PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Pic. My LS in the shop with two others.
  2. How does new cd changer looks in place of factory changer?
  3. Thinking about 18s...thoughts?
  4. One side lower than the other?
  5. Ride Height
  6. Dash warped from heat?
  7. ***Gen 1.5 Revamping Result***
  8. Lets see who has the least amount of miles...
  9. Is Daizen still around?
  10. Wheel Bearings or Brakes? HELP
  11. Backup camera installation
  12. HID HEADLITE Retrofit Kit Reviews
  13. New owner with questions ('96)
  14. Found a white LS400 with a white grille
  15. Black Chrome Grille installed 1998-2000 LS400
  16. New from cali
  17. 93-94 LS owners, I dont think its possible to use home filters for Cabin Air Filter
  18. lexus will not start
  19. Can you change the ball joint of the UCA?
  20. Acelerator pedal positioning sensor
  21. New member intro :D
  22. 91 Coilovers and other stuff...
  23. where to get down-n-out stickers?
  24. Possible Bearing Issue
  25. Cd Changer
  26. Bent Rear Spindle causing ABS fluctuation
  27. Help! About to buy 95 LS400
  28. Do I have to replace my Brake Booster?!!!
  29. GS Aluminium Alloy Wheel Set 18x8 on aa 2000 LS400??
  30. 95-97 ls speaker size
  31. Help me with some bushing noise
  32. UCF-20 "splash guards"
  33. How Much Attention Does Your Ls Get?
  34. problem need assistance
  35. Spark plugs and wires.
  36. cracked door mirror, best place to source new one?
  37. ICE!!! Slipping and Sliding (PIC INSIDE)
  38. UCF20 Pre-m/c factory touchscreen!?
  39. Which shocks for first Gen LS?
  40. Suspension For 96 Ls 400
  41. 1995 LS400 Power Steering Pump Problem...
  42. K&N filter question
  43. here she is!!
  44. Stock Lugs for UCF10....
  45. im in ur doorz (a problem with my driver's side power window '90)
  46. 92 to 98 Front end conversion
  47. Instrument Cluster Issues
  48. 99 LS400 one owner, 56K, Buy Or no Buy?
  49. 91 Ls400 : Please Help All Suggestions
  50. Air suspension LS, reliability and longevity?
  51. 96 one owner ls400....worth??
  52. wheel fitment on 1gen ls400? 18x9.5 +35mm
  53. opinion on celsior headlights
  54. Fuel problem in 93 LS400? 162k
  55. Need help...heater dont work...code 21, 24
  56. Re-did my shifter and steering wheel but...
  57. Couple of fixes for my 95 LS
  58. suspension question 90 LS400
  59. What is the stock wheel width? How skinny can I go?
  60. air suspension
  61. coilovers showed up today! UCF10
  62. Choice between keeping a 97' or getting a 93'.
  63. Ticking Sound Accelarating While Cold
  64. Oil burning/Power Steering '90
  65. Replacement keys.
  66. Vibration at 1100 rpm
  67. New site or password for service manuals
  68. Gen1 Strut Tower Brace Info
  69. Coil over system
  70. Burning Regular for the 1st time
  71. Hyper Yellow Bulbs! anyone else in love?
  72. code 25?
  73. oem cd changer doesn't work well in cold weather ??
  74. ...brake problems...please help!!!!!!!
  75. HID + DRL...full voltage possible?
  76. New Guy.
  77. Cruse control not working on 1995 LS400
  78. With much work is it worth keeping my '91?
  79. Sc400 Intake?
  80. Which ADUS bushing goes with which arm?
  81. Shift Lock Solenoid
  82. Height line flashing?
  83. keyless entry programming instructions
  84. Fuel Guage Problems.... Help!!
  85. 5th Power Steering Pump - boiling fluid
  86. 05 LS430 5 spoke wheels on a 1st Gen LS?
  87. Ls400 parts crossreference with Camery
  88. Eibach Sport Spring for Gen1 LS at TireRack!!!
  89. Power steering pump
  90. Quick Audio Question
  91. KYB GR-2 with Eibach combo
  92. just sold my wheels, what do i do with teh money?
  93. LAST pics of my LS before i take off wheels!
  94. pinku frake
  95. Need some help on buying this Ls 400
  96. Weird, loud crazy engine (A/c) noise...help!
  97. First Gen LS 400 Tailights
  98. Check-in: Post your current mileage.
  99. Can't find an aftermarket intake for a 91.
  100. Some pics from yesterdays drive.
  101. Nature's CAI.
  102. Got my JDM LIP
  103. Seized pulley -- need replacement pn
  104. driver side door prob. on 92 LS
  105. replacing a cartridge fuse-HELP
  106. Gauges Went Haywire After Hitting a Curb!
  107. 1995 ls 400.My serpentine belt broke.
  108. 97 SC RIMS on a 92 LS...
  109. slight but distinct steering vibration
  110. NGK iridium's on my98 LS400
  111. New Member Intro
  112. Where to take my car for timing belt and valva adjustment?
  113. input on possible new car.
  114. My LS' first time in the snow.. pics
  115. I think I have an electrical issue that is beyond simple cluster repair
  116. Help...95'LS seatbelts dont snap back to place
  117. Replaced my rear axle carrier bushings in my 96
  118. HELP again (Please read sticky on thread titles)
  119. TEIN CS, v1, v2, CST?? Difference? UCF20
  120. Strange Braking/electrical Issue just started today!
  121. '91 LS400 horrible gas mileage and gas meter off?
