PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Rear brake calipers - 430 or 460 bolt up?
  2. 1995 LS400 rear seat removal w/pictures
  3. Who wants to see some dyno testing? and intro
  4. LS400 or Supra TT brake swap
  5. differential to axle allen bolts stuck!
  6. 1999 ls400 electrical issues
  7. LS400 washer pump problem
  8. Mechanic can't figure out why there is a misfire when he puts on engine cover 1995
  9. 1998 LS 400 Seats, Fan, Headlights, Horn Malfunctions
  10. 1995 ls400 idle issue/smoke/confusion
  11. Alternator / Voltage Regulator Voltage ? 90 Ls400
  12. what year ls400 do i want?
  13. car turn off while driving help
  14. Another ECM question yes I searched
  15. Radiator options
  16. front end shakining over 40 mi an hrs
  17. Windshield Wiper Motor Bushings
  18. '94 LS400: wiper issues
  19. BBS Rims For 1990 LS400? Ideal rim and tire packs?
  20. Catalytic Converter needed
  21. Untwisting Twisted Seatbelts...Can't get the buckles to face inboard!
  22. 94 LS400 - Problem with Differential & Right Axle feels Loose?
  23. New Member from LasVegas
  24. thank you DaveGS4 for your Blessings
  25. Is my serpentine belt too tight or tensioner too weak?
  26. The paint on my LS400 looks better than the paint on any car i've ever seen
  27. My 99 Ls400 Won't Start. Possible Immobiliser or ECM Problem?
  28. 1uzfe swap with 1uzfe vvti
  29. New Member & First Post: 1991 LS400
  30. Murdered out my lexus
  31. 1990 Lexus LS 400 Error Code Help?
  32. 96 LS400 transmission issue
  33. Lost my 97 LS400 car clicker
  34. We really need some stickys around here
  35. Door window channels
  36. 1997 Lexus door ajar issue
  37. 1995 LS400 lowbeam bulb replacement pics
  38. 1995 LS400 front amber corner marker
  39. Dupli-color Exact Match Colors for my LS 400?
  40. New timing belt water pump opnions or directions to good shops online or psychic stor
  41. No FS in the discussion section
  42. Are these LED bulbs plug and play in my 95?
  43. '91 LS400 - temperature gauge running 3/4 up, also tach is "dead"
  44. The 'pacifier'
  45. Vibration at low idle cured by different fuel?
  46. weird question.. jam/pinch protection
  47. How to fix this Bottom Part of Lexus LS 400- under cover
  48. AandSC to the rescue
  49. How to Set Auto Door Lock When Shifted to Drive?
  50. Custom fit Heavy duty all weather floor mats for UCF20?
  51. Oracle Halo light installation
  52. Need help sourcing wiring harness plastic clamps
  53. Newbie- 1990 with 47K miles
  54. OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!
  55. plastic clips
  56. Electronic Radiator Fans
  57. New here with 2 questions.
  58. Does anyone know...Cusco underbody brace?
  59. Ls400 ignition coil upgrades
  60. I have a problem in the car- acceleration pause
  61. Transmission fluid
  62. Is buying a 98-00 high mileage differential ok? (close to 200k,Pics)
  63. Please Help - ABS & Brake light on- will not move
  64. VIN number on motor?
  65. 1996 ls400 antenna mast
  66. Turn signal driving lights?
  67. Need Advice - 1st Time Shopper
  68. Engine / Motor Mounts
  69. A newbie to the forum
  70. LS400 vs Jeep Compass
  71. Need Help! 91 rough idle, backfiring, tranny slipping
  72. Video from a couple weeks ago
  73. LS 400 vs Deer
  74. Urgent help! 1998 Ls400 Driver door entire locking/unlock mechanism 200% unfunctional
  75. windshield washer tank
  76. Upper rear window 3rd brake light
  77. 1992 Lexus LS400 - Rough idle, low engine power, faint white smoke from under hood
  78. power window switch lights
  79. Steering wheel intermittently no longer returning to previous position
  80. First Lexus
  81. Integration Relay
  82. Oh why hello there!
  83. 2000 ls400 finding parts
  84. lets see if you can figure this one out! 95 ls400 - corner lights
  85. Removing 1st gen phone system [retitled]
  86. for anyone wondering what the muffler delete sounds like
  87. There are things I love about my LS400...
  88. 1994 ls400 buying tips (what to look for?)
