PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Fixed my moaning P/S noise!
  2. Will 2006 Ls430 Rims Fit A 1999 Ls400?
  3. Photoshoot with my '92 LS400
  4. Need Help on 95 Ls400.
  5. Anyone previously owned an Acura Legend ???
  6. Stock Camber Adjustment?
  7. was wondering....
  8. photoshoot! autofashion/balboa park
  9. does anyone know the part number for..
  10. Brake Pad/Rotor Recommendation?
  11. Disc Changer - Error 16
  12. "Performance Chip"?
  13. importing a celsior?
  14. Thermostat & Radiator Choices...
  15. looking at buying '98 LS 400-wht shd I lk 4
  16. Used Part supplyer?
  17. Need Help Bad!!!
  18. Just bought a LS... need help with a few things.
  19. Another MPG thread for 70% local 30% freeway
  20. Where are the motor mounts located?
  21. Nice Car But To Small
  22. NEW Nagisa Auto Suspension Parts for the UCF2#
  23. Spring rates?
  24. 1994 ls 400/w few problems
  25. GS rims on LS400...
  26. High Flow cats (91 LS400)
  27. Strange Coolant Leak '92 LS400
  28. Vibration while breaking
  29. Starter Replaced-now A/C Not Cooling
  30. Anyone use LS400 to tow something?
  31. Just started my audio project.
  32. LS430 Calipers , why no fit ??
  33. newbie checking in - what to look
  34. How do I replace the sunroof?
  35. Lights - front/rear
  36. 1ls 6.5" Speakers all-around?
  37. Max Tire Size LS400
  38. Will IS350 rims fit a 96' LS??
  39. License Plate Lights 1992 LS
  40. Clear Side Markers for a 1999 LS 400
  41. seafoam vacuum wipers
  42. Looking To Buy Rims For My Ls400
  43. Smoking from rear of engine
  44. 90 LS400 for 2500! good or no?
  45. Suspension question.
  46. what LS 92/96 improvements
  47. Avalon vrs. LS400
  48. New here
  49. Cheap speaker fix for those with dead speakers...
  50. Did my first seafoam on my '91 LS400
  51. 90 LS 400 Crank no Start
  52. Pics of my 93 Ls400
  53. im new to the family...here is my new car
  54. Oil pressure indicator
  55. no electrical power until I rev the engine ??????
  56. Vehicle speed sensor. Need to locate!
  57. Picture of my LS400
  58. New! Nagisa Auto suspension parts for LS400
  59. LS460 wheels on 1LS
  60. LS headrest question
  61. Found a goofy LS at Sewell Lexus...
  62. Please Help:need Pic Of 95-00ls400 Front Suspension
  63. New tint pics!
  64. Some better pics of my new 94 LS400
  65. Anyone have a picture of new IS 18s on a 1LS?
  66. Is there any way to obtain one plug wire?
  67. Some Pictures of my LS (In need of fender rolling / drop)
  68. Tried to clean throttle body, broke a hose instead..
  69. What kind of 0-60 times are you actually getting?
  70. new pictures!
  71. Camber or Fender Rolling? Help.
  72. 91 LS400 with suspension noises
  73. Will 20x9, 20x10 (245 & 275) rims and tires fit on a 96' LS400??
  74. 2LS caliper clearance issues on 1LS with various OEM wheels.
  75. Standard suspension what one is what?
  76. double din bezel
  77. Timing Belt: 1992 LS400 250K KM
  78. New To This Forum...
  79. Got a slow seatbelt ? Get your 1 tip ready
  80. disable factory alarm??
  81. Search Help,,
  82. ECT and rear light issues?
  83. Strange steering issue with the LS today
  84. Opinion about Rotors..
  85. Gated Shifter
  86. 1995 Lexus LS 400 - Loud Squealing... Engine Area
  87. Just picked up a '92 LS400
  88. 1991 LS400 New Owner Help!
  89. best drop shock for a 98 ls
  90. '98-'00 Search ?'s
  91. Dolce UCF 10 -> UCF21 and UCF30/31 Conversion
  92. distributor cap problem
  93. Whirring noise while slowing down '93
  94. Removing and replacing drivers seat
  95. 97 ls400 hu help
  96. Whats the most money you put into a first generation LS400 with no avail
  97. I just had the front struts replaced on my 1990 LS400 because of rattling noice
  98. When I win the Lottery should I buy a Lexus lS460, or a BMW 750, or Mercedes S600
  99. Can I take the chrome Lexus emblems off an Es300 and put them on an Ls400
  100. A/C Problem Related
  101. Diagnosing need for bushing replacement
  102. Quick air intake box mod question, UCF21
  103. wiring diagrams
  104. Toronto LS400 prices - 1998 - 1999
  105. Auto shifter inhibitor module location on gen 1
  106. Did you upgrade from a Pinto or something worse to your new Lexus
  107. Why are the LS Models the Ultimate Lexus has to offer
  108. What can a bad radiator cap do to your vehicles cooling system
  109. Do you use lowbudget parts and service for your car
  110. What do you guys think it is
  111. Did I fix the Problem? Low engine coolant light, gen1
  112. Blew motor, how much labor in swapping?
  113. Yeah or Nay to this mod
  114. POLL : strut tower bar
  115. problem when changing spark plug wires
  116. The search never ends...
  117. My new Quad pipes !!
  118. Sirius satellite into 2000 LS400 w/nakamichi
  119. 1uz trans?
  120. Fog Light Bulb
  121. Why does the "LOW ENGINE COOLANT LEVEL WARNING LIGHT" keep going off
  122. Black grill for '91 LS400
  123. Exhaust question (L-Tuned parts)
  124. Celsior Up in Japan...
  125. starter problem ( MAJOR )
  126. engine feels sluggish
  127. need help stereo shows SEC in my ls400
  128. A host of car troubles... help !
  129. time to retire my '90?
