PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 1992 Lexus LS 400 interior parts questions
  2. Suspension question about '97
  3. Dummy Head Light Q's for '97
  4. 1990 LS 400 no start
  5. Replacing LS400 tranny with JDM used one.
  6. OEM store?
  7. rims question '90
  8. HIN San DIEGO. BEST LEXUS PICTURE
  9. Billet grills and light trims?
  10. 94-00 coilovers on 90-92
  11. I thought my biggest expense was my air suspension
  12. integration relay
  13. Electrical Problem.... '90
  14. Selling a bunch of NEW IN THE PACKAGE, parts for the 1st gens
  15. Radio cuts in and out when I hit bumps / stop and go.. :(
  16. Coil Over Compatibility
  17. Reasons why or why not to get a 98-00 LS400
  18. Burning Rubber smell and Sputtering Idle
  19. Does It Fit ?
  20. Please Help Locate This Part
  21. 95LS torque converter question
  22. Hood Question
  23. recommended wheel and tire - 2000 LS?
  24. '91 door problem
  25. Levoc Shifter With Relocated OD Switch
  26. 100 more miles till 100,000
  27. '93 LS400 cracked sunroof
  28. Will 07 GS350 fit an LS400?
  29. 98 LS 400 Radio LCD segments out
  30. Tanabe DF210 available
  31. Intake filter Size
  32. Extended Warranty..any recommendations
  33. exhaust question (best exhaust for a '92?)
  34. After cleaning Throttle body, Jumpy highway performance
  35. My Battery Mistake
  36. 93 ls400 - ac evaporator housing foam on flapper doors bad
  37. Used LS400 TV-review..sort of...
  38. Modded my airbox - If you haven't, DO IT!
  39. how to replace O2 sensor
  40. where to buy O2 sensor?
  41. Got my gearshifter and wheel recovered in new leather
  42. Joining the LS forum :)
  43. 98 LS400 on DF210/KYB GR-2 before and after...
  44. Easiest way to drill out rotor set screws?
  45. 1LS on IS350 OEM 18x8.5 test fit v.pic
  46. 1LS on IS350 OEM 18x8.5 test fit v.pic
  47. How much is this gonna cost? ('90 LS body damage)
  48. Rim Compatability
  49. Minimum Tire Load Ratings
  50. Updates Updates Updates!
  51. my 92 ls400 has trans problem
  52. new guy got some new wheels
  53. Diagnostic Codes - O/D Off light flashing
  54. HID replacement options question
  55. 1999 ls400 a/c problems ?
  56. Diff/Tranny problem... need help
  57. 1990 ls TPS
  58. Does anyone have the instructions for
  59. Squeaking noises from wheels
  60. Modified my air intake using Jbrady Mod
  61. Maintaining ride quality with 18s on LS400?
  62. are the 95 and 98 fan motors interchangeable?
  63. Bulb or Ballast?
  64. Seat modification, is it possible? Any ideas?
  65. taillights
  66. Paint integrity issues?
  67. Bad Catalytic converter 1996 ls
  68. Electric Fan Kit
  69. High mile ucf10 - What oil?
  70. Lexus at an acura meet...
  71. Need help with smog problem
  72. Discount on OEM parts?
  73. Discount on OEM parts?
  74. 94 heater fan motor
  75. Warm/Hot air from all but right-most vent!!!
  76. 95 problems
  77. Wheel cover caps
  78. Front Conversions.
  79. Is there RCA out in Nakamichi headunit?
  80. MAF question
  81. Is it possible?
  82. Strong smell of gasoline while idling.. running rich?
  83. Can timing be retarded on the 1uz motors?
  84. Windshield sun-shade?
  85. Pictures of my 99LS400 ... finally
  86. 1995 to 1991 transmission
  87. What is the Platinum package?
  88. UCF20 Audio LCD problem
  89. convert to four doors
  90. Help me w/reasons to upgrade from 96 to 98-00
  91. Spark plug service
  92. Hacked up my intake box yesterday...
  93. UCF10 Vibrations while Braking ... Rotors or ABS??
  94. Ball joints replaced
  95. removal of radio in 99 LS400
  96. Starion with 1UZ motor
  97. New guy
  98. Air Conditioning Problem
  99. 1996 Ls400 20" offset?
  100. Where to find 1LS fog light housing?
  101. new wheels and tint
  102. Swift Racing HFI for Lexus LS400 98-00
  103. accleration problem
  104. Repainting the car... color choice help needed
  105. 1LS Aftermarket Headunit Wiring Question
  106. Painting/bodykit opinions.
  107. LCD Climate Install
  108. 98 LS400 Navigation Obsolete!
  109. CD-RW in pioneer changer
  110. Looking to buy a '98 LS400
  111. Just got my repaired LCD back...
  112. Just Passed Emissions Test
  113. Low Idle issue resolved! '00 LS
  114. 1st Gen LS400 seat compatability
  115. Help me identify this part
  116. Pictures of the Mikado keyless kit...
  117. climate control problem
  118. Anyone ever figure out how to take apart the center armrest?
  119. 91 Ls tranny issue
  120. Need a quick advise!
  121. IS350 18" on 1LS... does anyone *know* for sure?
  122. my LS for sale
  123. LS pics,,, Neloc meet- Carlisle, Pa.
  124. Got my hoodie on LOL!!!!
  125. ucf20 visors on ucf10/11?
  126. Should I Buy?
  127. Not Exactly New LS Owner (& LS Accolades)
  128. 93 Ls400 a/c uses r12 or 134?