  89. LS430 Water Inlet Housing in LS400
  90. 98 LS400 moonroof panel rattling, worse after cleaning + silicone spray
  91. First Post, my '99 LS400 has transmission issues
  92. (1991 LS) Some kind of shaking in the Transmission?
  93. Restoring steering wheel
  94. Just a first post and a hello!
  95. Passenger side wiper insert
  96. What is this?
  97. Need a fastner source
  98. 99 Nakamichi radio listen to MP3s.
  99. Error Code Error - Say What? (rough idle, shakes)
  100. Lights Out
  101. transmission radiator - yes/no? why?
  102. Which color?
  103. Name this sound
  104. how smooth is a 90 ls400 engine
  105. How to test - OEM audio system
  106. Catalytic converter issue--I think
  107. Just bought an LS400!!!
  108. Millennium edition options/differences?
  109. remote keys 95 ls400
  110. LS400 AC Recharge Fail
  111. Part Number For Screw On Key/Remote?
  112. Denso plug sale
  113. '94 LS400 Fuel Economy
  114. another new guy
  115. help please car wont start anti theft problem
  116. Last post before crossing over 300K!
  117. '95 LS400 Odometer out
  118. Lug nuts and center caps for LS430 Wheels
  119. 1994 Sunroof Leak
  120. Here is a new one -PS shaft sheared - Ever heard of this?
  121. Drive shaft Flexjoint/Couplers problems
  122. too bazaar not to post..p0773 shift solenoid e electrical
  123. Need thoughts on
  124. Timing Belt and Water Pump Question
  125. Replacing front wheel bearings
  126. 97 lS400 Parrot MKi9200 install - Help!
  127. Ideas when selling an LS400
  128. Need help on purchasing a 1994 ls400
  129. 1997 Overheating Problem - New Guy Here
  130. Challenging No-Start / No-Spark Condition
  131. S&S Headers... are PPE headers the same?
  132. Help Geting 18x7.5 +35 rims all around for LS second gen
  133. Tie rod snapped
  134. 1998 LS400 5 speed swap
  135. How much offset is needed?
  136. VIP trays
  137. confusing issue. ohms testing a lock-up soleniod
  138. Front passenger door compatibility
  139. Upgrade Alarm on LS400 1997 ? Any Recommendations ?
  140. 98-2000 Valve Adjustment?
  141. ISO 90-94 Front door speakers
  142. LS400 1995 AC working mildly
  143. 90 Celsior tilt steering problem
  144. Speedometer off by about 16 MPH
  145. 240sx s13 1uzfe 93 swap
  146. Faded needle fixed itself.....?
  147. Engine mounts
  148. air intake "upgrade"
  149. New guy - help pls =) - control arm and bushings
  150. ECU interchange ?
  151. 90 starts and runs good then dies
  152. Help how to wire 1UZ FE VVTI 97 WITH 89661-50450 STANDARD ECU
  153. Lost spark on some cylinders
  154. K Sport UCF20 coilovers on UCF10?
  155. 2000 LS400 arm rest squeak - how to remove?
  156. '93 LS400 noise comming from rear wheel
  157. Front strut reinstallation - Help!
  158. 1994 Lexus LS 400: Starter needs replaced?
  159. Coilover question
  160. '93 LS400 noise from engine compartment
  161. window motor/ loose connector HELP
  162. 1994 LS400/when cold transmission feels like its slipping?