  130. charcola canister and evap valve
  131. 1992 Ls 400 Eg001-98
  132. Platform
  133. Family member might be getting a LS400
  134. What fuel additives do you use, and how often?
  135. What RPM does your car shift at?
  136. 1998-2000 Ls400 Fog Lights, The easiest upgrade for added light ever.
  137. My New Exhaust System With An X Pipe, Removed everything but the rear Lsportline muff
  138. 1991 LS400....many minor problems
  139. a couple more pictures of my car and a friend's
  140. Downshifting....Do U do it.....????
  141. Clock and Seat Memory problems
  142. WTB? 95 LS400 rear tranny mount.
  143. Should I go with Monroe Sensa Tract or KYB shocks
  144. Did the Jamaican get Ripped OFF?
  145. Is anyone dumb enough to pay dealer prices for parts and service on their Lexus
  146. Idle is too high at startup
  147. Warning Light/Dome to the left of anti-lock brake light
  148. Remove Gold from Lexus Emblems
  149. O2 sensor replacement
  150. Infinti wheels on a Lexus
  151. How does the LS rear wheel handle in snow?
  152. Man I am lucky.
  153. Cd Changer Help Pleaseee.... '93
  154. Please Post your UCF20/21 pics
  155. How does your car perform with a full passenger load?
  156. 92 ls400 ... slow takeoff
  157. Rubber Cargo/Trunk Liner for UCF10...
  158. SoCal + Heat = Tint
  159. bought myself a birthday present...2nd generation LS400
  160. whining noise...
  161. 97 LS400 Automatic door lock/unlock
  162. What type of suspension do you have?
  163. idler pulley bearing
  164. Help Horn problem
  165. which shocks would be best with universalair?
  166. Catalytic Converter RED!
  167. Amplifier Location on '96 LS
  168. No A/C in 99 LS400, missing low-side A/C cap?
  169. any good shops in dallas
  170. Radiator Cooling Fan and shroud '91
  171. How to connect JDM Headlight wiring harness to USDM Headlight wiring harness?
  172. Chrome Wheel Center Cap / Emblem
  173. DIY A/C recharge?
  174. 2000 LS400 Passenger Wing Mirror Glass Replacement
  175. Where to find idle control valve for 1991 Ls400?
  176. How Often Do U Do maintenance wk on ur LS???
  177. Where did you observe the ugliest looking Ls400, describe it and do you have any
  178. What is L-Tuned Steering ECU and could it be installed on a 90 ls400
  179. Helpful web site for maint. and my new car
  180. [pics]She's BACKK!!
  181. White LS w/ tinted Tail/headlights
  182. MP3 & Satellite Radio Install?????
  183. Wood Trim Kits Yes or No
  184. '91 400 audio problem
  185. Will 19X8.5 +28 and 19x10+35 fit a 1995 LS400? thanks
  186. LS430 Cupholder Work in LS400?
  187. Hids for fogs, low and high beams
  188. Best modifications for 1990-94 LS400?
  189. AC whine HELP.
  190. Parking lights?
  191. spark plug blues
  192. The Great Flood
  193. Check Engine: Code 25
  194. Why do you think your Lexus is one of the best cars made?
  195. Navigation system in early gens?
  196. SC400 and LS400 wheels
  197. P/S Fluid leak - not easy to steer.
  198. New to the Forum
  199. My soon to be EXE(vip) Ls400
  200. Help!! need parts '94
  201. Super ghetto 45-minute EGR "fix"
  202. Common Problems Fixed
  203. Right tire for 45 minute commutes size 225/40/18
  204. Boring!!!
  205. My 98 LS with 05 18" wheels
  206. LS400 Rebuild
  207. 92 with 263000 gone 95 with 78000 well 79000
  208. Name Of head lights, anyone help?
  209. OBDC supported by 90 LS400
  210. Washer Fluid light comes on even though fluid is full?
  211. LS400 Wipers not working
  212. Need to replace struts....what else should I consider
  213. Right tire for 1990 ls400 with 18" 2006 Sc430 rims
  214. Were to buy Koni sport struts for gen1 LS400
  215. 1998 Electrical Problem - Alternator?
  216. New LS400 soon, any ideas and suggestions??
  217. EFI fuse keeps blowing.??
  218. I love my LS400
  219. rattle
  220. Got Cold Air>?????????????????
  221. Do the lexls.com tutorials apply to the 96 LS?
  222. Curbed 16 inch LS400 chrome - rechrome, or new rim??
  223. Is this a Good Deal???
  224. devils body kit...
  225. Stuck Tach!
  226. 98 LS400 navigation
  227. 98 ls400 flashing defroster light
  228. brake light sensor location
  229. How to tell if water pump is bad??
  230. Can someone help me out and check their tachometer...
  231. Finally got my car painted !
  232. 06-07 GS350 17" Original wheels on 91 LS400
  233. Lowering a LS400
  234. rattle
  235. seat cover replacements?
  236. Quick look at non OEM and OEM drive shaft bushing
  237. What Tyres Should I Put !!!
  238. '94 stalls
  239. Got some new wheels..
  240. Car won't start!!!
  241. problem getting into the trunk w valet key!!!
  242. Wiring for sub amps
  243. NOW some good pictures of my 90 on low and super low!
  244. Possible Alternator Problem?
  245. R1 Cross drilled/slotted rotors...your opinions?
  246. alarm / starter problems
  247. What year LS is best to get? selling my SC400
  248. Tick tick tick coming from engine compartment..
  249. Tein Coils for LS
  250. no park lights