  129. Asistance with O2 Sensor
  130. bad air suspension ?
  131. anyone have this woodgrainkit from ebay??
  132. Doing a Suspension job....
  133. Where to get L-sportline exhaust?
  134. HELP!!! Question about installing aftermarket radio to replace broken nakamichi
  135. Auxillary input adapter
  136. Blue LED's
  137. My steering wheel has selective memory LOL
  138. Need a little help on Instrument cluster....
  139. Infiniti Q45
  140. 91 LS400 with veers to right..........
  141. Need Help..1990 LS400 Too Low In Rear
  142. Flaky 95 o/d temp display
  143. 95 hiccups
  144. Air con pulling me along
  145. 91 LS400 Steering Column Noises
  146. Check Engine Light - Code PO763
  147. Have a question regarding '95+ LS 400....
  148. crack in dash
  149. Electrics Fan Conversion...
  150. Just bought and 95 lex and began the maintenance :)
  151. PIC REQUEST: 98-00 LS400 with aftermarket wheels
  152. 1992 LS400 wheel question
  153. 1990 on Ebay with cloth seats!
  154. One small klick begins disaster for engine
  155. Pic on vacation
  156. 1991 ls 400 healight question
  157. I feel like I've failed her...
  158. 18x7.5 +35 ok for 1990 LS
  159. 2000 LS400 I Went Monotone
  160. window visors?
  161. Looking for a carpet replacement kit for '92 LS
  162. 1996 LS 400 price check
  163. Lexux owners in CT
  164. My LS400 Burning Out. >--VIDEO--<
  165. 95-00 LS400 Air Intake!
  166. Time for new struts? Price and shopping list
  167. Where find Marker Light? '90
  168. looking to purchase lowering springs
  169. 1992 ls400 spedometer and odometer problems
  170. Clear side markers and signals
  171. kick panel help! bad wires
  172. UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
  173. OEQ Ball Joints ..what does OEQ stand for?
  174. Need advice: What year LS 400 to buy?
  175. 1992 LS400 with GS400 Rims
  176. Rear Seat Pocket.
  177. rattle under the hood
  178. TPS and trac light help
  179. battery light stays on after alternator change
  180. Please post pics of your LS (w/stock rims or aftermarket)
  181. mass air flow sensor
  182. Headlight adjustment.
  183. 1998 - 2000 Lexus Ls400 Car Service/ Repair Manual
  184. Possibly buying 93 Lexus LS400. What to look for?
  185. Help with eletrical problems, 1990
  186. 1992 LS 400 Caps & rotors
  187. In Park, Brake is applied - "thunk" from shift-area
  188. pixs of my unpainted wald lip
  189. RX300 Shifter on 1LS...
  190. 1st Lex (95 LS) What do I need to know. Please help
  191. 1LS burning oil possibly... WTF
  192. test drive of 95 LS
  193. Silly light question - 96 LS400
  194. Steering problem on '91 LS400 after pump was replaced...
  195. Wrong Spare???
  196. Same ole,, same ole
  197. check vsc HELP
  198. Need Help, just bought 93 LS400
  199. blue book, 1990 ls 400
  200. 99 ls400 "headlight leveling" warning?
  201. 90 LS 400 running like ****
  202. how to save money on gas and make your LS quiet
  203. HELP!!! No sound from stereo
  204. Hey GUYS!
  205. hard downshift from o/d
  206. In general, how do you know if spark plug wires need replacing?
  207. Alignment
  208. Muffler delete: makes the cabin too loud too talk in?
  209. 93 ls400 - ac common leak spots to check?
  210. 95 LS400,to buy or not to buy
  211. HELP... High Pressure Hose for Power Steering - 620 Dollars?
  212. Clearing out gen 1 LS tail lights
  213. Im back but my car is dead
  214. 1993 LS400 Climate LCD <Please Help!
  215. Boo-boo fixed.
  216. Removing RHS spark plug cover
  217. Leaky exhaust throw a DTC?
  218. New pictures. Custom Grill.
  219. Newest pics 1992 LS400...
  220. "All Auto" window switches to replace driver only auto
  221. Hey guys..Anyone need a fuelpump?
  222. starter motor removal? help required!
  223. shocks for 91 ls 400
  224. noise from rear.....bearing?
  225. LS400 with low idle speed AC off only
  226. Problems with car - 90 ls400 diagnostic codes
  227. What do you guys think about these wheels
  228. Radio swap and new interior for 91 ls 400
  229. 92 Ls 400
  230. Refurbished Power Steering Pump - QUESTION...
  231. Bushes Bushes BUSHES!
  232. Mercedes Wheels 98LS4?
  233. 94 Ls Seat belt not retracting propertly
  234. Very weird engine rev stutter
  235. 94'LS 400- The tipping point?
  236. Rear brake pads 94' LS
  237. brakes...$1525..now I've seen everything
  238. Engine stalls after prolong Freeway driving
  239. water in the exhaust
  240. how to run fogs with after market hid's
  241. 92 ls4oo 140k misfires new plug wires cap and plugs. need firing order. Sugestions?
  242. Looking for the commuter car "sweet spot"
  243. Help! My Windshield Wipers Wont Come Up.
  244. Replacing caliper mount only...
  245. White exhaust smoke when starting
  246. Newbie LS owner quesion
  247. Help with vibration please!!
  248. Design/themes...what would u reccommend?
  249. TOM'S Celsior
  250. 92 LS400 - drivers side view mirror vibrates