  163. Almost 100k Miles
  164. Is it just me or .....Electonic Control Throttle-surging
  165. ls400 need help
  166. pulley belt tensioner
  167. New To Me LS400
  168. steering play
  169. An ECU question
  170. Exhaust modifications
  171. Exhaust tips
  172. 92- LS400 weird engine sound.
  173. Painted Factory 90-94 LS400 Rims?
  174. warm and cool air at the same time (1996)
  175. Considering 95-97 LS400, common issues?
  176. green glass
  177. interior and exterior ls400 2000
  178. After a rain, the car runs horrible(?)
  179. Saying good by and hello RX family
  180. 1995 LS400 wiper arm access
  181. Stereo wiring Schematic '99 Celsior
  182. General Questions
  183. Some cluster lights comming on?
  184. Looked for exhaust leaks, now car pulsates
  185. JDM vs USDM 1UZFE VVTi questions
  186. Car Overheating LS 400
  187. New here- first LS!
  188. Question about wheel bearing
  189. 92 LS400 Rear Susp. Bushing
  190. Gen 1 front suspension
  191. how to compress the front caliper pistons
  192. Need Help-LS400 stuck in park, dash lights out
  193. 1994 ls 400 : Front coil springs
  194. Road noise
  195. Flickering Cluster: Does Anyone Repair Them?
  196. My 1st lexus - '98 w/200k
  197. Dashboard electrical problem. (Vid included)
  198. Turbo sizing
  199. ucf11 steering problem
  200. LS400 outside Door handle
  201. Cluster Change 90 to 93-94
  202. It feels like the transmission jumps into neutral
  203. TOYOBD1 and its wonders.
  204. 93 running rough. Need some insight.
  205. Labor cost 94 ls400
  206. Best aftermarket LBJ?!?
  207. Yamae question
  208. 1999 Celsior Radio Cassette Part number
  209. 1UZ swap looking for new dif setup
  210. Are mismatched tie rods OK?
  211. Interior Interchange???
  212. Alignment necessary after strut replacement?
  213. Compressor problem or leaky ECU caps?
  214. First gen vs. second gen front bumpers
  215. Power Steering Geyser From Reservoir
  216. What are the beginning signs of power steering pump failure
  217. 1990 Celsior UCF11
  218. Coilover tool help
  219. HELP: Fender removal
  220. Power steering reservoir question. 00' LS400
  221. timing check on '92 LS400
  222. 1997 LS Crankshaft Position Sensor Help
  223. First Time Buyer Tips
  224. 94 radio bull****
  225. UCF-10 Car Phone?
  226. Need help -Error Codes on ls400 1998 - p0420, p1126, p1129
  227. 1992 LS400 factory camber adjustment
  228. Avid.1 AV50 on the 1992 LS400
  229. UCF21 Climate Control Unit Smoking !!
  230. ls400 acceleration issues
  231. What Does A Million Miles Really Tell Us?
  232. Wanted: feedback from those running aftermarket UCA's.
  233. '92 LS400 -motor has missing problem
  234. 96 lexus ls400
  235. Anyone have a pic of the Low Beam cannon plug/connectors on a 95-97?
  236. Just a bought a new LS 400
  237. Rear Strut replacement cost
  238. 99 LS400 Upper ball joint replacement: control arm needed too?
  239. '99 Celsior. Changed battery now won't start
  240. Oil Change--They put in wrong kind?
  241. 17 years of great service from my 1991 ls 400
  242. Limp needle fix (impact)
  243. LS400 valve adjustment shim diameter?
  244. New struts - buy whole assembly or just cartridges?
  245. 98+ bumper On 95-97
  246. '92 LS 400 firing order needed
  247. Maintenance Question- 41,000 miles, TB/WP never replaced
  248. help finding a part number, or name! ls400 trans sub-harmess
  249. No matter how huge the wheels.I love this
  250. Headlights come on by themsleves...ideas?
