PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. New Ls 400 Owner
  2. Tach Signal Where does it come from?
  3. 91 ls 400
  4. Service schedule?
  5. Need to return to stock height
  6. Change ugly stock yellow foglight bulbs!!!
  7. Dyno of my 99 LS400 / Wild Ride in a 450whp EVO
  8. 92 gas guage- different problem
  9. Dealer service costs...?
  10. Steering wheel quick Qn '91
  11. Another Stereo Install Question '00
  12. Changed Plugs
  13. Brought home new baby tonite
  14. A running LS 400.
  15. HAs anyone ever opened up their tail lights?
  16. Got my new 20's put on.. let me know what you think!
  17. which cluster caps for 92 gas gauge??
  18. Lexus LS 400 Suspension Problems. '90
  19. 1990 ls400 electrical problem
  20. Timing Belt tensioner change?
  21. 98 LS w/ Nakamichi + phone
  22. Question about trans. mount
  23. Took a drive, 27.7 mpg.
  24. Considering LS- Your Opinion Appreciated Greatly
  25. Will Supra TT Brake lines work for gen II (97 lS400)?
  26. Climate control bulb(s) question
  27. 1990 Lexus LS400 Starts but won't stay running. :(
  28. Tricking Navigation to think its night?
  29. Auto tilt steering wheel
  30. Really weird knocking noise while breaking...
  31. Very bad gas mileage :(
  32. Help with instrument cluster - 92 LS400
  33. Absolute best door speakers? Price is not a problem...
  34. CAR WASH---Your Opinion?
  35. hot wire
  36. gas prop strut hood support replacement ebay 1990 ls400
  37. Do you have a vibration issue that comes and goes and comes and goes?
  38. how to replace parking light bulb on 1st gen?
  39. Brake of 96 LS, 140K
  40. 95 Lexus fender and bumper?
  41. Mysterious stall-out/electrical power drop
  42. 98GS4 wheels on 95 LS.......spacers??
  43. Computer for 93 LS400
  44. Seat Heater Bulb - easy to replace?
  45. Stock Wheels....Good Price?...Finish?
  46. First Break Down :( (not too serious)
  47. Radio Probs - Audio Weak - FM Fades away
  48. 95 ls400 alternator??
  49. Full exhaust/exhaust tip pictures??
  50. Any way to increase treble? 98 w/NAK
  51. Where is the exterior color code located?
  52. Size (and snow) matters
  53. Have you ever used spring clamps to lower?
  54. Links to articles of praise for the LS400??
  55. Well I finally replaced the propeller shaft assy - '95
  56. Longevity questions LS400
  57. Help!! 1994 LS400 Engine hard to start in morning
  58. Looking for engine mount diagrams/instructions.
  59. what to look for on a '98LS
  60. Interior from UFC21 into 20?
  61. LS400 Video on YouTube... sad, sad, sad....
  62. Who is the best place for control arms?
  63. www.carsteering.com experience?!?
  64. Power window motor source... anyone have one?
  65. Need some suspension info pls (2nd gen)
  66. Can I add an MSD blaster coil to the LS ignition?
  67. 2nd installment: My LS mpg on $25 super-unleaded.
  68. Added an Electric fan and power steering filter to my 98 LS400
  69. '92 LS400 Nakamichi Amp
  70. help please
  71. Whats my car worth - 1996 LS400 w/ 49k miles
  72. Missing(running rough) '95
  73. a 1gen LS on 22's!?
  74. '90 LS400 keys
  75. new ecu or reset?
  76. Bouncing hood
  77. Battery Q?
  78. Going lower with Coilovers...
  79. Engine Code 25
  80. '90 LS400 subwoofer removal
  81. 10 thousand for a lexus ls400!!
  82. Strange noise from rear passenger side suspension ....
  83. I have a rim question thats been bothering me...
  84. How hard is it to change your own lowering springs?
  85. Airbox mod Debate and questions.
  86. VSC still on after Batt Change
  87. LED interior lighting
  88. How to program the garage opener
  89. What size is the Optima Yellow Top for 00 LS400?
  90. Fluid Drip To Driver Side Exhaust
  91. Will 275/30/zr20 rear tires fit on 92 LS?
  92. Did anyone here buy their LS....
  93. In Dash DVD/ Navigation
  94. THERMOSTAT DIAMETER /No app listing
  95. '90 LS400, deacceleration whine
  96. Hi-tech ipod dock for LS400 console
  97. Differential lube...
  98. Low mi. '94 LS for me?
  99. any fix for ABS not working
  100. Help, my moonroof might be leaking
  101. Help needed diagnosing 97 LS tranny!
  102. 98-00 Factory LS Wood Color Names/Codes
  103. It's the little things (tire PSI)
  104. Brakes squeak when going in reverse.
  105. Factory NAV question
  106. H&R Sport Springs on '90 LS400
  107. Transmission life???
  108. Am I nuts for thinking about buying a 96 LS400 with 198k on it?
  109. Non-technical foglight issue 1995 LS400
  110. repair shop near me
  111. Blown EFI FUSE
  112. Hello, need help with steering wheel replacement.
  113. Another newbe question
  114. Painted Grille
  115. Timing Belt DONE!!!
  116. How do I know if my distributor cap is bad?
  117. New to the LS Family
  118. Gen 2 LS crystal park lamp lense
  119. Traction control button not working!!!
  120. Name your price
  121. What parts to replace in AC system on a '90 LS400?
  122. New member Intro - 96 LS400
  123. Driver's School question about my 1999 LS trans.
  124. Ever have one of those true "oops" moments where you hate yourself?
  125. 98-00 LS400 Xenon Foggies...
