differential Question
  117. Tanabe Hybrid Airbag+Coilover suspension thread - link
  118. UCF10-11 Rotor / Caliper Swap?
  119. 90 LS integration relay diagram
  120. Powers Mirrors Don't Work
  121. Power Lock not working on Drivers side Door!
  122. 98 LS400 Starter won't engage
  123. LS 400 on 19's post your pics!
  124. tape player stoped working
  125. New to the forums, question on first gen!
  126. Performance Mods for 98 LS
  127. Road Trip with 20"" rims ?????
  128. whats the widest tire u can put on 98 stock rim?
  129. Anyone want these wood grain kit pieces? FREE
  130. TRC light on?
  131. 98 LS 400 Tailight Mods?
  132. Cel codes after maintaince
  133. Noob w/ quick question?? LS400 air ride??
  134. Questions about 98-00 LS400
  135. 12V Switched Power / Overhead
  136. Strange Vibration in the Rear
  137. front end knocking on 99 LS400
  138. Service Manual?
  139. 93' LS possibly power steering issue......
  140. Lip Kit(add-ons) for 90-94 ls400??
  141. 92 LS400 seat removal
  142. Tom's Advox coilover - how to adjust?
  143. iPOD install
  144. Are ASA ST4's any good???
  145. Pioneer or Nakamichi Stereo
  146. Transmission
  147. ACC Cabin Filter
  148. Pinging under hard acceleration between 3000-5000 rpm?
  149. How do I spice up a pearl white LS400?
  150. Ethanol-related Fuel Pump Probs in 1st Gen LSs?
  151. Rear Seat Removal
  152. Issues with 18 or 20 inch rims
  153. New Strut bar.. now engine sounds different?
  154. Just did the paperclip trick (pretty neat)... received a code 13.
  155. JDM celsior cluster on LS400 ??
  156. 2 Cars One Dilema
  157. AC doesn't work. Need a diagnosis
  158. '90 LS400 - Valve Adjustment
  159. Engine runs fine cold, heated not good??
  160. Need help, do I buy the 97 LS or 99 GS?
  161. Purchase : 1999 LS 400
  162. Just got my 99, coilover, suspension questions...
  163. 1991 LS400 Suspension Problem!!
  164. LS pics from NELOC meet 7/22
  165. Timing Belt
  166. Any ideas how to retrofit a cabin air filter for 91 LS400
  167. HID Kit
  168. whats A good coilover setup for 90-94 Ls400?
  169. Question about these tail lights for a 1st Gen LS400
  170. 92 LS Interior Light sQuestion
  171. Just bought a Toyota Celsior...need help
  172. 00LS400 Wind visors from luxurymods.com?
  173. '98 LS400 with Odd option combination
  174. question with ac on and off
  175. LS dies all of a sudden, but is fine when jump started and while running.
  176. Are the lugnuts for 90-94 and 98-2000 LS400 the same?
  177. LS on 20's :-)
  178. Its been awhile....two pics
  179. 20" rims on LS 400
  180. Lexus Transmissions
  181. Engine dies after cranking. Will run w/foot on gas!
  182. replace master window switch
  183. Window Motor
  184. Engine stalls while shutting off AC or switching to neutral
  185. Nakamichi Stereo 1992 Model LS400
  186. help (help me with stock alarm reset)
  187. Just Installed my Tokicos
  188. 93 LS 400 stereo probs
  189. Power Tilt Binding
  190. 98 ls 400
  191. 96 LS400 Panic button issue
  192. Just picked up a 93' LS400 DD'er
  193. DIY guard flaring – My photo’s.
  194. Mechanical Locker – No one knows?
  195. Car jerking at a stop
  196. 1992 LS 400 - A/C problems
  197. question about dash
  198. Moonroof LS 400 '90
  199. 2jz Conversion
  200. Catasrophic paint failure on 94 LS400
  201. question about knob under dash
  202. Car just took a ****. :(
  203. new owner - few general questions
  204. driver seat problem
  205. Need Help for High TEMP gauge
  206. Some Drifting Fun (Video) NWS for language
  207. Simple wheel question
  208. Strut Installation Problems
  209. How much is it to get the L Sportline kit painted and installed?
  210. Will the new Tein CS with EDFC fit on a 00 LS400?
  211. Key cutting in Dallas?
  212. Need '98 LS Purchase Advice
  213. Headlight Wire/connector help.
  214. Gentex Mirror in the LS400
  215. 1st gen drivers side window intermittent, lets get to the bottom of this.
  216. Hood Strut
  217. Suggestions: Going to look at a 93' LS400
  218. Newbie gearbox worry
  219. 91 LS400 shape simple questions
  220. A/C Fans??
  221. need a little help
  222. engine problems
  223. HELP..1993 LS400 Replace Bulb- Tail light
  224. Which of These Wheels Would You Test Fit on My Car????
  225. List of Service - Op Codes
  226. LCD Screens on eBay
  227. 1997 LS400 key program
  228. Does 94 LS400 have an external amplifier, or its built into the HU?
  229. Different idea on installing i-pod
  230. Pinstripe Removal
  231. 98+ Fog Lights!
  232. Does anyone have Stainless steel brake lines on a 95-2000 LS?
  233. Fuel Pump ECU location for bypass
  234. How to fix your speedo needle when it does not work
  235. Help!! Abs Pump Wont Turn Off!!!
  236. LS 400 interior question
  237. Door Speaker Grills / Guards
  238. What do you think of these wheels.
  239. So I'm picking up a 1994 LS400 with 98k miles on saturday.
  240. newbie question : which wheel and tire size for my 91 LS400
  241. 1993 LS400 sound problem!
  242. Replacement Headlight Bulbs for 95 LS400
  243. Whats wrong with this picture?
  244. L-Sportline bodykit instructions needed ..... do you have it?
  245. Just bought a 92 LS400 - Air Shock Question
  246. Power Seats
  247. iPOD Install
  248. pics.......
  249. Trac
  250. windshild washer reservior