  122. New To CL...Love it....
  123. Help identify this vacuum coolant switch ??
  124. LS 5 speed pedals and clutch pieces?
  125. 100% Custom Dual Exhaust (video)
  126. 98 LS remote lock, unlock and trunk not working
  127. Megan Racing Coilovers
  128. Stabilizer link nut
  129. Looking for OEM Chrome Wheels for '98 LS 400
  130. do you know where the parking brake wire is?
  131. 98-00 wheels on my 95 LS4
  132. Looking to buy a 1998 LS400.
  133. water pump replacement
  134. Beeping sound coming from speakers '91 LS
  135. Anyone use BBA Remanufacturing to repair their cluster?
  136. dealer or independent shops
  137. TPS Sensor? ('91 with 250K)
  138. Aftermarket amp with factory radio?
  139. Junkyard near me has first gen with Air Susp...
  140. 1994 LS400 rocks back and forth when shifting
  141. Gauge Cluster AND dash lights AND R D N lights dont come up... help pls
  142. Will aftermaket Remotestart/alarm--make factory system not work?
  143. hi guys!
  144. New LS owner here.
  145. Clicking noise at the shifter...getting louder
  146. Quick Question about Gen1.5 LS400
  147. Rubber Coil Spring Inserts to Raise Spring Rates
  148. Any DIY info for back rotor replacement? (98-00)
  149. Sound Deadening. Any info?
  150. LS430 Coil Covers on LS400?
  151. LS400 problems, please help
  152. 1997 LS400 keyless remote....
  153. 94 LS400 Surges at more than half throttle...
  154. Start-up Whinning Noise
  155. Tokico Blues
  156. Tranny shifts hard on Park
  157. is the "Accessory and Main Drive Belt" the timing belt?
  158. 1991 LS400 starts for split-second and then dies!
  159. Replacing 98 LS 400 Transmission Mount
  160. newb so cal ucf10 member
  161. will 20x10 fit in the front ucf10
  162. Navigation unit where ashtray is?
  163. 95 LS warning light..What does it mean?
  164. question about back of ls400 '96 stock radio
  165. SC400 tranny in an LS?
  166. W/S washer low fluid warning
  167. What do i need to do to lower my ls400?
  168. 92 LS 400 Engine Stalls
  169. Nav in a 2LS
  170. LS Commercials & Articles
  171. wide body ls4 on ebay
  172. 93 Cluster Problem
  173. LS vs. SC
  174. ugh, airride wont go down
  175. AME Shallen test fit pt.2
  176. UCF10 F&R Kevlar/Ceramic brake pads
  177. I need serious help (headlights on affects engine)
  178. Cleaning up the front end with some JDM
  179. Need Help!!!!!
  180. All Weather Mats?
  181. Best scale model or diecast LS400?
  182. Help Cluster Is Blacked Out
  183. Happy 2008 From Australia
  184. bluetooth for 00 ls400? recommended technology/products?
  185. good buy or stay away?
  186. Best Clear bra?
  187. My Son Locked The Keys In The Trunk On My Ls400
  188. Help! Electrical Issue!
  189. Aftermarket Catalytic Converter for 93LS
  190. Timing Belt Issues on 99 LS 400
  191. Wheel Fitment
  192. Car cranks every other day
  193. Bad ground? Taillight goes off when brakes applied... also marker light questions
  194. Stalling and vibration
  195. My Cabin Air Filter
  196. Left rear tire Bald
  197. Starter bad?
  198. Update on projects
  199. DIY: 98-00 LS400 Navigation System Update
  200. two things, Paint and Hid's
  201. same poopy different thread
  202. 95 Idle high when cold?
  203. Can't find accesories!!!
  204. Speedometer Needle stopped lighting up...
  205. Looking to get a UCF 21...QUESTION
  206. 3 Problems with my 99 LS All on Christmas day
  207. Help - replaced timing belt, car wont start, backfires through intake.
  208. About to buy the Wald executive kit
  209. Should I swap my 20s for these 18s
  210. "rumbling" type vibration on my friends LS 93'
  211. Christmas
  212. My 99
  213. Pics Finally!
  214. 1994 LS400 trunk release
  215. GOT some NEW rims(again) 18 MRR HR3..Last pixs of the year!!!!
  216. 1990 Ls400 rear wheel bearing specs
  217. Ls400 Auto To Manual Conversion.....
  218. Wiring into the existing sub?
  219. Truck street/sport tires on 98 LS400
  220. Need front struts and/or springs?
  221. Update on my LS400.
  222. LS or GS
  223. Khumo Solus tires
  224. Delayed start
  225. 1992 Lexus LS400 for sale....Funny car?
  226. Quiet Exhaust????
  227. Will these LS430 wheels fit an LS400?
  228. Roof Spoiler, do they make them?
  229. Fuel pump fuse?
  230. 93 LS: Few recent fixes
  231. Question about Nakamichi AMP for GS and LS
  232. LS400 windshield wipers and steering wheel noise
  233. HELP! Need to compare Starter specs...
  234. Steering Creaks
  235. Need HELP - Tell me what you like!!
  236. LS400 lunges when you drop it in (drive) '94
  237. what to pay for ls400 95,with 47k miles
  238. my 92' LS stalls every now and then
  239. Paint estimate please 94 ls400
  240. Newbie from New York in the house...
  241. 2000 Ls400
  242. 95 LS400 Starter dead....DIY replacement in progress
  243. For my 1000th post...
  244. Rear side panel body repair estimate. Any info?
  245. What mileage did your starter go out?
  246. Front Struts are going
  247. Can Someone Verify This...
  248. 1996 Lexus LS400 Limo for sale.........
  249. Really Need Advice on Exhaust Leak
  250. 1996 wiring harness / double din dash kit