  126. Regular to Synthetic Oil at High Mileage...
  127. 1991 LS400 w/ nakamichi sounds components factory crossover ?
  128. '91 LS Radiator Replacement.
  129. LS400 Model 1993 goes Slow
  130. new shoes
  131. Ball joint replacement
  132. To tint or not to tint?
  133. Just purchased a 1990 LS400
  134. Lexus Ls400 2000 brake problem
  135. My last mpg on $25 premium.
  136. Hello there, new owner of an old 94 LS400
  137. New Mounts Fitted
  138. Trunk Lift Struts
  139. warning speed signal ls400 1990
  140. Magnaflow Wide Open Series 95 LS400
  141. I lost my TRAC and ABS!
  142. Problem with tilt function
  143. "LS400" emblem for 1990?
  144. LED tails for gen 1 LS400
  145. Tein EDFC Range...
  146. Steering wheel
  147. Quick pic...
  148. What is the absolute quietest, smoothest tire for a 2000 ls400 stock?
  149. battery disconnect, elec. ?
  150. '93 LS, check engine, trac light on...
  151. How gentled do I need to be with a high-mileage LS400
  152. What do you guys think about this LS400 fixer upper?
  153. WOT Shift Points
  154. Powdercoat stock rims for 1990 LS400?
  155. These rims gonna fit?
  156. 93 ls4, 161k, need help with codes.. 51,22
  157. Why would your heater not be very hot?
  158. Shhhhh
  159. Ball Joint awareness
  160. what are these called?
  161. Looking for new wheels
  162. Leaking Raditor Fluid_HELP
  163. Daizens - WOW!
  164. Ls400 New Info On Problem
  165. Looking for a 98-00 repair manual..
  166. need help with 1990 ls400 coolant leak
  167. Sirius radio install in 99 with Nakimichi
  168. 1990 LS400, brake upgrades?
  169. 1990 LS400, power mirrors not working
  170. like son, like father... another LS400 (pictures)
  171. How to remove side panels on an LS?
  172. 93 ls key locked in ignition!!
  173. Two Questions, tires, gold emblems
  174. Almost Owned by not 1, but 2 Deer!!!
  175. What is this on 93 LS400
  176. some updated pics of my ls
  177. Running 245/50/16, how far off is my speedo from stock?
  178. Quick Tire Question
  179. Question? (chrome door handles for UCF10)
  180. 1992 LS400 running extremy rich and rough
  181. 1997 ls400
  182. 99 LS400 with 18"AME Shallen LX
  183. dead shocks
  184. how did you guys run the power wire from the front to the back of your ls
  185. 2nd gen power steering leak
  186. Just thought I would post....
  187. 1991 Lexus LS400 - need good door speakers....
  188. Back from the shop...
  189. need help at identifying a problem (pic)
  190. take a look!.... lol...
  191. Car dead
  192. air suspension strutmasters convertors
  193. Thanks CL! This is what $21k got me
  194. Front replacement speakers?......
  195. interference v. non-interference
  196. 95 LS400 A/C Unit
  197. Do the FX35 rims fit the 93-94 LS400?
  198. trac light on upon start up botton doesnt turn trac off when cold
  199. Another newbe question
  200. 93' LS -Replaced factory head unit, now no lights on radio or a/c
  201. 1991 LS400 question!
  202. JIC Magic Twin Spartan SUS Exhaust Opinions?
  203. 1999 LS400 Navigation Override / Unlock
  204. PIC REQUEST: 1998-99 LS400 with SC430 18" wheels
  205. Front end fixed!!! Update
  206. My NEW ride!
  207. First gen questions
  208. 91 ls400 all warning lights come on and go off
  209. Failed Emissions....Help?
  210. Wiring stock amp with new headunit
  211. Really strange problem (bug between plastic and LCD screen '99)
  212. Almost bought Silverstar 9003 bulbs for lowbeams...
  213. How well does an LS get around in the snow?
  214. Post any pics you have of modded LS400's!
  215. A Few Random Questions Regarding My 98
  216. Replacing serpentine tensioner
  217. Slight surging with light throttle.. suggestions?
  218. Anyone add oil to their fan clutch?
  219. dash lights 91 LS400
  220. 2000 LS400 Platinum
  221. Volk Te 37?
  222. sc400 versus ls400 trannys
  223. Gearshift Lightbulb ... how to get to it? 2000 LS400
  224. 91 Ls Car Won't Start. Help!
  225. Need to know if transmissions have a vin#
  226. Higher Stall Converter Questioin?
  227. 95 LS 400 Wiring Diagrams needed. Audio Most important at the moment.
  228. 1998 - Shaky When Revving
  229. Purchased 1995 LS400 blue w/tan (pictures)
  230. mpg diagnosis
  231. Having problems with my headlights...Please help me!
  232. Did something alittle crazy yesterday...
  233. 18x9" Wheels for a 95 LS400
  234. new member with questions
  235. P/s Oe Srvc. Vacuum Valve Ls400? Plz Help!
  236. Video of my 99 LS400 with Muffler Delete / Jbrady|Lexkost type Intake
  237. 1998 Lexus Phone Removal
  238. S/S Brake Lines for a 2000 LS?
  239. Front Suspension Problems. Need advice
  240. My 98 LSadded 15mm spacers with OEM 16's
  241. problem with cd changer
  242. 96 LS400 audio
  243. Cluster Needle Going Dark '90
  244. who makes adjustable pillowball mounts for 95+ ls400?
  245. Oil Pan Gasket '91
  246. Ticking noise on acceleration 91 LS
  247. Replacing Fuel Filter In LS400
  248. Daizen bushing problem?
  249. Need to identify what year my 1uz HELP!!!! Please
  250. EGR delete problem
